path: root/drivers/net/appletalk
2006-02-13[APPLETALK]: warning fixAndrew Morton
drivers/net/appletalk/cops.c: In function `cops_load': drivers/net/appletalk/cops.c:539: warning: assignment discards qualifiers from pointer target type drivers/net/appletalk/cops.c:547: warning: assignment discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-11[NET]: move config options out to individual protocolsSam Ravnborg
Move the protocol specific config options out to the specific protocols. With this change net/Kconfig now starts to become readable and serve as a good basis for further re-structuring. The menu structure is left almost intact, except that indention is fixed in most cases. Most visible are the INET changes where several "depends on INET" are replaced with a single ifdef INET / endif pair. Several new files were created to accomplish this change - they are small but serve the purpose that config options are now distributed out where they belongs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[LTPC]: Replace schedule_timeout() with ssleep()/msleep()Nishanth Aravamudan
Use ssleep() / msleep() [as appropriate] instead of schedule_timeout() to guarantee the task delays as expected. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[ATALK]: Add alloc_ltalkdev().Christoph Hellwig
this matches the API used by other link layer like ethernet or token ring. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 3Al Viro
Drivers that expect ISA DMA API are marked as such in Kconfig. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
