[ Upstream commit a5af83925363eb85d467933e3d6ec5a87001eb7c ]
The latest gcc-7 snapshot warns about bfa_ioc_send_enable/bfa_ioc_send_disable
writing undefined values into the hardware registers:
drivers/net/ethernet/brocade/bna/bfa_ioc.c: In function 'bfa_iocpf_sm_disabling_entry':
arch/arm/include/asm/io.h:109:22: error: '*((void *)&disable_req+4)' is used uninitialized in this function [-Werror=uninitialized]
arch/arm/include/asm/io.h:109:22: error: '*((void *)&disable_req+8)' is used uninitialized in this function [-Werror=uninitialized]
The two functions look like they should do the same thing, but only one
of them initializes the time stamp and clscode field. The fact that we
only get a warning for one of the two functions seems to be arbitrary,
based on the inlining decisions in the compiler.
To address this, I'm making both functions do the same thing:
- set the clscode from the ioc structure in both
- set the time stamp from ktime_get_real_seconds (which also
avoids the signed-integer overflow in 2038 and extends the
well-defined behavior until 2106).
- zero-fill the reserved field
Fixes: 8b230ed8ec96 ("bna: Brocade 10Gb Ethernet device driver")
[ Upstream commit 13e2d5187f6b965ba3556caedb914baf81b98ed2 ]
We could allocate less memory than intended because we do:
bnad->regdata = kzalloc(len << 2, GFP_KERNEL);
The shift can overflow leading to a crash. This is debugfs code so the
impact is very small.
Fixes: 7afc5dbde091 ("bna: Add debugfs interface.")
Acked-by: Rasesh Mody <rasesh.mody@cavium.com>
Several functions can return negative value in case of error,
so their return type should be fixed as well as type of variables
to which this value is assigned.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Check for DMA mapping errors, recover from them and register them in
ethtool stats like other errors.
Cc: Rasesh Mody <rasesh.mody@qlogic.com>
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Acked-by: Rasesh Mody <rasesh.mody@qlogic.com>
The commit "e29aa33 bna: Enable Multi Buffer RX" moved packets counter
increment from the beginning of the NAPI processing loop after the check
for erroneous packets so they are never accounted. This counter is used
to inform firmware about number of processed completions (packets).
As these packets are never acked the firmware fires IRQs for them again
and again.
Fixes: e29aa33 ("bna: Enable Multi Buffer RX")
This howto made sense in the 1990s when users had to manually configure
ISA cards with jumpers or vendor utilities, but with the implementation
of PCI it became increasingly less and less relevant, to the point where
it has been well over a decade since I last updated it. And there is
no value in anyone else taking over updating it either.
However the references to it continue to spread as boiler plate text
from one Kconfig file into the next. We are not doing end users any
favours by pointing them at this old document, so lets kill it with
fire, once and for all, to hopefully stop any further spread.
No code is changed in this commit, just Kconfig help text.
BIT value is already unsigned so casting is not necessary.
...and remove some of them. It is not necessary to log when .probe() and
.remove() are called or when TxQ is started or stopped. Also log level
of some of them was changed to more appropriate one (link up/down,
firmware loading failure.
Timeout functions are defined with 'void *' ptr argument. They should
be defined directly with 'struct bfa_ioc *' type to avoid type conversions.
Remove macros for manipulation with struct list_head and replace them
with standard ones.
Pointer cmpl used to iterate through completion entries is updated at
the beginning of while loop as well as at the end. The update at the end
of the loop is useless.
Patch converts kzalloc->copy_from_user sequence to memdup_user. There
is also one useless assignment of NULL to bnad->regdata as it is followed
by assignment of kzalloc output.
TX_E_PRIO_CHANGE event is never sent for bna_tx so it doesn't need to be
handled. After this change bna_tx->flags cannot contain
BNA_TX_F_PRIO_CHANGED flag and it can be also eliminated.
The bna_rx_config struct member paused can be removed as it is never
written and as it cannot have non-zero value the bna_rxf struct member
flags also cannot have BNA_RXF_F_PAUSED value and is always zero.
So the flags member can be removed as well as bna_rxf_flags enum and
the code-paths that needs to have non-zero bna_rxf->flags.
This clean-up makes bna_rxf_sm_paused state unsed and can be also removed.
RXF_E_PAUSE & RXF_E_RESUME events are never sent for bna_rxf object so
they needn't to be handled. The bna_rxf's state bna_rxf_sm_fltr_clr_wait
and function bna_rxf_fltr_clear are unused after this so remove them also.
removed:
bna_rx_ucast_add
bna_rx_ucast_del
simplified:
bna_enet_pause_config
bna_rx_mcast_delall
bna_rx_mcast_listset
bna_rx_mode_set
bna_rx_ucast_listset
bna_rx_ucast_set
replaced macros:
BNA_MAC_IS_EQUAL -> ether_addr_equal
BNA_POWER_OF_2 -> is_power_of_2
BNA_TO_POWER_OF_2_HIGH -> roundup_pow_of_two
removed unused macros:
bfa_fsm_get_state
bfa_ioc_clr_stats
bfa_ioc_fetch_stats
bfa_ioc_get_alt_ioc_fwstate
bfa_ioc_isr_mode_set
bfa_ioc_maxfrsize
bfa_ioc_mbox_cmd_pending
bfa_ioc_ownership_reset
bfa_ioc_rx_bbcredit
bfa_ioc_state_disabled
bfa_sm_cmp_state
bfa_sm_get_state
bfa_sm_send_event
bfa_sm_set_state
bfa_sm_state_decl
BFA_STRING_32
BFI_ADAPTER_IS_{PROTO,TTV,UNSUPP)
BFI_IOC_ENDIAN_SIG
BNA_{C,RX,TX}Q_PAGE_INDEX_MAX
BNA_{C,RX,TX}Q_PAGE_INDEX_MAX_SHIFT
BNA_{C,RX,TX}Q_QPGE_PTR_GET
BNA_IOC_TIMER_FREQ
BNA_MESSAGE_SIZE
BNA_QE_INDX_2_PTR
BNA_QE_INDX_RANGE
BNA_Q_GET_{C,P}I
BNA_Q_{C,P}I_ADD
BNA_Q_FREE_COUNT
BNA_Q_IN_USE_COUNT
BNA_TO_POWER_OF_2
containing_rec
The patch converts mac_t type to widely used 'u8 [ETH_ALEN]'.
