path: root/drivers/net/can
2011-06-29net/can: activate bit-timing calculation and netlink based drivers by defaultMarc Kleine-Budde
The two options "CAN bit-timing calculation" and "Platform CAN drivers with Netlink support" have a "default Y". In order to activate them by default, change to "default y". Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) tg3: Fix tg3_skb_error_unmap() net: tracepoint of net_dev_xmit sees freed skb and causes panic drivers/net/can/flexcan.c: add missing clk_put net: dm9000: Get the chip in a known good state before enabling interrupts drivers/net/davinci_emac.c: add missing clk_put af-packet: Add flag to distinguish VID 0 from no-vlan. caif: Fix race when conditionally taking rtnl lock usbnet/cdc_ncm: add missing .reset_resume hook vlan: fix typo in vlan_dev_hard_start_xmit() net/ipv4: Check for mistakenly passed in non-IPv4 address iwl4965: correctly validate temperature value bluetooth l2cap: fix locking in l2cap_global_chan_by_psm ath9k: fix two more bugs in tx power cfg80211: don't drop p2p probe responses Revert "net: fix section mismatches" drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run() sctp: stop pending timers and purge queues when peer restart asoc drivers/net: ks8842 Fix crash on received packet when in PIO mode. ip_options_compile: properly handle unaligned pointer iwlagn: fix incorrect PCI subsystem id for 6150 devices ...
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-02drivers/net/can/flexcan.c: add missing clk_putJulia Lawall
The failed_get label is used after the call to clk_get has succeeded, so it should be moved up above the call to clk_put. The failed_req labels doesn't do anything different than failed_get, so delete it. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26mfd: Use mfd cell platform_data for janz cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-10slcan: fix ldisc->open retvalOliver Hartkopp
TTY layer expects 0 if the ldisc->open operation succeeded. Reported-by: Matvejchikov Ilya <matvejchikov@gmail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-05-05can: fix SJA1000 dlc for RTR packetsKurt Van Dijck
RTR frames do have a valid data length code on CAN. The driver for SJA1000 did not handle that situation properly. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13net: can: mscan: fix build breakage in mpc5xxx_canAnatolij Gustschin
Commit 74888760d40b3ac9054f9c5fa07b566c0676ba2d "dt/net: Eliminate users of of_platform_{,un}register_driver" broke building mscan driver. Fix it. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
2011-04-06can: mcp251x: Allow pass IRQ flags through platform data.Enric Balletbo i Serra
When an interrupt occurs, the INT pin is driven low by the MCP251x controller (falling edge) but in some cases the INT pin can be connected to the MPU through a transistor or level translator which inverts this signal. In this case interrupt should be configured in rising edge. This patch adds support to pass the IRQ flags via mcp251x_platform_data. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits) xfrm: Restrict extended sequence numbers to esp xfrm: Check for esn buffer len in xfrm_new_ae xfrm: Assign esn pointers when cloning a state xfrm: Move the test on replay window size into the replay check functions netdev: bfin_mac: document TE setting in RMII modes drivers net: Fix declaration ordering in inline functions. cxgb3: Apply interrupt coalescing settings to all queues net: Always allocate at least 16 skb frags regardless of page size ipv4: Don't ip_rt_put() an error pointer in RAW sockets. net: fix ethtool->set_flags not intended -EINVAL return value mlx4_en: Fix loss of promiscuity tg3: Fix inline keyword usage tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h> net: use CHECKSUM_NONE instead of magic number Net / jme: Do not use legacy PCI power management myri10ge: small rx_done refactoring bridge: notify applications if address of bridge device changes ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo() can: c_can: Fix tx_bytes accounting can: c_can_platform: fix irq check in probe ...
