path: root/drivers/net/bnx2x_init.h
2009-08-12bnx2x: Re-factor the initialization codeEilon Greenstein
Moving the code to a more logical place and beautifying it. No real change in behavior. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: Separated FW from the source.Vladislav Zolotarov
>From now on FW will be downloaded from the binary file using request_firmware. There will be different files for every supported chip. Currently 57710 (e1) and 57711 (e1h). File names have the following format: bnx2x-<chip version>-<FW version>.fw. ihex versions of current FW files are submitted in the next patch. Each binary file has a header in the following format: struct bnx2x_fw_file_section { __be32 len; __be32 offset; } struct bnx2x_fw_file_hdr { struct bnx2x_fw_file_section init_ops; struct bnx2x_fw_file_section init_ops_offsets; struct bnx2x_fw_file_section init_data; struct bnx2x_fw_file_section tsem_int_table_data; struct bnx2x_fw_file_section tsem_pram_data; struct bnx2x_fw_file_section usem_int_table_data; struct bnx2x_fw_file_section usem_pram_data; struct bnx2x_fw_file_section csem_int_table_data; struct bnx2x_fw_file_section csem_pram_data; struct bnx2x_fw_file_section xsem_int_table_data; struct bnx2x_fw_file_section xsem_pram_data; struct bnx2x_fw_file_section fw_version; } Each bnx2x_fw_file_section contains the length and the offset of the appropriate section in the binary file. Values are stored in the big endian format. Data types of arrays: init_data __be32 init_ops_offsets __be16 XXsem_pram_data u8 XXsem_int_table_data u8 init_ops struct raw_op { u8 op; __be24 offset; __be32 data; } fw_version u8 >From now boundaries of a specific initialization stage are stored in init_ops_offsets array instead of being defined by separate macroes. The index in init_ops_offsets is calculated by BLOCK_OPS_IDX macro: #define BLOCK_OPS_IDX(block, stage, end) \ (2*(((block)*STAGE_IDX_MAX) + (stage)) + (end)) Security: In addition to sanity check of array boundaries bnx2x will check a FW version. Additional checks might be added in the future. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02bnx2x: WhitespaceEilon Greenstein
2009-03-02bnx2x: Using DMA engineEilon Greenstein
Using DMA engine (DMAE) to initialize large consecutive memories in the chip Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: VersionEilon Greenstein
And updating the year Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: Comments and printsEilon Greenstein
2009-02-15bnx2x: Optimize chip MPS configurationEilon Greenstein
2009-02-15bnx2x: Memory clean up on failureEilon Greenstein
2009-02-15bnx2x: Manual setting for MRRSEilon Greenstein
Allows better debug capabilities if the user wants to force an MRRS value Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03bnx2x: PCI configuration bug on big-endianEilon Greenstein
The current code read nothing but zeros on big-endian (wrong part of the 32bits). This caused poor performance on big-endian machines. Though this issue did not cause the system to crash, the performance is significantly better with the fix so I view it as critical bug fix. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: Checkpatch complianceEilon Greenstein
Checkpatch compliance The latest version of checkpatch found the following style errors in the code Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: Spelling mistakesEilon Greenstein
Spelling mistakes Spelling has to L's in it... Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-23bnx2x: Add support for BCM57711 HWEilon Greenstein
Supporting the 57711 and 57711E - refers to in the code as E1H. The 57710 is referred to as E1. To support the new members in the family, the bnx2x structure was divided to 3 parts: common, port and function. These changes caused some rearrangement in the bnx2x.h file. A set of accessories macros were added to make access to the bnx2x structure more readable Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-23bnx2x: New init infrastructureEilon Greenstein
This new initialization code supports the 57711 HW. It also supports the emulation and FPGA for the 57711 and 57710 initializations values (very small amount of code which is very helpful in the lab - less than 30 lines). The initialization is done via DMAE after the DMAE block is ready - before it is ready, some of the initialization is done via PCI configuration transactions (referred to as indirect write). A mutex to protect the DMAE from being overlapped was added. There are few new registers which needs to be initialized by SW - the full comment for those registers is added to the register file. A place holder for the 57711 (referred to as E1H) microcode was added- the microcode itself is too big and it is split over the following 4 patches Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-23bnx2x: New link codeYaniv Rosner
New Link code: Moving all the link related code (including the calculations, the initialization of the MAC and PHY and the external PHY's code) into a separated file. The changes from the code that used to be part of bnx2x.c (now called bnx2x_main.c) are: - Using separate structures for link inputs and link outputs to clearly identify what was configured and what is the outcome - Adding code to read external PHY FW version and print it as part of ethtool -i - Adding code to upgrade external PHY FW from ethtool -E with special magic number - Changing the link down indication to ERR level - Adding a lock on all PHY access to prevent an interrupt and setting changes to overlap - Adding support for emulation and FPGA (small chunk of code that really helps in the lab) - Adding support for 1G on BCM8706 PHY - Adding clear debug print incase of fan failure (the PHY type is now "failure") Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12bnx2x: Updating the MaintainerEilon Greenstein
I would like to thank Eliezer Tamir for writing and maintaining the driver for the past two years. I will take over maintaining the bnx2x driver from now on. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Prevent PCI queue overflowEliezer Tamir
Limit traffic through an internal queue to prevent overflow. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28add bnx2x driver for BCM57710Eliezer Tamir
