[ Upstream commit 4a4d2d372fb9b9229327e2ed01d5d9572eddf4de ]
Commit 04f05230c5c13 ("bnx2x: Remove configured vlans as
part of unload sequence."), introduced a regression in driver
that as a part of VF's reload flow, VLANs created on the VF
doesn't get re-configured in hardware as vlan metadata/info
was not getting cleared for the VFs which causes vlan PING to stop.
This patch clears the vlan metadata/info so that VLANs gets
re-configured back in the hardware in VF's reload flow and
PING/traffic continues for VLANs created over the VFs.
Fixes: 04f05230c5c13 ("bnx2x: Remove configured vlans as part of unload sequence.")
Signed-off-by: Manish Chopra <manishc@marvell.com>
Signed-off-by: Sudarsana Kalluru <skalluru@marvell.com>
Signed-off-by: Shahed Shaikh <shshaikh@marvell.com>
[ Upstream commit d1f0b5dce8fda09a7f5f04c1878f181d548e42f5 ]
Commit 3968d38917eb ("bnx2x: Fix Multi-Cos.") which enabled multi-cos
feature after prolonged time in driver added some regression causing
numerous issues (sudden reboots, tx timeout etc.) reported by customers.
We plan to backout this commit and submit proper fix once we have root
cause of issues reported with this feature enabled.
Fixes: 3968d38917eb ("bnx2x: Fix Multi-Cos.")
Signed-off-by: Sudarsana Reddy Kalluru <skalluru@marvell.com>
[ Upstream commit 3c91f25c2f72ba6001775a5932857c1d2131c531 ]
Currently bnx2x ptp worker tries to read a register with timestamp
information in case of TX packet timestamping and in case it fails,
the routine reschedules itself indefinitely. This was reported as a
kworker always at 100% of CPU usage, which was narrowed down to be
bnx2x ptp_task.
By following the ioctl handler, we could narrow down the problem to
an NTP tool (chrony) requesting HW timestamping from bnx2x NIC with
RX filter zeroed; this isn't reproducible for example with ptp4l
(from linuxptp) since this tool requests a supported RX filter.
It seems NIC FW timestamp mechanism cannot work well with
RX_FILTER_NONE - driver's PTP filter init routine skips a register
write to the adapter if there's not a supported filter request.
This patch addresses the problem of bnx2x ptp thread's everlasting
reschedule by retrying the register read 10 times; between the read
attempts the thread sleeps for an increasing amount of time starting
in 1ms to give FW some time to perform the timestamping. If it still
fails after all retries, we bail out in order to prevent an unbound
resource consumption from bnx2x.
The patch also adds an ethtool statistic for accounting the skipped
TX timestamp packets and it reduces the priority of timestamping
error messages to prevent log flooding. The code was tested using
both linuxptp and chrony.
Reported-and-tested-by: Przemyslaw Hausman <przemyslaw.hausman@canonical.com>
Suggested-by: Sudarsana Reddy Kalluru <skalluru@marvell.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@canonical.com>
Acked-by: Sudarsana Reddy Kalluru <skalluru@marvell.com>
[ Upstream commit ea811b795df24644a8eb760b493c43fba4450677 ]
This patch fixes an issue seen on Power systems with bnx2x which results
in the skb is NULL WARN_ON in bnx2x_free_tx_pkt firing due to the skb
pointer getting loaded in bnx2x_free_tx_pkt prior to the hw_cons
load in bnx2x_tx_int. Adding a read memory barrier resolves the issue.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
[ Upstream commit 484c016d9392786ce5c74017c206c706f29f823d ]
Driver performs the internal reload when it receives tx-timeout event from
the OS. Internal reload might fail in some scenarios e.g., fatal HW issues.
In such cases OS still see the link, which would result in undesirable
functionalities such as re-generation of tx-timeouts.
The patch addresses this issue by indicating the link-down to OS when
tx-timeout is detected, and keeping the link in down state till the
internal reload is successful.
Please consider applying it to 'net' branch.
Signed-off-by: Sudarsana Reddy Kalluru <Sudarsana.Kalluru@cavium.com>
Signed-off-by: Ariel Elior <ariel.elior@cavium.com>
[ Upstream commit f7084059a9cb9e56a186e1677b1dcffd76c2cd24 ]
While in recovery process of PCI error (called EEH on PowerPC arch),
another PCI transaction could be corrupted causing a situation of
nested PCI errors. Also, this scenario could be reproduced with
error injection mechanisms (for debug purposes).
