path: root/drivers/net/bnx2.c
2008-06-12net: Eliminate flush_scheduled_work() calls while RTNL is held.David S. Miller
If the RTNL is held when we invoke flush_scheduled_work() we could deadlock. One such case is linkwatch, it is a work struct which tries to grab the RTNL semaphore. The most common case are net driver ->stop() methods. The simplest conversion is to instead use cancel_{delayed_}work_sync() explicitly on the various work struct the driver uses. This is an OK transformation because these work structs are doing things like resetting the chip, restarting link negotiation, and so forth. And if we're bringing down the device, we're about to turn the chip off and reset it anways. So if we cancel a pending work event, that's fine here. Some drivers were working around this deadlock by using a msleep() polling loop of some sort, and those cases are converted to instead use cancel_{delayed_}work_sync() as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02bnx2: Update version to 1.7.5.Michael Chan
Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02bnx2: Update RV2P firmware for 5709.Michael Chan
The new RV2P firmware fixes 2 issues: 1. The jumbo rx buffer page size is now configurable and set to the proper PAGE_SIZE. Before, it was assumed to be always 4K. 2. Driver sometimes would crash when receiving jumbo packets mixed with firmware management packets. This was caused by the old firmware DMA'ing to the wrong address. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02bnx2: Zero out context memory for 5709.Michael Chan
We should zero out the context memory for 5709 before each reset. When we resume after suspend for example, the memory may not be zero and the chip may not function correctly. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02bnx2: Fix register test on 5709.Michael Chan
The register BNX2_CTX_STATUS (0x1004) should be skipped on 5709 as it contains reserved bits. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02bnx2: Fix remote PHY initial link state.Michael Chan
On some remote PHY blade systems, the driver receives no initial link interrupt. As a result, the GMII/MII MAC mode does not get setup properly. To fix this problem, we add an initial poll of the link state after chip reset. With this change, the setting of the initial carrier state in the init code can be eliminated. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02bnx2: Refine remote PHY locking.Michael Chan
bnx2_set_remote_link() should be called under bp->phy_lock to protect against concurrent polling and interrupt calls. This change is needed by the next patch which will add one initial poll of the remote PHY link status. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-01net: fix returning void-valued expression warningsHarvey Harrison
drivers/net/8390.c:37:2: warning: returning void-valued expression drivers/net/bnx2.c:1635:3: warning: returning void-valued expression drivers/net/xen-netfront.c:1806:2: warning: returning void-valued expression net/ipv4/tcp_hybla.c:105:3: warning: returning void-valued expression net/ipv4/tcp_vegas.c:171:3: warning: returning void-valued expression net/ipv4/tcp_veno.c:123:3: warning: returning void-valued expression net/sysctl_net.c:85:2: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-23[BNX2]: Update version to 1.7.4.Michael Chan
2008-02-23[BNX2]: Disable parallel detect on an HP blade.Michael Chan
Because of some board issues, we need to disable parallel detect on an HP blade. Without this patch, the link state can become stuck when it goes into parallel detect mode. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-23[BNX2]: More 5706S link down workaround.Michael Chan
The previous patches to workaround the 5706S on an HP blade were not sufficient. The link state still does not change properly in some cases. This patch adds polling to make it completely reliable. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09bnx2: section fixAndrew Morton
gcc-3.4.4 on powerpc: drivers/net/bnx2.c:67: error: version causes a section type conflict Cc: Jeff Garzik <jeff@garzik.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Fix ASYM PAUSE advertisement for remote PHY.Michael Chan
We were checking for the ASYM_PAUSE bit for 1000Base-X twice instead checking for both the 1000Base-X bit and the 10/100/1000Base-T bit. The purpose of the logic is to tell the firmware that ASYM_PAUSE is set on either the Serdes or Copper interface. Problem was discovered by Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Update version to 1.7.3.Michael Chan
2008-01-31[BNX2]: Fine-tune flow control on 5709.Michael Chan
Make use of the programmable high/low water marks in 5709 for 802.3 flow control. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Remove CTX_WR macro.Michael Chan
The CTX_WR macro is unnecessary and obfuscates the code. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Remove REG_WR_IND/REG_RD_IND macros.Michael Chan
The REG_WR_IND/REG_RD_IND macros are unnecessary and obfuscate the code. Many callers to these macros read and write shared memory from the bp->shmem_base, so we add 2 similar functions that automatically add the shared memory base. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Refine tx coalescing setup.Michael Chan
Make the tx coalescing setup code independent of the MSIX vector. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Fix 5706 serdes link down bug.Michael Chan
1. Correct the MII expansion serdes control register definition. 2. Check an additional RUDI_INVALID bit when determining 5706S link. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28bnx2 annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[BNX2]: Fix driver phy_flags name space.Michael Chan
Prefix "bp->phy_flags" names with BNX2_PHY_FLAG_* for consistency. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Fix driver software flag namespace.David S. Miller
Prefix "bnx2->flags" names with BNX2_* for consistency. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2] Update version to 1.7.2.Michael Chan
2008-01-28[BNX2]: Add link-down workaround on 5706 serdes.Michael Chan
