path: root/drivers/net/e1000
2008-04-16e1000: convert uint16_t style integers to u16Joe Perches
Conglomerate from 4 separate patches from Joe. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-26e1000: remove irq_semJesse Brandeburg
irq_sem was just a hack to prevent interrupts from being enabled unexpectedly in deep call paths. Simply finding those call paths and fixing them by hand results in a driver that behaves as we expect and doesn't need the atomic at all. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-26e1000: Convert boolean_t to boolJoe Perches
On Thu, 2008-03-06 at 10:07 -0800, Kok, Auke wrote: > send me a patch for e1000 and for ixgb and I'll happily apply those :) boolean_t to bool TRUE to true FALSE to false comment typo ahread to ahead Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11e1000: warn if this driver is used for e1000e devicesAuke Kok
We're already starting to see reports from users still using e1000 where they should be using e1000e now that this is actually possible. Just to prevent some of this thrash, add a big warning on load on these devices that people should switch to e1000e. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11replace code with FIELD_SIZEOFJulia Lawall
Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11e1000: Fix for 32 bits platforms with 64 bits resourcesBenjamin Herrenschmidt
The e1000 driver stores the content of the PCI resources into unsigned long's before ioremapping. This breaks on 32 bits platforms that support 64 bits MMIO resources such as ppc 44x. This fixes it by removing those temporary variables and passing directly the result of pci_resource_start/len to ioremap. The side effect is that I removed the assignments to the netdev fields mem_start, mem_end and base_addr, which are totally useless for PCI devices. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> -- drivers/net/e1000/e1000_main.c | 18 +++++------------- 1 file changed, 5 insertions(+), 13 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03e1000: make e1000_dump_eeprom() staticAdrian Bunk
This patch makes the needlessly global e1000_dump_eeprom() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[net] Gracefully handle shared e1000/1000e driver PCI ID'sLinus Torvalds
Both the old e1000 driver and the new e1000e driver can drive some PCI-Express e1000 cards, and we should avoid ambiguity about which driver will pick up the support for those cards when both drivers are enabled. This solves the problem by having the old driver support those cards if the new driver isn't configured, but otherwise ceding support for PCI Express versions of the e1000 chipset to the newer driver. Thus allowing both legacy configurations where only the old driver is active (and handles all chips it knows about) and the new configuration with the new driver handling the more modern PCIE variants. Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30Mostly revert "e1000/e1000e: Move PCI-Express device IDs over to e1000e"Linus Torvalds
The new e1000e driver is apparently not yet suitable for general use, so mark it experimental, and re-instate all the PCI-Express device IDs in the old and stable e1000 driver so that people (namely me) can continue to use a driver that actually works. Auke & co have been appraised of the situation. Cc: Auke Kok <auke-jan.h.kok@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28e1000: Dump the eeprom when a user encounters a bad checksumAuke Kok
To help supporting users with a bad eeprom checksum, dump the eeprom info when such a situation is encountered by a user. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28e1000: remove no longer used code for pci read/write cfgAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28e1000 endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[netdrvr] checkpatch cleanupsJeff Garzik
2008-01-28[E1000]: Secondary unicast address supportPatrick McHardy
Add support for configuring secondary unicast addresses. Unicast addresses take precendece over multicast addresses when filling the exact address filters to avoid going to promiscous mode. When more unicast addresses are present than filter slots, unicast filtering is disabled and all slots can be used for multicast addresses. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[E1000]: Convert regtest macro's to functionsJoe Perches
Minimal macro to function conversion in e1000_ethtool.c Adds functions reg_pattern_test and reg_set_and_check Changes REG_PATTERN_TEST and REG_SET_AND_CHECK macros to call these functions. Saves ~2.5KB Compiled x86, untested (no hardware) old: $ size drivers/net/e1000/e1000_ethtool.o text data bss dec hex filename 16778 0 0 16778 418a drivers/net/e1000/e1000_ethtool.o new: $ size drivers/net/e1000/e1000_ethtool.o text data bss dec hex filename 14128 0 0 14128 3730 drivers/net/e1000/e1000_ethtool.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[E1000]: update netstats traffic counters realtimeAuke Kok
formerly e1000/e1000e only updated traffic counters once every 2 seconds with the register values of bytes/packets. With newer code however in the interrupt and polling code we can real-time fill in these values in the netstats struct for users to see. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28e1000/e1000e: Move PCI-Express device IDs over to e1000eAuke Kok
