path: root/drivers/net/ehea
2007-06-09ehea: Fixed possible kernel panic on VLAN packet recvThomas Klein
This patch fixes a possible kernel panic due to not checking the vlan group when processing received VLAN packets and a malfunction in VLAN/hypervisor registration. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-30ehea: Fixed multi queue RX bugThomas Klein
Must access the respective queue's dummy netdev instead of the port's netdev. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (40 commits) [netdrvr] atl1: fix build pasemi_mac: Use local-mac-address instead of mac-address if available pasemi_mac: PHY support pasemi_mac: Add msglevel support and "debug" module param pasemi_mac: Logic cleanup / rx performance improvements pasemi_mac: Minor cleanup / define fixes pasemi_mac: Add SKB reuse / copy-break pasemi_mac: Timer and interrupt fixes pasemi_mac: Abstract and fix up interrupt restart routines pasemi_mac: Move the IRQ mapping from the PCI layer to the driver tc35815: Remove unnecessary skb->dev assignment drivers/net/dm9000: Convert to generic boolean AT91RM9200 Ethernet: Fix multicast addressing AT91RM9200 Ethernet: Support additional PHYs PCMCIA-NETDEV : xirc2ps_cs: bugfix of multicast code sky2: re-enable 88E8056 for most motherboards MIPS: Drop unnecessary CONFIG_ISA from RBTX49XX ne: MIPS: Use platform_driver for ne on RBTX49XX ne: Add NEEDS_PORTLIST to control ISA auto-probe ne: Misc fixes for platform driver. ... Fix conflict in drivers/net/pasemi_mac.c (get_property() got renamed to of_get_property()) manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ehea: Fix skb header accessThomas Klein
Adapt to new skb header access functions. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-02[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
These are all the remaining instances of get_property. Simple rename of get_property to of_get_property. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] get_property returns constStephen Rothwell
This is the last place that needs changing since get_property was changed to return "const void *". Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-28ehea: fix for dlpar supportThomas Klein
Certain resources may only be allocated when first logical port is available, and must be removed when last logical port has been removed. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: fix for sysfs entriesThomas Klein
Create symbolic link from each logical port to ehea driver Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: removing unused functionalityJan-Bernd Themann
This patch includes: - removal of unused fields in structs - ethtool statistics cleanup - removes unsed functionality from send path Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28strlcpy is smart enoughJean Delvare
strlcpy already accounts for the trailing zero in its length computation, so there is no need to substract one to the buffer size. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jan-Bernd Themann <themann@de.ibm.com> Cc: Thomas Klein <osstklei@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: code cleanupJan-Bernd Themann
This patch includes: - code cleanup related to resource management - extended error data gathering for resource management - removing trailing whitespaces Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: fix for dynamic lpar supportJan-Bernd Themann
The patch fixes bugs related to the probe / remove adapter functionality (handling of OFDT nodes) Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: NAPI multi queue TX/RX path for SMPJan-Bernd Themann
This patch provides a functionality that allows parallel RX processing on multiple RX queues by using dummy netdevices. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: dynamic add / remove portJan-Bernd Themann
This patch introduces functionality to dynamically add / remove ehea ports via an userspace DLPAR tool. It creates a subnode for each logical port in the sysfs. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[TCP]: Introduce tcp_hdrlen() and tcp_optlen()Arnaldo Carvalho de Melo
The ip_hdrlen() buddy, created to reduce the number of skb->h.th-> uses and to avoid the longer, open coded equivalent. Ditched a no-op in bnx2 in the process. I wonder if we should have a BUG_ON(skb->h.th->doff < 5) in tcp_optlen()... Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[IP]: Introduce ip_hdrlen()Arnaldo Carvalho de Melo
For the common sequence "skb->nh.iph->ihl * 4", removing a good number of open coded skb->nh.iph uses, now to go after the rest... Just out of curiosity, here are the idioms found to get the same result: skb->nh.iph->ihl << 2 skb->nh.iph->ihl<<2 skb->nh.iph->ihl * 4 skb->nh.iph->ihl*4 (skb->nh.iph)->ihl * sizeof(u32) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[VLAN]: Avoid a 4-order allocation.Dan Aloni
This patch splits the vlan_group struct into a multi-allocated struct. On x86_64, the size of the original struct is a little more than 32KB, causing a 4-order allocation, which is prune to problems caused by buddy-system external fragmentation conditions. I couldn't just use vmalloc() because vfree() cannot be called in the softirq context of the RCU callback. Signed-off-by: Dan Aloni <da-x@monatomic.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17Merge branch 'master' into upstreamJeff Garzik