We observe that in case of nested PCI errors, bnx2x might attempt to
initialize its shmem and cause a kernel crash due to bad addresses
read from MCP. Multiple different stack traces were observed depending
on the point the second PCI error happens.
This patch avoids the crashes by:
* failing PCI recovery in case of nested errors (since multiple
PCI errors in a row are not expected to lead to a functional
adapter anyway), and by,
* preventing access to adapter FW when MCP is failed (we mark it as
failed when shmem cannot get initialized properly).
Reported-by: Abdul Haleem <abdhalee@linux.vnet.ibm.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
Acked-by: Shahed Shaikh <Shahed.Shaikh@cavium.com>
Get rid of struct tc_to_netdev which is now just unnecessary container
and rather pass per-type structures down to drivers directly.
Along with that, consolidate the naming of per-type structure variables
in cls_*.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
only
Change the return value from -EINVAL to -EOPNOTSUPP. The rest of the
drivers have it like that, so be aligned.
As ndo_setup_tc is generic offload op for whole tc subsystem, does not
really make sense to have cls-specific args. So move them under
cls_common structurure which is embedded in all cls structs.
Since the type is always present, push it to be a separate argument to
ndo_setup_tc. On the way, name the type enum and use it for arg type.
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
VF clients are configured as enforced, meaning firmware is validating
the correctness of their ethertype/vid during transmission.
Once txvlan is disabled, VF would start getting SKBs for transmission
here vlan is on the payload - but it'll pass the packet's ethertype
instead of the vid, leading to firmware declaring it as malicious.
Signed-off-by: Yuval Mintz <Yuval.Mintz@cavium.com>
We need to push the chain index down to the drivers, so they have the
information to which chain the rule belongs. For now, no driver supports
multichain offload, so only chain 0 is supported. This is needed to
prevent chain squashes during offload for now. Later this will be used
to implement multichain offload.
Apparently multi-cos isn't working for bnx2x quite some time -
driver implements ndo_select_queue() to allow queue-selection
for FCoE, but the regular L2 flow would cause it to modulo the
fallback's result by the number of queues.
The fallback would return a queue matching the needed tc
[via __skb_tx_hash()], but since the modulo is by the number of TSS
queues where number of TCs is not accounted, transmission would always
be done by a queue configured into using TC0.
Fixes: ada7c19e6d27 ("bnx2x: use XPS if possible for bnx2x_select_queue instead of pure hash")
The bnx2x driver is not providing proper alignment on the receive buffers it
passes to build_skb(), causing skb_shared_info to be misaligned.
skb_shared_info contains an atomic, and while PPC normally supports
unaligned accesses, it does not support unaligned atomics.
Aligning the size of rx buffers will ensure that page_frag_alloc() returns
aligned addresses.
This can be reproduced on PPC by setting the network MTU to 1450 (or other
non-multiple-of-4) and then generating sufficient inbound network traffic
(one or two large "wget"s usually does it), producing the following oops:
Unable to handle kernel paging request for unaligned access at address 0xc00000ffc43af656
Faulting instruction address: 0xc00000000080ef8c
Oops: Kernel access of bad area, sig: 7 [#1]
SMP NR_CPUS=2048
NUMA
PowerNV
Modules linked in: vmx_crypto powernv_rng rng_core powernv_op_panel leds_powernv led_class nfsd ip_tables x_tables autofs4 xfs lpfc bnx2x mdio libcrc32c crc_t10dif crct10dif_generic crct10dif_common
CPU: 104 PID: 0 Comm: swapper/104 Not tainted 4.11.0-rc8-00088-g4c761da #2
