path: root/drivers/net/amd8111e.c
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21amd8111e: use net_device_stats from struct net_deviceEric Dumazet
struct net_device has its own struct net_device_stats member, so use this one instead of a private copy in the amd8111e_priv struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-16drivers/net: Adjust confusing if indentationJulia Lawall
In amd8111e.c, indent the branch of an if. In eepro.c, outdent the code following the if. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03drivers/net/amd8111e.c: Fix continuation line formatsJoe Perches
String constants that are continued on subsequent lines with \ are not good. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07amd8111e: convert to net_device_opsStephen Hemminger
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/p54/p54common.c
2008-10-31amd8111e: fix dma_free_coherent contextChunbo Luo
Acoording commit aa24886e379d2b641c5117e178b15ce1d5d366ba, dma_free_coherent() need irqs enabled. This patch fix following warning messages: WARNING: at linux/arch/x86/kernel/pci-dma.c:376 dma_free_coherent+0xaa/0xb0() Call Trace: [<ffffffff8023f80f>] warn_on_slowpath+0x5f/0x90 [<ffffffff80496ffa>] ? __kfree_skb+0x3a/0xa0 [<ffffffff802a4723>] ? discard_slab+0x23/0x40 [<ffffffff8021274a>] dma_free_coherent+0xaa/0xb0 [<ffffffff8043668f>] amd8111e_close+0x10f/0x1b0 [<ffffffff8049f3ae>] dev_close+0x5e/0xb0 [<ffffffff8049efa1>] dev_change_flags+0xa1/0x1e0 [<ffffffff806b2171>] ic_close_devs+0x36/0x4e [<ffffffff806b29ee>] ip_auto_config+0x581/0x10f3 [<ffffffff803a6e19>] ? kobject_add+0x69/0x90 [<ffffffff803a698a>] ? kobject_get+0x1a/0x30 [<ffffffff803a785b>] ? kobject_uevent+0xb/0x10 [<ffffffff803a6c62>] ? kset_register+0x52/0x60 [<ffffffff803a6f9b>] ? kset_create_and_add+0x6b/0xa0 [<ffffffff804e2e74>] ? tcp_ca_find+0x24/0x50 [<ffffffff806b246d>] ? ip_auto_config+0x0/0x10f3 [<ffffffff8020903c>] _stext+0x3c/0x150 [<ffffffff802772d3>] ? register_irq_proc+0xd3/0xf0 [<ffffffff802f0000>] ? mb_cache_create+0x80/0x1f0 [<ffffffff80688693>] kernel_init+0x141/0x1b8 [<ffffffff80688552>] ? kernel_init+0x0/0x1b8 [<ffffffff8020d609>] child_rip+0xa/0x11 [<ffffffff80688552>] ? kernel_init+0x0/0x1b8 [<ffffffff80688552>] ? kernel_init+0x0/0x1b8 [<ffffffff8020d5ff>] ? child_rip+0x0/0x11 Signed-off-by: Chunbo Luo <chunbo.luo@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-28amd8111e: Fix rx return codeChris Friesen
The amd8111e rx poll routine currently mishandles the case when we process exactly the number of packets specified in the budget. This patch is basically as suggested by David Miller. Signed-off-by: Chris Friesen <cfriesen@nortel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-07amd8111e: delete non NAPI code from the driver.Francois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28drivers/net: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-23amd8111e: don't call napi_enable if configured w/o NAPIJiri Bohac
The amd8111e network driver was broken by bea3348eef27e6044b6161fd04c3152215f96411, which makes the driver call napi_enable() and napi_disable() even if the driver had been configured without CONFIG_AMD8111E_NAPI, and thus netif_napi_add() had not been called on initialization. This triggers a BUG in napi_enable(). This patch fixes the problem. Please apply. Signed-off-by: Jiri Bohac <jbohac@suse.cz> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10amd8111e big-endian fixAl Viro
amd8111e_calc_coalesce() ends up with insane values of tx_data_rate since ->tx_bytes increments missing conversion from little- to host-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10amd8111e: trivial endianness annotations, NULL noise removalAl Viro
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03network drivers: eliminate unneeded kill_vid codeStephen Hemminger
Many drivers had code that did kill_vid, but they weren't doing vlan filtering. With new API the stub is unneeded unless device sets NETIF_F_HW_VLAN_FILTER. Bad habit: I couldn't resist fixing a couple of nearby style things in acenic, and forcedeth. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[VLAN]: Avoid a 4-order allocation.Dan Aloni
This patch splits the vlan_group struct into a multi-allocated struct. On x86_64, the size of the original struct is a little more than 32KB, causing a 4-order allocation, which is prune to problems caused by buddy-system external fragmentation conditions. I couldn't just use vmalloc() because vfree() cannot be called in the softirq context of the RCU callback. Signed-off-by: Dan Aloni <da-x@monatomic.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-06NET: turn local_save_flags() + local_irq_disable() into local_irq_save()Jiri Kosina
drivers/net/amd8111e.c::amd8111e_poll() contains local_irq_disable() after local_save_flags(). Turn it into local_irq_save(). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] amd8111e use standard CRC libStephen Hemminger
I noticed this driver (and several others) reinvent their own copy of the existing CRC library. Don't have the hardware, but tested by extracting code and comparing result. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[git] change permissions on drivers/net/amd8111e.[ch] to 0644,Jeff Garzik
removing executable bits.
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Use pci_set_dma_mask() instead of direct assignment of DMA maskTobias Klauser
The amd8111e driver directly assigns the DMA mask to the dma_mask member of the struct pci_dev instead of using pci_set_dma_mask(). This makes the call to pci_dma_supported() redundant as pci_set_dma_mask() does this check. I do not own this device so I only compile-tested this patch. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
