After:
commit 6146b1a4da98377e4abddc91ba5856bef8f23f1e
Author: Jay Vosburgh <fubar@us.ibm.com>
Date: Tue Nov 4 17:51:15 2008 -0800
bonding: Fix ALB mode to balance traffic on VLANs
the dev field in the RLB ARP packet handler was set to NULL to wildcard
and accommodate balancing VLANs on top of bonds.
This has the side-effect of the packet handler being called against
other, non RLB-enabled bonds, and a kernel oops results when it tries to
dereference rx_hashtbl in rlb_update_entry_from_arp(), which won't be
set for those bonds, e.g. active-backup.
With the __netif_receive_skb() changes from:
commit 1f3c8804acba841b5573b953f5560d2683d2db0d
Author: Andy Gospodarek <andy@greyhouse.net>
Date: Mon Dec 14 10:48:58 2009 +0000
bonding: allow arp_ip_targets on separate vlans to use arp validation
frames received on VLANs correctly make their way to the bond's handler,
so we no longer need to wildcard the device.
The oops can be reproduced by:
modprobe bonding
echo active-backup > /sys/class/net/bond0/bonding/mode
echo 100 > /sys/class/net/bond0/bonding/miimon
ifconfig bond0 xxx.xxx.xxx.xxx netmask xxx.xxx.xxx.xxx
echo +eth0 > /sys/class/net/bond0/bonding/slaves
echo +eth1 > /sys/class/net/bond0/bonding/slaves
echo +bond1 > /sys/class/net/bonding_masters
echo balance-alb > /sys/class/net/bond1/bonding/mode
echo 100 > /sys/class/net/bond1/bonding/miimon
ifconfig bond1 xxx.xxx.xxx.xxx netmask xxx.xxx.xxx.xxx
echo +eth2 > /sys/class/net/bond1/bonding/slaves
echo +eth3 > /sys/class/net/bond1/bonding/slaves
Pass some traffic on bond0. Boom.
[ Tested, behaves as advertised. I do not believe a test of the bonding
mode is necessary, as there is no race between the packet handler and
the bonding mode changing (the mode can only change when the device is
closed). Also updated the log message to include the reproduction and
full commit ids. -J ]
Signed-off-by: Greg Edwards <greg.edwards@hp.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Acked-by: Andy Gospodarek <andy@greyhouse.net>
When two systems using bonding devices in adaptive load
balancing (ALB) communicates with each other, an endless
ping-pong of ARP replies starts between these two systems.
What happens? In the ALB mode, bonding driver keeps track
of each client connected in a hash table, so it can do the
receive load balancing (RLB). This hash table is updated
when an ARP reply is received, then it scans for the client
entry, updates its MAC address and flag it to be announced
later. Therefore, two seconds later, the alb monitor runs
and send for each updated client entry two ARP replies
updating this specific client. The same process happens on
the receiving system, causing the endless ping-pong of arp
replies.
See more information including the relevant functions below:
System 1 System 2
bond0 bond0
ping <system2>
ARP request --------->
<--------- ARP reply
+->rlb_arp_recv <---------------------+ <--- loop begins
| rlb_update_entry_from_arp |
| client_info->ntt = 1; |
| bond_info->rx_ntt = 1; |
| <communication succeed> |
| bond_alb_monitor |
| rlb_update_rx_clients |
| rlb_update_client |
| arp_create(ARPOP_REPLY) |
| send ARP reply --------------> V
| rlb_arp_recv
| < snipped, same as in system 1>
+------- <-------------- send ARP reply
Besides the unneeded networking traffic, this loop breaks
a cluster because a backup system can't take over the IP
address. There is always one system sending an ARP reply
poisoning the network.
This patch fixes the problem adding a check for the MAC
address before updating it. Thus, if the MAC address didn't
change, there is no need to update neither to announce it later.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
Support for netpoll over bonded interfaces was added here:
commit f6dc31a85cd46a959bdd987adad14c3b645e03c1
Author: WANG Cong <amwang@redhat.com>
Date: Thu May 6 00:48:51 2010 -0700
bonding: make bonding support netpoll
but it is bad enough that we should probably just disable netpoll over
bonding until some of the locking logic in the bonding driver is changed
or converted completely to RCU. Simple actions like changing the active
slave in active-backup mode will hang the box if a high enough printk
debugging level is enabled.
Keeping the old code around will be good for anyone that wants to work
on it (and for after the RCU conversion), so I propose this small patch
rather than ripping it all out.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
Based on Andy's work, but I modified a lot.
Similar to the patch for bridge, this patch does:
1) implement the 2 methods to support netpoll for bonding;
2) modify netpoll during forwarding packets via bonding;
3) disable netpoll support of bonding when a netpoll-unabled device
is added to bonding;
4) enable netpoll support when all underlying devices support netpoll.
