VF Driver should use mailbox command timeout specified in t4fw_interface.h
rather than hard-coded value of 500ms.
Signed-off-by: Casey Leedom <leedom@chelsio.com>
For the VFs, the Mailbox Data "registers" are actually backed by
T4's "MA" interface rather than PL Registers (as is the case for
the PFs). Because these are in different coherency domains, the
write to the VF's PL-register-backed Mailbox Control can race in
front of the writes to the MA-backed VF Mailbox Data "registers".
So we need to do a read-back on at least one byte of the VF Mailbox
Data registers before doing the write to the VF Mailbox Control
register.
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
We were truncating the number of unicast and multicast MAC addresses
supported. Additionally, we were incorrectly computing the MAC Address
hash (a "1 << N" where we needed a "1ULL << N").
Minor cleanup of comments and symbolic constant names for clarity.
Add call to Firmware to reset its VF State when we first attach to the VF.
Fix off-by-one error in checking for the end of the mailbox response delay
array. We ended up walking off the end and, if we were unlucky, we'd end up
pulling in a 0 and never terminate the mailbox response delay loop ...
device communication code
Add core T4 PCI-E SR-IOV Virtual Function hardware definitions and device
communication code.