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09ehea: Fixed error recoveryJan-Bernd Themann
Error recovery for QP errors: Reset QPs and dump error information Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30ehea: Fixed missing tasklet_kill() callThomas Klein
NEQ-Tasklet wasn't killed when module is removed. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30ehea: Fixed wrong jumbo frames status queryThomas Klein
This patch fixes the wrong query and logging of the per interface jumbo frames enabled/disabled status. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: Fixed possible nullpointer accessThomas Klein
Fixed possible nullpointer access in event queue processing Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: Added logging off associated errorsThomas Klein
Added logging of error events associated with a specific queue pair Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: Improved logging of permission issuesThomas Klein
Disabled dump of hcall regs on some permission issues and fixed appropriate misleading logmessages Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: New method to determine number of available portsThomas Klein
Count OFDT nodes to determine the number of available ports instead of using the possibly outdated value from the hypervisor Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: Modified initial autoneg state determinationThomas Klein
Logical partitions are not allowed to (try to) set the autonegotiation status. This patch removes the respective function call from the port setup function. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: Fixing firmware queue config issueThomas Klein
Fix to use exactly one queue for incoming packets in all firmware configurations Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23ehea: Fixed wrong dereferencationThomas Klein
Not only check the pointer against 0 but also the dereferenced value Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] severing skbuff.h -> mm.hAl Viro
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-06[PATCH] ehea: 64K page support fixThomas Klein
This patch fixes 64k page support by using PAGE_MASK and appropriate pagesize defines in several places. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-06[PATCH] ehea: Removed redundant defineThomas Klein
Removed define H_CB_ALIGNMENT which is already defined in include/asm-powerpc/hvcall.h Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-06[PATCH] ehea: Nullpointer dereferencation fixThomas Klein
Fix: Must check for nullpointer before dereferencing it - not afterwards. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-31[PATCH] ehea: kzalloc GFP_ATOMIC fixJan-Bernd Themann
This patch fixes kzalloc parameters (GFP_ATOMIC instead of GFP_KERNEL) Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-11[PATCH] ehea: fix port state notification, default queue sizesJan-Bernd Themann
This patch includes a bug fix for the port state notification and fixes the default queue sizes. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-11[PATCH] ehea: firmware (hvcall) interface changesJan-Bernd Themann
This eHEA patch covers required changes related to Anton Blanchard's new hvcall interface. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-19[PATCH] ehea: bugfix for register access functionsJan-Bernd Themann
Hi Jeff, sorry to bother you again. We figured out that the readq function we included in the eHEA patch we sent yesterday to access eHEA registers is defined as little endian on POWER. This collides with our adapter. We talked to some PPC people who told us there is a discussion going on about new access functions. We were told to use __raw_readq / __raw_writeq for now. This patch fixes this bug found by our internal tests today. Please apply this small patch on the latest patch we sent you yesterday. If it is easier for you I can also give you the entire eHEA patch again. sorry and thanks a lot, Jan-Bernd Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> drivers/net/ehea/ehea.h | 2 +- drivers/net/ehea/ehea_hw.h | 11 ++++++++--- 2 files changed, 9 insertions(+), 4 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-13[PATCH] ehea: IBM eHEA Ethernet Device DriverJan-Bernd Themann
Hi Jeff, I fixed the __iomem issue and tested the driver with sparse. Looks good so far. Thanks for your effort. Jan-Bernd Themann Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> drivers/net/Kconfig | 9 drivers/net/Makefile | 1 drivers/net/ehea/Makefile | 6 drivers/net/ehea/ehea.h | 447 ++++++ drivers/net/ehea/ehea_ethtool.c | 294 ++++ drivers/net/ehea/ehea_hcall.h | 51 drivers/net/ehea/ehea_hw.h | 287 ++++ drivers/net/ehea/ehea_main.c | 2654 ++++++++++++++++++++++++++++++++++++++++ drivers/net/ehea/ehea_phyp.c | 705 ++++++++++ drivers/net/ehea/ehea_phyp.h | 455 ++++++ drivers/net/ehea/ehea_qmr.c | 582 ++++++++ drivers/net/ehea/ehea_qmr.h | 358 +++++ 12 files changed, 5849 insertions(+) Signed-off-by: Jeff Garzik <jeff@garzik.org>