Cc: Andy Gospodarek <gospo@redhat.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Jay Vosburgh <fubar@us.ibm.com>
Signed-off-by: WANG Cong <amwang@redhat.com>
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
+little renaming of unicast functions to be smooth with multicast ones
bond_uninit() is invoked with rtnl_lock held, when it does destroy_workqueue()
which will potentially flush all works in this workqueue, if we hold rtnl_lock
again in the work function, it will deadlock.
So move destroy_workqueue() to destructor where rtnl_lock is not held any more,
suggested by Eric.
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Commit a2fd940f (bonding: fix broken multicast with round-robin mode)
added a problem on litle endian machines.
drivers/net/bonding/bond_main.c:4159: warning: comparison is always
false due to limited range of data type
Round-robin (mode 0) does nothing to ensure that any multicast traffic
originally destined for the host will continue to arrive at the host when
the link that sent the IGMP join or membership report goes down. One of
the benefits of absolute round-robin transmit.
Keeping track of subscribed multicast groups for each slave did not seem
like a good use of resources, so I decided to simply send on the
curr_active slave of the bond (typically the first enslaved device that
is up). This makes failover management simple as IGMP membership
reports only need to be sent when the curr_active_slave changes. I
tested this patch and it appears to work as expected.
Originally reported by Lon Hohberger <lhh@redhat.com>.
CC: Lon Hohberger <lhh@redhat.com>
CC: Jay Vosburgh <fubar@us.ibm.com>
Signed-off-by: Frans Pop <elendil@planet.nl>
After the type change, addresses in unicast and multicast lists wouldn't make
sense, not to mention possible different lenghts. So flush both lists here.
Note "dev_addr_discard" will be very soon replaced by "dev_mc_flush" (once
mc_list conversion will be done).
Convert to list macro's for the list of addresses per interface
in IPv6.
This patch adds the possibility to refuse the bonding type change for
other subsystems (such as for example bridge, vlan, etc.)
Since generally there could be more netdevices changing type other
than bonding, making this event type name "bonding-unrelated"
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
This makes the class attributes the same as sysdev_class attributes
and plain attributes.
This will allow further cleanups in drivers.
Full tree sweep converting all users.
When the register_netdevice() call fails, the newly allocated device is
not freed.
There is no need to maintain stats in the bonding structure.
Use the instance of net_device_stats in netdevice.
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
The convention for API functions in kernel is to return errno value;
bond_open would return -1 if alb setup failed. The only reason that
could happen is if kmalloc() failed.
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
drivers/net/benet/be_cmds.h
include/linux/sysctl.h
This allows a bond device to specify an arp_ip_target as a host that is
not on the same vlan as the base bond device and still use arp
validation. A configuration like this, now works:
BONDING_OPTS="mode=active-backup arp_interval=1000 arp_ip_target=10.0.100.1 arp_validate=3"
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
2: eth1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000
link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000
8: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue
inet6 fe80::213:21ff:febe:33e9/64 scope link
9: bond0.100@bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue
inet 10.0.100.2/24 brd 10.0.100.255 scope global bond0.100
Ethernet Channel Bonding Driver: v3.6.0 (September 26, 2009)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: None
Currently Active Slave: eth1
MII Status: up
MII Polling Interval (ms): 0
Up Delay (ms): 0
Down Delay (ms): 0
ARP Polling Interval (ms): 1000
ARP IP target/s (n.n.n.n form): 10.0.100.1
Slave Interface: eth1
MII Status: up
Link Failure Count: 1
Permanent HW addr: 00:40:05:30:ff:30
Slave Interface: eth0
MII Status: up
Link Failure Count: 0
Permanent HW addr: 00:13:21:be:33:e9
A few lines earlier we assume that best->slave could be either null or non-null so
we should check it here as well.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Remove DRV_NAME from pr_<level>s
Consolidate long format strings
Remove some extra tab indents
Remove some unnecessary ()s from pr_<level>s arguments
Align pr_<level> arguments
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
fix some typos and punctuation in comments
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
Take advantage of the new pernet automatic storage management,
and stop using compatibility network namespace functions.
drivers/net/sfc/sfe4001.c
drivers/net/wireless/libertas/cmd.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/rtl8187se/Kconfig
drivers/staging/rtl8192e/Kconfig
The language of 802.3ad 43.4.9 requires the "recordPDU" function
to, in part, compare the Partner parameter values in a received LACPDU
to the stored Actor values. If those match, then the Partner's
synchronization state is set to true.
The current 802.3ad implementation is performing these steps out
of order; first, the synchronization check is done, then the paramters are
checked to see if they match (the synch check being done against a match
check of a prior LACPDU). This causes delays in establishing aggregators
in some circumstances.
This patch modifies the 802.3ad code to call __choose_matched,
the function that does the "match" comparisions, as the first step of
__record_pdu, instead of immediately afterwards. This new behavior is
in compliance with the language of the standard.
Some additional commentary relating to code vs. standard is also
added.