task: c00000ffd4892400 task.stack: c00000ffd4920000
NIP: c00000000080ef8c LR: c00000000080eee8 CTR: c0000000001f8320
REGS: c00000ffffc33710 TRAP: 0600 Not tainted (4.11.0-rc8-00088-g4c761da)
MSR: 9000000000009033 <SF,HV,EE,ME,IR,DR,RI,LE>
CR: 24082042 XER: 00000000
CFAR: c00000000080eea0 DAR: c00000ffc43af656 DSISR: 00000000 SOFTE: 1
GPR00: c000000000907f64 c00000ffffc33990 c000000000dd3b00 c00000ffcaf22100
GPR04: c00000ffcaf22e00 0000000000000000 0000000000000000 0000000000000000
GPR08: 0000000000b80008 c00000ffc43af636 c00000ffc43af656 0000000000000000
GPR12: c0000000001f6f00 c00000000fe1a000 000000000000049f 000000000000c51f
GPR16: 00000000ffffef33 0000000000000000 0000000000008a43 0000000000000001
GPR20: c00000ffc58a90c0 0000000000000000 000000000000dd86 0000000000000000
GPR24: c000007fd0ed10c0 00000000ffffffff 0000000000000158 000000000000014a
GPR28: c00000ffc43af010 c00000ffc9144000 c00000ffcaf22e00 c00000ffcaf22100
NIP [c00000000080ef8c] __skb_clone+0xdc/0x140
LR [c00000000080eee8] __skb_clone+0x38/0x140
Call Trace:
[c00000ffffc33990] [c00000000080fb74] skb_clone+0x74/0x110 (unreliable)
[c00000ffffc339c0] [c000000000907f64] packet_rcv+0x144/0x510
[c00000ffffc33a40] [c000000000827b64] __netif_receive_skb_core+0x5b4/0xd80
[c00000ffffc33b00] [c00000000082b2bc] netif_receive_skb_internal+0x2c/0xc0
[c00000ffffc33b40] [c00000000082c49c] napi_gro_receive+0x11c/0x260
[c00000ffffc33b80] [d000000066483d68] bnx2x_poll+0xcf8/0x17b0 [bnx2x]
[c00000ffffc33d00] [c00000000082babc] net_rx_action+0x31c/0x480
[c00000ffffc33e10] [c0000000000d5a44] __do_softirq+0x164/0x3d0
[c00000ffffc33f00] [c0000000000d60a8] irq_exit+0x108/0x120
[c00000ffffc33f20] [c000000000015b98] __do_irq+0x98/0x200
[c00000ffffc33f90] [c000000000027f14] call_do_irq+0x14/0x24
[c00000ffd4923a90] [c000000000015d94] do_IRQ+0x94/0x110
[c00000ffd4923ae0] [c000000000008d90] hardware_interrupt_common+0x150/0x160
The configurable priority to traffic class mapping and the user specified
queue ranges are used to configure the traffic class, overriding the
hardware defaults when the 'hw' option is set to 0. However, when the 'hw'
option is non-zero, the hardware QOS defaults are used.
This patch makes it so that we can pass the data the user provided to
ndo_setup_tc. This allows us to pull in the queue configuration if the
user requested it as well as any additional hardware offload type
requested by using a value other than 1 for the hw value.
Finally it also provides a means for the device driver to return the level
supported for the offload type via the qopt->hw value. Previously we were
just always assuming the value to be 1, in the future values beyond just 1
may be supported.
Signed-off-by: Amritha Nambiar <amritha.nambiar@intel.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
napi_complete_done() allows to opt-in for gro_flush_timeout,
added back in linux-3.19, commit 3b47d30396ba
("net: gro: add a per device gro flush timer")
This allows for more efficient GRO aggregation without
sacrifying latencies.
Commit 4cace675d687 ("bnx2x: Alloc 4k fragment for each rx ring buffer
element") added extra put_page() and get_page() calls on arches where
PAGE_SIZE=4K like x86
Reorder things to avoid this overhead.
Cc: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Yuval Mintz <Yuval.Mintz@cavium.com>
Cc: Ariel Elior <ariel.elior@cavium.com>
Since offset is zero, it's not necessary to use set function. Reset
function is straightforward, and will remove the unnecessary add
operation in set function.
Signed-off-by: Zhang Shengju <zhangshengju@cmss.chinamobile.com>
Switch from napi_complete() to napi_complete_done()
for better GRO support (gro_flush_timeout) and core NAPI
features.
Do not rearm interrupts if we are busy polling,
to reduce bus and interrupts overhead.
