[ Upstream commit 66cf4710b23ab2adda11155684a2c8826f4fe732 ]
The ibm,mac-address-filters property defines the maximum number of
addresses the hypervisor's multicast filter list can support. It is
encoded as a big-endian integer in the OF device tree, but the virtual
ethernet driver does not convert it for use by little-endian systems.
As a result, the driver is not behaving as it should on affected systems
when a large number of multicast addresses are assigned to the device.
Reported-by: Hangbin Liu <liuhangbin@gmail.com>
Signed-off-by: Thomas Falcon <tlfalcon@linux.ibm.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
[ Upstream commit e95d22c69b2c130ccce257b84daf283fd82d611e ]
The IBM virtual ethernet driver's polling function continues
to process frames after rescheduling NAPI, resulting in a warning
if it exhausted its budget. Do not restart polling after calling
napi_reschedule. Instead let frames be processed in the following
instance.
[ Upstream commit 756af9c642329d54f048bac2a62f829b391f6944 ]
Commit 33a48ab105a7 ("ibmveth: Fix DMA unmap error") fixed an issue in the
normal code path of ibmveth_xmit_start() that was originally introduced by
Commit 6e8ab30ec677 ("ibmveth: Add scatter-gather support"). This original
fix missed the error path where dma_unmap_page is wrongly called on the
header portion in descs[0] which was mapped with dma_map_single. As a
result a failure to DMA map any of the frags results in a dmesg warning
when CONFIG_DMA_API_DEBUG is enabled.
DMA-API: ibmveth 30000002: device driver frees DMA memory with wrong function
[device address=0x000000000a430000] [size=172 bytes] [mapped as page] [unmapped as single]
WARNING: CPU: 1 PID: 8426 at kernel/dma/debug.c:1085 check_unmap+0x4fc/0xe10
<snip>
DMA-API: Mapped at:
ibmveth_start_xmit+0x30c/0xb60
dev_hard_start_xmit+0x100/0x450
sch_direct_xmit+0x224/0x490
__qdisc_run+0x20c/0x980
__dev_queue_xmit+0x1bc/0xf20
This fixes the API misuse by unampping descs[0] with dma_unmap_single.
Fixes: 6e8ab30ec677 ("ibmveth: Add scatter-gather support")
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
[ Upstream commit 23d28a859fb847fd7fcfbd31acb3b160abb5d6ae ]
When using the ibmveth driver in a KVM/QEMU based VM, it currently
always prints out a scary error message like this when it is started:
ibmveth 71000003 (unregistered net_device): unable to change
checksum offload settings. 1 rc=-2 ret_attr=71000003
This happens because the driver always tries to enable the checksum
offloading without checking for the availability of this feature first.
QEMU does not support checksum offloading for the spapr-vlan device,
thus we always get the error message here.
According to the LoPAPR specification, the "ibm,illan-options" property
of the corresponding device tree node should be checked first to see
whether the H_ILLAN_ATTRIUBTES hypercall and thus the checksum offloading
feature is available. Thus let's do this in the ibmveth driver, too, so
that the error message is really only limited to cases where something
goes wrong, and does not occur if the feature is just missing.
Signed-off-by: Thomas Huth <thuth@redhat.com>
[ Upstream commit 94acf164dc8f1184e8d0737be7125134c2701dbe ]
Include calculations to compute the number of segments
that comprise an aggregated large packet.
Signed-off-by: Thomas Falcon <tlfalcon@linux.vnet.ibm.com>
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Jonathan Maxwell <jmaxwell37@gmail.com>
This patch is based on an earlier one submitted
by Jon Maxwell with the following commit message:
"We recently encountered a bug where a few customers using ibmveth on the
same LPAR hit an issue where a TCP session hung when large receive was
enabled. Closer analysis revealed that the session was stuck because the
one side was advertising a zero window repeatedly.
We narrowed this down to the fact the ibmveth driver did not set gso_size
which is translated by TCP into the MSS later up the stack. The MSS is
used to calculate the TCP window size and as that was abnormally large,
it was calculating a zero window, even although the sockets receive buffer
was completely empty."
We rely on the Virtual I/O Server partition in a pseries
environment to provide the MSS through the TCP header checksum
field. The stipulation is that users should not disable checksum
offloading if rx packet aggregation is enabled through VIOS.
Some firmware offerings provide the MSS in the RX buffer.
This is signalled by a bit in the RX queue descriptor.
Reviewed-by: Brian King <brking@linux.vnet.ibm.com>
Reviewed-by: Pradeep Satyanarayana <pradeeps@linux.vnet.ibm.com>
Reviewed-by: David Dai <zdai@us.ibm.com>
If skb_linearize fails, the driver should drop the packet
instead of trying to copy it into the bounce buffer.
This is an API consolidation only. The use of kmalloc + memset to 0
is equivalent to kcalloc in this case as it is allocating an array
of elements.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
The name NETIF_F_ALL_CSUM is a misnomer. This does not correspond to the
set of features for offloading all checksums. This is a mask of the
checksum offload related features bits. It is incorrect to set both
NETIF_F_HW_CSUM and NETIF_F_IP_CSUM or NETIF_F_IPV6 at the same time for
features of a device.
