path: root/drivers/net/arm/at91_ether.h
2008-07-22at91_ether: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-08AT91RM9200 Ethernet: Support additional PHYsAndrew Victor
Add support for a number of new PHY's in the AT91RM9200 Ethernet driver. - Teridian 78Q21x3 - SMSC LAN83C185 (Patch from Luca Gamma) - National Semiconductor DP83848 (Patches from Ivan Kuten & Thomas Foldesi) Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] AT91RM9200 Ethernet: Move check_timer variable and use mod_timer()Andrew Victor
Move the global 'check_timer' variable into the private data structure. Also now use mod_timer(). Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] AT91RM9200 Ethernet #3: CleanupAndrew Victor
Moved global ether_clk variable into controller data structure. Patch from David Brownell. Davicom 9161 PHY was being incorrectly displayed as "9196". Patch from Brian Stafford. clk_get() doesn't return NULL on error, so the return value needs to be tested with IS_ERR(). Whitespace cleanup. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-24[PATCH] AT91RM9200 Ethernet driverAndrew Victor
This patch adds support for the Ethernet controller integrated in the Atmel AT91RM9200 SoC processor. Changes since the previous submission (01/02/2006) are: - Make use of the clk.h clock infrastructure. - The multicast hash function is not crc32. [Patch by Pedro Perez] Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
