commit ed770f01360b392564650bf1553ce723fa46afec upstream.
If the call to phy_connect fails, we will return directly instead of freeing
the previously allocated struct net_device.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
With the removal of BUS_ID_SIZE, cpmac was not fully
converted to use MII_BUS_ID_SIZE as it ought to. This
patch fixes the following cpmac build failure:
CC drivers/net/cpmac.o
drivers/net/cpmac.c: In function 'cpmac_start_xmit':
drivers/net/cpmac.c:563: warning: comparison of distinct pointer types lacks a cast
drivers/net/cpmac.c: In function 'cpmac_probe':
drivers/net/cpmac.c:1112: error: 'BUS_ID_SIZE' undeclared (first use in this function)
drivers/net/cpmac.c:1112: error: (Each undeclared identifier is reported only once
drivers/net/cpmac.c:1112: error: for each function it appears in.)
Reported-by: Ralf Baechle <ralf@linux-mips.org>
This patch slows down the MDIO_ALIVE busy waiting to let
switches and PHY come up after reset. Previous loop was
too quick for IC+175C and ADM6996C/L switches to come up.
This patch adds support for fixed PHY connected in MII mode
to cpmac. We allow external and dumb_switch module parameters
to override the PHY detection process since they are always connected
with MDIO bus identifier 0. This lets fixed PHYs to be detected
correctly and be connected to the their corresponding MDIO
bus identifier.
This patch fixes the wrong MDIO bus identifier which was
set to 0 unconditionaly, suitable for external switches while
it is actually 1 for PHYs different than external switches
which are autodetected.
This patch fixes and obvious typo in the netdev_ops initialization:
ndo_so_ioctl should be ndo_do_ioctl.
We should not be stopping the subqueues in cpmac_end_xmit
but rather test the status of them. Replace the calls to
netif_subqueue_stop by __netif_subqueue_stopped. This
fixes an unrecoverable exception from happening when
running the driver.
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
This patch removes the unused variables in
cpmac_hw_error, cpmac_tx_timeout and cpmac_probe.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Following the removal of the unused struct net_device * parameter from
the NAPI functions named *netif_rx_* in commit 908a7a1, they are
exactly equivalent to the corresponding *napi_* functions and are
therefore redundant.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
When the napi api was changed to separate its 1:1 binding to the net_device
struct, the netif_rx_[prep|schedule|complete] api failed to remove the now
vestigual net_device structure parameter. This patch cleans up that api by
properly removing it..
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This patch introduces mdiobus_alloc() and mdiobus_free(), and
makes all mdio bus drivers use these functions to allocate their
struct mii_bus'es dynamically.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Acked-by: Andy Fleming <afleming@freescale.com>
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION.
drivers/net/acenic.c
drivers/net/bnx2x_link.c
drivers/net/bnx2x_main.c
drivers/net/cpmac.c
drivers/net/gianfar_sysfs.c
drivers/net/ipg.h
drivers/net/ppp_mppe.c
drivers/net/pppol2tp.c
drivers/net/r6040.c
drivers/net/sh_eth.c
drivers/net/sky2.c
drivers/net/tehuti.h
drivers/net/typhoon.c
This patch removes the said #include <linux/version.h>.
Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com>
The drivers were touching net queue before it has been started, so
without this patch, the drivers will potentially WARN at
net/core/dev.c:1328.
I don't have the hardware for the drivers below, so this patch is
untested, and thus should be carefully peer reviewed.
tc35815.c
au1000_eth.c
bfin_mac.c
macb.c
^ The four drivers are using phylib, they're calling netif_start_queue()
in open() callback. So trivially remove netif_tx_schedule_all().
Phylib will handle netif_carrier_*().
cpmac.c
fec_mpc52xx.c
fs_enet/fs_enet-main.c
sh_eth.c
^ The same as above, but these were also needlessly calling
netif_carrier_*() functions. So removed queue calls and also remove
carrier calls, since phylib will handle it. fs_enet-main.c also didn't
call netif_start_queue() at open(), this is fixed now.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This effectively "flips the switch" by making the core networking
and multiqueue-aware drivers use the new TX multiqueue structures.
Non-multiqueue drivers need no changes. The interfaces they use such
as netif_stop_queue() degenerate into an operation on TX queue zero.
So everything "just works" for them.
