path: root/drivers/net/atlx/atlx.h
2011-08-11atl*: Move the Atheros driversJeff Kirsher
Move the Atheros drivers into drivers/net/ethernet/atheros/ and make the necessary Kconfig and Makefile changes. CC: Jay Cliburn <jcliburn@gmail.com> CC: Chris Snook <chris.snook@gmail.com> CC: Jie Yang <jie.yang@atheros.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2009-05-26atlx: move modinfo data from atlx.h to atl1.cAlex Chiang
Both atl1.c and atl2.c include atlx.h, which defines some modinfo stuff. But atl2.c seems like it doesn't want the modinfo data from atlx.h, as it defines its own. Running modinfo on atl2.ko, we get conflicting information: $ /sbin/modinfo drivers/net/atlx/atl2.ko | egrep "version|description|author" version: 2.2.3 description: Atheros Fast Ethernet Network Driver author: Atheros Corporation <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com> version: 2.1.3 author: Xiong Huang <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com>, Jay Cliburn <jcliburn@gmail.com> Move the modinfo data out of atlx.h and into atl1.c to eliminate the confusion: $ /sbin/modinfo drivers/net/atlx/atl1.ko | egrep "version|description|author" version: 2.1.3 author: Xiong Huang <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com>, Jay Cliburn <jcliburn@gmail.com> description: Atheros L1 Gigabit Ethernet Driver $ /sbin/modinfo drivers/net/atlx/atl2.ko | egrep "version|description|author" version: 2.2.3 description: Atheros Fast Ethernet Network Driver author: Atheros Corporation <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com> Reported-by: Scott Scriven <scott.scriven@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-13atl1: bump version numberJay Cliburn
atl1-2.1.3. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13atl1: add PHY power save modeJay Cliburn
Using vendor-provided magic, add code to enter power save mode on the PHY. We'll need this for suspend and wake-on-lan. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-17atl1: move common functions to atlx filesJay Cliburn
The future atl2 driver and the existing atl1 driver can share certain functions and definitions. Move these shareable functions and definitions out of atl1-specific files and into atlx.c and atlx.h. Some transitory hackery will be present until atl2 is merged. Reduce the number of source files by moving ethtool, hw, and param functions from separate files into atl1_main.c, then rename it to just atl1.c. Move all atl1-specific definitions from atl1_hw.h to atl1.h. Finally, clean up to make checkpatch.pl happy. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
