path: root/drivers/net/cassini.c
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03cassini: fix off by oneDan Carpenter
There are only 6 link_modes. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17drivers/net/cassini.c: Use (pr|netdev|netif)_<level> macro helpersJoe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove #define PFX Use pr_<level> Use netdev_<level> Use netif_<level> Remove periods from formats Coalesce long formats Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17cassini: convert to use netdev_for_each_mc_addrJiri Pirko
Introduced a new function to do the mc list processing, makes code clearer after transition. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28netdev: remove HAVE_ leftoversAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06NET: cassini, fix lock imbalanceJiri Slaby
Stanse found that one error path in cas_open omits to unlock pm_mutex. Fix that. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/Kconfig
2009-02-02cassini/sungem: limit reaches -1, but 0 testedRoel Kluin
while (limit--) if (test()) break; if (limit <= 0) goto test_failed; In the last iteration, limit is decremented after the test to 0. If just thereafter test() succeeds and a break occurs, the goto still occurs because limit is 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07cassini: update to net_device_opsStephen Hemminger
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25cassini: fix warning in drivers/net/cassini.cIngo Molnar
this warning: drivers/net/cassini.c: In function ‘cas_rx_ringN’: drivers/net/cassini.c:2350: warning: ‘skb’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between cas_rx_process_pkt() and 'skb'. Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22cassini: use request_firmwareJaswinder Singh
Firmware blob looks like this... __le16 load_address unsigned char data[] [akpm@linux-foundation.org: include vmalloc.h] Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-21net: Remove __skb_insert() calls outside of skbuff internals.David S. Miller
This minor cleanup simplifies later changes which will convert struct sk_buff and friends over to using struct list_head. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26mm: speculative page referencesNick Piggin
If we can be sure that elevating the page_count on a pagecache page will pin it, we can speculatively run this operation, and subsequently check to see if we hit the right page rather than relying on holding a lock or otherwise pinning a reference to the page. This can be done if get_page/put_page behaves consistently throughout the whole tree (ie. if we "get" the page after it has been used for something else, we must be able to free it with a put_page). Actually, there is a period where the count behaves differently: when the page is free or if it is a constituent page of a compound page. We need an atomic_inc_not_zero operation to ensure we don't try to grab the page in either case. This patch introduces the core locking protocol to the pagecache (ie. adds page_cache_get_speculative, and tweaks some update-side code to make it work). Thanks to Hugh for pointing out an improvement to the algorithm setting page_count to zero when we have control of all references, in order to hold off speculative getters. [kamezawa.hiroyu@jp.fujitsu.com: fix migration_entry_wait()] [hugh@veritas.com: fix add_to_page_cache] [akpm@linux-foundation.org: repair a comment] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21cassini: Only use chip checksum for ipv4 packets.David S. Miller
According to David Monro, at least with Natsemi Saturn chips the cassini driver has some trouble with ipv6 checksums. Until we have more information about what's going on here, only use the chip checksums for ipv4. This workaround was suggested and tested by David. Update version and release date. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[CASSINI]: Use shorter list_splice_init() macro for brevity.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28netdev: use ARRAY_SIZE() instead of sizeof(array) / ETH_GSTRING_LENAlejandro Martinez Ruiz
Using ARRAY_SIZE() on arrays of the form array[][K] makes it unnecessary to know the value of K when checking its size. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-04[CASSINI]: Bump driver version and release date.David S. Miller
2008-01-04[CASSINI]: Fix two obvious NAPI bugs.David S. Miller
1) close should do napi_disable() not napi_enable 2) remove unused local var 'todo' Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-04[CASSINI]: Set skb->truesize properly on receive packets.David S. Miller
skb->truesize was not being incremented at all to reflect the page based data added to RX SKBs. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-04[CASSINI]: Program parent Intel31154 bridge when necessary.David S. Miller
2008-01-04[CASSINI]: Revert 'dont touch page_count'.David S. Miller
This reverts changeset fa4f0774d7c6cccb4d1fda76b91dd8eddcb2dd6a ([CASSINI]: dont touch page_count) because it breaks the driver. The local page counting added by this changeset did not account for the asynchronous page count changes done by kfree_skb() and friends. The change adds extra atomics and on top of it all appears to be totally unnecessary as well. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Nick Piggin <npiggin@suse.de>
2008-01-04[CASSINI]: Fix endianness bug.Al Viro
Here's proposed fix for RX checksum handling in cassini; it affects little-endian working with half-duplex gigabit, but obviously needs testing on big-endian too. The problem is, we need to convert checksum to fixed-endian *before* correcting for (unstripped) FCS. On big-endian it won't matter (conversion is no-op), on little-endian it will, but only if FCS is not stripped by hardware; i.e. in half-duplex gigabit mode when ->crc_size is set. cassini.c part is that fix, cassini.h one consists of trivial endianness annotations. With that applied the sucker is endian-clean, according to sparse. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15netdev: convert non-obvious instances to use ARRAY_SIZE()Alejandro Martinez Ruiz
This will convert remaining non-obvious or naive calculations of array sizes to use ARRAY_SIZE() macro. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11PCI: add pci_try_set_mwiRandy Dunlap
As suggested by Andrew, add pci_try_set_mwi(), which does not require return-value checking. - add pci_try_set_mwi() without __must_check - make it return 0 on success, errno if the "try" failed or error - review callers Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-31[CASSINI]: Fix printk message typo.David S. Miller
2007-05-24[CASSINI]: Check pci_set_mwi() return value.David S. Miller
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-02[NET]: Split skb->csumAl Viro
... into anonymous union of __wsum and __u32 (csum and csum_offset resp.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
