Weiping Pan noticed that the module option description for
xmit_hash_policy was incorrect and was nice enough to post a patch to
fix it. The text was correct, but created a line over 80 characters and
I would rather not add those. I realized I could take a few minutes and
clean up all the descriptions and things would look much better. This
is the result.
Based on patch from Weiping Pan <panweiping3@gmail.com>.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
CC: Weiping Pan <panweiping3@gmail.com>
Reviewed-by: Weiping Pan <panweiping3@gmail.com>
Improves the documentation about how IGMP resend parameter
works, fix two missing checks and coding style issues.
Signed-off-by: Flavio Leitner <fbl@redhat.com>
Acked-by: Rick Jones <rick.jones2@hp.com>
This soft lockup was recently reported:
[root@dell-per715-01 ~]# echo +bond5 > /sys/class/net/bonding_masters
[root@dell-per715-01 ~]# echo +eth1 > /sys/class/net/bond5/bonding/slaves
bonding: bond5: doing slave updates when interface is down.
bonding bond5: master_dev is not up in bond_enslave
[root@dell-per715-01 ~]# echo -eth1 > /sys/class/net/bond5/bonding/slaves
BUG: soft lockup - CPU#12 stuck for 60s! [bash:6444]
CPU 12:
Modules linked in: bonding autofs4 hidp rfcomm l2cap bluetooth lockd sunrpc
be2d
Pid: 6444, comm: bash Not tainted 2.6.18-262.el5 #1
RIP: 0010:[<ffffffff80064bf0>] [<ffffffff80064bf0>]
.text.lock.spinlock+0x26/00
RSP: 0018:ffff810113167da8 EFLAGS: 00000286
RAX: ffff810113167fd8 RBX: ffff810123a47800 RCX: 0000000000ff1025
RDX: 0000000000000000 RSI: ffff810123a47800 RDI: ffff81021b57f6f8
RBP: ffff81021b57f500 R08: 0000000000000000 R09: 000000000000000c
R10: 00000000ffffffff R11: ffff81011d41c000 R12: ffff81021b57f000
R13: 0000000000000000 R14: 0000000000000282 R15: 0000000000000282
FS: 00002b3b41ef3f50(0000) GS:ffff810123b27940(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00002b3b456dd000 CR3: 000000031fc60000 CR4: 00000000000006e0
Call Trace:
[<ffffffff80064af9>] _spin_lock_bh+0x9/0x14
[<ffffffff886937d7>] :bonding:tlb_clear_slave+0x22/0xa1
[<ffffffff8869423c>] :bonding:bond_alb_deinit_slave+0xba/0xf0
[<ffffffff8868dda6>] :bonding:bond_release+0x1b4/0x450
[<ffffffff8006457b>] __down_write_nested+0x12/0x92
[<ffffffff88696ae4>] :bonding:bonding_store_slaves+0x25c/0x2f7
[<ffffffff801106f7>] sysfs_write_file+0xb9/0xe8
[<ffffffff80016b87>] vfs_write+0xce/0x174
[<ffffffff80017450>] sys_write+0x45/0x6e
[<ffffffff8005d28d>] tracesys+0xd5/0xe0
It occurs because we are able to change the slave configuarion of a bond while
the bond interface is down. The bonding driver initializes some data structures
only after its ndo_open routine is called. Among them is the initalization of
the alb tx and rx hash locks. So if we add or remove a slave without first
opening the bond master device, we run the risk of trying to lock/unlock a
spinlock that has garbage for data in it, which results in our above softlock.
Note that sometimes this works, because in many cases an unlocked spinlock has
the raw_lock parameter initialized to zero (meaning that the kzalloc of the
net_device private data is equivalent to calling spin_lock_init), but thats not
true in all cases, and we aren't guaranteed that condition, so we need to pass
the relevant spinlocks through the spin_lock_init function.
