path: root/drivers/net/bnx2_fw.h
2011-08-10broadcom: Move the Broadcom driversJeff Kirsher
Moves the drivers for Broadcom devices into drivers/net/ethernet/broadcom/ and the necessary Kconfig and Makefile changes. CC: Eilon Greenstein <eilong@broadcom.com> CC: Michael Chan <mchan@broadcom.com> CC: Matt Carlson <mcarlson@broadcom.com> CC: Gary Zambrano <zambrano@broadcom.com> CC: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2009-04-04bnx2: Use request_firmware()Michael Chan
Based on original patch by Ben Hutchings <ben@decadent.org.uk> and Bastian Blank <waldi@debian.org>, with the following main changes: Separated the mips firmware and rv2p firmware into different files to make it easier to update them separately. Added some code to fixup the rv2p code with run-time information such as PAGE_SIZE. Update version to 2.0.0. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-12bnx2: Update 5706/5708 firmware.Michael Chan
New firmware fixes a data corruption issue when receiving and placing jumbo frames into host buffers. In some cases, the buffer descriptor is not updated correctly and this will lead to the driver linking the wrong number of pages into the SKB. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-09bnx2: Update 5706/5708 firmware.Michael Chan
With this new firmware, the driver no longer has to modify the TCP/IP header fields when transmitting TSO packets. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-16bnx2: Pre-initialize struct cpu_reg.Benjamin Li
Instead of assigning values for the struct cpu_reg's at runtime, we already know these values at compile time. Therefore, we can use designated initializers, to initialize these structures and not have to incur this assignment cost at run-time. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[BNX2]: Update firmware.Michael Chan
Update firmware to support programmable flow control. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[BNX2]: Update firmware to support S/G RX buffers.Michael Chan
2007-10-10[BNX2]: Optimize firmware loading.Michael Chan
This is a follow up to the patches from Denys Vlasenkos <vda.linux@googlemail.com> to further optimize firmware loading. 1. In bnx2_init_cpus(), we allocate memory for decompression once and use it repeatedly instead of doing this for every firmware image. 2. We eliminate the BSS and SBSS firmware sections in bnx2_fw*.h since these are always zeros. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[BNX2]: factor out gzip unpackerDenys Vlasenko
This patch modifies gzip unpacking code in bnx2 driver so that it does not depend on bnx2 internals. I will move this code out of the driver and into zlib in follow-on patch. It can be useful in other drivers which need to store firmwares or any other relatively big binary blobs - fonts, cursor bitmaps, whatever. Patch is run tested by Michael Chan (driver author). Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[BNX2]: Update 5708 firmware.Michael Chan
This fixes the problem of not counting all dropped multicast packets. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[BNX2]: Re-organize firmware structures.Michael Chan
Re-organize the firmware handling code and declarations a bit to make the code more compact. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[BNX2]: Fix Xen problem.Michael Chan
This fixes the problem of not receiving packets in the Xen bridging environment. The Xen script sets the device's MAC address to FE:FF:FF:FF:FF:FF and puts the device in promiscuous mode. The firmware had problem receiving all packets in this configuration. New firmware and setting the PROM_VLAN bit when in promiscuous mode will fix this problem. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Use compressed firmwareMichael Chan
Change bnx2_fw.h to use compressed text for all CPU images. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-01-23[BNX2]: Update version and copyright yearMichael Chan
Update version to 1.4.31 and add 2006 copyright. Skip the last digit when reporting the firmware version. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[BNX2]: Fix UDP checksum verificationMichael Chan
Fix TCP/UDP checksum verification. Use status bits in the buffer descriptor instead of the checksum value to verify rx checksum. Using the checksum value will be incorrect if the UDP packet has zero in the UDP checksum field. Firmware update required for this fix. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-05[PATCH] bnx2: update firmware for 5708Michael Chan
Update bnx2 firmware with support for 5708. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-05-26[BNX2]: New Broadcom gigabit network driver.Michael Chan
A new driver bnx2 for Broadcom bcm5706 is available. The patch also includes new 1000BASE-X advertisement bit definitions in mii.h Thanks to David Miller and Jeff Garzik for reviewing and their valuable feedback. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
