The eHEA driver uses the recently modified walk_memory_resource for powerpc
functionality to detect the memory layout. It further uses the memory hotplug
notifiers to catch memory hotplug events.
Signed-off-by: Hannes Hering <hering2@de.ibm.com>
drivers/net/ehea/ehea_main.c
drivers/net/wireless/iwlwifi/Kconfig
drivers/net/wireless/rt2x00/rt61pci.c
net/ipv4/inet_timewait_sock.c
net/ipv6/raw.c
net/mac80211/ieee80211_sta.c
This patch fixes two weaknesses in send/receive packet handling which may
lead to kernel panics during DLPAR memory add operations.
Signed-off-by: Thomas Klein <tklein@de.ibm.com>
Convert the port_lock to a mutex. There is also some additional cleanup. The
line length inside the ehea_rereg_mrs was getting long so I made some
adjustments to shorten them.
[akpm@linux-foundation.org: dec99ification]
Signed-off-by: Daniel Walker <dwalker@mvista.com>
Cc: Christoph Raisch <raisch@de.ibm.com>
Cc: Jan-Bernd Themann <themann@de.ibm.com>
Cc: Thomas Klein <tklein@de.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Convert the ehea_bcmc_regs.lock to a mutex.
Converted the ehea_fw_handles.lock to a mutex.
Indicate that HEA calculates IPv4 checksums only
This patch adds kdump support to the ehea driver. As the firmware doesn't free
resource handles automatically, the driver has to run an as simple as possible
free resource function in case of a crash shutdown. The function iterates over
two arrays freeing all resource handles which are stored there. The arrays are
kept up-to-date during normal runtime. The crash handler fn is triggered by the
recently introduced PPC crash shutdown reg/unreg functions.
Signed-off-by: Doug Maxey <dwm@austin.ibm.com>
Prevent driver from brawly logging packet checksum errors.
Using own tx_packets counter instead of firmware counters.
eHEA resources that are allocated via H_CALLs have a unique identifier each.
These identifiers are necessary to free the resources. A reboot notifier
is used to free all eHEA resources before the indentifiers get lost, i.e
before kexec starts a new kernel.
Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com>
napi_disable / napi_enable must be applied on all ehea queues.
eHEA drivers
Replace struct ibmebus_dev and struct ibmebus_driver with struct of_device
and struct of_platform_driver, respectively. Match the external ibmebus
interface and drivers using it.
Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com>
Acked-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
eHEA recovery and DLPAR functions are called seldomly. The eHEA workqueues
are replaced by the kernel event queue.
Due to stability issues in high load situations the HW queue handling
has to be changed. The HW queues are now stopped and restarted again instead
of destroying and allocating new HW queues.
Several devices have multiple independant RX queues per net
device, and some have a single interrupt doorbell for several
queues.
In either case, it's easier to support layouts like that if the
structure representing the poll is independant from the net
device itself.
The signature of the ->poll() call back goes from:
int foo_poll(struct net_device *dev, int *budget)
to
int foo_poll(struct napi_struct *napi, int budget)
The caller is returned the number of RX packets processed (or
the number of "NAPI credits" consumed if you want to get
abstract). The callee no longer messes around bumping
dev->quota, *budget, etc. because that is all handled in the
caller upon return.
The napi_struct is to be embedded in the device driver private data
structures.
Furthermore, it is the driver's responsibility to disable all NAPI
instances in it's ->stop() device close handler. Since the
napi_struct is privatized into the driver's private data structures,
only the driver knows how to get at all of the napi_struct instances
it may have per-device.
With lots of help and suggestions from Rusty Russell, Roland Dreier,
Michael Chan, Jeff Garzik, and Jamal Hadi Salim.
Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra,
Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan.
[ Ported to current tree and all drivers converted. Integrated
Stephen's follow-on kerneldoc additions, and restored poll_list
handling to the old style to fix mutual exclusion issues. -DaveM ]
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Introduces a module parameter to decide whether the physical
port link state is propagated to the network stack or not.