Fix it by moving the spin_lock_init calls for the tx and rx hashtable locks to
the ndo_init path, so they are ready for use by the bond_store_slaves path.
Change notes:
v2) Based on conversation with Jay and Nicolas it seems that the ability to
enslave devices while the bond master is down should be safe to do. As such
this is an outlier bug, and so instead we'll just initalize the errant spinlocks
in the init path rather than the open path, solving the problem. We'll also
remove the warnings about the bond being down during enslave operations, since
it should be safe
v3) Fix spelling error
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: jtluka@redhat.com
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: nicolas.2p.debian@gmail.com
CC: "David S. Miller" <davem@davemloft.net>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
s/NETDEV_BONDING_DESLAVE/NETDEV_RELEASE/ as Andy suggested.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Andy Gospodarek <andy@greyhouse.net>
Cc: Neil Horman <nhorman@redhat.com>
V3: rename NETDEV_ENSLAVE to NETDEV_JOIN
Currently we do nothing when we enslave a net device which is running netconsole.
Neil pointed out that we may get weird results in such case, so let's disable
netpoll on the device being enslaved. I think it is too harsh to prevent
the device being ensalved if it is running netconsole.
By the way, this patch also removes the NETDEV_GOING_DOWN from netconsole
netdev notifier, because netpoll will check if the device is running or not
and we don't handle NETDEV_PRE_UP neither.
This patch is based on net-next-2.6.
drivers/net/vmxnet3/vmxnet3_ethtool.c
net/core/dev.c
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
With some combinations of arch/compiler (e.g. arm-linux-gcc) the sizeof
operator on structure returns value greater than expected. In cases when the
structure is used for mapping PDU fields it may lead to unexpected results
(such as holes and alignment problems in skb data). __packed prevents this
undesired behavior.
Signed-off-by: Vitalii Demianets <vitas@nppfactor.kiev.ua>
This should also fix updating of vlan_features and propagating changes to
VLAN devices on the bond.
Side effect: it allows user to force-disable some offloads on the bond
interface.
Note: NETIF_F_VLAN_CHALLENGED is managed by bond_fix_features() now.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Pull read_lock(&bond->lock) and BOND_IS_OK() to bond_start_xmit() from
mode-dependent xmit functions.
netif_running() is always true in hard_start_xmit.
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
For backward compatibility, we should retain the module parameters and
sysfs attributes to control the number of peer notifications
(gratuitous ARPs and unsolicited NAs) sent after bonding failover.
Also, it is possible for failover to take place even though the new
active slave does not have link up, and in that case the peer
notification should be deferred until it does.
Change ipv4 and ipv6 so they do not automatically send peer
notifications on bonding failover.
Change the bonding driver to send separate NETDEV_NOTIFY_PEERS
notifications when the link is up, as many times as requested. Since
it does not directly control which protocols send notifications, make
num_grat_arp and num_unsol_na aliases for a single parameter. Bump
the bonding version number and update its documentation.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Brian Haley <brian.haley@hp.com>
Resolved logic conflicts causing a build failure due to
drivers/net/r8169.c changes using a patch from Stephen Rothwell.
Since now when bonding uses rx_handler, all traffic going into bond
device goes thru bond_handle_frame. So there's no need to go back into
bonding code later via ptype handlers. This patch converts
original ptype handlers into "bonding receive probes". These functions
are called from bond_handle_frame and they are registered per-mode.
Note that vlan packets are also handled because they are always untagged
thanks to vlan_untag()
Note that this also allows arpmon for eth-bond-bridge-vlan topology.
The slave member of struct aggregator does not necessarily point
to a slave which is part of the aggregator. It points to the
slave structure containing the aggregator structure, while
completely different slaves (or no slaves at all) may be part of
the aggregator.
The agg_device_up() function wrongly uses agg->slave to find the state
of the aggregator. Use agg->lag_ports->slave instead. The bug has
been introduced by commit 4cd6fe1c6483cde93e2ec91f58b7af9c9eea51ad
("bonding: fix link down handling in 802.3ad mode").
