(Applied over Eric's "ehea: fix use after free" patch)
Currently ehea stats are broken. The bytes counters are got from
the hardware, while the packets counters are got from the device
driver. Also, the device driver counters are resetted during the
the down process, and the hardware aren't, causing some weird
numbers.
This patch just consolidates the packets and bytes on the device
driver.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
ehea_start_xmit() dereferences skb after its freeing in ehea_xmit3() to
get vlan tags.
Move the offending block before the potential ehea_xmit3() call.
net/core/dev.c
Many (but not all) drivers check to see whether there is a vlan
group configured before using a tag stored in the skb. There's
not much point in this check since it just throws away data that
should only be present in the expected circumstances. However,
it will soon be legal and expected to get a vlan tag when no
vlan group is configured, so remove this check from all drivers
to avoid dropping the tags.
Signed-off-by: Jesse Gross <jesse@nicira.com>
Currently we set all skbs with CHECKSUM_UNNECESSARY, even
those whose protocol we don't know. This patch just
add the CHECKSUM_COMPLETE tag for non TCP/UDP packets.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Simplify: ((a && b) || (!a && !b)) => (a == b)
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Acked-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Removing the msleep() call in check_sqs() function, and replacing by a wait queue.
This patch just remove a msleep loop and change to wait queue,
making the code cleaner.
This patch removes the unconditional return in the end of the
function check_sqs()
"foo = &function" is more commonly written "foo = function"
Done with coccinelle script:
// <smpl>
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
// </smpl>
drivers/net/tehuti.c used a function and struct with the
same name, the function was renamed.
Compile tested x86 only.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
netfilter: fix CONFIG_COMPAT support
isdn/avm: fix build when PCMCIA is not enabled
header: fix broken headers for user space
e1000e: don't check for alternate MAC addr on parts that don't support it
e1000e: disable ASPM L1 on 82573
ll_temac: Fix poll implementation
netxen: fix a race in netxen_nic_get_stats()
qlnic: fix a race in qlcnic_get_stats()
irda: fix a race in irlan_eth_xmit()
net: sh_eth: remove unused variable
netxen: update version 4.0.74
netxen: fix inconsistent lock state
vlan: Match underlying dev carrier on vlan add
ibmveth: Fix opps during MTU change on an active device
ehea: Fix synchronization between HW and SW send queue
bnx2x: Update bnx2x version to 1.52.53-4
bnx2x: Fix PHY locking problem
rds: fix a leak of kernel memory
netlink: fix compat recvmsg
netfilter: fix userspace header warning
When memory is added to / removed from a partition via the Memory DLPAR
mechanism, the eHEA driver has to do a couple of things to reflect the
memory change in its own IO address translation tables. This involves
stopping and restarting the HW queues.
During this operation, it is possible that HW and SW pointer into these
queues get out of sync. This results in a situation where packets that
are attached to a send queue are not transmitted immediately, but
delayed until further X packets have been put on the queue.
This patch detects such loss of synchronization, and resets the ehea
port when needed.
Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com>
Signed-off-by: Andre Detsch <adetsch@br.ibm.com>
These changes may be slightly safer in some instances.
There are other kzalloc calls with a multiply, but those
calls are typically "small fixed #" * sizeof(some pointer)"
and those are not converted.
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Luciano Coelho <luciano.coelho@nokia.com>
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
Since ehea_get_stats calls ehea_h_query_ehea_port, which
can sleep, we can also sleep when allocating a page in
this function. This fixes some memory allocation failure
warnings seen under low memory conditions.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
net/ipv4/ip_output.c
Port reset operations and memory add/remove operations need to
be serialized to avoid a kernel deadlock. The deadlock is caused
by calling the napi_disable() function twice.
Therefore we have to employ the dlpar_mem_lock in the ehea_reset_port
function as well
In the eHEA poll function an rmb() is required. Without that some packets
on the receive queue are not seen and thus delayed until the next interrupt
is handled for the same receive queue.
cleanup patch.
Use new __packed annotation in drivers/net/
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
The following structure elements duplicate the information in
'struct device.of_node' and so are being eliminated. This patch
makes all readers of these elements use device.of_node instead.
