path: root/drivers/net/benet
2011-05-24be2net: hash key for rss-config cmd not setSathya Perla
A non-zero, non-descript value is needed as the hash key. The hash variable was left un-initialized; but sometimes it gets a zero value and hashing is not effective. The constant value used now (not of any significance) seems to work fine. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19be2net: Kill set but unused variable 'req' in lancer_fw_download()David S. Miller
2011-05-18be2net: Enable SR-IOV for LancerMammatha Edhala
Enable SR-IOV for Lancer Signed-off-by: Mammatha Edhala <mammatha.edhala@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: FW download for LancerShripad Nunjundarao
Added implementation of FW download feature for Lancer. Signed-off-by: Shripad Nunjundarao <shripad.nunjundarao@emulex.com> Signed-off-by: Sevin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Stats for LancerSelvin Xavier
Added Lancer stats implementation. Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Support for version 1 of stats for BE3Ajit Khaparde
Added support to get version 1 of the stats for BE3. Use old stats command for BE2. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13be2net: fix mbox polling for signal receptionSathya Perla
Sending mbox cmds require multiple steps of writing to the DB register and polling for an ack. Gettting interrupted in the middle by a signal breaks the mbox protocol. Use msleep() to not get interrupted. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13be2net: handle signal reception while waiting for POSTSathya Perla
If waiting on POST returns prematurely (due to a signal), abort polling and return an error. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11be2net: Fix to prevent flooding of TX queuePadmanabh Ratnakar
Start/stop TX queue is controlled by TX queue "used" counter. It is incremented while WRBs are posted to TX queue and decremented when TX completions are received. This counter was getting decremented before HW is informed about processing of TX completions. As used counter is decremented, transmit function posts new WRBs and creates completion queue full scenario in HW. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11be2net: Use NTWK_RX_FILTER command for promiscous modePadmanabh Ratnakar
Use OPCODE_COMMON_NTWK_RX_FILTER command for promiscous mode as OPCODE_ETH_PROMISCUOUS command is getting deprecated. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11be2net: In case of UE, do not dump registers for LancerPadmanabh Ratnakar
In case of UE, do not dump registers for Lancer as they are not supported. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11be2net: Disable coalesce water mark mode of CQ for LancerPadmanabh Ratnakar
Disable coalesce water mark mode of CQ for Lancer Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11be2net: Handle error completion in LancerPadmanabh Ratnakar
In Lancer if a frame is DMAed partially due to lack of RX buffers, an error completion is sent with packet size as zero and num_recvd indicating number of used buffers. These buffers need to be freed and packet dropped. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6 Conflicts: drivers/net/benet/be_main.c
2011-05-09be2net: Fixed bugs related to PVID.Somnath Kotur
Fixed bug to make sure 'pvid' retrieval will work on big endian hosts. Fixed incorrect comparison between the Rx Completion's 16-bit VLAN TCI and the PVID. Now comparing only the relevant 12 bits corresponding to the VID. Renamed 'vid' field under Rx Completion to 'vlan_tag' to reflect accurate description. Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Resolved logic conflicts causing a build failure due to drivers/net/r8169.c changes using a patch from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-25be2net: Fixed a bug in be_cmd_get_regs().Somnath Kotur
Same WRB entry was being reused over different iterations of a loop while issuing non-embedded IOCTL requests.Fixed couple of minor bugs in this path as well. Re-factored code to alloc/free memory for DMA outside of loop Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21be2net: increment work_counter in be_workerIvan Vecera
The commit 609ff3b ("be2net: add code to display temperature of ASIC") adds support to display temperature of ASIC but there is missing increment of work_counter in be_worker. Because of this 1) the function be_cmd_get_die_temperature is called every 1 second instead of every 32 seconds 2) be_cmd_get_die_temperature is called, although it is not supported. This patch fixes this bug. Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19be2net: add code to display default value of tx rate for VFsAjit Khaparde
This change will allow the default value of tx rate to be displayed when ip link show is called on a PF interface. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19be2net: pass domain id to be_cmd_link_status_queryAjit Khaparde
2011-04-19be2net: fix be_mcc_compl_process to identify eth_get_stat commandAjit Khaparde
eth_get_statistics and vlan_config command have same opcode. Use opcode subsystem id to differentiate one from other. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19be2net: Add code to display nic speeds other than 1Gbps/10GbpsAjit Khaparde
2011-04-19be2net: allow register dump only for PFsAjit Khaparde
