It was recently brought to my attention that 802.3ad mode bonds would no
longer form when using some network hardware after a driver update.
After snooping around I realized that the particular hardware was using
page-based skbs and found that skb->data did not contain a valid LACPDU
as it was not stored there. That explained the inability to form an
802.3ad-based bond. For balance-alb mode bonds this was also an issue
as ARPs would not be properly processed.
This patch fixes the issue in my tests and should be applied to 2.6.36
and as far back as anyone cares to add it to stable.
Thanks to Alexander Duyck <alexander.h.duyck@intel.com> and Jesse
Brandeburg <jesse.brandeburg@intel.com> for the suggestions on this one.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
CC: Alexander Duyck <alexander.h.duyck@intel.com>
CC: Jesse Brandeburg <jesse.brandeburg@intel.com>
CC: stable@kerne.org
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
A few lines earlier we assume that best->slave could be either null or non-null so
we should check it here as well.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Remove DRV_NAME from pr_<level>s
Consolidate long format strings
Remove some extra tab indents
Remove some unnecessary ()s from pr_<level>s arguments
Align pr_<level> arguments
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
The language of 802.3ad 43.4.9 requires the "recordPDU" function
to, in part, compare the Partner parameter values in a received LACPDU
to the stored Actor values. If those match, then the Partner's
synchronization state is set to true.
The current 802.3ad implementation is performing these steps out
of order; first, the synchronization check is done, then the paramters are
checked to see if they match (the synch check being done against a match
check of a prior LACPDU). This causes delays in establishing aggregators
in some circumstances.
This patch modifies the 802.3ad code to call __choose_matched,
the function that does the "match" comparisions, as the first step of
__record_pdu, instead of immediately afterwards. This new behavior is
in compliance with the language of the standard.
Some additional commentary relating to code vs. standard is also
added.
Reported by Martin Patterson <martin@gear6.com> who also supplied
the logic of the fix and verified the patch.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
Now that the bonding device is no longer used in determining the device to
which to send packets, it can be dropped from the argument list of the various
xmit_hash_policy calls.
Signed-off-by: Jasper Spaans <spaans@fox-it.com>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
I did not introduce new lines over 80 chars. I even eliminated some of
them.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
AD_SHORT_TIMEOUT and AD_STATE_LACP_ACTIVITY have the same value, but
AD_STATE_LACP_ACTIVITY better reflects the intended semantics.
[ J adds: AD_STATE_LACP_ACTIVITY is a value defined by the standard, and
should be set here in accordance with 802.3ad 43.4.12; AD_SHORT_TIMEOUT
is a constant specific to the Linux 802.3ad implementation that happens
to have the same value ]
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
struct port_params p;
* p.port_state |= AD_SHORT_TIMEOUT
// </smpl>
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
drivers/scsi/fcoe/fcoe.c
One of the purposes of bonding is to allow for redundant links, and failover
correctly if the cable is pulled. If all the members of a bonded device have
no carrier present, the bonded device itself needs to report no carrier present
to user space so management tools (like routing daemons) can respond.
Bonding in 802.3ad mode does not work correctly for this because it incorrectly
chooses a link that is down as a possible aggregator.
Patch fixes issues with dev->dev_addr changing from array to pointer.
Hopefully there are no others.
802.3ad has its own ethhdr-like structure in the form of an ad_header,
which is at the start of both the LACPDU and marker PDU. Both are
the same from the struct values, both are packed as well.
It's therefore perfectly fine to replace the ad_header by the ethhdr
and to remove its definition.
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
Generalize out mac address initializer for the LACPDU multicast
address and use in two places. Remove the now unused
AD_MULTICAST_LACPDU_ADDR.
Save some text by initializing ports LACPDU from const initializer,
then get rid of ad_initialize_lacpdu().
Turn ports is_individual into a bool. There is no functional change.
Signed-off-by: Holger Eitzenberger <heitzenberger@astaro.com>
Turn ports is_enabled into a bool. There is no functional change.
Turn Need-To-Transmit port variable into a bool. There is no
functional change.
I also removed some of the unneeded braces in the if condition to
improve readability and a little bit of reformatting.
They are all defined before used, it's therefore ok to remove
them.
Also remove the pointless comment at the top.
It helps in maintaining the various partner information values from
the LACPDU. It also removes the pointless comment at the top.
It generally helps to handle those values in various places, using it
might make the code more readable and gives room for other improvements.
The IEEE standard talks about them as "parameter values".
The previous code was just a funny way of assigning both values (they
are both of type u8).
Use pr_debug() instead of own macros.
We have some reasons to kill netdev->priv:
1. netdev->priv is equal to netdev_priv().
2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously
netdev_priv() is more flexible than netdev->priv.
But we cann't kill netdev->priv, because so many drivers reference to it
directly.
