path: root/drivers/net/Kconfig
2009-11-20net: ETHOC should depend on HAS_DMAGeert Uytterhoeven
When building for Sun 3: drivers/net/ethoc.c:1091: undefined reference to `dma_free_coherent' drivers/built-in.o: In function `ethoc_probe': drivers/net/ethoc.c:965: undefined reference to `dma_alloc_coherent' drivers/net/ethoc.c:1063: undefined reference to `dma_free_coherent' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14vmxnet: fix 2 build problemsRandy Dunlap
vmxnet3 uses in_dev* interfaces so it should depend on INET. Also fix so that the driver builds when CONFIG_PCI_MSI is disabled. vmxnet3_drv.c:(.text+0x2a88cb): undefined reference to `in_dev_finish_destroy' drivers/net/vmxnet3/vmxnet3_drv.c:1335: error: 'struct vmxnet3_intr' has no member named 'msix_entries' drivers/net/vmxnet3/vmxnet3_drv.c:1384: error: 'struct vmxnet3_intr' has no member named 'msix_entries' drivers/net/vmxnet3/vmxnet3_drv.c:2137: error: 'struct vmxnet3_intr' has no member named 'msix_entries' drivers/net/vmxnet3/vmxnet3_drv.c:2138: error: 'struct vmxnet3_intr' has no member named 'msix_entries' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bhavesh davda <bhavesh@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14net: add support for STMicroelectronics Ethernet controllers.Giuseppe Cavallaro
This is the driver for the ST MAC 10/100/1000 on-chip Ethernet controllers (Synopsys IP blocks). Driver documentation: o http://stlinux.com/drupal/kernel/network/stmmac Revisions: o http://stlinux.com/drupal/kernel/network/stmmac-driver-revisions Performances: o http://stlinux.com/drupal/benchmarks/networking/stmmac Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14net: ks8851_mll uses mii interfacesRandy Dunlap
From: Randy Dunlap <randy.dunlap@oracle.com> ks8851_mll uses mii interfaces so it needs to select MII. ks8851_mll.c:(.text+0xf95ac): undefined reference to `generic_mii_ioctl' ks8851_mll.c:(.text+0xf96a0): undefined reference to `mii_ethtool_gset' ks8851_mll.c:(.text+0xf96fa): undefined reference to `mii_ethtool_sset' ks8851_mll.c:(.text+0xf9754): undefined reference to `mii_link_ok' ks8851_mll.c:(.text+0xf97ae): undefined reference to `mii_nway_restart' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: VMware virtual Ethernet NIC driver: vmxnet3Shreyas Bhatewara
Ethernet NIC driver for VMware's vmxnet3 From: Shreyas Bhatewara <sbhatewara@vmware.com> This patch adds driver support for VMware's virtual Ethernet NIC: vmxnet3 Guests running on VMware hypervisors supporting vmxnet3 device will thus have access to improved network functionalities and performance. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Ronghua Zhang <ronghua@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30drivers/net: ks8851_mll ethernet network driverChoi, David
This is the first registration of ks8851 network driver with MLL(address/data multiplexed) interface. Signed-off-by : David J. Choi <david.choi@micrel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/cpc-usb/TODO drivers/staging/cpc-usb/cpc-usb_drv.c drivers/staging/cpc-usb/cpc.h drivers/staging/cpc-usb/cpc_int.h drivers/staging/cpc-usb/cpcusb.h
2009-09-22fec: Add FEC support for MX25 processorFabio Estevam
Add FEC support for MX25 processor. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-17MIPS: BCM63xx: Add integrated ethernet mac support.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-14Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (257 commits) [ARM] Update mach-types ARM: 5636/1: Move vendor enum to AMBA include ARM: Fix pfn_valid() for sparse memory [ARM] orion5x: Add LaCie NAS 2Big Network support [ARM] pxa/sharpsl_pm: zaurus c3000 aka spitz: fix resume ARM: 5686/1: at91: Correct AC97 reset line in at91sam9263ek board ARM: 5640/1: This patch modifies the support of AC97 on the at91sam9263 ek board ARM: 5689/1: Update default config of HP Jornada 700-series machines ARM: 5691/1: fix cache aliasing issues between kmap() and kmap_atomic() with highmem ARM: 5688/1: ks8695_serial: disable_irq() lockup ARM: 5687/1: fix an oops with highmem ARM: 5684/1: Add nuc960 platform to w90x900 ARM: 5683/1: Add nuc950 platform to w90x900 ARM: 5682/1: Add cpu.c and dev.c and modify some files of w90p910 platform ARM: 5626/1: add suspend/resume functions to amba-pl011 serial driver ARM: 5625/1: fix hard coded 4K resource size in amba bus detection MMC: MMCI: convert realview MMC to use gpiolib ARM: 5685/1: Make MMCI driver compile without gpiolib ARM: implement highpte ARM: Show FIQ in /proc/interrupts on CONFIG_FIQ ... Fix up trivial conflict in arch/arm/kernel/signal.c. It was due to the TIF_NOTIFY_RESUME addition in commit d0420c83f ("KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures") and follow-ups.