In some blade systems using the 5706 serdes, the hardware sometimes does not properly generate link down interrupts. We add a workaround in the driver's timer to force a link-down when some PHY registers report loss of SYNC. The parallel detect logic is cleaned up slightly to better integrate the workaround. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Fix minor bug in bnx2_has_work().Michael Chan
It is more correct to get the status block from the bnx2_napi struct instead of the bnx2 struct. It happens that they are the same in this case because we are using the first MSIX vector. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Disable jumbo rx paging on 5709 Ax.Michael Chan
The chip has problem running in this mode and needs to be disabled. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Fix compiler warning.Michael Chan
Change bnx2_init_napi() to void. Warning was noted by DaveM. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Update version to 1.7.1.Michael Chan
2008-01-28[BNX2]: Enable new tx ring.Michael Chan
Enable new tx ring and add new MSIX handler and NAPI poll function for the new tx ring. Enable MSIX when the hardware supports it. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add support for a new tx ring.Michael Chan
To separate TX IRQs into a different MSIX vector, we need to support a new tx ring. The original tx ring will still be used when not using MSIX. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Support multiple MSIX IRQs.Michael Chan
Change bnx2_napi struct into an array and add code to manage multiple IRQs. MSIX hardware structures and new registers are also added. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Move rx indexes into bnx2_napi struct.Michael Chan
Rx related fields used in NAPI polling are moved from the main bnx2 struct to the bnx2_napi struct. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Move tx indexes into bnx2_napi struct.Michael Chan
Tx related fields used in NAPI polling are moved from the main bnx2 struct to the bnx2_napi struct. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Introduce new bnx2_napi structure.Michael Chan
Introduce a bnx2_napi structure that will hold a napi_struct and other fields to handle NAPI polling for the napi_struct. Various tx and rx indexes and status block pointers will be moved from the main bnx2 structure to this bnx2_napi structure. Most NAPI path functions are modified to be passed this bnx2_napi struct pointer. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Restructure IRQ datastructures.Michael Chan
Add a table to keep track of multiple IRQs and restructure the IRQ request and free functions so that they can be easily expanded to handle multiple IRQs. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add function to fetch hardware tx index.Michael Chan
This makes the code cleaner and easier to support different tx rings. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Update version to 1.6.9.Michael Chan
2008-01-28[BNX2]: Enable S/G for jumbo RX.Michael Chan
If the MTU requires more than 1 page for the SKB, enable the page ring and calculate the size of the page ring. This will guarantee order-0 allocation regardless of the MTU size. Fixup loopback test packet size so that we don't deal with the pages during loopback test. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add fast path code to handle RX pages.Michael Chan
Add function to reuse a page in case of allocation or other errors. Add code to construct the completed SKB with the additional data in the pages. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add init. code to handle RX pages.Michael Chan
Add new fields to keep track of the pages and the page rings. Add functions to allocate and free pages. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Update firmware to support S/G RX buffers.Michael Chan
2008-01-28[BNX2]: Restructure RX ring init. code.Michael Chan
Factor out the common functions that will be used to initialize the normal RX rings and the page rings. Change the copybreak constant RX_COPY_THRESH to 128. This same constant will be used for the max. size of the linear SKB when pages are used. Copybreak will be turned off when pages are used. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Restructure RX fast path handling.Michael Chan
Add a new function to handle new SKB allocation and to prepare the completed SKB. This makes it easier to add support for non-linear SKB. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add ring constants.Michael Chan
Define the various ring constants to make the code cleaner. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-11[BNX2]: Update version to 1.6.9.Michael Chan
2007-12-11[BNX2]: Fix RX packet rot.Michael Chan
Packets can be left in the RX ring if the NAPI budget is reached. This is caused by storing the latest rx index at the beginning of bnx2_rx_int(). We may not process all the work up to this index if the budget is reached and so some packets in the RX ring may rot when we later check for more work using this stored rx index. The fix is to not store this latest hw index and only store the processed rx index. We use a new function bnx2_get_hw_rx_cons() to fetch the latest hw rx index. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-11[BNX2]: Add PHY_DIS_EARLY_DAC workaround.Michael Chan
5709 Ax and Bx chips all need this workaround. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (51 commits) [IPV6]: Fix again the fl6_sock_lookup() fixed locking [NETFILTER]: nf_conntrack_tcp: fix connection reopening fix [IPV6]: Fix race in ipv6_flowlabel_opt() when inserting two labels [IPV6]: Lost locking in fl6_sock_lookup [IPV6]: Lost locking when inserting a flowlabel in ipv6_fl_list [NETFILTER]: xt_sctp: fix mistake to pass a pointer where array is required [NET]: Fix OOPS due to missing check in dev_parse_header(). [TCP]: Remove lost_retrans zero seqno special cases [NET]: fix carrier-on bug? [NET]: Fix uninitialised variable in ip_frag_reasm() [IPSEC]: Rename mode to outer_mode and add inner_mode [IPSEC]: Disallow combinations of RO and AH/ESP/IPCOMP [IPSEC]: Use the top IPv4 route's peer instead of the bottom [IPSEC]: Store afinfo pointer in xfrm_mode [IPSEC]: Add missing BEET checks [IPSEC]: Move type and mode map into xfrm_state.c [IPSEC]: Fix length check in xfrm_parse_spi [IPSEC]: Move ip_summed zapping out of xfrm6_rcv_spi [IPSEC]: Get nexthdr from caller in xfrm6_rcv_spi [IPSEC]: Move tunnel parsing for IPv4 out of xfrm4_input ...
