path: root/drivers/net/cxgb3
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-27cxgb3: Wait longer for control packets on initializationAndre Detsch
In some Power7 platforms, when using VIOS (Virtual I/O Server), we need to wait longer for control packets to finish transfer during initialization. Without this change, initialization may fail prematurely. Signed-off-by: Wen Xiong <wenxiong@us.ibm.com> Signed-off-by: Andre Detsch <adetsch@br.ibm.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21cxgb3: fix linkup issueHiroshi Shimamoto
I encountered an issue that not to link up on cxgb3 fabric. I bisected and found that this regression was introduced by 0f07c4ee8c800923ae7918c231532a9256233eed. Correct to pass phy_addr to cphy_init() at t3_xaui_direct_phy_prep(). Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13cxgb3: use the DMA state API instead of the pci equivalentsFUJITA Tomonori
This replace the PCI DMA state API (include/linux/pci-dma.h) with the DMA equivalents since the PCI DMA state API will be obsolete. No functional change. For further information about the background: http://marc.info/?l=linux-netdev&m=127037540020276&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits) bridge: ensure to unlock in error path in br_multicast_query(). drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages sky2: Avoid rtnl_unlock without rtnl_lock ipv6: Send netlink notification when DAD fails drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant ipconfig: Handle devices which take some time to come up. mac80211: Fix memory leak in ieee80211_if_write() mac80211: Fix (dynamic) power save entry ipw2200: use kmalloc for large local variables ath5k: read eeprom IQ calibration values correctly for G mode ath5k: fix I/Q calibration (for real) ath5k: fix TSF reset ath5k: use fixed antenna for tx descriptors libipw: split ieee->networks into small pieces mac80211: Fix sta_mtx unlocking on insert STA failure path rt2x00: remove KSEG1ADDR define from rt2x00soc.h net: add ColdFire support to the smc91x driver asix: fix setting mac address for AX88772 ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}. net: Fix dev_mc_add() ...
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-04cxgb3: fix hot plug removal crashDivy Le Ray
queue restart tasklets need to be stopped after napi handlers are stopped since the latter can restart them. So stop them after stopping napi. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (48 commits) IB/srp: Clean up error path in srp_create_target_ib() IB/srp: Split send and recieve CQs to reduce number of interrupts RDMA/nes: Add support for KR device id 0x0110 IB/uverbs: Use anon_inodes instead of private infinibandeventfs IB/core: Fix and clean up ib_ud_header_init() RDMA/cxgb3: Mark RDMA device with CXIO_ERROR_FATAL when removing RDMA/cxgb3: Don't allocate the SW queue for user mode CQs RDMA/cxgb3: Increase the max CQ depth RDMA/cxgb3: Doorbell overflow avoidance and recovery IB/core: Pack struct ib_device a little tighter IB/ucm: Clean whitespace errors IB/ucm: Increase maximum devices supported IB/ucm: Use stack variable 'base' in ib_ucm_add_one IB/ucm: Use stack variable 'devnum' in ib_ucm_add_one IB/umad: Clean whitespace IB/umad: Increase maximum devices supported IB/umad: Use stack variable 'base' in ib_umad_init_port IB/umad: Use stack variable 'devnum' in ib_umad_init_port IB/umad: Remove port_table[] IB/umad: Convert *cdev to cdev in struct ib_umad_port ...
2010-02-24RDMA/cxgb3: Doorbell overflow avoidance and recoverySteve Wise
T3 hardware doorbell FIFO overflows can cause application stalls due to lost doorbell ring events. This has been seen when running large NP IMB alltoall MPI jobs. The T3 hardware supports an xon/xoff-type flow control mechanism to help avoid overflowing the HW doorbell FIFO. This patch uses these interrupts to disable RDMA QP doorbell rings when we near an overflow condition, and then turn them back on (and ring all the active QP doorbells) when when the doorbell FIFO empties out. In addition if an doorbell ring is dropped by the hardware, the code will now recover. Design: cxgb3: - enable these DB interrupts - in the interrupt handler, schedule work tasks to call the ULPs event handlers with the new events. - ring all the qset txqs when an overflow is detected. iw_cxgb3: - disable db ringing on all active qps when we get the DB_FULL event - enable db ringing on all active qps and ring all active dbs when we get the DB_EMPTY event - On DB_DROP event: - disable db rings in the event handler - delay-schedule a work task which rings and enables the dbs on all active qps. - in post_send and post_recv logic, don't ring the db if it's disabled. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-17cxgb3: convert to use netdev_for_each_addrJiri Pirko
Removed whole t3_rx_mode structure and appropriate helpers cause they are no longer needed. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15cxgb3: fix link flapDivy Le Ray
The driver is expected to report that the link is up when the phy Rx signal is established and the mac has not detected a link fault. The code is however broken, the driver does not check the link fault status when the phy link status changes. The link fault status being checked within a short period of time, it leads to link up/link down events. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15cxgb3: FIx VLAN over Jumbo framesDivy Le Ray
The mac is expected to auto-inflate the Maximum Frame size for VLAN tagged frames. It however does not work with jumbo frames. Work around the bug adding 4 to the Maximum Frame for MTUs greater than 1536. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09Merge branch 'master' of ↵David S. Miller
2010-02-08cxgb3: fix GRO checksum checkDivy Le Ray
Verify the HW checksum state for frames handed to GRO processing. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-05Fix spelling of 'platform' in comments and docStefan Weil
