[ Upstream commit 688db0c7a4a69ddc8b8143a1cac01eb20082a3aa ]
Currently, driver only allow configuring ETS bandwidth of TCs according
to the max TC number queried from firmware. However, the hardware actually
supports 8 TCs and users may need to configure ETS bandwidth of all TCs,
so remove the restriction.
Fixes: 330baff5423b ("net: hns3: add ETS TC weight setting in SSU module")
Signed-off-by: Guangbin Huang <huangguangbin2@huawei.com>
[ Upstream commit 731797fdffa3d083db536e2fdd07ceb050bb40b1 ]
If ets dwrr bandwidth of tc is set to 0, the hardware will switch to SP
mode. In this case, this tc may occupy all the tx bandwidth if it has
huge traffic, so it violates the purpose of the user setting.
To fix this problem, limit the ets dwrr bandwidth must greater than 0.
Fixes: cacde272dd00 ("net: hns3: Add hclge_dcb module for the support of DCB feature")
[ Upstream commit 8c1671e0d13d4a0ba4fb3a0da932bf3736d7ff73 ]
Currently, when query PFC configuration by dcbtool, driver will return
PFC enable status based on TC. As all priorities are mapped to TC0 by
default, if TC0 is enabled, then all priorities mapped to TC0 will be
shown as enabled status when query PFC setting, even though some
priorities have never been set.
for example:
$ dcb pfc show dev eth0
pfc-cap 4 macsec-bypass off delay 0
prio-pfc 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off
$ dcb pfc set dev eth0 prio-pfc 0:on 1:on 2:on 3:on
prio-pfc 0:on 1:on 2:on 3:on 4:on 5:on 6:on 7:on
To fix this problem, just returns user's PFC config parameter saved in
driver.
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Some device only support 4 TCs, but the driver check the total
bandwidth of 8 TCs, so may cause wrong configurations write to
the hw.
This patch uses hdev->tc_max to instead HNAE3_MAX_TC to fix it.
Fixes: e432abfb99e5 ("net: hns3: add common validation in hclge_dcb")
Signed-off-by: Yonglong Liu <liuyonglong@huawei.com>
Signed-off-by: Huazhong Tan <tanhuazhong@huawei.com>
When a TC's PFC is disabled or enabled, the RX private buffer for
this TC need to be changed too, otherwise this may cause packet
dropped problem.
This patch fixes it by calling hclge_buffer_alloc to reallocate
buffer when pfc_en changes.
Signed-off-by: Yunsheng Lin <linyunsheng@huawei.com>
The pfc_en and pfc_map need to be displayed in hexadecimal notation,
printing dma address should use %pad, and the end of printed string
needs to be add "\n".
This patch modifies them.
In hclge_dcb.c, these pair of codes:
hclge_notify_client(hdev, HNAE3_DOWN_CLIENT);
hclge_notify_client(hdev, HNAE3_UNINIT_CLIENT);
and
hclge_notify_client(hdev, HNAE3_INIT_CLIENT);
hclge_notify_client(hdev, HNAE3_UP_CLIENT);
are called many times, so make them into a function.
Reviewed-by: Peng Li <lipeng321@huawei.com>
Some times just see the eth interface have been down/up via
dmesg, but can not know why the eth down. So adds some debug
messages to identify the cause for this.
Signed-off-by: Peng Li <lipeng321@huawei.com>
Currently when TC num is one, the DCB will be disabled no matter if
pfc_en is non-zero or not.
This patch enables the DCB if pfc_en is non-zero, even when TC num
is one.
When the VF shares the same TC config as PF, the business
running on PF and VF must have samiliar module.
For simplicity, we are not considering VF sharing the same tc
configuration as PF use case, so this patch removes the support
of TC configuration from VF and forcing VF to just use single
TC.
hns3_client_setup_tc in enet is for updating TC configuration to
stack, and hclge_setup_tc in hclge_dcb is mainly for setting the
configuration to hardware.
This patch removes the hns3_nic_set_real_num_queue from
hns3_setup_tc in enet, and call hclge_client_setup_tc to update
TC configuration to stack with netdev down, because the netdev
down operation is done in hclge_dcb now.
After doing down/uninit/init/up in hclge_dcb, it is not necessary
to call dcb_ops->map_update in enet, so hclge_map_update can be
called directly in hclge_dcb.
This is for preparing to call hns3_nic_set_real_num_queue with
netdev down when user changes mqprio configuration.
When user changes the mqprio configuration, enet need to be
uninited and inited besides down'ed and up'ed, because the queue
num may change when the TC num changes.
Also, it is more suitable to do the down/unint/init/up operation
in hclge module using hclge_notify_client, because this config
change may affect PF and its VF.
Currently hclge_ieee_setets returns error directly when there is
error, which may cause netdev not up problem.
This patch adds some error handling when setting ETS configuration
fails.
The PFC enabling is based on user priority, currently it is
based on TC, which may cause PFC not setting correctly when pri
to TC mapping is not one to one relation.
This patch adds pfc_en in tm_info to fix it.
GE MAC does not support PFC, when driver is initializing and MAC
is in GE Mode, ignore the fw not supported error, otherwise
initialization will fail.
Shaper setting does not change currently, when TC num changes,
which may cause shaper parameter not setting problem.
This patch fixes it by setting the shaper parameter when TC num
changes.
When the ETS information is changed, the network device needs to be
re-initialized, otherwise the information such as the receiving queue
will be incorrect.
Before setting tm related configuration to hardware, driver
needs to check the configuration provided by user is valid.
Currently hclge_ieee_setets and hclge_setup_tc both implement
their own checking, which has a lot in common.
This patch addes hclge_dcb_common_validate to do the common
checking. The checking in hclge_tm_prio_tc_info_update
and hclge_tm_schd_info_update is unnecessary now, so change
the return type to void, which removes the need to do error
handling when one of the checking fails.
Also, ets->prio_tc is indexed by user prio and ets->tc_tsa is
indexed by tc num, so this patch changes them to use different
index.
Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com>
hclge_tm_schd_info_update should return an error when num_tc is greater
than alloc_tqps.
This patch changes the return type of hnae3_register_ae_algo from void
to int.
Signed-off-by: Salil Mehta <salil.mehta@huawei.com>
There is a defect in hclge_ets_validate(). If each member of tc_tsa is
not IEEE_8021QAZ_TSA_ETS, the variable total_ets_bw won't be updated.
In this case, the check for value of total_ets_bw will fail. This patch
fixes it by checking total_ets_bw only after it has been updated.
Signed-off-by: Jian Shen <shenjian15@huawei.com>
Add the SPDX identifiers to HNS3 PF driver.
This patch add support for querying pfc puase packets statistic
in hclge_ieee_getpfc, which is used to tell user how many pfc
puase packets have been sent and received by this mac port.
RSS configuration will be set to default value by hclge_rss_init_hw
during reset, which causes the RSS configuration loss problem.
This patch fixes it by setting the default value in
hclge_rss_init_cfg function, which will not be called in the reset
process.
When using tc qdisc, dcb_ops->setup_tc is used to tell hclge_dcb
module to do the tm related setup. Only TC_MQPRIO_MODE_CHANNEL
offload mode is supported.
The hclge_dcb module calls the interface from hclge_main/tm
and provide interface for the dcb netlink interface.
This patch also update Makefiles required to build the DCB
supported code in HNS3 Ethernet driver and update the existing
Kconfig file in the hisilicon folder.
