path: root/drivers/net/ehea
2011-08-11ehea/ibm*: Move the IBM driversJeff Kirsher
Move the IBM drivers into drivers/net/ethernet/ibm/ and make the necessary Kconfig and Makefile changes. - Renamed ibm_new_emac to emac - Cleaned up Makefile and Kconfig options which referred to IBM_NEW_EMAC to IBM_EMAC - ibmlana driver is a National Semiconductor SONIC driver so it was not moved CC: Christoph Raisch <raisch@de.ibm.com> CC: Santiago Leon <santil@linux.vnet.ibm.com> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: David Gibson <dwg@au1.ibm.com> CC: Kyle Lucke <klucke@us.ibm.com> CC: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-21ehea: do vlan cleanupJiri Pirko
- unify vlan and nonvlan rx path - kill port->vgrp and ehea_vlan_rx_register Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21drivers/net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script (and a little editing): $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Acked-By: Chris Snook <chris.snook@gmail.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David Dillow <dave@thedillows.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23ehea: Fix multicast registration on semi-promiscuous modeBreno Leitao
Ehea will not register multicast groups in phyp if the physical interface is in promiscuous mode. But it should register if the logical port is in promiscuous mode, but the physical port is not. Ehea physical promiscuous mode is defined by ehea_port->promisc, while logical port is defined by IFF_PROMISC. So currently, if the user set the interface in promiscuous mode, IGMP will not be registred in PHYP, and PHYP will never pass the multicast packet to the logical port, which is bad So, this patch just fixes it, assuring that we register in phyp if the physical port is not on promiscuous mode. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
2011-05-12ehea: Fix memory hotplug oopsAnton Blanchard
The ehea driver oopses during memory hotplug if the ports are not up. A simple testcase: # ifconfig ethX down # echo offline > /sys/devices/system/memory/memory32/state Oops: Kernel access of bad area, sig: 11 [#1] last sysfs file: /sys/devices/system/memory/memory32/state REGS: c000000709393110 TRAP: 0300 Not tainted (2.6.39-rc2-01385-g7ef73bc-dirty) DAR: 0000000000000000, DSISR: 40000000 ... NIP [c000000000067c98] .__wake_up_common+0x48/0xf0 LR [c00000000006d034] .__wake_up+0x54/0x90 Call Trace: [c00000000006d034] .__wake_up+0x54/0x90 [d000000006bb6270] .ehea_rereg_mrs+0x140/0x730 [ehea] [d000000006bb69c4] .ehea_mem_notifier+0x164/0x170 [ehea] [c0000000006fc8a8] .notifier_call_chain+0x78/0xf0 [c0000000000b3d70] .__blocking_notifier_call_chain+0x70/0xb0 [c000000000458d78] .memory_notify+0x28/0x40 [c0000000001871d8] .remove_memory+0x208/0x6d0 [c000000000458264] .memory_section_action+0x94/0x140 [c0000000004583ec] .memory_block_change_state+0xdc/0x1d0 [c0000000004585cc] .store_mem_state+0xec/0x160 [c00000000044768c] .sysdev_store+0x3c/0x50 [c00000000020b48c] .sysfs_write_file+0xec/0x1f0 [c00000000018f86c] .vfs_write+0xec/0x1e0 [c00000000018fa88] .SyS_write+0x58/0xd0 To fix this, initialise the waitqueues during port probe instead of port open. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@kernel.org Acked-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6 Conflicts: drivers/net/benet/be_main.c
2011-05-09ehea: fix wrongly reported speed and portKleber Sacilotto de Souza
Currently EHEA reports to ethtool as supporting 10M, 100M, 1G and 10G and connected to FIBRE independent of the hardware configuration. However, when connected to FIBRE the only supported speed is 10G full-duplex, and the other speeds and modes are only supported when connected to twisted pair. Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com> Acked-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Resolved logic conflicts causing a build failure due to drivers/net/r8169.c changes using a patch from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20ehea: Fix a DLPAR bug on ehea_rereg_mrs().Breno Leitao
We are currently continuing if ehea_restart_qps() fails, when we do a memory DLPAR (remove or add more memory to the system). This patch just let the NAPI disabled if the ehea_restart_qps() fails. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17net: ehea: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11ehea: Increase the skb array usageBreno Leitao
Currently the skb array is not fully allocated, and the allocation is done as it's requested, which is not the expected way. This patch just allocate the full skb array at driver initialization. Also, this patch increases ehea version to 107. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-04Merge branch 'master' of ↵David S. Miller
2010-12-28ehea: Avoid changing vlan flagsBreno Leitao
This patch avoids disabling the vlan flags using ethtool. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-20ehea: Fixing some message levelBreno Leitao
Currently there are some info message that is set as error, and an error message that is set as debug. This patch just fixes it. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-13ehea: Use the standard logging functionsJoe Perches
Remove ehea_error, ehea_info and ehea_debug macros. Use pr_fmt, pr_<level>, netdev_<level> and netif_<level> as appropriate. Fix messages to use trailing "\n", some messages had an extra one as the old ehea_<level> macros added a trailing "\n". Coalesced long format strings. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12ehea: don't use flush_scheduled_work()Tejun Heo
Directly cancel port->reset_task from ehea_shutdown_single_port() instead. As this cancels the work for each port on driver detach, flushing system_wq from ehea_remove() or ehea_module_exit() is no longer necessary. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Breno Leitao <leitao@linux.vnet.ibm.com> Cc: netdev@vger.kernel.org
2010-12-12ehea: kill unused ehea_rereg_mr_taskTejun Heo
ehea_rereg_mr_task is not used. Remove it and drop @work parameter from ehea_rereg_mrs(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Breno Leitao <leitao@linux.vnet.ibm.com> Cc: netdev@vger.kernel.org
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-12-08ehea: Fixing LRO configurationBreno Leitao