Cc: Willem de Bruijn <willemb@google.com>
Cc: Adam Belay <abelay@google.com>
Cc: Tariq Toukan <tariqt@mellanox.com>
tg3: min_mtu 60, max_mtu 9000/1500
bnxt: min_mtu 60, max_mtu 9000
bnx2x: min_mtu 46, max_mtu 9600
- Fix up ETH_OVREHEAD -> ETH_OVERHEAD while we're in here, remove
duplicated defines from bnx2x_link.c.
bnx2: min_mtu 46, max_mtu 9000
- Use more standard ETH_* defines while we're at it.
bcm63xx_enet: min_mtu 46, max_mtu 2028
- compute_hw_mtu was made largely pointless, and thus merged back into
bcm_enet_change_mtu.
b44: min_mtu 60, max_mtu 1500
CC: netdev@vger.kernel.org
CC: Michael Chan <michael.chan@broadcom.com>
CC: Sony Chacko <sony.chacko@qlogic.com>
CC: Ariel Elior <ariel.elior@qlogic.com>
CC: Dept-HSGLinuxNICDev@qlogic.com
CC: Siva Reddy Kallam <siva.kallam@broadcom.com>
CC: Prashant Sreedharan <prashant@broadcom.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
When driver has hit a parity event, HW can no longer write to host memory.
As a result, Tx completions cannot be written to the host SB memory, and
waiting for Tx completions eventually timeout.
As driver is willing to delay as much as 1-2 seconds per Tx queue for its
draining and this delay is sequential, the time to recover might greatly
lengthen needlessly in case the recovery is done under multi-connection
traffic.
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
I added this check in setup_tc to multiple drivers,
if (handle != TC_H_ROOT || tc->type != TC_SETUP_MQPRIO)
Unfortunately restricting to TC_H_ROOT like this breaks the old
instantiation of mqprio to setup a hardware qdisc. This patch
relaxes the test to only check the type to make it equivalent
to the check before I broke it. With this the old instantiation
continues to work.
A good smoke test is to setup mqprio with,
# tc qdisc add dev eth4 root mqprio num_tc 8 \
map 0 1 2 3 4 5 6 7 \
queues 0@0 1@1 2@2 3@3 4@4 5@5 6@6 7@7
Fixes: e4c6734eaab9 ("net: rework ndo tc op to consume additional qdisc handle paramete")
Reported-by: Singh Krishneil <krishneil.k.singh@intel.com>
Reported-by: Jake Keller <jacob.e.keller@intel.com>
CC: Murali Karicheri <m-karicheri2@ti.com>
CC: Shradha Shah <sshah@solarflare.com>
CC: Or Gerlitz <ogerlitz@mellanox.com>
CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
CC: Bruce Allan <bruce.w.allan@intel.com>
CC: Jesse Brandeburg <jesse.brandeburg@intel.com>
CC: Don Skidmore <donald.c.skidmore@intel.com>
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
This patch updates setup_tc so we can pass additional parameters into
the ndo op in a generic way. To do this we provide structured union
and type flag.
This lets each classifier and qdisc provide its own set of attributes
without having to add new ndo ops or grow the signature of the
callback.
Acked-by: Jiri Pirko <jiri@mellanox.com>
The ndo_setup_tc() op was added to support drivers offloading tx
qdiscs however only support for mqprio was ever added. So we
only ever added support for passing the number of traffic classes
to the driver.
This patch generalizes the ndo_setup_tc op so that a handle can
be provided to indicate if the offload is for ingress or egress
or potentially even child qdiscs.
bnx2x_schedule_sp_rtnl is exported by bnx2x, although no other module
uses it.
Reported-by: Benjamin Poirier <bpoirier@suse.com>
Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com>
FW has a rare corner case in which a fragmented packet using lots
of frags would not be linearized, causing the FW to assert while trying
to transmit the packet.
To prevent this, we need to make sure the window of fragements containing
MSS worth of data contains 1 BD less than for regular packets due to
the additional parsing BD.
These fields are updated but never read.
Remove the overhead.
Under heavy TX load, bnx2x_poll() can loop forever and trigger
soft lockup bugs.
A napi poll handler must yield after one TX completion round,
risk of livelock is too high otherwise.
Bug is very easy to trigger using a debug build, and udp flood, because
of added cpu cycles in TX completion, and we do not receive enough
packets to break the loop.