Code that really wants to do "X" to all TX queues now invokes a
routine that does so, such as netif_tx_wake_all_queues(),
netif_tx_stop_all_queues(), etc.
pktgen and netpoll required a little bit more surgery than the others.
In particular the pktgen changes, whilst functional, could be largely
improved. The initial check in pktgen_xmit() will sometimes check the
wrong queue, which is mostly harmless. The thing to do is probably to
invoke fill_packet() earlier.
The bulk of the netpoll changes is to make the code operate solely on
the TX queue indicated by by the SKB queue mapping.
Setting of the SKB queue mapping is entirely confined inside of
net/core/dev.c:dev_pick_tx(). If we end up needing any kind of
special semantics (drops, for example) it will be implemented here.
Finally, we now have a "real_num_tx_queues" which is where the driver
indicates how many TX queues are actually active.
With IGB changes from Jeff Kirsher.
There is no need for a feature bit for something that
can be tested by simply checking the TX queue count.
Multiple TX queue support is a core networking feature.
* Resolve some locking issues using atomic_inc/atomic_dec
* move status code in cpmac_check_status
* unmark the BROKEN flag in Kconfig
* move code which should have been in platform code in
arch/mips/ar7/platform.c
* fixed an IRQ storm which lets the kernel hang
* fixed a double call to netif_start_queue which causes a kernel panic
* don't fail to register the PHY, works on many devices now
Signed-off-by: Matteo Croce <matteo@openwrt.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network
platform drivers, to re-enable auto loading.
NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support.
That looks problematic in the first place (it even uses the ancient "struct
device_driver" binding scheme for platform_bus!) and I suspect it will vanish
soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have
needed more thought to sort out.
[akpm@linux-foundation.org: fix sgiseeq.c]
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Vitaly Bordug <vitb@kernel.crashing.org>
Cc: Dale Farnsworth <dale@farnsworth.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Andrew Victor <andrew@sanpeople.com>
Cc: Bryan Wu <bryan.wu@analog.com>
Having the id field be an int was making more complex bus topologies
excessively difficult. For now, just convert it to a string, and
change all instances of "bus->id = val" to
snprintf(id, MII_BUS_ID_LEN, "%x", val).
Signed-off-by: Andy Fleming <afleming@freescale.com>
This patch converts cpmac to the new Fixed PHY infrastructure, though it
doesn't fix all the problems with that driver. I didn't even bother to
test this patch to compile, because cpmac driver is broken in several ways:
1. This driver won't compile by itself because lack of its header describing
platform data;
2. It assumes that fixed PHYs should be created by the ethernet driver.
It is wrong assumption: fixed PHYs creation is platform code authority,
driver must blindly accept bus_id and phy_id platform data variables
instead.
Also, it seem that that driver doesn't have actual in-tree users, so
nothing to fix further.
The main purpose of that patch is to get rid of the following Kconfig
warning:
scripts/kconfig/conf -s arch/powerpc/Kconfig
drivers/net/Kconfig:1713:warning: 'select' used by config symbol
'CPMAC' refers to undefined symbol 'FIXED_MII_100_FDX'
* use irq_handler_t where appropriate
* no need to use 'irq' function arg, its already stored in a data struct
* rename irq handler 'irq' argument to 'dummy', where the function
has been analyzed and proven not to use its first argument.
* remove always-false "dev_id == NULL" test from irq handlers
* remove pointless casts from void*
* declance: irq argument is not const
* add KERN_xxx printk prefix
* fix minor whitespace weirdness
Please apply this patch since i reverted by mistake
the commit 4e3ab47a547616e583c7a5458beced6aa34c8ef3
in 6cd043d99dcf5d252fcc682958541f449113f7b3
Signed-off-by: Matteo Croce <technoboy85@gmail.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Use fixed_mdio_get_phydev for obtaining fixed phy instances and adopt to
changed fixed phy device naming.
Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru>
Convert cpmac to new napi_struct API introduced by
bea3348eef27e6044b6161fd04c3152215f96411 [NET]: Make NAPI polling independent
of struct net_device objects.
Only disable rx interrupts if napi actually has been scheduled.
Switch to using DECLARE_MAC_BUF/print_mac() added by commit
0795af5729b18218767fab27c44b1384f72dc9ad [NET]: Introduce and use print_mac()
and DECLARE_MAC_BUF().
Make the helper for getting the field, symmetrical to
the "set" one. Return 0 if CONFIG_NETDEVICES_MULTIQUEUE=n
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
New version which uses less locking and drops old API