2009-09-12Merge branch 'master' into develRussell King
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-09-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/yellowfin.c
2009-08-30ucc_geth: Remove UGETH_MAGIC_PACKET Kconfig symbol and codeAnton Vorontsov
This patch removes currently unused UGETH_MAGIC_PACKET Kconfig symbol and code, i.e. magic_packet_detection_{enable,disable} functions. The two functions each contain just two steps that we'll place into suspend/resume code path under CONFIG_PM. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23net: Fix Micrel KSZ8842 Kconfig descriptionAndreas Mohr
Signed-off-by: Andreas Mohr <andi@lisas.de> Acked-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-20net: add Xilinx emac lite device driverJohn Linn
This patch adds support for the Xilinx Ethernet Lite device. The soft logic core from Xilinx is typically used on Virtex and Spartan designs attached to either a PowerPC or a Microblaze processor. Signed-off-by: Sadanand M <sadanan@xilinx.com> Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-19net: fix ks8851 build errorsRandy Dunlap
Fix build errors due to missing Kconfig select of CRC32: ks8851.c:(.text+0x7d2ee): undefined reference to `crc32_le' ks8851.c:(.text+0x7d2f5): undefined reference to `bitrev32' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: MDC/MDIO CL45 IOCTLsEilon Greenstein
As suggested by Ben Hutchings <bhutchings@solarflare.com>, using the MDC/MDIO IOCTL Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05cpmac: unmark as brokenFlorian Fainelli
Starting with version 0.5.1, cpmac is no longer broken. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-22net: KS8851 needs to depend on MIIAlexander Beregalov
fix this build error when CONFIG_MII is not set drivers/net/ks8851.c:999: undefined reference to `generic_mii_ioctl' drivers/net/ks8851.c:1050: undefined reference to `mii_link_ok' drivers/net/ks8851.c:1056: undefined reference to `mii_nway_restart' drivers/net/ks8851.c:1044: undefined reference to `mii_ethtool_sset' drivers/net/ks8851.c:1038: undefined reference to `mii_ethtool_gset' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Acked-by: Ben Dooks <ben@simtec.co.uk>
2009-07-20net: Micrel KS8851 SPI network driverBen Dooks
Network driver for the SPI version of the Micrel KS8851 network chip. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-27[ARM] 5572/1: at91: Support for at91sam9g45 series: core chip & board supportNicolas Ferre
Here are the at91 specific files dedicated to the at91sam9g45 series. They mimic the traditional at91 way of managing chips & boards. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. In the future, the main board for this 9g45 series will be the AT91SAM9M10G45-EK (I choose this last name for the board file). Simple drivers are enabled in _devices and board- files. Newer peripheral support will be added in future patches. Incuded peripherals support (for now): - USART - SPI - Ethernet - NAND flash - LCD - gpio/joystick/buttons - leds and pwm Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: bnx2: Fix the behavior of ethtool when ONBOOT=no qla3xxx: Don't sleep while holding lock. qla3xxx: Give the PHY time to come out of reset. ipv4 routing: Ensure that route cache entries are usable and reclaimable with caching is off net: Move rx skb_orphan call to where needed ipv6: Use correct data types for ICMPv6 type and code net: let KS8842 driver depend on HAS_IOMEM can: let SJA1000 driver depend on HAS_IOMEM netxen: fix firmware init handshake netxen: fix build with without CONFIG_PM netfilter: xt_rateest: fix comparison with self netfilter: xt_quota: fix incomplete initialization netfilter: nf_log: fix direct userspace memory access in proc handler netfilter: fix some sparse endianess warnings netfilter: nf_conntrack: fix conntrack lookup race netfilter: nf_conntrack: fix confirmation race condition netfilter: nf_conntrack: death_by_timeout() fix
2009-06-23net: let KS8842 driver depend on HAS_IOMEMHeiko Carstens
Fixes this compile error on s390: CC drivers/net/ks8842.o drivers/net/ks8842.c: In function 'ks8842_select_bank': drivers/net/ks8842.c:124: error: implicit declaration of function 'iowrite16' drivers/net/ks8842.c: In function 'ks8842_write8': drivers/net/ks8842.c:131: error: implicit declaration of function 'iowrite8' Cc: Richard Rojfors <richard.rojfors.ext@mocean-labs.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-22s6gmac: xtensa s6000 on-chip ethernet driverOskar Schirmer