In order to set LRO on ehea, the user must set a module parameter, which is not the standard way to do so. This patch adds a way to set LRO using the ethtool tool. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06Revert "ehea: Use the standard logging functions"David S. Miller
This reverts commit 539995d18649023199986424d140f1d620372ce5. As reported by Stephen Rothwell, this breaks the build. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06ehea: Use the standard logging functionsJoe Perches
Remove ehea_error, ehea_info and ehea_debug macros. Use pr_fmt, pr_<level>, netdev_<level> and netif_<level> as appropriate. Fix messages to use trailing "\n", some messages had an extra one as the old ehea_<level> macros added a trailing "\n". Coalesced long format strings. Uncompiled/untested. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Breno Leitao<leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ehea: Add some info messages and fix an issueBreno Leitao
This patch adds some debug information about ehea not being able to allocate enough spaces. Also it correctly updates the amount of available skb. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27drivers/net: use vzalloc()Eric Dumazet
Use vzalloc() and vzalloc_node() in net drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27ehea: Fixing statisticsBreno Leitao
(Applied over Eric's "ehea: fix use after free" patch) Currently ehea stats are broken. The bytes counters are got from the hardware, while the packets counters are got from the device driver. Also, the device driver counters are resetted during the the down process, and the hardware aren't, causing some weird numbers. This patch just consolidates the packets and bytes on the device driver. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27ehea: fix use after freeEric Dumazet
ehea_start_xmit() dereferences skb after its freeing in ehea_xmit3() to get vlan tags. Move the offending block before the potential ehea_xmit3() call. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13ehea: Fix a checksum issue on the receive pathBreno Leitao
Currently we set all skbs with CHECKSUM_UNNECESSARY, even those whose protocol we don't know. This patch just add the CHECKSUM_COMPLETE tag for non TCP/UDP packets. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-09ehea: simplify conditionalNicolas Kaiser
Simplify: ((a && b) || (!a && !b)) => (a == b) Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Acked-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05ehea: converting msleeps to waitqueue on check_sqs() functionBreno Leitao
Removing the msleep() call in check_sqs() function, and replacing by a wait queue. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05ehea: using wait queues instead of msleep on ehea_flush_sqBreno Leitao
This patch just remove a msleep loop and change to wait queue, making the code cleaner. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ehea: Remove a silly returnBreno Leitao
This patch removes the unconditional return in the end of the function check_sqs() Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) netfilter: fix CONFIG_COMPAT support isdn/avm: fix build when PCMCIA is not enabled header: fix broken headers for user space e1000e: don't check for alternate MAC addr on parts that don't support it e1000e: disable ASPM L1 on 82573 ll_temac: Fix poll implementation netxen: fix a race in netxen_nic_get_stats() qlnic: fix a race in qlcnic_get_stats() irda: fix a race in irlan_eth_xmit() net: sh_eth: remove unused variable netxen: update version 4.0.74 netxen: fix inconsistent lock state vlan: Match underlying dev carrier on vlan add ibmveth: Fix opps during MTU change on an active device ehea: Fix synchronization between HW and SW send queue bnx2x: Update bnx2x version to 1.52.53-4 bnx2x: Fix PHY locking problem rds: fix a leak of kernel memory netlink: fix compat recvmsg netfilter: fix userspace header warning ...
2010-08-21Merge branch 'master' of ↵David S. Miller
2010-08-18ehea: Fix synchronization between HW and SW send queueAndre Detsch
ehea: Fix synchronization between HW and SW send queue When memory is added to / removed from a partition via the Memory DLPAR mechanism, the eHEA driver has to do a couple of things to reflect the memory change in its own IO address translation tables. This involves stopping and restarting the HW queues. During this operation, it is possible that HW and SW pointer into these queues get out of sync. This results in a situation where packets that are attached to a send queue are not transmitted immediately, but delayed until further X packets have been put on the queue. This patch detects such loss of synchronization, and resets the ehea port when needed. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Andre Detsch <adetsch@br.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17drivers/net: Convert unbounded kzalloc calls to kcallocJoe Perches
These changes may be slightly safer in some instances. There are other kzalloc calls with a multiply, but those calls are typically "small fixed #" * sizeof(some pointer)" and those are not converted. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-07-01ehea: Allocate stats buffer with GFP_KERNELBrian King
Since ehea_get_stats calls ehea_h_query_ehea_port, which can sleep, we can also sleep when allocating a page in this function. This fixes some memory allocation failure warnings seen under low memory conditions. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/ip_output.c
2010-06-16ehea: Fix kernel deadlock in DLPAR-mem processingJan-Bernd Themann
Port reset operations and memory add/remove operations need to be serialized to avoid a kernel deadlock. The deadlock is caused by calling the napi_disable() function twice. Therefore we have to employ the dlpar_mem_lock in the ehea_reset_port function as well Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16ehea: fix delayed packet processingJan-Bernd Themann
In the eHEA poll function an rmb() is required. Without that some packets on the receive queue are not seen and thus delayed until the next interrupt is handled for the same receive queue. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