(struct of_device *)->node
(struct dev_archdata *)->prom_node (sparc)
(struct dev_archdata *)->of_node (powerpc & microblaze)
switch and while statements don't need semicolons at end of statement
[ Fixup minor conflicts with recent wimax merge... -DaveM ]
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
Force serialization of userspace-triggered DLPAR/mem operations
Signed-off-by: Thomas Klein <tklein@de.ibm.com>
Reset a port's resources only if they're actually in an error state
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb)
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (151 commits)
powerpc: Fix usage of 64-bit instruction in 32-bit altivec code
MAINTAINERS: Add PowerPC patterns
powerpc/pseries: Track previous CPPR values to correctly EOI interrupts
powerpc/pseries: Correct pseries/dlpar.c build break without CONFIG_SMP
powerpc: Make "intspec" pointers in irq_host->xlate() const
powerpc/8xx: DTLB Miss cleanup
powerpc/8xx: Remove DIRTY pte handling in DTLB Error.
powerpc/8xx: Start using dcbX instructions in various copy routines
powerpc/8xx: Restore _PAGE_WRITETHRU
powerpc/8xx: Add missing Guarded setting in DTLB Error.
powerpc/8xx: Fixup DAR from buggy dcbX instructions.
powerpc/8xx: Tag DAR with 0x00f0 to catch buggy instructions.
powerpc/8xx: Update TLB asm so it behaves as linux mm expects.
powerpc/8xx: Invalidate non present TLBs
powerpc/pseries: Serialize cpu hotplug operations during deactivate Vs deallocate
pseries/pseries: Add code to online/offline CPUs of a DLPAR node
powerpc: stop_this_cpu: remove the cpu from the online map.
powerpc/pseries: Add kernel based CPU DLPAR handling
sysfs/cpu: Add probe/release files
powerpc/pseries: Kernel DLPAR Infrastructure
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
include/linux/kvm.h
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
Move ehea hcall definitions into hvcall.h.
Acked-by: Thomas Klein <tklein@de.ibm.com>
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/cpc-usb/TODO
drivers/staging/cpc-usb/cpc-usb_drv.c
drivers/staging/cpc-usb/cpc.h
drivers/staging/cpc-usb/cpc_int.h
drivers/staging/cpc-usb/cpcusb.h
Originally, walk_memory_resource() was introduced to traverse all memory
of "System RAM" for detecting memory hotplug/unplug range. For doing so,
flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for
memory hotplug.
But for using other purpose, /proc/kcore, this may includes some firmware
area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the
check strict to find out busy "System RAM".
Note: PPC64 keeps their own walk_memory_resouce(), which walk through
ppc64's lmb informaton. Because old kclist_add() is called per lmb, this
patch makes no difference in behavior, finally.
And this patch removes CONFIG_MEMORY_HOTPLUG check from this function.
Because pfn_valid() just show "there is memmap or not* and cannot be used
for "there is physical memory or not", this function is useful in generic
to scan physical memory range.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
The definitions of vnet_ops and ehea_netdev_ops have initializations of a
local function and eth_change_mtu for their respective ndo_change_mtu
fields. This change uses only the local function.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
identifier I, s, fld;
position p0,p;
expression E;
struct I s =@p0 { ... .fld@p = E, ...};
@s@
identifier I, s, r.fld;
position r.p0,p;
expression E;
@script:python@
p0 << r.p0;
fld << r.fld;
ps << s.p;
pr << r.p;
if int(ps[0].line)!=int(pr[0].line) or int(ps[0].column)!=int(pr[0].column):
cocci.print_main(fld,p0)
// </smpl>
This patch fixes the napi list handling when an ehea interface is shut
down to avoid corruption of the napi list.
Signed-off-by: Hannes Hering <hering2@de.ibm.com>
alloc_etherdev() used to install a default implementation of this
operation, but it must now be explicitly installed in struct
net_device_ops.
alloc_etherdev() used to install default implementations of these
operations, but they must now be explicitly installed in struct
net_device_ops.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
documentation and source comments.
Signed-off-by: Martin Olsson <martin@minimum.se>
include/net/tcp.h
