path: root/drivers/net/bna
2011-01-12bna: Remove unnecessary memset(,0,)Joe Perches
kzalloc'd memory doesn't need a memset to 0. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Update the driver version to 2.3.2.3Rasesh Mody
Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: IOC failure auto recovery fixRasesh Mody
Change Details: - Made IOC auto_recovery synchronized and not timer based. - Only one PCI function will attempt to recover and reinitialize the ASIC on a failure, that too after all the active PCI functions acknowledge the IOC failure. Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Restore VLAN filter tableRasesh Mody
Change Details: - Retrieve the VLAN configuration from the networking stack and apply it to the base interface during ifconfig up Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Removed unused codeRasesh Mody
Change Details: - Remove unused APIs and code cleanup Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: IOC uninit check and misc cleanupRasesh Mody
Change Details: - Added a check in ioc firmware lock function to see if IOC is in BFI_IOC_UNINIT state or not. If it is not in UNINIT state and the last IOC boot was not done by OS driver, force IOC state to BFI_IOC_UNINIT - Unused macro and API cleanup Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Fix for TX queueRasesh Mody
Change Details: - Call netif_wake_queue() if we have freed up sufficient elements at the end of completion processing - Add netif_queue_stopped counter back to bnad_drv_stats {} - Get netif_queue_stopped value from stack - Remove BUG_ON() on value returned by pci_unmap_addr() Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Enable pure priority tagged packet reception and rxf uninit cleanup fixRasesh Mody
Change Details: - Enable reception of pure priority tagged packets by default by turning on VLAN Id = 0 - Clear the promiscuous mode, all multicast mode flags when bna_rxf_uninit is called Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Fix ethtool register dump and reordered an APIRasesh Mody
Change Details: - Removed semaphore register dump from ethtool - Moved netif_carrier_off() call to before calling bna_init() Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: Port enable disable sync and txq priority fixRasesh Mody
Change Details: - Fixed port enable/disable sync through a change in LL port state machine - Change txq->priority masking to 0x7 (3 bits) from 0x3 (2 bits) Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-25bna: TxRx and datapath fixRasesh Mody
Change Details: - Check HW ready condition before accessing h/w register in data-path - Postpone clean-up of data buffers to the data-path restart path and wait in the cleanup routines for in-flight DMA to complete - Separate out Tx completion processing from Rx poll routine Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05bna: scope and dead code cleanupRasesh Mody
As suggested by Stephen Hemminger: 1) Made functions and data structures static wherever possible. 2) Removed unused code. Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05bna: fix interrupt handlingRasesh Mody
This fix handles the case when IRQ handler is called (for shared IRQs) even before the driver is ready to handle interrupts. Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-19bna: off by oneDan Carpenter
The mod->mbhdlr[] array has BFI_MC_MAX elements. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-12bna: Check for NULL before deref in bnad_cb_tx_cleanupDavid S. Miller
Reported-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06NET: bna, fix lock imbalanceJiri Slaby
bnad_set_rx_mode omit to unlock bna_lock on one fail path. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Debashis Dutt <ddutt@brocade.com> Cc: Rasesh Mody <rmody@brocade.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02bna: fix stats handlingEric Dumazet
get_stats() method incorrectly clears a global array before folding various stats. This can break SNMP applications. Switch to 64 bit flavor to work on a user supplied buffer, and provide 64bit counters even on 32bit arches. Fix a bug in bnad_netdev_hwstats_fill(), for rx_fifo_errors, missing a folding (only the last counter was taken into account) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25bna: Fixed build break for allyesconfigRasesh Mody
This is the patch to fix the build break caused by multiple definitions of symbols between Brocade's FC/FCOE driver(BFA) and 10G Networking Driver(BNA). Changes are: 1. locally used functions are made static 2. unused functions are removed 3. using unique namespaces for the function names that must be globally visible Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23bna: Delete get_flags and set_flags ethtool methods.David S. Miller
This driver doesn't support LRO, NTUPLE, or the RXHASH features. So it should not set these ethtool operations. This also fixes the warning: drivers/net/bna/bnad_ethtool.c:1272: warning: initialization from incompatible pointer type Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23bna: Brocade 10Gb Ethernet device driverRasesh Mody
This is patch 1/6 which contains linux driver source for Brocade's BR1010/BR1020 10Gb CEE capable ethernet adapter. Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