The s6000 on-chip MAC supports 10/100/1000Mbit and is connected to an external PHY via MII or RGMII interface. [jw@emlix.com: don't use device->bus_id directly] Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Daniel Glockner <dg@emlix.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic79xx: make driver respect nvram for IU and QAS settings [SCSI] don't attach ULD to Dell Universal Xport [SCSI] lpfc 8.3.3 : Update driver version to 8.3.3 [SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint [SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash [SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes [SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences [SCSI] qla2xxx: Resolve a performance issue in interrupt [SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set. [SCSI] nsp_cs: time_out reaches -1 [SCSI] qla2xxx: fix printk format warnings [SCSI] ncr53c8xx: div reaches -1 [SCSI] compat: don't perform unneeded copy in sg_io code [SCSI] zfcp: Update FC pass-through support [SCSI] zfcp: Add FC pass-through support [SCSI] FC Pass Thru support
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15[SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set.Michael Chan
CNIC and BNX2I must depend on PCI. Dependencies do not get propagated through select. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-09[SCSI] cnic: Add new Broadcom CNIC driver.Michael Chan
The CNIC driver controls BNX2 hardware rings and resources used by iSCSI. Most hardware resources for iSCSI are separate from those used for ethernet networking. iSCSI uses a separate MAC address and IP address. The CNIC driver creates a UIO interface to handle the non-offloaded packets such as ARP, etc in userspace. Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09ieee802154: add simple HardMAC driver sampleSergey Lapin
fakehard is a really simple driver implementing only necessary callbacks and serves the role of an example of driver for HardMAC IEEE 802.15.4 device. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netdev: Added KS8842 driverRichard Ršöjfors
This is a driver for the Micrel KS8842 ethernet switch. The supplied code is for driving the KS8842 through the Timberdale FPGA on the Russellville board, a development board for Intel Atom CPU in the automotive area. Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netdev: smsc911x: allow building on Blackfin systemsMike Frysinger
The smsc911x driver works fine on Blackfin systems, so add it to the arch list in the Kconfig. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29fec: Add FEC support for MX35 processorFabio Estevam
Add FEC support for MX35 processor. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: sh_eth: Add support SH7724Yoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: Remove obsolete MV64360 config optionGabriel Paubert
Signed-off-by: Gabriel Paubert <paubert@iram.es> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25net: remove COMPAT_NET_DEV_OPSAlexander Beregalov
All drivers are already converted to new net_device_ops API and nobody uses old API anymore. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: Add TI DaVinci EMAC driverAnant Gole
Add support for TI DaVinci EMAC driver. TI DaVinci Ethernet Media Access Controller module is based upon TI CPPI 3.0 DMA engine and supports 10/100 Mbps on all and Gigabit modes on some TI devices. It supports MII/RMII and has up to 8Kbytes of internal descriptor memory. This driver has been working on several TI devices including DM644x, DM646x and DA830 platforms. The specs of this device are available at: http://www.ti.com/litv/pdf/sprue24a Signed-off-by: Anant Gole <anantgole@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17mv643xx_eth: Remove a stale PPC_MULTIPLATFORMEmil Medve
PPC_MULTIPLATFORM was killed in commit 28794d3 but this stale occurrence was hiding the mv643xx_eth driver in some cases (e.g. Pegasos II) Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29ixgbe: Use generic MDIO definitions and functionsBen Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29cxgb3: Use generic MDIO definitions and mdio_mii_ioctl()Ben Hutchings