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
NETDEV_NOTIFY_PEERS
It is undesirable for the bonding driver to be poking into higher
level protocols, and notifiers provide a way to avoid that. This does
mean removing the ability to configure reptitition of gratuitous ARPs
and unsolicited NAs.
The variable 'vlan_dev' is set but unused in
bond_send_gratuitous_arp(). Just kill it off.
This updates the bonding driver to support v2.6.27-rc3 enhancements
(b11f8d8c aka. "ethtool: Expand ethtool_cmd.speed to 32 bits") which
allow to encode the Mbps link speed on 32-bits (Max 4 Pbps) instead of
16 (Max 65536 Mbps).
This patch also attempts to compact struct slave by reordering its
fields.
Signed-off-by: David Decotigny <decot@google.com>
The __get_link_speed() function returns a u16 value which was stored
in a u32 local variable. This patch uses the return value directly,
thus fixing that minor type consistency.
The 'duplex' field in struct slave being encoded on 8 bits, to be more
consistent we use a u8 integer (instead of u16) whenever we copy it to
local variables.
This gets rid of minor sparse complaints:
drivers/net/bonding/bond_main.c:4361:4: warning: do-while statement is not a compound statement
drivers/net/bonding/bond_main.c:243:12: warning: symbol 'bond_mode_name' was not declared. Should it be static?
drivers/net/smsc911x.c
replace relpy with reply.
replace premanent with permanent.
Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com>
replace tranmitted with transmitted.
replace tranmitting with transmitting.
Now, alb_bond_info uses rx_ntt,rlb_update_delay_counter and
rlb_update_retry_counter to decide when to call rlb_update_rx_clients().
Now bonding-alb uses delayed_work instead of timer_list.
It is unnecessary to set save_load to 1 here,
as the tx_hashtbl is just kzalloced.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
This patch uses __copy_from_user_nocache on transmit to bypass data
cache for a performance improvement. skb_add_data_nocache and
skb_copy_to_page_nocache can be called by sendmsg functions to use
this feature, initial support is in tcp_sendmsg. This functionality is
configurable per device using ethtool.
Presumably, this feature would only be useful when the driver does
not touch the data. The feature is turned on by default if a device
indicates that it does some form of checksum offload; it is off by
default for devices that do no checksum offload or indicate no checksum
is necessary. For the former case copy-checksum is probably done
anyway, in the latter case the device is likely loopback in which case
the no cache copy is probably not beneficial.
This patch was tested using 200 instances of netperf TCP_RR with
1400 byte request and one byte reply. Platform is 16 core AMD x86.
No-cache copy disabled:
672703 tps, 97.13% utilization
50/90/99% latency:244.31 484.205 1028.41
No-cache copy enabled:
702113 tps, 96.16% utilization,
50/90/99% latency 238.56 467.56 956.955
Using 14000 byte request and response sizes demonstrate the
effects more dramatically:
79571 tps, 34.34 %utlization
50/90/95% latency 1584.46 2319.59 5001.76
83856 tps, 34.81% utilization
50/90/95% latency 2508.42 2622.62 2735.88
Note especially the effect on latency tail (95th percentile).
This seems to provide a nice performance improvement and is
consistent in the tests I ran. Presumably, this would provide
the greatest benfits in the presence of an application workload
stressing the cache and a lot of transmit data happening.
Signed-off-by: Tom Herbert <therbert@google.com>
use accumulates instead of acumulates.
Signed-off-by: Pan Weiping <panweiping3@gmail.com>
This prevents possible race between bond_enslave and bond_handle_frame
as reported by Nicolas by moving rx_handler register/unregister.
slave->bond is added to hold pointer to master bonding sructure. That
way dev->master is no longer used in bond_handler_frame.
