path: root/drivers/net/Makefile
2014-11-24ipvlan: Initial check-in of the IPVLAN driver.Mahesh Bandewar
This driver is very similar to the macvlan driver except that it uses L3 on the frame to determine the logical interface while functioning as packet dispatcher. It inherits L2 of the master device hence the packets on wire will have the same L2 for all the packets originating from all virtual devices off of the same master device. This driver was developed keeping the namespace use-case in mind. Hence most of the examples given here take that as the base setup where main-device belongs to the default-ns and virtual devices are assigned to the additional namespaces. The device operates in two different modes and the difference in these two modes in primarily in the TX side. (a) L2 mode : In this mode, the device behaves as a L2 device. TX processing upto L2 happens on the stack of the virtual device associated with (namespace). Packets are switched after that into the main device (default-ns) and queued for xmit. RX processing is simple and all multicast, broadcast (if applicable), and unicast belonging to the address(es) are delivered to the virtual devices. (b) L3 mode : In this mode, the device behaves like a L3 device. TX processing upto L3 happens on the stack of the virtual device associated with (namespace). Packets are switched to the main-device (default-ns) for the L2 processing. Hence the routing table of the default-ns will be used in this mode. RX processins is somewhat similar to the L2 mode except that in this mode only Unicast packets are delivered to the virtual device while main-dev will handle all other packets. The devices can be added using the "ip" command from the iproute2 package - ip link add link <master> <virtual> type ipvlan mode [ l2 | l3 ] Signed-off-by: Mahesh Bandewar <maheshb@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Maciej Żenczykowski <maze@google.com> Cc: Laurent Chavey <chavey@google.com> Cc: Tim Hockin <thockin@google.com> Cc: Brandon Philips <brandon.philips@coreos.com> Cc: Pavel Emelianov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05net: reduce USB network driver config options.Francois Romieu
USB network drivers are already handled in drivers/net/usb/Kconfig. Let's save the maintenance burden of dependencies in drivers/net/Makefile. The newly introduced USB_NET_DRIVERS umbrella config option defaults to 'y' so as to minimize the changes of behavior. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-04net: remove spurious zd1201 rule.Francois Romieu
Leftover from 5c601d0c942f5aaf7f3cff7e08f61047d70a964e ("wireless: move zd1201 where it belongs"). Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-24packet: nlmon: virtual netlink monitoring device for packet socketsDaniel Borkmann
Currently, there is no good possibility to debug netlink traffic that is being exchanged between kernel and user space. Therefore, this patch implements a netlink virtual device, so that netlink messages will be made visible to PF_PACKET sockets. Once there was an approach with a similar idea [1], but it got forgotten somehow. I think it makes most sense to accept the "overhead" of an extra netlink net device over implementing the same functionality from PF_PACKET sockets once again into netlink sockets. We have BPF filters that can already be easily applied which even have netlink extensions, we have RX_RING zero-copy between kernel- and user space that can be reused, and much more features. So instead of re-implementing all of this, we simply pass the skb to a given PF_PACKET socket for further analysis. Another nice benefit that comes from that is that no code needs to be changed in user space packet analyzers (maybe adding a dissector, but not more), thus out of the box, we can already capture pcap files of netlink traffic to debug/troubleshoot netlink problems. Also thanks goes to Thomas Graf, Flavio Leitner, Jesper Dangaard Brouer. [1] http://marc.info/?l=linux-netdev&m=113813401516110 Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17net: Add support for NTB virtual ethernet deviceJon Mason
A virtual ethernet device that uses the NTB transport API to send/receive data. Signed-off-by: Jon Mason <jon.mason@intel.com> Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-01vxlan: virtual extensible lanstephen hemminger
This is an implementation of Virtual eXtensible Local Area Network as described in draft RFC: http://tools.ietf.org/html/draft-mahalingam-dutt-dcops-vxlan-02 The driver integrates a Virtual Tunnel Endpoint (VTEP) functionality that learns MAC to IP address mapping. This implementation has not been tested only against the Linux userspace implementation using TAP, not against other vendor's equipment. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30drivers/ieee802154: move ieee802154 drivers to net folderalex.bluesman.smirnov@gmail.com
