path: root/drivers/net/atlx
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net: remove redundant codeEric Dumazet
eth_type_trans(skb, netdev) does the "skb->dev = netdev;" initialization, we can remove it from various network drivers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-27drivers/net: Fix continuation linesJoe Perches
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07NET: atlx, fix memory leakJiri Slaby
Stanse found a memory leak in atl2_get_eeprom. eeprom_buff is not freed/assigned on all paths. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <chris.snook@gmail.com> Cc: Jie Yang <jie.yang@atheros.com> Cc: atl1-devel@lists.sourceforge.net Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-09atlx: strncpy does not null terminate stringRoel Kluin
strlcpy() will always null terminate the string. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <csnook@redhat.com> Cc: Jie Yang <jie.yang@atheros.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-13atlx: duplicate testing of MCAST flagroel kluin
Fix duplicate testing of MCAST flag Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11net: ntohs() misuseEric Dumazet
Some drivers incorrectly use ntohs() instead of htons() A cleanup as htons() returns same result than ntohs(), but better to use the proper one. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-26atlx: move modinfo data from atlx.h to atl1.cAlex Chiang
Both atl1.c and atl2.c include atlx.h, which defines some modinfo stuff. But atl2.c seems like it doesn't want the modinfo data from atlx.h, as it defines its own. Running modinfo on atl2.ko, we get conflicting information: $ /sbin/modinfo drivers/net/atlx/atl2.ko | egrep "version|description|author" version: 2.2.3 description: Atheros Fast Ethernet Network Driver author: Atheros Corporation <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com> version: 2.1.3 author: Xiong Huang <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com>, Jay Cliburn <jcliburn@gmail.com> Move the modinfo data out of atlx.h and into atl1.c to eliminate the confusion: $ /sbin/modinfo drivers/net/atlx/atl1.ko | egrep "version|description|author" version: 2.1.3 author: Xiong Huang <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com>, Jay Cliburn <jcliburn@gmail.com> description: Atheros L1 Gigabit Ethernet Driver $ /sbin/modinfo drivers/net/atlx/atl2.ko | egrep "version|description|author" version: 2.2.3 description: Atheros Fast Ethernet Network Driver author: Atheros Corporation <xiong.huang@atheros.com>, Chris Snook <csnook@redhat.com> Reported-by: Scott Scriven <scott.scriven@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13drivers/net: replace BUG() with BUG_ON() if possibleAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-17drivers/net/atlx: fix sparse warnings: fix signednessHannes Eder
Impact: While being at it: statics do not need to be initialized with 0. Fix this sparse warnings: drivers/net/atlx/atl1.c:109:1: warning: incorrect type in initializer (different signedness) drivers/net/atlx/atl2.c:2870:1: warning: incorrect type in initializer (different signedness) drivers/net/atlx/atl2.c:2880:1: warning: incorrect type in initializer (different signedness) drivers/net/atlx/atl2.c:2894:1: warning: incorrect type in initializer (different signedness) drivers/net/atlx/atl2.c:2904:1: warning: incorrect type in initializer (different signedness) drivers/net/atlx/atl2.c:2913:1: warning: incorrect type in initializer (different signedness) Signed-off-by: Hannes Eder <hannes@hanneseder.net> Acked-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25drivers/net/atlx: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/atlx/atl1.c:198:16: warning: symbol 'atl1_check_options' was not declared. Should it be static? drivers/net/atlx/atl1.c:526:5: warning: symbol 'atl1_read_mac_addr' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25atlx: fix warning in drivers/net/atlx/atl2.cIngo Molnar
fix this warning: drivers/net/atlx/atl2.c: In function ‘atl2_request_irq’: drivers/net/atlx/atl2.c:644: warning: unused variable ‘err’ 'err' is unused in the !CONFIG_PCI_MSI case. Instead of further increasing the #ifdeffery in this function, restructure the code a bit and get rid of the #ifdef. This relies on the fact that pci_enable_msi() will always fail in the !CONFIG_PCI_MSI case. There should be no change in driver behavior. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-20atl2: don't request irq on resume if netif runningAlan Jenkins
