path: root/drivers/net/bnx2.h
2008-01-28[BNX2]: Restructure IRQ datastructures.Michael Chan
Add a table to keep track of multiple IRQs and restructure the IRQ request and free functions so that they can be easily expanded to handle multiple IRQs. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add fast path code to handle RX pages.Michael Chan
Add function to reuse a page in case of allocation or other errors. Add code to construct the completed SKB with the additional data in the pages. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add init. code to handle RX pages.Michael Chan
Add new fields to keep track of the pages and the page rings. Add functions to allocate and free pages. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Restructure RX ring init. code.Michael Chan
Factor out the common functions that will be used to initialize the normal RX rings and the page rings. Change the copybreak constant RX_COPY_THRESH to 128. This same constant will be used for the max. size of the linear SKB when pages are used. Copybreak will be turned off when pages are used. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Add ring constants.Michael Chan
Define the various ring constants to make the code cleaner. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-11[BNX2]: Fix RX packet rot.Michael Chan
Packets can be left in the RX ring if the NAPI budget is reached. This is caused by storing the latest rx index at the beginning of bnx2_rx_int(). We may not process all the work up to this index if the budget is reached and so some packets in the RX ring may rot when we later check for more work using this stored rx index. The fix is to not store this latest hw index and only store the processed rx index. We use a new function bnx2_get_hw_rx_cons() to fetch the latest hw rx index. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[BNX2]: Fix default WoL setting.Michael Chan
Change the default WoL setting to match the NVRAM's setting. It always defaulted to WoL disabled before and caused a lot of confusion for users. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[BNX2]: Optimize firmware loading.Michael Chan
This is a follow up to the patches from Denys Vlasenkos <vda.linux@googlemail.com> to further optimize firmware loading. 1. In bnx2_init_cpus(), we allocate memory for decompression once and use it repeatedly instead of doing this for every firmware image. 2. We eliminate the BSS and SBSS firmware sections in bnx2_fw*.h since these are always zeros. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[BNX2]: factor out gzip unpackerDenys Vlasenko
This patch modifies gzip unpacking code in bnx2 driver so that it does not depend on bnx2 internals. I will move this code out of the driver and into zlib in follow-on patch. It can be useful in other drivers which need to store firmwares or any other relatively big binary blobs - fonts, cursor bitmaps, whatever. Patch is run tested by Michael Chan (driver author). Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-18[BNX2]: Support NVRAM on 5709.Michael Chan
The NVRAM interface is slightly modified on the 5709. To properly support it, we need to change the buffered flag in the flash data structure into multiple flags to indicate buffered operation, address translation, and the use of write enable (WREN). The 5709 flash only requires the buffered operation bit to be set. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[BNX2]: Print management firmware version.Michael Chan
Add management firmware version for ethtool -i. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[BNX2]: Enhance the heartbeat.Michael Chan
In addition to the periodic heartbeat, we're adding a heartbeat request interrupt when the heartbeat is late. This is needed during netpoll where the timer is not available. -rt kernels will also benefit since the timer is not as accurate. [ We discussed this patch last time and we decided that the -rt kernel problem alone did not justify this patch. I think the netpoll problem makes this patch necessary. ] Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[BNX2]: Add remote PHY bit definitions.Michael Chan
Add new fields in struct bnx2 and other bit definitions in shared memory to support remote PHY. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[BNX2]: Enable DMA on 5709.Michael Chan
Add missing code to enable DMA on 5709 A1. The bit is a no-op on A0 and therefore can be set on all 5709 chips. Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Update version and reldate.Michael Chan
Update version to 1.5.10. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Print bus information for PCIE devices.Michael Chan
Fix the code to print PCI or PCIE bus information for all devices. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Add 1-shot MSI handler for 5709.Michael Chan
The 5709 supports the one-shot MSI handler similar to some of the tg3 chips. In this mode, the MSI disables itself automatically until it is re-enabled at the end of NAPI poll. Put the request_irq/free_irq logic in common procedures. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Add indirect spinlock.Michael Chan
The indirect register access method will be used by more than one caller in BH context (NAPI poll and timer), so a spinlock is required. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Add support for 5709 Serdes.Michael Chan
Add PCI ID and code to support the 5709 Serdes PHY. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Put MII register offsets in the bnx2 struct.Michael Chan
The 5709 Serdes device uses non-standard MII register offsets. This re-structuring will make it easier to support 5709 Serdes. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Add ipv6 TSO and checksum for 5709.Michael Chan
2007-05-03[BNX2]: Add 40-bit DMA workaround for 5708.Michael Chan
The internal PCIE-to-PCIX bridge of the 5708 has the same 40-bit DMA limitation as some of the tg3 chips. Set dma_mask and persistent DMA mask to 40-bit to workaround. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-24[BNX2]: Fix occasional NETDEV WATCHDOG on 5709.Michael Chan
Tweak a register setting to prevent the tx mailbox from halting. Update version to 1.5.8. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-02[BNX2]: PHY workaround for 5709 A0.Michael Chan
5709 A0 copper devices will not link up with some link partners without this workaround. Update driver to 1.5.5. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[BNX2]: Add new 5709 registers (part 2).Michael Chan
2006-12-02[BNX2]: Add new 5709 registers (part 1).Michael Chan
2006-12-02[BNX2]: Re-organize firmware structures.Michael Chan
Re-organize the firmware handling code and declarations a bit to make the code more compact. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[BNX2]: Add 5708S parallel detection.Michael Chan
Add code to parallel detect 1Gbps and 2.5Gbps link speeds. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[BNX2]: Improve SerDes handling.Michael Chan
