Make many functions that are only used in one file static.
Remove dead code for override_led_value.
Make the bnx2x driver use the new vlan accleration model.
Signed-off-by: Hao Zheng <hzheng@nicira.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
CC: Eilon Greenstein <eilong@broadcom.com>
Many (but not all) drivers check to see whether there is a vlan
group configured before using a tag stored in the skb. There's
not much point in this check since it just throws away data that
should only be present in the expected circumstances. However,
it will soon be legal and expected to get a vlan tag when no
vlan group is configured, so remove this check from all drivers
to avoid dropping the tags.
the value of the constant is the same, but it's clearer to use original
constant provided by HSI
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
Optimized the branching in the bnx2x_rx_int() based on the fact
that FP CQE will always have at least one of START or STOP flags set,
so if not both bits are set and START bit is not set,
then it's a STOP bit that is set.
This patch does not include any functional changes.
The changes are: empty lines, indentation and comments.
Return proper L2 and L5 SPQ (slow path queue) credits. Previously, all
SPQ events were counted as L5 types.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Decide which interrupt mode to use (MSI-X, MSI, INTa) only once in probe() and
initialize appropriate structures.
57712 HW supported with same set of features as for 57710/57711
MF (multi-function) mode supported not only by 57711E (E1H) devices,
but also by coming 57712E, then we use more generic names.
This is the new FW HSI blob and the relevant definitions without logic changes.
It also included code adaptation for new HSI. New features are not enabled.
New FW/HSI includes:
- Support for 57712 HW
- Future support for VF (not used)
- Improvements in FW interrupts scheme
- FW FCoE hooks (stubs for future usage)
Moved enabling of MSI to the bnx2x_set_num_queues() - the same functions that
handles the initialization of the MSI-X.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Default number of rx buffers will be divided equally
between allocated queues. This will decrease amount of
pre-allocated buffers on systems with multiple CPUs.
User can override this behavior with ethtool -G.
Minimum amount of rx buffers per queue set to 128.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Add required changes in order to support dual-media boards.
Signed-off-by: Yaniv Rosner <yanivr@broadcom.com>
fresh skbs have ip_summed set to CHECKSUM_NONE (0)
We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers.
Introduce skb_checksum_none_assert() helper so that we keep this
assertion documented in driver sources.
Change most occurrences of :
skb->ip_summed = CHECKSUM_NONE;
by :
skb_checksum_none_assert(skb);
Loading firmware when actually bringing eth device up.
This also will allow driver to be insmoded when filesystem with
firmware files is not available yet.
Suggested by Stephen Hemminger <shemminger@vyatta.com>
Newly created files have no functionality changes,
but includes some functionality from bnx2x_main.c which
is common for PF and coming in the future VF driver.