The IEEE 802.15.4 standard represents a networking protocol. I don't exactly know why drivers for this protocol are stored into the root 'driver' folder, but better will be to store them with other networking stuff. Currently there are only 3 drivers available for IEEE 802.15.4 stack, so lets do it now with the smallest overhead. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15tokenring: delete all remaining driver supportPaul Gortmaker
This represents the mass deletion of the of the tokenring support. It gets rid of: - the net/tr.c which the drivers depended on - the drivers/net component - the Kbuild infrastructure around it - any tokenring related CONFIG_ settings in any defconfigs - the tokenring headers in the include/linux dir - the firmware associated with the tokenring drivers. - any associated token ring documentation. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-09Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits) net/hyperv: Add support for jumbo frame up to 64KB net/hyperv: Add NETVSP protocol version negotiation net/hyperv: Remove unnecessary kmap_atomic in netvsc driver staging/rtl8192e: Register against lib80211 staging/rtl8192e: Convert to lib80211_crypt_info staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops staging/rtl8192e: Add lib80211.h to rtllib.h staging/mei: add watchdog device registration wrappers drm/omap: GEM, deal with cache staging: vt6656: int.c, int.h: Change return of function to void staging: usbip: removed unused definitions from header staging: usbip: removed dead code from receive function staging:iio: Drop {mark,unmark}_in_use callbacks staging:iio: Drop buffer mark_param_change callback staging:iio: Drop the unused buffer enable() and is_enabled() callbacks staging:iio: Drop buffer busy flag staging:iio: Make sure a device is only opened once at a time staging:iio: Disallow modifying buffer size when buffer is enabled staging:iio: Disallow changing scan elements in all buffered modes staging:iio: Use iio_buffer_enabled instead of open coding it ... Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of module_init due to using module_i2c_driver() helper, next to removal of MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
2011-11-29staging: hv: move hv_netvsc out of staging areaHaiyang Zhang
hv_netvsc has been reviewed on netdev mailing list on 6/09/2011. All recommended changes have been made. We are requesting to move it out of staging area. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: KY Srinivasan <kys@microsoft.com> Signed-off-by: Mike Sterling <Mike.Sterling@microsoft.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-29dsa: Move switch drivers to new directory drivers/net/dsaBen Hutchings
Support for specific hardware belongs under drivers/net/ not net/. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-13net: introduce ethernet teaming deviceJiri Pirko
This patch introduces new network device called team. It supposes to be very fast, simple, userspace-driven alternative to existing bonding driver. Userspace library called libteam with couple of demo apps is available here: https://github.com/jpirko/libteam Note it's still in its dipers atm. team<->libteam use generic netlink for communication. That and rtnl suppose to be the only way to configure team device, no sysfs etc. Python binding of libteam was recently introduced. Daemon providing arpmon/miimon active-backup functionality will be introduced shortly. All what's necessary is already implemented in kernel team driver. v7->v8: - check ndo_ndo_vlan_rx_[add/kill]_vid functions before calling them. - use dev_kfree_skb_any() instead of dev_kfree_skb() v6->v7: - transmit and receive functions are not checked in hot paths. That also resolves memory leak on transmit when no port is present v5->v6: - changed couple of _rcu calls to non _rcu ones in non-readers v4->v5: - team_change_mtu() uses team->lock while travesing though port list - mac address changes are moved completely to jurisdiction of userspace daemon. This way the daemon can do FOM1, FOM2 and possibly other weird things with mac addresses. Only round-robin mode sets up all ports to bond's address then enslaved. - Extended Kconfig text v3->v4: - remove redundant synchronize_rcu from __team_change_mode() - revert "set and clear of mode_ops happens per pointer, not per byte" - extend comment of function __team_change_mode() v2->v3: - team_change_mtu() uses rcu version of list traversal to unwind - set and clear of mode_ops happens per pointer, not per byte - port hashlist changed to be embedded into team structure - error branch in team_port_enter() does cleanup now - fixed rtln->rtnl v1->v2: - modes are made as modules. Makes team more modular and extendable. - several commenters' nitpicks found on v1 were fixed - several other bugs were fixed. - note I ignored Eric's comment about roundrobin port selector as Eric's way may be easily implemented as another mode (mode "random") in future. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29net: Fix duplicate CONFIG_SLIP entry in driver/net/MakefileDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29net: fix Makefile typos & build errorsRandy Dunlap