e1000e will from now on support the PCI-Express adapters that previously were supported by e1000. This support means better performance and easier debugging from now on for both the old PCI-X/PCI hardware and PCI-Express adapters. This patch also moves 3 recently merged device IDs over to e1000e that are identical to quad-port versions of already existing dual port versions. With this last bit every former e1000 pci-e device should work now with e1000e. Here is a brief list of which gigabit driver to use with which adapter: e1000: 82540 -> 82547 e1000e: 82571 -> 82573 ich8, ich9 (82562 or 82566) es2lan (80003eslan) igb: (not yet merged, only available from e1000.sf.net) 82575 Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28netdev: use ARRAY_SIZE() instead of sizeof(array) / ETH_GSTRING_LENAlejandro Martinez Ruiz
Using ARRAY_SIZE() on arrays of the form array[][K] makes it unnecessary to know the value of K when checking its size. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-20[NET]: Fix interrupt semaphore corruption in Intel drivers.David S. Miller
Several of the Intel ethernet drivers keep an atomic counter used to manage when to actually hit the hardware with a disable or an enable. The way the net_rx_work() breakout logic works during a pending napi_disable() is that it simply unschedules the poll even if it still has work. This can potentially leave interrupts disabled, but that is OK because all of the drivers are about to disable interrupts anyways in all such code paths that do a napi_disable(). Unfortunately, this trips up the semaphore used here in the Intel drivers. If you hit this case, when you try to bring the interface back up it won't enable interrupts. A reload of the driver module fixes it of course. So what we do is make sure all the sequences now go: napi_disable(); atomic_set(&adapter->irq_sem, 0); *_irq_disable(); which makes sure the counter is always in the correct state. Reported by Robert Olsson. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-17[NET]: Fix TX timeout regression in Intel drivers.David S. Miller
This fixes a regression added by changeset 53e52c729cc169db82a6105fac7a166e10c2ec36 ("[NET]: Make ->poll() breakout consistent in Intel ethernet drivers.") As pointed out by Jesse Brandeburg, for three of the drivers edited above there is breakout logic in the *_clean_tx_irq() code to prevent running TX reclaim forever. If this occurs, we have to elide NAPI poll completion or else those TX events will never be serviced. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
2008-01-08[NET]: Make ->poll() breakout consistent in Intel ethernet drivers.David S. Miller
This makes the ->poll() routines of the E100, E1000, E1000E, IXGB, and IXGBE drivers complete ->poll() consistently. Now they will all break out when the amount of RX work done is less than 'budget'. At a later time, we may want put back code to include the TX work as well (as at least one other NAPI driver does, but by in large NAPI drivers do not do this). But if so, it should be done consistently across the board to all of these drivers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Auke Kok <auke-jan.h.kok@intel.com>
2008-01-08[NET]: Do not check netif_running() and carrier state in ->poll()David S. Miller
Drivers do this to try to break out of the ->poll()'ing loop when the device is being brought administratively down. Now that we have a napi_disable() "pending" state we are going to solve that problem generically. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-07e1000: fix memcpy in e1000_get_stringsRoel Kluin
drivers/net/e1000/e1000_ethtool.c:113: #define E1000_TEST_LEN sizeof(e1000_gstrings_test) / ETH_GSTRING_LEN drivers/net/e1000e/ethtool.c:106: #define E1000_TEST_LEN sizeof(e1000_gstrings_test) / ETH_GSTRING_LEN E1000_TEST_LEN*ETH_GSTRING_LEN will expand to sizeof(e1000_gstrings_test) / (ETH_GSTRING_LEN * ETH_GSTRING_LEN) A lack of parentheses around defines causes unexpected results due to operator precedences. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01e1000: Fix NAPI state bug when Rx completeAuke Kok
Don't exit polling when we have not yet used our budget, this causes the NAPI system to end up with a messed up poll list. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-13[E1000]: Fix schedule while atomic when called from mii-tool.Jesse Brandeburg
mii-tool can cause the driver to call msleep during nway reset, bugzilla.kernel.org bug 8430. Fix by simply calling reinit_locked outside of the spinlock, which is safe from ethtool, so it should be safe from here. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30e1000: sparse warnings fixesStephen Hemminger
Fix sparse warnings and problems from e1000 driver. Added a sparse fix for the module param array index -- Auke Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-20fix typo about TBI in e1000 commentMasatake YAMATO
Signed-off-by: Masatake YAMATO <jet@gyve.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10e1000: Simple optimizations in e1000_xmit_frameKrishna Kumar
Some simple optimizations in e1000_xmit_frame. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10PCI-X/PCI-Express read control interfaces: use them in e1000Peter Oruba
These driver changes incorporate the proposed PCI-X / PCI-Express read byte count interface. Reading and setting those valuse doesn't take place "manually", instead wrapping functions are called to allow quirks for some PCI bridges. Signed-off by: Peter Oruba <peter.oruba@amd.com> Based on work by Stephen Hemminger <shemminger@linux-foundation.org> Acked-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-27e1000: Add device IDs of blade version of the 82571 quad portAuke Kok
