The PCIE capability offset is saved during PCI bus walking. It will
remove an unnecessary search in the PCI configuration space if this
value is referenced instead of reacquiring it.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
This removes some of the remnants of LRO -> GRO conversion.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Make local functions static. Remove functions that are
defined and never used. Compile tested only.
Acked-by: Divy Le Ray <divy@chelsio.com>
Removed whole t3_rx_mode structure and appropriate helpers cause they are no
longer needed.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Replace run-time string formatting with preprocessor string
manipulation.
use request_firmware() to load the phy's EDC programmation
Signed-off-by: Divy Le Ray <divy@chelsio.com>
Add support for the Aquantia AQ1002 10G-BaseT phy.
Add support for the AEL2020 phy.
Add PCI IDs of the boards using this phy.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Compile-tested only.
Separate ports from H/W Tx channels.
The driver currently ignores the local or remote link faults
raised at the mac layer. This patch fixes it.
Our mac however only advertizes link events, so wait for the
phy to stabilize the link, then enable mac link events interrupts.
The NIC driver can work with mutliple versions of the FW.
Let the driver load when the embedded FW does not match,
and the FW update mechanism failed.
The iWARP module will make its own loading decision.
Update copyright banner to 2008.
Add support for 1G optical Vitesse PHY.
Add support for SR PHY.
Auto-detect phy module type, and report type changes.
Add generic code to manage interrupt driven PHYs.
Do not reset the phy after link parameters update,
the new values might get lost.
Return early from link change notification
when the link parameters remain unchanged.
Do not require PHY interrupts to be connected to GPIs in ascending order.
Base interrupt availability both on PHYs supporting them and on GPIs being
hooked up. Allows boards to specify interrupt GPIs though the PHYs don't
use them.
Remove spurious PHY interrupts due to clearing T3DBG interrupts before
setting their polarity.
Second step in overall phy layer reorganization.
Clean up the port_type_info structure.
Support coextistence of clause 22 and clause 45 MDIO devices.
Select the type of MDIO transaction on a per transaction basis.
First step towards overall PHY layering re-organization.
Allow a status return when a PHY is reset.
Allocate a queue set per core, up to the maximum of available qsets.
Share the queue sets on multi port adapters.
Rename MSI-X interrupt vectors ethX-N, N being the queue set number.
when a fatal error occurs, bring ports down, reset the chip,
and bring ports back up.
Factorize code used for both EEH and fatal error recovery.
Fix timer usage when bringing up/resetting sge queue sets.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
Add LRO support.
Reset the chip when the PCI link goes down.
Preserve the napi structure when a sge qset's resources are freed.
Replay only HW initialization when the chip comes out of reset.
Signed-off-by: Divy Le ray <divy@chelsio.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
The new microcode engine version is set to 1.1.0
add driver recognition for T3C rev board.
Qualify toggling of xgmac tx enable with not getting pause frames,
we might not make forward progress because the peer is sending
lots of pause frames.
Update firmware version.
Allow the driver to be up and running with older FW image
Log HW serial number when cxgb3 module is loaded.
Reduce Rx coalescing length to 12288
Large bursts from the adapter to the host create back pressure
on the chip. Reducing the burst size avoids the issue.
Update the MAC workaround to deal with switches that do not
honor pause frames.
Load the engine microcode when an interface
is brought up, instead of of doing it when the module
is loaded.
Loosen up tight binding between the driver and the
engine microcode version.
There is no need for microcode update with T3A boards.
Fix the file naming.
Do a better job at logging the loading activity.
The chip executes microcode present in internal RAM,
whose content is loaded from EEPROM on power cycle.
This patch allows an update of the microcode through PIO
without forcing a power cycle.
The MAC watchdog was failing if the peer interface was brought down.
Differentiate NIC only adapters from RNICs.
Initialize offload capabilities for RNICs only.
Ensure that the TCAM active region size is at least 16.
Under rare conditions, the MAC might hang while generating a pause frame.
This patch fine tunes the MAC settings to avoid the issue, allows for
periodic MAC state check, and triggers a recovery if hung.
Also fix one MAC statistics counter for the rev board T3B2.
Dual licensing, needed for OFED 1.2
This driver is required by the Chelsio T3 RDMA driver posted by
Steve Wise.