Fix many (randconfig) PPP build errors by fixing typos in drivers/net/Makefile. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net: Kconfig & Makefile cleanupJeff Kirsher
The is does a general cleanup of the drivers/net/ Kconfig and Makefile. This patch create a "core" option and places all the networking core drivers into this option (default is yes for this option). In addition, it alphabitizes the Kconfig driver options. As a side cleanup, found that the arcnet, token ring, and PHY Kconfig options were a tri-state option and should have been a bool option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27com20020_cs: Move the PCMCIA Arcnet driverJeff Kirsher
Move the COM20020 PCMICA Arcnet driver into drivers/net/arcnet/ with the other Arcnet drivers. Made the necessary Kconfig and Makefile changes as well. Since this was the "last" PCMCIA driver in drivers/net/pcmcia/, this patch also cleans up the references to drivers/net/pcmcia. CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27slip: Move the SLIP driversJeff Kirsher
Move the Serial Line Internet Protocol (SLIP) drivers into drivers/net/slip/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Alan Cox <alan@linux.intel.com>
2011-08-27plip: Move the PLIP driverJeff Kirsher
Move the Parallel Line Internet Protocol (PLIP) driver into drivers/net/plip/ and make the necessary Kconfig and Makefile changes. CC: Niibe Yutaka <gniibe@mri.co.jp> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Alan Cox <alan@linux.intel.com>
2011-08-27hippi: Move the HIPPI driverJeff Kirsher
Move the HIPPI driver into drivers/net/hippi/ and make the necessary Kconfig and Makefile changes. CC: Jes Sorensen <jes@wildopensource.com> CC: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27ppp: Move the PPP driversJeff Kirsher
Move the PPP drivers into drivers/net/ppp/ and make the necessary Kconfig and Makefile changes. CC: Paul Mackerras <paulus@samba.org> CC: Frank Cusack <fcusack@fcusack.com> CC: Michal Ostrowski <mostrows@speakeasy.net> CC: Michal Ostrowski <mostrows@earthlink.net> CC: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27fddi: Move the FDDI driversJeff Kirsher
Move the FDDI drivers into drivers/net/fddi/ and make the necessary Kconfig and Makefile changes. CC: "Maciej W. Rozycki" <macro@linux-mips.org> CC: Christoph Goos <cgoos@syskonnect.de> CC: <linux@syskonnect.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-16net: Fix sungem_phy sharing.David S. Miller
Since sungem_phy is used by multiple, unrelated, drivers make it build as a real module under drivers/net. depmod will pick up the symbol dependency and make sure sungem_phy.ko gets loaded any time sungem.ko or spider_net.ko is loaded. Tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13drivers/net: Kconfig and Makefile cleanupJeff Kirsher
After the move of the Ethernet drivers into drivers/net/ethernet/ there was some leftover cleanup to do in the Kconfig and Makefile. Removed the 10/100, 1000, and 10GbE Kconfig menus. Removed the out-dated pci-skeleton.c file which was used an example driver. With the current networking features and structure, the file is no longer a good example to use for driver creation. CC: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12tile: Move the Tilera driverJeff Kirsher
Move the Tilera driver into drivers/net/ethernet/tile and make the necessary Kconfig and Makefile changes. Updated the Kconfig so that the options defualt to y if TILE kernel. CC: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12sh_eth: Move the Renesas SuperH driverJeff Kirsher
Move the Renesas driver into drivers/net/ethernet/renesas/ and make the necessary Kconfig and Makefile changes. CC: Yoshihiro Shimoda <yoshihiro.shirmoda.uh@renesas.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12netx: Move the netx driverJeff Kirsher
Move the netx driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-12dm9000: Move the Davicom driverJeff Kirsher
Move the Davicom driver into drivers/net/ethernet/davicom/ and make the necessary Kconfig and Makefile changes. CC: Ben Dooks <ben@simtec.co.uk> CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-12enc28j60: Move the Microchip driverJeff Kirsher
Move the Microchip driver into drivers/net/ethernet/microchip/ and make the necessary Kconfig and Makefile changes. CC: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12greth: Move the Aeroflex Gaisler driverJeff Kirsher