Parameters of all ether_addr_copy instances were checked for proper
alignment. Alignment of bnad_bcast_addr is forced to 2 as the implicit
alignment is 1.
I have also renamed address parameter of bnad_set_mac_address() to addr.
The name mac_addr was a little bit confusing as the real parameter is
struct sockaddr *.
v2: added __aligned directive to bnad_bcast_addr, renamed parameter of
bnad_set_mac_address() (thx joe@perches.com)
EXTRA_CFLAGS should be used on the command line only.
Since EXTRA_CFLAGS here add only a non-existant path to compiler
include paths (by -I), remove EXTRA_CFLAGS completely.
Bug in the driver initialization causes soft-lockup if firmware
initialization timeout is reached. Polling function bfa_ioc_poll_fwinit()
incorrectly calls bfa_nw_iocpf_timeout() when the timeout is reached.
The problem is that bfa_nw_iocpf_timeout() calls again
bfa_ioc_poll_fwinit()... etc. The bfa_ioc_poll_fwinit() should directly
send timeout event for iocpf and the same should be done if firmware
download into HW fails.
Driver starts iocpf timer prior bnad_ioceth_enable() call and this is
unreasonable. This piece of code probably originates from Brocade/Qlogic
out-of-box driver during initial import into upstream. This driver uses
only one timer and queue to implement multiple timers and this timer is
started at this place. The upstream driver uses multiple timers instead
of this.
Firmware required by bna is stored in appropriate files as sequence
of LE32 integers. After loading by request_firmware() they need to be
byte-swapped on big-endian arches. Without this conversion the NIC
is unusable on big-endian machines.
To test a checkpatch spelling patch, I ran codespell against
drivers/net/ethernet/.
$ git ls-files drivers/net/ethernet/ | \
while read file ; do \
codespell -w $file; \
done
I removed a false positive in e1000_hw.h
This patch updates the BNA driver version to 3.2.25.1 and the firmware version
to 3.2.5.1
Signed-off-by: Rasesh Mody <rasesh.mody@qlogic.com>
Re-brand the BNA driver to QLogic.
The same macros are used for rx as well. So rename it.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The second init_completion call should be a reinit_completion here.
patch is against 3.18.0 linux-next
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
Use netdev_rss_key_fill() helper, as it provides better support for some
bonding setups.
skb->truesize is not meant to be tracking amount of used bytes
in an skb, but amount of reserved/consumed bytes in memory.
For instance, if we use a single byte in last page fragment,
we have to account the full size of the fragment.
skb->truesize can be very different from skb->len, that has
a very specific safety purpose.
When Tx VLAN offloading is disabled frames with size ~ MTU are not
transmitted as the driver does not account 4 bytes of VLAN header added
by stack. It should use VLAN_ETH_HLEN instead of ETH_HLEN.
The second problem is with newer BNA chips (BNA 1860). These chips filter
out any VLAN tagged frames in Tx path. This is a problem when Tx VLAN
offloading is disabled and frames are tagged by stack. Older chips like
1010/1020 are not affected as they probably don't do such filtering.
Use container_of instead of casting first structure member.
Compiled but untested.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This device claims TSO and checksum support for vlans. It also
allows a user to control vlan acceleration offloading. As such,
it is possible to turn off vlan acceleration and configure a vlan
which will continue to support TSO.
In such situation the packet passed down the the device will contain
a vlan header and skb->protocol will be set to ETH_P_8021Q.
The device assumes that skb->protocol contains network protocol
value and uses that value to set up TSO information. This results
in corrupted frames sent on the wire.
This patch extract the protocol value correctly and corrects TSO
and checksums for non-accelerated traffic.
CC: Rasesh Mody <rmody@brocade.com>
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
drivers/net/Makefile
net/ipv6/sysctl_net_ipv6.c
Two ipv6_table_template[] additions overlap, so the index
of the ipv6_table[x] assignments needed to be adjusted.
In the drivers/net/Makefile case, we've gotten rid of the
garbage whereby we had to list every single USB networking
driver in the top-level Makefile, there is just one
"USB_NETWORKING" that guards everything.
The recent commit "e29aa33 bna: Enable Multi Buffer RX" is causing
a performance regression. It does not properly update 'cmpl' pointer
at the end of the loop in NAPI handler bnad_cq_process(). The result is
only one packet / per NAPI-schedule is processed.
A driver should fill magic field of ethtool_eeprom struct in .get_eeprom
and validate it in .set_eeprom. The bna incorrectly validates it in both
and this makes its .get_eeprom interface unusable.
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