If the device is suspended with the cable disconnected, then resumed with the cable connected, dev->open is called before resume. During resume, we request an IRQ, but the IRQ was already assigned during dev->open, resulting in the warning shown below. Don't request an IRQ if the device is running. Call Trace: [<c011b89a>] warn_on_slowpath+0x40/0x59 [<c023df15>] raw_pci_read+0x4d/0x55 [<c023dff3>] pci_read+0x1c/0x21 [<c01bcd81>] __pci_find_next_cap_ttl+0x44/0x70 [<c01bce86>] __pci_find_next_cap+0x1a/0x1f [<c01bcef9>] pci_find_capability+0x28/0x2c [<c01c4144>] pci_msi_check_device+0x53/0x62 [<c01c49c2>] pci_enable_msi+0x3a/0x1cd [<e019f17b>] atl2_write_phy_reg+0x40/0x5f [atl2] [<c01061b1>] dma_generic_alloc_coherent+0x0/0xd7 [<e019f107>] atl2_request_irq+0x15/0x49 [atl2] [<e01a1481>] atl2_open+0x20b/0x297 [atl2] [<c024a35c>] dev_open+0x62/0x91 [<c0248b9a>] dev_change_flags+0x93/0x141 [<c024f308>] do_setlink+0x238/0x2d5 [<c02501b2>] rtnl_setlink+0xa9/0xbf [<c0297f0c>] mutex_lock+0xb/0x19 [<c024ffa7>] rtnl_dump_ifinfo+0x0/0x69 [<c0250109>] rtnl_setlink+0x0/0xbf [<c024fe42>] rtnetlink_rcv_msg+0x185/0x19f [<c0240fd1>] sock_rmalloc+0x23/0x57 [<c024fcbd>] rtnetlink_rcv_msg+0x0/0x19f [<c0259457>] netlink_rcv_skb+0x2d/0x71 [<c024fcb7>] rtnetlink_rcv+0x14/0x1a [<c025929e>] netlink_unicast+0x184/0x1e4 [<c025992a>] netlink_sendmsg+0x233/0x240 [<c023f405>] sock_sendmsg+0xb7/0xd0 [<c0129131>] autoremove_wake_function+0x0/0x2b [<c0129131>] autoremove_wake_function+0x0/0x2b [<c0147796>] mempool_alloc+0x2d/0x9e [<c020c923>] scsi_pool_alloc_command+0x35/0x4f [<c0297f0c>] mutex_lock+0xb/0x19 [<c028e867>] unix_stream_recvmsg+0x357/0x3e2 [<c01b81c9>] copy_from_user+0x23/0x4f [<c02452ea>] verify_iovec+0x3e/0x6c [<c023f5ab>] sys_sendmsg+0x18d/0x1f0 [<c023ffa8>] sys_recvmsg+0x146/0x1c8 [<c0240016>] sys_recvmsg+0x1b4/0x1c8 [<c0118f48>] __wake_up+0xf/0x15 [<c02586cd>] netlink_table_ungrab+0x17/0x19 [<c01b83ba>] copy_to_user+0x25/0x3b [<c023fe4a>] move_addr_to_user+0x50/0x68 [<c0240266>] sys_getsockname+0x6f/0x9a [<c0240280>] sys_getsockname+0x89/0x9a [<c015046a>] do_wp_page+0x3ae/0x41a [<c0151525>] handle_mm_fault+0x4c5/0x540 [<c02405d0>] sys_socketcall+0x176/0x1b0 [<c010376d>] sysenter_do_call+0x12/0x21 Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19atlx: convert to net_device_opsStephen Hemminger
Convert this driver to network device ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-14atl1: Do not enumerate options unsupported by chipJ. K. Cliburn
Of the various WOL options provided in include/linux/ethtool.h, the L1 NIC supports only magic packet. Remove all options except magic packet from the atl1 driver. Signed-off-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-02atlx: timer cleanupStephen Hemminger
Do some cleanup on timer usage in this driver: * Use round_jiffies to align wakeups and reduce power. * Remove atl1_watchdog which does nothing but rearm itself * Use setup_timer() function Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-02atlx: use embedded net_device_statsStephen Hemminger
There is now a net_device_stats structure inside net_device that should be used if possible by devices. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31atl1: fix vlan tag regressionJay Cliburn
Commit 401c0aabec4b97320f962a0161a846d230a6f7aa introduced a regression in the atl1 driver by storing the VLAN tag in the wrong TX descriptor field. This patch causes the VLAN tag to be stored in its proper location. Tested-by: Ramon Casellas <ramon.casellas@cttc.es> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-08atl1: update introductory commentsJay Cliburn
Update the driver's introductory comments. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08atl1: remove LLTXJay Cliburn
NETIF_F_LLTX is deprecated. Remove private TX locking from the driver and remove the NETIF_F_LLTX feature flag. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08atl1: fix transmit timeout bugJay Cliburn
See http://marc.info/?l=linux-netdev&m=121931988219314&w=2 Stop the queue and turn off carrier to prevent transmit timeouts when the cable is unplugged/replugged. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: remove LLTX in atl2 driverKevin Hao
When NETIF_F_LLTX is set, the atlx driver will use a private lock. But in recent kernels this implementation seems redundant and can cause problems where AF_PACKET sees things twice. Since NETIF_F_LLTX is marked as deprecated and shouldn't be used in new driver, this patch removes NETIF_F_LLTX and adds a mmiowb before sending packet. I have tested this driver on a Eee PC. It works well. Signed-off-by: Kevin Hao <kexin.hao@windriver.com> Acked-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: add net poll support for atl2 driverKevin Hao
Add netconsole support for Atheros L2 10/100 network device. Signed-off-by: Kevin Hao <kexin.hao@windriver.com> Acked-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24atl2: add tx bytes statisticJay Cliburn
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-18atl2: add atl2 driverChris Snook
Driver for Atheros L2 10/100 network device. Includes necessary changes for Kconfig, Makefile, and pci_ids.h. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-27atl1: disable TSO by defaultJay Cliburn
The atl1 driver is causing stalled connections and file corruption whenever TSO is enabled. Two examples are here: http://lkml.org/lkml/2008/7/15/325 http://lkml.org/lkml/2008/8/18/543 Disable TSO by default until we can determine the source of the problem. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