It makes sense not to take the physical port state into account
on machines with more logical partitions that communicate
with each other. This is always possible no matter what the physical
port state is. Thus eHEA can be considered as a switch there.
Fix: Workqueue ehea_driver_wq was not destroyed
net_poll support for eHEA added
The driver didn't allow an interface's MAC address to be modified if the
respective interface wasn't setup - a failing Hcall was the result. Thus
bonding wasn't usable. The fix moves the failing Hcall which was registering
a MAC address for the reception of BC packets in firmware from the port up
and down functions to the port resources setup functions. Additionally the
missing update of the last_rx member of the netdev structure was added.
This patch adds support for DLPAR memory add to the eHEA driver. To detect
whether memory was added the driver uses its own memory mapping table and
checks for kernel addresses whether they're located in already known memory
sections. If not the function ehea_rereg_mrs() is triggered which performs
a rebuild of the mapping table and a re-registration of the global memory
region.
This patch introduces a capability flag that is used by the DLPAR userspace
tool to check which DLPAR features are supported by the eHEA driver.
Missing goto has been included.
This patch fixes several whitespace issues.
This patch fixes a possible kernel panic due to not checking the vlan group
when processing received VLAN packets and a malfunction in VLAN/hypervisor
registration.
Must access the respective queue's dummy netdev instead of the port's netdev.
Certain resources may only be allocated when first logical port is available,
and must be removed when last logical port has been removed.
Create symbolic link from each logical port to ehea driver
This patch includes:
- removal of unused fields in structs
- ethtool statistics cleanup
- removes unsed functionality from send path
- code cleanup related to resource management
- extended error data gathering for resource management
- removing trailing whitespaces
The patch fixes bugs related to the probe / remove adapter
functionality (handling of OFDT nodes)
This patch provides a functionality that allows parallel
RX processing on multiple RX queues by using dummy netdevices.
This patch introduces functionality to dynamically add / remove
ehea ports via an userspace DLPAR tool. It creates a subnode for
each logical port in the sysfs.
Error recovery for QP errors: Reset QPs and dump error information
This patch fixes the wrong query and logging of the per interface jumbo frames
enabled/disabled status.
Not only check the pointer against 0 but also the dereferenced value
Removed define H_CB_ALIGNMENT which is already defined in include/asm-powerpc/hvcall.h
This patch includes a bug fix for the port state notification
and fixes the default queue sizes.
Hi Jeff,
sorry to bother you again. We figured out that the readq function we
included in the eHEA patch we sent yesterday to access eHEA registers
is defined as little endian on POWER. This collides with our adapter.
We talked to some PPC people who told us there is a discussion going
on about new access functions. We were told to use __raw_readq /
__raw_writeq for now.
This patch fixes this bug found by our internal tests today.
Please apply this small patch on the latest patch we sent you yesterday.
If it is easier for you I can also give you the entire eHEA patch again.
sorry and thanks a lot,
Jan-Bernd
drivers/net/ehea/ehea.h | 2 +-
drivers/net/ehea/ehea_hw.h | 11 ++++++++---
2 files changed, 9 insertions(+), 4 deletions(-)
Hi Jeff,
I fixed the __iomem issue and tested the driver with sparse. Looks good so far.
Thanks for your effort.
Jan-Bernd Themann
drivers/net/Kconfig | 9
drivers/net/Makefile | 1
drivers/net/ehea/Makefile | 6
drivers/net/ehea/ehea.h | 447 ++++++
drivers/net/ehea/ehea_ethtool.c | 294 ++++
drivers/net/ehea/ehea_hcall.h | 51
drivers/net/ehea/ehea_hw.h | 287 ++++
drivers/net/ehea/ehea_main.c | 2654 ++++++++++++++++++++++++++++++++++++++++
drivers/net/ehea/ehea_phyp.c | 705 ++++++++++
drivers/net/ehea/ehea_phyp.h | 455 ++++++
drivers/net/ehea/ehea_qmr.c | 582 ++++++++
drivers/net/ehea/ehea_qmr.h | 358 +++++
12 files changed, 5849 insertions(+)