Reported by Martin Patterson <martin@gear6.com> who also supplied
the logic of the fix and verified the patch.
- Don't call rtnl_link_unregister if rtnl_link_register fails
- Set .priv_size so we aren't stomping on uninitialized memory
when we use netdev_priv, on bond devices created with
ip link add type bond.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
This implements a basic set of rtnl link ops and takes advantage of
the fact that rtnl_link_unregister kills all of the surviving
devices to all us to kill bond_free_all. A module alias
is added so ip link add can pull in the bonding module.
Manually inline the code from bond_deinit to bond_uninit. bond_uninit
is the only caller and it is short.
Move the call of bond_release_all from the netdev notifier into
bond_uninit. The call site is effectively the same and performing
the call explicitly allows all the paths for destroying a
bonding device to behave the same way.
Stop calling dev_get_by_name to see if the bond device already
exists. register_netdevice already does that.
Stop calling bond_deinit if register_netdevice fails as bond_uninit
is guaranteed to be called if bond_init succeeds.
This patch delegates the work of creating the sysfs groups
to the netdev layer and ultimately to the device layer. This
closes races between uevents.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits)
net: Fix 'Re: PACKET_TX_RING: packet size is too long'
netdev: usb: dm9601.c can drive a device not supported yet, add support for it
qlge: Fix firmware mailbox command timeout.
qlge: Fix EEH handling.
AF_RAW: Augment raw_send_hdrinc to expand skb to fit iphdr->ihl (v2)
bonding: fix a race condition in calls to slave MII ioctls
virtio-net: fix data corruption with OOM
sfc: Set ip_summed correctly for page buffers passed to GRO
cnic: Fix L2CTX_STATUSB_NUM offset in context memory.
MAINTAINERS: rt2x00 list is moderated
airo: Reorder tests, check bounds before element
mac80211: fix for incorrect sequence number on hostapd injected frames
libertas spi: fix sparse errors
mac80211: trivial: fix spelling in mesh_hwmp
cfg80211: sme: deauthenticate on assoc failure
mac80211: keep auth state when assoc fails
mac80211: fix ibss joining
b43: add 'struct b43_wl' missing declaration
b43: Fix Bugzilla #14181 and the bug from the previous 'fix'
rt2x00: Fix crypto in TX frame for rt2800usb
In mii monitor mode, bond_check_dev_link() calls the the ioctl
handler of slave devices. It stores the ndo_do_ioctl function
pointer to a static (!) ioctl variable and later uses it to call the
handler with the IOCTL macro.
If another thread executes bond_check_dev_link() at the same time
(even with a different bond, which none of the locks prevent), a
race condition occurs. If the two racing slaves have different
drivers, this may result in one driver's ioctl handler being
called with a pointer to a net_device controlled with a different
driver, resulting in unpredictable breakage.
Unless I am overlooking something, the "static" must be a
copy'n'paste error (?).
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Now that the bonding device is no longer used in determining the device to
which to send packets, it can be dropped from the argument list of the various
xmit_hash_policy calls.
Signed-off-by: Jasper Spaans <spaans@fox-it.com>
drivers/net/sh_eth.c
Modify bonding hash transmit policies to use the psource MAC address of
the packet instead of the MAC address configured for the bonding device.
The old sitation conflicts with the documentation.
The function bond_create_proc_entry is currently of type int.
Two versions of this function exist:
The one in the ifdef CONFIG_PROC_FS branch always return 0.
The one in the else branch (which is empty) return nothing.
When CONFIG_PROC_FS is undef, this cause the following warning:
drivers/net/bonding/bond_main.c: In function `bond_create_proc_entry':
drivers/net/bonding/bond_main.c:3393: warning: control reaches end of
non-void function
No caller of this function use the returned value.
So change the returned type from int to void and remove the
useless return 0; .
Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Reported-by: Rakib Mullick <rakib.mullick@gmail.com>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
The variable old_active is first set to bond->curr_active_slave.
Then, it is unconditionally set to new_active, without being used in between.
The first assignment, having no side effect, is useless.
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
When parsing module parameters, bond_check_params() erroneously use
'xor_mode' as the name of a module parameter in an error message.
The right name for this parameter is 'xmit_hash_policy'.
In some cases there is not desirable to switch back to primary interface when
it's link recovers and rather stay with currently active one. We need to avoid
packetloss as much as we can in some cases. This is solved by introducing
primary_reselect option. Note that enslaved primary slave is set as current
active no matter what.
Patch modified by Jay Vosburgh as follows: fixed bug in action
after change of option setting via sysfs, revised the documentation
update, and bumped the bonding version number.
Primary module parameter passed to bonding is pernament. That means if you
release the primary slave and enslave it again, it becomes the primary slave
again. But if you set primary slave via sysfs, the primary slave is only set
once and it's not remembered in bond->params structure. Therefore the setting is
lost after releasing the primary slave. This simple one-liner fixes this.