2011-03-27can: c_can: Fix tx_bytes accountingJan Altenberg
The current SocketCAN implementation for the Bosch c_can cell doesn't account the TX bytes correctly, because it calls c_can_inval_msg_object() (which clears the msg ctrl register) before reading the DLC value: for (/* nix */; (priv->tx_next - priv->tx_echo) > 0; priv->tx_echo++) { msg_obj_no = get_tx_echo_msg_obj(priv); c_can_inval_msg_object(dev, 0, msg_obj_no); val = c_can_read_reg32(priv, &priv->regs->txrqst1); if (!(val & (1 << msg_obj_no))) { can_get_echo_skb(dev, msg_obj_no - C_CAN_MSG_OBJ_TX_FIRST); stats->tx_bytes += priv->read_reg(priv, &priv->regs->ifregs[0].msg_cntrl) & IF_MCONT_DLC_MASK; stats->tx_packets++; } } So, we will always read 0 for the DLC value and "ifconfig" will report *0* TX Bytes. The fix is quite easy: Just move c_can_inval_msg_object() to the end of the if() statement. So: * We only call c_can_inval_msg_object() if the message was actually transmitted * We read out the DLC value _before_ clearing the msg ctrl register Signed-off-by: Jan Altenberg <jan@linutronix.de> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27can: c_can_platform: fix irq check in probeMarc Kleine-Budde
This patch fixes the check in the probe function whether a IRQ was supplied to the driver. The original driver check the irq "struct resource *" against <= 0. Use "platform_get_irq" instead. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Cc: Bhupesh Sharma <bhupesh.sharma@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27can: c_can: disable one shot mode until driver is fixedMarc Kleine-Budde
This patch disables the one shot mode, until the driver has been fixed and tested to support it. > I'm quite sure I've seen a situation where msg_obj 17 "seemed" to be > pending, while msg_obj 18 and 19 already have been transmitted. But > in that case, I enabled ONESHOT for the can interface, which enables > the DA mode (automatic retransmission is disabled). Reported-by: Jan Altenberg <jan@linutronix.de> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Cc: Bhupesh Sharma <bhupesh.sharma@st.com> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-23mfd: mfd_cell is now implicitly available to janz driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-21can: c_can: Do basic c_can configuration _before_ enabling the interruptsJan Altenberg
I ran into some trouble while testing the SocketCAN driver for the BOSCH C_CAN controller. The interface is not correctly initialized, if I put some CAN traffic on the line, _while_ the interface is being started (which means: the interface doesn't come up correcty, if there's some RX traffic while doing 'ifconfig can0 up'). The current implementation enables the controller interrupts _before_ doing the basic c_can configuration. I think, this should be done the other way round. The patch below fixes things for me. Signed-off-by: Jan Altenberg <jan@linutronix.de> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-15Merge branch 'master' of ↵David S. Miller
2011-03-14can: wrong index used in inner looproel kluin
Index i was already used in the outer loop. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-02-28dt/net: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/net. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-28CAN: add controller hardware name for Softing cardsKurt Van Dijck
I just found that the controller hardware name is not set for the Softing driver. After this patch, "$ ip -d link show" looks nicer. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/e1000e/netdev.c net/xfrm/xfrm_policy.c
2011-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits) net: deinit automatic LIST_HEAD net: dont leave active on stack LIST_HEAD net: provide default_advmss() methods to blackhole dst_ops tg3: Restrict phy ioctl access drivers/net: Call netif_carrier_off at the end of the probe ixgbe: work around for DDP last buffer size ixgbe: fix panic due to uninitialised pointer e1000e: flush all writebacks before unload e1000e: check down flag in tasks isdn: hisax: Use l2headersize() instead of dup (and buggy) func. arp_notify: unconditionally send gratuitous ARP for NETDEV_NOTIFY_PEERS. cxgb4vf: Use defined Mailbox Timeout cxgb4vf: Quiesce Virtual Interfaces on shutdown ... cxgb4vf: Behave properly when CONFIG_DEBUG_FS isn't defined ... cxgb4vf: Check driver parameters in the right place ... pch_gbe: Fix the MAC Address load issue. iwlwifi: Delete iwl3945_good_plcp_health. net/can/softing: make CAN_SOFTING_CS depend on CAN_SOFTING netfilter: nf_iterate: fix incorrect RCU usage pch_gbe: Fix the issue that the receiving data is not normal. ...
