path: root/drivers/net/chelsio/pm3393.c
2005-06-23Update Chelsio gige net driver.Scott Bardone
- Use extern prefix for functions required. - Removed a lot of wrappers, including t1_read/write_reg_4. - Removed various macros, using native kernel calls now. - Enumerated various #defines. - Removed a lot of shared code which is not currently used in "NIC only" mode. - Removed dead code. Documentation/networking/cxgb.txt: - Updated release notes for version 2.1.1 drivers/net/chelsio/ch_ethtool.h - removed file, no longer using ETHTOOL namespace. drivers/net/chelsio/common.h - moved code from osdep.h to common.h - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/cphy.h - removed dead code. - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/cxgb2.c - use DMA_{32,64}BIT_MASK in include/linux/dma-mapping.h. - removed unused code. - use printk message for link info resembling drivers/net/mii.c. - no longer using the MODULE_xxx namespace. - no longer using "pci_" namespace. - no longer using ETHTOOL namespace. drivers/net/chelsio/cxgb2.h - removed file, merged into common.h drivers/net/chelsio/elmer0.h - removed dead code. - added various enums. - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/espi.c - removed various macros, using native kernel calls now. - removed a lot of wrappers, including t1_read/write_reg_4. drivers/net/chelsio/espi.h - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/gmac.h - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/mv88x201x.c - changes to sync with Chelsio TOT. drivers/net/chelsio/osdep.h - removed file, consolidation. osdep was used to translate wrapper functions since our code supports multiple OSs. removed wrappers. drivers/net/chelsio/pm3393.c - removed various macros, using native kernel calls now. - removed a lot of wrappers, including t1_read/write_reg_4. - removed unused code. drivers/net/chelsio/regs.h - added a few register entries for future and current feature support. - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/sge.c - rewrote large portion of scatter-gather engine to stabilize performance. - using u8/u16/u32 kernel types instead of __u8/__u16/__u32 compiler types. drivers/net/chelsio/sge.h - rewrote large portion of scatter-gather engine to stabilize performance. - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/subr.c - merged tp.c into subr.c - removed various macros, using native kernel calls now. - removed a lot of wrappers, including t1_read/write_reg_4. - removed unused code. drivers/net/chelsio/suni1x10gexp_regs.h - modified copyright and authorship of file. - added comment to #endif indicating which symbol it closes. drivers/net/chelsio/tp.c - removed file, merged into subr.c. drivers/net/chelsio/tp.h - removed file. include/linux/pci_ids.h - patched to include PCI_VENDOR_ID_CHELSIO 0x1425, removed define from our code.
2005-05-15[PATCH] A new 10GB Ethernet Driver by Chelsio CommunicationsChristoph Lameter
A Linux driver for the Chelsio 10Gb Ethernet Network Controller by Chelsio (http://www.chelsio.com). This driver supports the Chelsio N210 NIC and is backward compatible with the Chelsio N110 model 10Gb NICs. It supports AMD64, EM64T and x86 systems. Signed-off-by: Tina Yang <tinay@chelsio.com> Signed-off-by: Scott Bardone <sbardone@chelsio.com> Signed-off-by: Christoph Lameter <christoph@lameter.com> Adrian said: - my3126.c is unused (because t1_my3126_ops isn't used anywhere) - what are the EXTRA_CFLAGS in drivers/net/chelsio/Makefile for? - $(cxgb-y) in drivers/net/chelsio/Makefile seems to be unneeded - completely unused global functions: - espi.c: t1_espi_get_intr_counts - sge.c: t1_sge_get_intr_counts - the following functions can be made static: - sge.c: t1_espi_workaround - sge.c: t1_sge_tx - subr.c: __t1_tpi_read - subr.c: __t1_tpi_write - subr.c: t1_wait_op_done shemminger said: The performance recommendations in cxgb.txt are common to all fast devices, and should be in one file rather than just for this device. I would rather see ip-sysctl.txt updated or a new file on tuning recommendations started. Some of them have consequences that aren't documented well. For example, turning off TCP timestamps risks data corruption from sequence wrap. A new driver shouldn't need so may #ifdef's unless you want to putit on older vendor versions of 2.4 Some accessor and wrapper functions like: t1_pci_read_config_4 adapter_name t1_malloc are just annoying noise. Why have useless dead code like: /* Interrupt handler */ +static int pm3393_interrupt_handler(struct cmac *cmac) +{ + u32 master_intr_status; +/* + 1. Read master interrupt register. + 2. Read BLOCK's interrupt status registers. + 3. Handle BLOCK interrupts. +*/ Jeff said: step 1: kill all the OS wrappers. And do you really need hooks for multiple MACs, when only one MAC is really supported? Typically these hooks are at a higher level anyway -- struct net_device. From: Christoph Lameter <christoph@lameter Driver modified as suggested by Pekka Enberg, Stephen Hemminger and Andrian Bunk. Reduces the size of the driver to ~260k. - clean up tabs - removed my3126.c - removed 85% of suni1x10gexp_regs.h - removed 80% of regs.h - removed various calls, renamed variables/functions. - removed system specific and other wrappers (usleep, msleep) - removed dead code - dropped redundant casts in osdep.h - dropped redundant check of kfree - dropped weird code (MODVERSIONS stuff) - reduced number of #ifdefs - use kcalloc now instead of kmalloc - Add information about known issues with the driver - Add information about authors Signed-off-by: Scott Bardone <sbardone@chelsio.com> Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Andrew Morton <akpm@osdl.org> diff -puN /dev/null Documentation/networking/cxgb.txt