1. Add support for 2.5Gbps forced speed setting. 2. Remove a long udelay() loop and change to msleep(). 3. Other misc. SerDes fixes. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-17[BNX2]: Fix tx race condition.Michael Chan
Fix a subtle race condition between bnx2_start_xmit() and bnx2_tx_int() similar to the one in tg3 discovered by Herbert Xu: CPU0 CPU1 bnx2_start_xmit() if (tx_ring_full) { tx_lock bnx2_tx() if (!netif_queue_stopped) netif_stop_queue() if (!tx_ring_full) update_tx_ring netif_wake_queue() tx_unlock } Even though tx_ring is updated before the if statement in bnx2_tx_int() in program order, it can be re-ordered by the CPU as shown above. This scenario can cause the tx queue to be stopped forever if bnx2_tx_int() has just freed up the entire tx_ring. The possibility of this happening should be very rare though. The following changes are made, very much identical to the tg3 fix: 1. Add memory barrier to fix the above race condition. 2. Eliminate the private tx_lock altogether and rely solely on netif_tx_lock. This eliminates one spinlock in bnx2_start_xmit() when the ring is full. 3. Because of 2, use netif_tx_lock in bnx2_tx_int() before calling netif_wake_queue(). 4. Add memory barrier to bnx2_tx_avail(). 5. Add bp->tx_wake_thresh which is set to half the tx ring size. 6. Check for the full wake queue condition before getting netif_tx_lock in tg3_tx(). This reduces the number of unnecessary spinlocks when the tx ring is full in a steady-state condition. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[BNX2]: Turn off link during shutdownMichael Chan
Minor change in shutdown logic to effect a link down. Update version to 1.4.43. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Use CPU native page sizeMichael Chan
Use CPU native page size to determine various ring sizes. This allows order-0 memory allocations on all systems. Added check to limit the page size to 16K since that's the maximum rx ring size that will be used. This will prevent using unnecessarily large page sizes on some architectures with large page sizes. [Suggested by David Miller] Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Add firmware decompressionMichael Chan
Add functions to decompress firmware before loading to the internal CPUs. Compressing the firmware reduces the driver size significantly. Added file name length sanity check in the gzip header to prevent going past the end of buffer [suggested by DaveM]. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Add an rx drop counterMichael Chan
Add a counter for packets dropped by firmware. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[BNX2]: Separate tx producer and consumer fieldsMichael Chan
Put the tx producer and consumer fields in separate cache lines in the device structure, similar to the VJ net channel queue structure. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[BNX2]: Move .h files to bnx2.cMichael Chan
Move all #include <> from bnx2.h to bnx2.c. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[BNX2]: Combine small mem allocationsMichael Chan
Combine two small (56 byte and 320 byte) pci consistent memory allocations into one allocation. Jeff Garzik suggested to store the combined size in the bp structure for later use when freeing the memory. Use kzalloc() instead of kmalloc() + memset(). Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[BNX2]: Fix link change handlingMichael Chan
Fix some link-related problems by doing a coalesce_now after link change interrupt to flush out the transient link status. To facilitate this, the host coalesce cmd register value is cached in the device structure. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BNX2]: include <linux/vmalloc.h>Michael Chan
Include <linux/vmalloc.h> so that it compiles properly on all archs. Update version to 1.4.38. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BNX2]: Support larger rx ring sizes (part 1)Michael Chan
Increase maximum receive ring size from 255 to 1020 by supporting up to 4 linked pages of receive descriptors. To accomodate the higher memory usage, each physical descriptor page is allocated separately and the software ring that keeps track of the SKBs and the DMA addresses is allocated using vmalloc. Some of the receive-related fields in the bp structure are re- organized a bit for better locality of reference. The max. was reduced to 1020 from 4080 after discussion with David Miller. This patch contains ring init code changes only. This next patch contains rx data path code changes. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Update version and copyright yearMichael Chan
Update version to 1.4.31 and add 2006 copyright. Skip the last digit when reporting the firmware version. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Fix nvram sizingMichael Chan
Add code to correctly determine nvram size. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Fix UDP checksum verificationMichael Chan
Fix TCP/UDP checksum verification. Use status bits in the buffer descriptor instead of the checksum value to verify rx checksum. Using the checksum value will be incorrect if the UDP packet has zero in the UDP checksum field. Firmware update required for this fix. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Misc. fixesMichael Chan
Some misc. fixes for WoL, 5708 B1, and a typo '=' instead of '=='. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Improve handshake with firmwareMichael Chan
Improve handshake with bootcode with the following changes: 1. Increase timeout to 100msec and use msleep instead of udelay. 2. Add more error checking for timeouts and errors. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Fix VLAN on ASFMichael Chan
Always set up the device to strip incoming VLAN tags when ASF is enabled. ASF firmware will not parse packets correctly if VLAN tags are not stripped. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-05[PATCH] bnx2: refine bnx2_pollMichael Chan
Refine bnx2_poll() logic to write back the most up-to-date status tag when all work has been processed. This eliminates some occasional extra interrupts when a older status tag is written even though all work has been processed. The idea is to read the status tag just before exiting bnx2_poll() and then check again for any new work. If no new work is pending, the status tag written back will not generate any extra interrupt. This logic is similar to the changes David Miller did to tg3_poll(). Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-11-05[PATCH] bnx2: update firmware handshake for 5708Michael Chan
Dynamically determine the shared memory location where eeprom parameters are stored instead of using a fixed location. Add speed reporting to management firmware. This allows management firmware to know the current speed without contending for MII registers. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