Reported-by: Willem de Bruijn <willemb@google.com>
Cc: Ariel Elior <ariel.elior@qlogic.com>
It's supposed to be impossible for TPA to give us anything else
than IPv4 or IPv6 here. But in case there is a way to reach this error
by some strange received frames, we don't want to flood the kernel log.
WARN_ONCE is better for this purpose.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
alloc_pages() already prints a warning when it fails. No need to emit
another message. Certainly not at KERN_ERR level, because it is no big
deal if this GFP_ATOMIC allocation fails occasionally.
NAPI drivers no longer need to observe a particular protocol
to benefit from busy polling (CONFIG_NET_RX_BUSY_POLL=y)
napi_hash_add() and napi_hash_del() are automatically called
from core networking stack, respectively from
netif_napi_add() and netif_napi_del()
This patch depends on free_netdev() and netif_napi_del() being
called from process context, which seems to be the norm.
Drivers might still prefer to call napi_hash_del() on their
own, since they might combine all the rcu grace periods into
a single one, knowing their NAPI structures lifetime, while
core networking stack has no idea of a possible combining.
Once this patch proves to not bring serious regressions,
we will cleanup drivers to either remove napi_hash_del()
or provide appropriate rcu grace periods combining.
We would like to automatically provide busy polling support
to all NAPI drivers, without them having to implement anything.
skb_mark_napi_id() can be called from napi_gro_receive() and
napi_get_frags().
Few drivers are still calling skb_mark_napi_id() because
they use netif_receive_skb(). They should eventually call
napi_gro_receive() instead. I will leave this to drivers
maintainers.
Switch to native NAPI polling, as this reduces overhead and complexity.
Normal path is faster, since one cmpxchg() is not anymore requested,
and busy polling with the NAPI polling has same performance.
Tested:
lpk50:~# cat /proc/sys/net/core/busy_read
70
lpk50:~# nstat >/dev/null;./netperf -H lpk55 -t TCP_RR;nstat
MIGRATED TCP REQUEST/RESPONSE TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to lpk55.prod.google.com () port 0 AF_INET : first burst 0
Local /Remote
Socket Size Request Resp. Elapsed Trans.
Send Recv Size Size Time Rate
bytes Bytes bytes bytes secs. per sec
16384 87380 1 1 10.00 40095.07
16384 87380
IpInReceives 401062 0.0
IpInDelivers 401062 0.0
IpOutRequests 401079 0.0
TcpActiveOpens 7 0.0
TcpPassiveOpens 3 0.0
TcpAttemptFails 3 0.0
TcpEstabResets 5 0.0
TcpInSegs 401036 0.0
TcpOutSegs 401052 0.0
TcpOutRsts 38 0.0
UdpInDatagrams 26 0.0
UdpOutDatagrams 27 0.0
Ip6OutNoRoutes 1 0.0
TcpExtDelayedACKs 1 0.0
TcpExtTCPPrequeued 98 0.0
TcpExtTCPDirectCopyFromPrequeue 98 0.0
TcpExtTCPHPHits 4 0.0
TcpExtTCPHPHitsToUser 98 0.0
TcpExtTCPPureAcks 5 0.0
TcpExtTCPHPAcks 101 0.0
TcpExtTCPAbortOnData 6 0.0
TcpExtBusyPollRxPackets 400832 0.0
TcpExtTCPOrigDataSent 400983 0.0
IpExtInOctets 21273867 0.0
IpExtOutOctets 21261254 0.0
IpExtInNoECTPkts 401064 0.0
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
Management firmware tells driver in case bandwidth configuration for
a specific function exists, but [regretably] the same field has different
meanings depending on the multi-function mode - it can either be
a percentile value or an actual speed.
For newer multi-function modes current logic is incorrect -
driver understands values as actual speeds instead of percentages,
causing the resulting chip configuration to be incorrect.
drivers/net/ethernet/cavium/Kconfig
The cavium conflict was overlapping dependency
changes.
On error flows its possible to free an SKB even if it was not allocated.
Current driver always uses vlan-promisc mode, i.e., it receives both
tagged and untagged traffic and lets the network stack drop packets
tagged with unrequested vlan tags.
This patch implements vlan-filtering offload in the driver -
Unless explicitly configured to promisc mode, only untagged packets or
packets tagged with requested vlans would reach the Rx flow.