This patch is a safe convert for netdev->priv to netdev_priv(netdev).
Since all of the netdev->priv is only for read.
But it is too big to be sent in one mail.
I split it to 4 parts and make every part smaller than 100,000 bytes,
which is max size allowed by vger.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
This patch implements alternative aggregator selection policies
for 802.3ad. The existing policy, now termed "stable," selects the active
aggregator by greatest bandwidth, and only reselects a new aggregator
if the active aggregator is entirely disabled (no more ports or all ports
down).
This patch adds two new policies: bandwidth and count, selecting
the active aggregator by total bandwidth (like the stable policy) or by
the number of ports in the aggregator, respectively. These two policies
also differ from the stable policy in that they will reselect the active
aggregator when availability-related changes occur in the bond (e.g.,
link state change).
This permits "gang failover" within 802.3ad, allowing redundant
aggregators along parallel paths to always maintain the "best" aggregator
as the active aggregator (rather than having to wait for the active to
entirely fail).
This patch also updates the driver version to 3.5.0.
Refactor mii monitor. As with the previous ARP monitor refactor,
the motivation for this is to handle locking rationally (in this case,
removing conditional locking) and generally clean up the code.
This patch breaks up the monolithic mii monitor into two phases:
an inspection phase, followed by an optional commit phase. The commit phase
is the only portion that requires RTNL or makes changes to state, and is
only called when inspection finds something to change.
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/usb/rndis_host.c
drivers/net/wireless/b43/dma.c
net/ipv6/ndisc.c
The 802.3ad state machine lock can be acquired in both softirq and
not softirq context, but was not held at _bh to prevent a deadlock (which
could occur if a LACPDU arrived and was processed while the lock was
held).
Corrected this, now hold the state machine lock at _bh to prevent
deadlock.
Bug reported by Todd Fleisher <todd@fleish.org>.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Convert bonding timers to workqueues. This converts the various
monitor functions to run in periodic work queues instead of timers. This
patch introduces the framework and convers the calls, but does not resolve
various locking issues, and does not stand alone.
Prior to use struct marker in the linux kernel markers, we need to clean
two drivers which use this structure name.
Change bonding driver types :
- struct marker to struct bond_marker.
- marker_t to bond_marker_t.
- marker_header to bond_marker_header.
- marker_header_t to bond_marker_header_t.
Change qla4xxx struct marker_entry usage :
- Change struct marker_entry for struct qla4_marker_entry.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Chad Tindel <ctindel@users.sourceforge.net>
Cc: Jay Vosburgh <fubar@us.ibm.com>
Cc: David Somayajulu <david.somayajulu@qlogic.com>
Cc: James Bottomley <James.Bottomley@SteelEye.com>
Cc: Ravi Anand <ravi.anand@qlogic.com>
This patch modifies every packet receive function
registered with dev_add_pack() to drop packets if they
are not from the initial network namespace.
This should ensure that the various network stacks do
not receive packets in a anything but the initial network
namespace until the code has been converted and is ready
for them.
Modify carrier state determination for 802.3ad mode to comply
with section 43.3.9 of IEEE 802.3, which requires that "Links that are
not successful candidates for aggregation (e.g., links that are attached
to other devices that cannot perform aggregation or links that have been
manually configured to be non-aggregatable) are enabled to operate as
individual IEEE 802.3 links."
Bug reported by Laurent Chavey <chavey@google.com>. This patch
is an updated version of his patch that changes the wording of
commentary and adds an update to the driver version.
Signed-off-by: Laurent Chavey <chavey@google.com>
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and
skb->mac to skb->mac_header, to match the names of the associated helpers
(skb[_[re]set]_{transport,network,mac}_header).
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Fixed handling of 802.3ad LACPDUs. Do not byte swap data in
place in the packet. Updated nomenclature of "__ntohs_lacpdu" to be
"htons"; it was previously used for both ntohs and htons operations, but
only called ntohs functions.
Allow channel bonding to enslave a 10 Gig adapter without errors.
Signed-off-by: Mitch Williams <mitch.a.williams@intel.com>
Acked-by: Jay Vosburgh <fubar@us.ibm.com>
Add support for the bonding master to specify its carrier state
based upon the state of the slaves. For 802.3ad, the bond is up if
there is an active, parterned aggregator. For other modes, the bond is
up if any slaves are up. Updates driver version to 3.0.3.
Based on a patch by jamal <hadi@cyberus.ca>.
No need to record this information in source code, its all in the git
repository, and kernel archives.
Add the bond name to all error messages so we can tell which one is
complaining. Also reformats some error messages to be more consistent.
Bonding just wants the device before the skb_bond()
decapsulation occurs, so simply pass that original
device into packet_type->func() as an argument.
It remains to be seen whether we can use this same
exact thing to get rid of skb->input_dev as well.