2011-04-17net: benet: convert to hw_features - fixupMichał Mirosław
Remove be_set_flags() as it's already covered by hw_features. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Ajit Khaparde ajit.khaparde@emulex.com Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17be2net: Fix unused-but-set variables.David S. Miller
The variables 'tx_min' and 'tx_max' are set but not used in be_set_coalesce(). Similarly for 'region' in be_do_flash(). Just kill them off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14ethtool: allow custom interval for physical identificationAllan, Bruce W
When physical identification of an adapter is done by toggling the mechanism on and off through software utilizing the set_phys_id operation, it is done with a fixed duration for both on and off states. Some drivers may want to set a custom duration for the on/off intervals. This patch changes the API so the return code from the driver's entry point when it is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to cycle the on/off states, and updates the drivers that have already been converted to use the new set_phys_id and use the synchronous method for identifying an adapter. The physical identification frequency set in the updated drivers is based on how it was done prior to the introduction of set_phys_id. Compile tested only. Also fixes a compiler warning in sfc. v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE v3: fold patchset into single patch and cleanup per Ben's feedback Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Sathya Perla <sathya.perla@emulex.com> Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com> Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: Don Fry <pcnet32@frontier.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com> Cc: Steve Hodgson <shodgson@solarflare.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Carlson <mcarlson@broadcom.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-10net: benet: convert to hw_features - fixupMichał Mirosław
Fix up after merge with NETIF_F_RXHASH implementation. This allows to toggle NETIF_F_RXHASH and NETIF_F_HW_VLAN_TX. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07net: benet: convert to hw_featuresMichał Mirosław
Simple conversion. This also fixes a bug in TX checksum toggling --- driver was changing NETIF_F_HW_CSUM instead of NETIF_F_IP_CSUM+NETIF_F_IPV6_CSUM. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: call FLR after setup wol in be_shutdownAjit Khaparde
Calling setup_wol after a reset is inconsequential. The WOL setting should be programmed before FLR. And yes, FLR does not erase wol information. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: dynamically allocate adapter->vf_cfgAjit Khaparde
Instead of a fixed sized array for vf_cfg, allocate the size dynamically depending on number of VFs the device supports. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: fix to get max VFs supported from adapterAjit Khaparde
The user supplied num_vfs value need not be compared against a static BE_MAX_VF, but can be checked against the actual VFs that the device can support. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: use common method to check for sriov function typeAjit Khaparde
Lancer and BE can both use SLI_INTF_REG to check a VF or a PF. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: add rxhash supportAjit Khaparde
Add rxhash support, Based on initial work by Eric Dumazet. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_main.c
2011-04-06be2net: Fix suspend/resume operationPadmanabh Ratnakar
eq_next_idx is not getting reset to zero during suspend. This causes resume to fail. Added the fix. Signed-off-by: Sarveswara Rao Mygapula <sarveswararao.mygapula@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-06be2net: Rename some struct members for clarityPadmanabh Ratnakar
Renamed msix_vec_idx to eq_idx in be_eq_obj struct. Renamed msix_vec_next_idx to eq_next_idx in be_adapter structure. These members are used in INTX mode also. Signed-off-by: Sarveswara Rao Mygapula <sarveswararao.mygapula@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-06benet: convert to set_phys_idstephen hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-06be2net: Fix a potential crash during shutdown.Ajit Khaparde
adapter could remain uninitialized if probe fails for some reason. A null pointer access could cause a crash if be_shutdown is called after that. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30be2net: remove one useless lineSathya Perla
2011-03-30be2net: cancel be_worker in be_shutdown() even when i/f is downSathya Perla
As the be_worker() workqueue is scheduled in be_probe() it must be canceled unconditionally in be_shutdown(). Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30be2net: remove redundant code in be_worker()Sathya Perla
2011-03-30be2net: parse vid and vtm fields of rx-compl only if vlanf bit is setSathya Perla
2011-03-30be2net: refactor code that decides adapter->num_rx_queuesSathya Perla
The code has been refactored to not set num_rx_qs inside be_enable_msix(). num_rx_qs is now set at the time of queue creation based on the number of available msix vectors. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30be2net: Support for FAT dump retrieval using ethtool --register-dump optionSomnath Kotur
2011-03-16be2net: Bump up the version numberAjit Khaparde