2009-04-29chelsio: Use generic MDIO definitions and mdio_mii_ioctl()Ben Hutchings
2009-04-29mdio: Add generic MDIO (clause 45) support functionsBen Hutchings
These roughly mirror many of the MII library functions and are based on code from the sfc driver. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: Separated FW from the source.Vladislav Zolotarov
>From now on FW will be downloaded from the binary file using request_firmware. There will be different files for every supported chip. Currently 57710 (e1) and 57711 (e1h). File names have the following format: bnx2x-<chip version>-<FW version>.fw. ihex versions of current FW files are submitted in the next patch. Each binary file has a header in the following format: struct bnx2x_fw_file_section { __be32 len; __be32 offset; } struct bnx2x_fw_file_hdr { struct bnx2x_fw_file_section init_ops; struct bnx2x_fw_file_section init_ops_offsets; struct bnx2x_fw_file_section init_data; struct bnx2x_fw_file_section tsem_int_table_data; struct bnx2x_fw_file_section tsem_pram_data; struct bnx2x_fw_file_section usem_int_table_data; struct bnx2x_fw_file_section usem_pram_data; struct bnx2x_fw_file_section csem_int_table_data; struct bnx2x_fw_file_section csem_pram_data; struct bnx2x_fw_file_section xsem_int_table_data; struct bnx2x_fw_file_section xsem_pram_data; struct bnx2x_fw_file_section fw_version; } Each bnx2x_fw_file_section contains the length and the offset of the appropriate section in the binary file. Values are stored in the big endian format. Data types of arrays: init_data __be32 init_ops_offsets __be16 XXsem_pram_data u8 XXsem_int_table_data u8 init_ops struct raw_op { u8 op; __be24 offset; __be32 data; } fw_version u8 >From now boundaries of a specific initialization stage are stored in init_ops_offsets array instead of being defined by separate macroes. The index in init_ops_offsets is calculated by BLOCK_OPS_IDX macro: #define BLOCK_OPS_IDX(block, stage, end) \ (2*(((block)*STAGE_IDX_MAX) + (stage)) + (end)) Security: In addition to sanity check of array boundaries bnx2x will check a FW version. Additional checks might be added in the future. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27net: add Xilinx ll_temac device driverGrant Likely
This patch adds support for the Xilinx ll_temac 10/100/1000 Ethernet device. The ll_temac ipcore is typically used on Xilinx Virtex and Spartan designs attached to either a PowerPC 4xx or Microblaze processor. At the present moment, this driver only works with Virtex5 PowerPC designs because it assumes DCR is used to access the DMA registers. However, the low level access to DMA registers is abstracted and it should be easy to adapt for the other implementations. I'm posting this driver now as an RFC. There are still some things that need to be tightened up, but it does appear to be stable. Derived from driver code written by Yoshio Kashiwagi and David H. Lynch Jr. Tested on Xilinx ML507 eval board with Base System Builder generated FPGA design. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-20net: fix "compatibility" typosMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08igbvf: add new driver to support 82576 virtual functionsAlexander Duyck
This adds an igbvf driver to handle virtual functions provided by the igb driver when SR-IOV has been enabled. A virtual function is a lightweight pci-e function that supports a single queue and shares resources with the 82576 physical function contained within the igb driver. To spawn virtual functions from the igb driver all that is needed is to enable CONFIG_PCI_IOV and have an 82576 Ethernet adapter on a system that supports SR-IOV in the BIOS. The virtual functions will appear after the interface is loaded. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08ethoc: fix library build errorsRandy Dunlap
ethoc indirectly uses crc32_le() and bitrev32(), so select those library functions to be built. drivers/built-in.o: In function `ethoc_set_multicast_list': ethoc.c:(.text+0x6226f): undefined reference to `crc32_le' ethoc.c:(.text+0x62276): undefined reference to `bitrev32' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