Move the Aeroflex Gaisler driver into drivers/net/ethernet/aeroflex/ and make the necessary Kconfig and Makefile changes. CC: Kristoffer Glembo <kristoffer@gaisler.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ethoc: Move the Avionic driverJeff Kirsher
Move the Avionic driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12dnet: Move the Dave Ethernet driverJeff Kirsher
Move the Dave Ethernet driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12hp100: Move the HP driverJeff Kirsher
Move the HP driver into drivers/net/ethernet/hp/ and made the necessary Kconfig and Makefile changes. CC: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12starfire: Move the Adaptec driverJeff Kirsher
Move the Adaptec driver into drivers/net/ethernet/adaptec/ and make the necessary Kconfig and Makefile changes. CC: Ion Badulescu <ionut@badula.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12forcedeth: Move the NVIDIA nForce driverJeff Kirsher
Move the nForce driver into drivers/net/ethernet/nvidia/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12fealnx: Move the Myson driverJeff Kirsher
Move the Myson driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12r6040: Move the RDC driverJeff Kirsher
Move the RDC driver into drivers/net/ethernet/rdc/ and make the necessary Kconfig and Makefile changes. CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12macb: Move the Atmel driverJeff Kirsher
Move the Atmel driver into drivers/net/ethernet/cadence/ and make the necessary Kconfig and Makefile changes. CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-08-12bfin_mac: Move the Analog Devices Inc driverJeff Kirsher
Move the Analog Devices Inc driver into drivers/net/ethernet/adi/ and make the necessary Kconfig and Makefile changes. CC: <uclinux-dist-devel@blackfin.uclinux.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Bob Liu <bob.liu@analog.com>
2011-08-12lantiq: Move the Lantiq SoC driverJeff Kirsher
Move the Lantiq driver into drivers/net/ethernet/ and the necessary Kconfig and Makefile changes. CC: John Crispin <blogic@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: John Crispin <blogic@openwrt.org>
2011-08-12mipsnet: Move the MIPS driverJeff Kirsher
Move the MIPS drivers into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12korina: Move the IDT driverJeff Kirsher
Move the IDT driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes CC: "IDT Inc." <rischelp@idt.com> CC: Felix Fietkau <nbd@openwrt.org> CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ipg: Move the IC Plus driverJeff Kirsher
Move the IC Plus driver into drivers/net/ethernet/icplus/ and make the necessary Kconfig and Makefile changes. CC: <craig_rich@sundanceti.com> CC: <sorbica@icplus.com.tw> CC: <jesse@icplus.com.tw> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12xilinx/ll_temac: Move the Xilinx driversJeff Kirsher
Move the Xilinx drivers into drivers/net/ethernet/xilinx/ and make the necessary Kconfig and Makefile changes. CC: John Williams <john.williams@petalogix.com> CC: "David H. Lynch Jr." <dhlii@dlasys.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12jme: Move the JME driverJeff Kirsher
Move the JME driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Guo-Fu Tseng <cooldavid@cooldavid.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12octeon: Move the Cavium driverJeff Kirsher
Move the Cavium driver to drivers/net/ethernet/octeon/ and make the necessary Kconfig and Makefile changes. CC: David Daney <david.daney@cavium.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: David Daney <david.daney@cavium.com>
2011-08-12hamachi/yellowfin: Move the packet engine driversJeff Kirsher
Move the packet engine drivers to drivers/net/ethernet/packetengines/ and the necessary Kconfig and Makefile changes. CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12davinci*/tlan/cpmac: Move the Texas Instruments (TI) driversJeff Kirsher
Move the Texas Instruments drivers to drivers/net/ethernet/ti/ and make the necessary Kconfig and Makefile changes. CC: Sriram <srk@ti.com> CC: Vinay Hegde <vinay.hegde@ti.com> CC: Cyril Chemparathy <cyril@ti.com> CC: Samuel Chessman <chessman@tux.org> CC: <torben.mathiasen@compaq.com> CC: Eugene Konev <ejka@imfi.kspu.ru> CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12s6gmac: Move the s6gmac driversJeff Kirsher
Move the s6gmac driver to drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Oskar Schirmer <os@emlix.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12tsi108*: Move the Tundra driverJeff Kirsher
Move the Tundra driver to drivers/net/ethernet/tundra/ and make the necessary Kocnfig and Makefile changes. CC: Kong Lai <kong.lai@tundra.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12sis*: Move the Silicon Integrated Systems (SiS) driversJeff Kirsher
Move the SiS drivers into drivers/net/ethernet/sis/ and make the necessary Kconfig and Makefile changes CC: Daniele Venzano <venza@brownhat.org> CC: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