This blade-specific board form factor is identical to the 82571EB board. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-14e1000: Add device IDs of new 82571 board variantsAuke Kok
This patch adds support for 2 new board variants: - A Quad port fiber 82571 board - A blade version of the 82571 quad copper board Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-03e1000: disable polling before registering netdeviceAuke Kok
To assure the symmetry of poll enable/disable in up/down, we should initialize the netdevice to be poll_disabled at load time. Doing this after register_netdevice leaves us open to another race, so lets move all the netif_* calls above register_netdevice so the stack starts out how we expect it to be. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Doug Chapman <doug.chapman@hp.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-30e1000: restore netif_poll_enable call but make sure IRQs are offHerbert Xu
This restores the previously removed netif_poll_enable call in e1000_open. It's needed on all but the first call to e1000_open for a NIC as e1000_close always calls netif_poll_disable. netif_poll_enable can only be called safely if no polls have been scheduled. This should be the case as long as we don't enter our IRQ handler. In order to guarantee this we explicitly disable IRQs as early as possible when we're probing the NIC. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: "Kok, Auke" <auke-jan.h.kok@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-21e1000: Don't enable polling in open() (was: e1000: assertion hit in ↵Auke Kok
e1000_clean(), kernel 2.6.21.1) Herbert Xu wrote: "netif_poll_enable can only be called if you've previously called netif_poll_disable. Otherwise a poll might already be in action and you may get a crash like this." Removing the call to netif_poll_enable in e1000_open should fix this issue, the only other call to netif_poll_enable is in e1000_up() which is only reached after a device reset or resume. Bugzilla: http://bugzilla.kernel.org/show_bug.cgi?id=8455 https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=240339 Tested by Doug Chapman <doug.chapman@hp.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-17e1000: Fix msi enable leak on error, don't print error message, cleanupAuke Kok
pci_enable_msi failure is a normal event so we should not print any error. Going over the code I spotted a missing pci_disable_msi() leak when irq allocation fails. The whole code also needed a cleanup, so I combined the two different calls to pci_request_irq into a single call making this look a lot better. All #ifdef CONFIG_PCI_MSI's have been removed. Compile tested with both CONFIG_PCI_MSI enabled and disabled. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09unify flush_work/flush_work_keventd and rename it to cancel_work_syncOleg Nesterov
flush_work(wq, work) doesn't need the first parameter, we can use cwq->wq (this was possible from the very beginnig, I missed this). So we can unify flush_work_keventd and flush_work. Also, rename flush_work() to cancel_work_sync() and fix all callers. Perhaps this is not the best name, but "flush_work" is really bad. (akpm: this is why the earlier patches bypassed maintainers) Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Auke Kok <auke-jan.h.kok@intel.com>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09e1000: use flush_work_keventd()Andrew Morton
Switch e1000 over to flush_work_keventd(). This probably fixes a netdev-close versus linkwatch rtnl_lock() deadlock which nobody knew about. (akpm: bypassed maintainers, sorry. There are other patches which depend on this) Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Acked-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-28e1000: ROUND_UP macro cleanup in drivers/net/e1000Milind Arun Choudhary
E1000_ROUNDUP macro cleanup, use ALIGN Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28e1000: Use kcalloc()Yan Burman
Replace kmalloc+memsetout the driver. Slightly modified by Auke Kok. Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28e1000: Use ARRAY_SIZE macro when appropriateAhmed S. Darwish
A patch to use ARRAY_SIZE macro already defined in kernel.h. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28user of the jiffies rounding code: e1000Arjan van de Ven
Use the round_jiffies() function in e1000. These timers all were of the "about once a second" or "about once every X seconds" variety and several showed up in the "what wakes the cpu up" profiles that the tickless patches provide. Some timers are highly dynamic based on network load; but even on low activity systems they still show up so the rounding is done only in cases of low activity, allowing higher frequency timers in the high activity case. The various hardware watchdogs are an obvious case; they run every 2 seconds but aren't otherwise specific of exactly when they need to run. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-27Merge branch 'e1000-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'e1000-fixes' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: e1000: FIX: Stop raw interrupts disabled nag from RT e1000: FIX: firmware handover bits e1000: FIX: be ready for incoming irq at pci_request_irq