Devices with up-to-date management FW will be able to store register dumps
on their persistent storage - in case management FW identifies a fatal
error it would gather and store such dumps, which could later be retrieved
using specific debug tools.
This patch adds the necessary part in the driver in order to make the
feature operational, as well as update users [under debug] during load
in case their device contains a dump of a previous crash.
This adds support to a new multi-function mode, enabling driver to
initialize such devices and correctly interacting with management FW
for fully utilizing their features.
bnx2x still appears as a Broadcom driver even though the devices it
utilizes belong to Qlogic for more than a year.
This patch changes the various headers and the device strings to indicate
the correct ownership of the device.
This moves bnx2x into using 7.12.30 FW. Said firmware fixes the following:
- Packets from a VF with pvid configured which were sent with a
different vlan were transmitted instead of being discarded.
- FCoE traffic might not recover after a failue while there's traffic
to another function.
In addition, this FW opens the door for the driver to implement several
new features; Specifically, this enhances the device's support for
encapsulated packets and will allow vxlan/geneve offloads to be added in
the future, as well as vlan filtering offload.
With CONFIG_DMA_API_DEBUG=y bnx2x triggers the error "DMA-API: device
driver frees DMA memory with wrong function".
On archs where PAGE_SIZE > SGE_PAGE_SIZE it also triggers "DMA-API:
device driver frees DMA memory with different size".
Fix this by making the mapping and unmapping symmetric:
- Do not map the whole pool page at once. Instead map the
SGE_PAGE_SIZE-sized pieces individually, so they can be unmapped in
the same manner.
- What's mapped using dma_map_page() must be unmapped using
dma_unmap_page().
Tested on ppc64.
Fixes: 4cace675d687 ("bnx2x: Alloc 4k fragment for each rx ring buffer element")
Due to FW constraints, driver must make sure that transmitted SKBs will
not be too fragmented, or in the case that they are - that each 'window'
of fragments passed to the FW would contain at least an mss worth of data.
For encapsultaed packets the calculation is wrong, since it ignores the
inner headers in the calculation of the headers' length.
This could lead to a FW assertion in case of a too-fragmented encapsulated
packet.
The driver allocates one page for each buffer on the rx ring, which is
too much on architectures like ppc64 and can cause unexpected allocation
failures when the system is under stress. Now, we keep a memory pool
per queue, and if the architecture's PAGE_SIZE is greater than 4k, we
fragment pages and assign each 4k segment to a ring element, which
reduces the overall memory consumption on such architectures. This
helps avoiding errors like the example below:
[bnx2x_alloc_rx_sge:435(eth1)]Can't alloc sge
[c00000037ffeb900] [d000000075eddeb4] .bnx2x_alloc_rx_sge+0x44/0x200 [bnx2x]
[c00000037ffeb9b0] [d000000075ee0b34] .bnx2x_fill_frag_skb+0x1ac/0x460 [bnx2x]
[c00000037ffebac0] [d000000075ee11f0] .bnx2x_tpa_stop+0x160/0x2e8 [bnx2x]
[c00000037ffebb90] [d000000075ee1560] .bnx2x_rx_int+0x1e8/0xc30 [bnx2x]
[c00000037ffebcd0] [d000000075ee2084] .bnx2x_poll+0xdc/0x3d8 [bnx2x] (unreliable)
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Acked-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
Reviewed-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Four minor merge conflicts:
1) qca_spi.c renamed the local variable used for the SPI device
from spi_device to spi, meanwhile the spi_set_drvdata() call
got moved further up in the probe function.
2) Two changes were both adding new members to codel params
structure, and thus we had overlapping changes to the
initializer function.
3) 'net' was making a fix to sk_release_kernel() which is
completely removed in 'net-next'.
4) In net_namespace.c, the rtnl_net_fill() call for GET operations
had the command value fixed, meanwhile 'net-next' adjusted the
argument signature a bit.
This also matches example merge resolutions posted by Stephen
Rothwell over the past two days.
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Submit 909d9faae2a44 ("bnx2x: Prevent inner-reload while VFs exist")
contained a bug - MTU change was not prevented by it; Instead, it
`randomally' prevented bnx2x_resume() from running [harmless yet wrong].
This moves the check to its correct spot.