Replace platfrom -> platform. This is a frequent spelling bug. Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-03cxgb3: add memory barriersDivy Le Ray
Add memory barriers to fix crashes observed on newest PowerPC platforms. The HW and driver state of the receive rings were getting out of sync. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03drivers/net/cxgb3: Use kzalloc for allocating only one thingJulia Lawall
Use kzalloc rather than kcalloc(1,...) The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ @@ - kcalloc(1, + kzalloc( ...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/net/tcp.h
2009-12-11cxgb3: Fixing EEH handlersBreno Leitao
After commit 4b77b0a2ba27d64f58f16d8d4d48d8319dda36ff ("PCI: Clear saved_state after the state has been restored"), the EEH is not working proplery on cxgb3. This patch fixes it, always saving the PCI state after a recovery, in order to allow further reoveries. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18cxgb3: fix premature page unmapDivy Le Ray
unmap Rx page only when guaranteed that this page won't be used anymore to allocate rx page chunks. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10cxgb3: declare MODULE_FIRMWAREBen Hutchings
Replace run-time string formatting with preprocessor string manipulation. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27cxgb3: Set the rxqKrishna Kumar
Set the rxq# for LRO when processing the last fragment of a frame. This helps in fast txq selection for routing workloads. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17cxgb3: No need to wake queue in xmit handlerKrishna Kumar
The xmit handler doesn't need to wake the queue after stopping it temporarily (some other drivers are doing the same). Patch on net-next-2.6, multiple netperf sessions tested. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13cxgb3: Added private MAC address and provisioning packet handler for iSCSIKaren Xie
This patch added support of private MAC address per port and provisioning packet handler for iSCSI traffic only. The above changes are isolated to the cxgb3 driver, independent of any scsi or iscsi driver changes. Acked-by: Karen Xie <kxie@chelsio.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Rakesh Ranjan <rakesh@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-05RDMA/cxgb3: Handle port events properlySteve Wise
Massage the err_handler upcall into an event handler upcall, pass netdev port events to the cxgb3 ULPs and generate RDMA port events based on LLD port events. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05cxgb3: fix 2 ports 1G regressionDivy Le Ray
commit 88045b3cf0f8981129cb489c7b6bc36c21dd33a7 cxgb3: fix mac index mapping Override the mac index computation for the gen2 adapter, as each port is expected to use index 0. introduces a regression on 2 port 1G adapter as its xauicfg vpd value is null. Add a check on the device id. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-02cxgb3: fix Gen2 pci default settingsDivy Le Ray
Modify control register settings to accommodate the bridge's max read requset size. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-02cxgb3: fix EDC filename stringDivy Le Ray
Fix a cut'n paste error in the AEL2020 twinax EDC file name Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09Merge branch 'master' of ↵David S. Miller
2009-07-09cxgb3: Fix crash caused by stashing wrong netdev_queueRoland Dreier
Commit c3a8c5b6 ("cxgb3: move away from LLTX") exposed a bug in how cxgb3 looks up the netdev_queue it stashes away in a qset during initialization. For multiport devices, the TX queue index it uses is offset by the first_qset index of each port. This leads to a crash once LLTX is removed, since hard_start_xmit is called with one TX queue lock held, while the TX reclaim timer task grabs a different (wrong) TX queue lock when it frees skbs. Fix this by removing the first_qset offset used to look up the TX queue passed into t3_sge_alloc_qset() from setup_sge_qsets(). Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: Drain Mac Tx fifo when the port goes down.Divy Le Ray
Drain the MAC TX fifos when a port goes down. Back pressure might otherwise occur, leading to both ports of the same adapter to hang. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: fix mac index mappingDivy Le Ray
Override the mac index computation for the gen2 adapter, as each port is expected to use index 0. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: Fix mss table initializationDivy Le Ray
Fix the HW SMT table initialization to avoid random mss miscomputations for offload connections. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: use request_firmware() for the EDC registers setupDivy Le Ray
use request_firmware() to load the phy's EDC programmation Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: AEL2020 phy support updateDivy Le Ray
We don't always see the link status update interrupt when we come out of reset and the peer is up. Check and report the link status right before enabling interrupts. Also fix LED settings, to get a consistent link status. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: Fix T3C MAC max packet size accessDivy Le Ray
Max packet size is not the only field in T3C's High Water Mark register. Mask the register to access this field. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: fix phy power downDivy Le Ray
2 phys are were not getting the Global Tx disable bit set when powered down, leading to an inconsistent link state on peer. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: AQ100X phy support updateDivy Le Ray
Add missing SUPPORTED_TP flag. Update FW version checking. Do the full initialization even if the FW version is unknown, it might help catching further issues. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
