path: root/drivers/net/es3210.c
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25es3210: convert to net_device_opsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-09[PATCH] kill eth_io_copy_and_sum()Al Viro
On all targets that sucker boils down to memcpy_fromio(sbk->data, from, len). The function name is highly misguiding (it _never_ does any checksums), the last argument is just a noise and simply expanding the call to memcpy_fromio() gives shorter and more readable source. For a lot of reasons it has almost no remaining users, so it's better to just outright kill it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-08-19[PATCH] es3210 section fixAndrew Morton
WARNING: drivers/net/es3210.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0xdf) and 'es_close' WARNING: drivers/net/es3210.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x100) and 'es_close' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-09[PATCH] fix a few "warning: 'cleanup_card' defined but not used"Denis Vlasenko
These warnings are emitted if non-modular network drivers are built. Fixes just move cleanup_card() definitions into #ifdef MODULE region. /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/wd.c:131: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/3c503.c:152: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ne.c:216: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp.c:106: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp-plus.c:142: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/smc-ultra.c:172: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/e2100.c:144: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/es3210.c:159: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lne390.c:149: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lance.c:313: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ac3200.c:127: warning: 'cleanup_card' defined but not used Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[netdrvr] Fix register_netdev() races in older ISA net drivers