2011-02-18Merge branch 'fixes-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq * 'fixes-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: make sure MAYDAY_INITIAL_TIMEOUT is at least 2 jiffies long workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable' workqueue: wake up a worker when a rescuer is leaving a gcwq
2011-02-16workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'Tejun Heo
There are two spellings in use for 'freeze' + 'able' - 'freezable' and 'freezeable'. The former is the more prominent one. The latter is mostly used by workqueue and in a few other odd places. Unify the spelling to 'freezable'. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Steven Whitehouse <swhiteho@redhat.com>
2011-02-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: set flow handler for secondary interrupt controller of 5249 m68knommu: remove use of IRQ_FLG_LOCK from 68360 platform support m68knommu: fix dereference of port.tty m68knommu: add missing linker __modver section m68knommu: fix mis-named variable int set_irq_chip loop m68knommu: add optimize memmove() function m68k: remove arch specific non-optimized memcmp() m68knommu: fix use of un-defined _TIF_WORK_MASK m68knommu: Rename m548x_wdt.c to m54xx_wdt.c m68knommu: fix m548x_wdt.c compilation after headers renaming m68knommu: Remove dependencies on nonexistent M68KNOMMU
2011-02-14net/can/softing: make CAN_SOFTING_CS depend on CAN_SOFTINGKurt Van Dijck
The statement 'select CAN_SOFTING' may ignore the dependancies for CAN_SOFTING while selecting CAN_SOFTING_CS, as is therefore a bad choice. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-13can: c_can: Added support for Bosch C_CAN controllerBhupesh Sharma
Bosch C_CAN controller is a full-CAN implementation which is compliant to CAN protocol version 2.0 part A and B. Bosch C_CAN user manual can be obtained from: http://www.semiconductors.bosch.de/media/en/pdf/ipmodules_1/c_can/users_manual_c_can.pdf This patch adds the support for this controller. The following are the design choices made while writing the controller driver: 1. Interface Register set IF1 has be used only in the current design. 2. Out of the 32 Message objects available, 16 are kept aside for RX purposes and the rest for TX purposes. 3. NAPI implementation is such that both the TX and RX paths function in polling mode. Signed-off-by: Bhupesh Sharma <bhupesh.sharma@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-09pch_can: fix tseg1/tseg2 setting issueTomoya MORINAGA
Previous patch "[PATCH 1/3] pch_can: fix 800k comms issue" is wrong. I should have modified tseg1_min not tseg2_min. This patch reverts tseg2_min to 1 and set tseg1_min to 2. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-09can: softing_cs needs slab.hRandy Dunlap
From: Randy Dunlap <randy.dunlap@oracle.com> softing_cs.c uses kzalloc & kfree, so it needs to include linux/slab.h. drivers/net/can/softing/softing_cs.c:234: error: implicit declaration of function 'kfree' drivers/net/can/softing/softing_cs.c:271: error: implicit declaration of function 'kzalloc' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-08pch_can: fix module reload issue with MSITomoya
Currently, in case reload pch_can, pch_can not to be able to catch interrupt. The cause is bus-master is not set in pch_can. Thus, add enabling bus-master processing. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-08pch_can: fix rmmod issueTomoya
Currently, when rmmod pch_can, kernel failure occurs. The cause is pci_iounmap executed before pch_can_reset. Thus pci_iounmap moves after pch_can_reset. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-08pch_can: fix 800k comms issueTomoya
Currently, 800k comms fails since prop_seg set zero. (EG20T PCH CAN register of prop_seg must be set more than 1) To prevent prop_seg set to zero, change tseg2_min 1 to 2. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-08m68knommu: Remove dependencies on nonexistent M68KNOMMUGeert Uytterhoeven
M68KNOMMU is set nowhere. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-04net: can: janz-ican3: world-writable sysfs termination fileVasiliy Kulikov
Don't allow everybody to set terminator via sysfs. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-04net: can: at91_can: world-writable sysfs filesVasiliy Kulikov
Don't allow everybody to write to mb0_id file. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-31CAN: softing driver depends on IOMEMChuck Ebbert
Without this dependency the softing driver will be buildable on s390, where it fails. Signed-Off-By: Chuck Ebbert <cebbert@redhat.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-30slcan: fix referenced website in Kconfig help textOliver Hartkopp
Fix the referenced project website to www.mictronics.de in the Kconfig help text for the slcan driver. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'can/at91_can-for-net-2.6' of ↵David S. Miller
git://git.pengutronix.de/git/mkl/linux-2.6