Also, this removes "BUG: scheduling while atomic" message
Reported-by: Nicolas de Pesloüan <nicolas.2p.debian@gmail.com>
Tested-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Only slaves that are up should transmit netpoll frames, so there is no
need to check to see if a slave is up before enabling netpoll on it.
This resolves a reported failure on active-backup bonds where a slave
interface is down when netpoll was enabled.
Tested-by: WANG Cong <amwang@redhat.com>
This patch allows rx_handlers to better signalize what to do next to
it's caller. That makes skb->deliver_no_wcard no longer needed.
kernel-doc for rx_handler_result is taken from Nicolas' patch.
Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Since bond-related code was moved from net/core/dev.c into bonding,
IFF_SLAVE_INACTIVE is no longer needed. Replace is with flag "inactive"
stored in slave structure
transfers slave->state into slave->backup (that it's going to transfer
into bitfield. Introduce wrapper inlines to do the work with it.
Now when bond-related code is moved from net/core/dev.c into bonding
code, multiple priv_flags are not needed anymore. So let them rot.
Register slave pointer as rx_handler data. That would eventually prevent
need to loop over slave devices to find the right slave.
Use synchronize_net to ensure that bond_handle_frame does not get slave
structure freed when working with that.
When the bonding module is loaded, it creates bond0 by default.
Then, when attempting to create bond0, the following messages
are printed to syslog:
kernel: bonding: bond0 is being created...
kernel: bonding: Bond creation failed.
Which seems to indicate a problem, when in reality there is no
problem. Since the actual error code is passed down from bond_create,
make use of it to print a bit less ominous message:
kernel: bond0 already exists.
Signed-off-by: Phil Oester <kernel@linuxace.com>
Bringing up a bond interface with all network cables disconnected
does not properly set the interface as DOWN because the call to
netif_carrier_off occurs too early in bond_init. The call needs
to occur after register_netdevice has set dev->reg_state to
NETREG_REGISTERED, so that netif_carrier_off will trigger the
call to linkwatch_fire_event.
When packets come in from a device with >= 16 receive queues
headed out a bonding interface, syslog gets filled with this:
kernel: bond0 selects TX queue 16, but real number of TX queues is 16
because queue_mapping is offset by 1. Adjust return value
to account for the offset.
This is a revision of my earlier patch (which did not use the
skb_rx_queue_* helpers - thanks to Ben for the suggestion).
Andy submitted a similar patch which emits a pr_warning on
invalid queue selection, but I believe the log spew is
not useful. We can revisit that question in the future,
but in the interim I believe fixing the core problem is
worthwhile.
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
drivers/net/bnx2x/bnx2x_cmn.c
V2: Move #ifdef CONFIG_PROC_FS into bonding.h, as suggested by David.
bond_main.c is bloating, separate the procfs code out,
move them to bond_procfs.c
Rename the rx_machine_lock to state_machine_lock as this makes more
sense in light of it now protecting all the state machines against
concurrency.
Signed-off-by: Nils Carlson <nils.carlson@ericsson.com>
Changes since v1:
* Clarify an unclear comment
* Move a (possible) name change to a separate patch
The ad_rx_machine, ad_periodic_machine and ad_port_selection_logic
functions all inspect and alter common fields within the port structure.
Previous to this patch, only the ad_rx_machines were mutexed, and the
periodic and port_selection could run unmutexed against an ad_rx_machine
trigged by an arriving LACPDU.
This patch remedies the situation by protecting all the state machines
from concurrency. This is accomplished by locking around all the state
machines for a given port, which are executed at regular intervals; and
the ad_rx_machine when handling an incoming LACPDU.
When there is a ptype handler holding a clone of this skb, whose
destination MAC addresse is overwritten, the owner of this handler may
get a corrupted packet.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
enabled
These two functions are only used when net poll controller is enabled.
Instead of on the stack.
Clearly it should be the size of ->ip_dst here.
Although this is harmless, but it still reads odd.