This patch:
- Changes instances of NETIF_F_ALL_CSUM to NETIF_F_CSUM_MASK (where
NETIF_F_ALL_CSUM is being used as a mask).
- Changes bonding, sfc/efx, ipvlan, macvlan, vlan, and team drivers to
use NEITF_F_HW_CSUM in features list instead of NETIF_F_ALL_CSUM.
Signed-off-by: Tom Herbert <tom@herbertland.com>
This patch adds support for a new method of signalling the firmware
that TSO packets are being sent. The new method removes the need to
alter the ip and tcp checksums and allows TSO6 support.
Enables receiving large packets from other LPARs. These packets
have a -1 IP header checksum, so we must recalculate to have
a valid checksum.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Cc: Brian King <brking@linux.vnet.ibm.com>
Add support for TSO. TSO is turned off by default and
must be enabled and configured by the user. The driver
version number is increased so that users can be sure
that they are using ibmveth with TSO support.
This patch enables 64k rx buffer pools by default. If Cooperative
Memory Overcommitment (CMO) is enabled, the number of 64k buffers
is reduced to save memory.
AFAIK the PAPR document which defines the virtual device interface used by
the ibmveth driver doesn't specify a specific maximum MTU. So, in the
ibmveth driver, the maximum allowed MTU is determined by the maximum
allocated buffer size of 64k (corresponding to one page in the common case)
minus the per-buffer overhead IBMVETH_BUFF_OH (which has value 22 for 14
bytes of ethernet header, plus 8 bytes for an opaque handle).
This suggests a maximum allowable MTU of 65514 bytes, but in fact the
driver only permits a maximum MTU of 65513. This is because there is a <
instead of an <= in ibmveth_change_mtu(), which only permits an MTU which
is strictly smaller than the buffer size, rather than allowing the buffer
to be completely filled.
This patch fixes the buglet.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: Thomas Falcon <tlfalcon@linux.vnet.ibm.com>
The interrupt is enabled before napi_complete(). A network timeout
occurs if the interrupt handler is called before napi_complete().
Fix the bug by enabling the interrupt after napi_complete().
Signed-off-by: Yongbae Park <yongbae2@gmail.com>
Add a function that will enable changing the MAC address
of an ibmveth interface while it is still running.
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
Hidden away in the last 8 bytes of the buffer_list page is a solitary
statistic. It needs to be byte swapped or else ethtool -S will
produce numbers that terrify the user.
Since we do this in multiple places, create a helper function with a
comment explaining what is going on.
Cc: stable@vger.kernel.org
Replace dev_kfree_skb with dev_consume_skb_any in ibmveth_start_xmit
that can be called in hard irq and other contexts.
In this code path the packet can have either been transmitted
or dropped, dev_consume_skb_any was choosen because that preserves
the existing semantics of the code, and a transmitted packet is
more likely.
Processing any incoming packets with a with a napi budget of 0
is incorrect driver behavior.
This matters as netpoll will shortly call drivers with a budget of 0
to avoid receive packet processing happening in hard irq context.
The code to load a MAC address into a u64 for passing to the
hypervisor via a register is broken on little endian.
Create a helper function called ibmveth_encode_mac_addr
which does the right thing in both big and little endian.
We were storing the MAC address in a long in struct ibmveth_adapter.
It's never used so remove it - we don't need another place in the
driver where we create endian issues with MAC addresses.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"So here's my next branch for powerpc. A bit late as I was on vacation
last week. It's mostly the same stuff that was in next already, I
just added two patches today which are the wiring up of lockref for
powerpc, which for some reason fell through the cracks last time and
is trivial.
The highlights are, in addition to a bunch of bug fixes:
- Reworked Machine Check handling on kernels running without a
hypervisor (or acting as a hypervisor). Provides hooks to handle
some errors in real mode such as TLB errors, handle SLB errors,
etc...
- Support for retrieving memory error information from the service
processor on IBM servers running without a hypervisor and routing
them to the memory poison infrastructure.
- _PAGE_NUMA support on server processors
- 32-bit BookE relocatable kernel support
- FSL e6500 hardware tablewalk support
- A bunch of new/revived board support
- FSL e6500 deeper idle states and altivec powerdown support
You'll notice a generic mm change here, it has been acked by the
relevant authorities and is a pre-req for our _PAGE_NUMA support"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits)
powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked()
powerpc: Add support for the optimised lockref implementation
powerpc/powernv: Call OPAL sync before kexec'ing
powerpc/eeh: Escalate error on non-existing PE
powerpc/eeh: Handle multiple EEH errors
powerpc: Fix transactional FP/VMX/VSX unavailable handlers
powerpc: Don't corrupt transactional state when using FP/VMX in kernel
powerpc: Reclaim two unused thread_info flag bits
powerpc: Fix races with irq_work
Move precessing of MCE queued event out from syscall exit path.
pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines
powerpc: Make add_system_ram_resources() __init
powerpc: add SATA_MV to ppc64_defconfig
powerpc/powernv: Increase candidate fw image size
powerpc: Add debug checks to catch invalid cpu-to-node mappings
powerpc: Fix the setup of CPU-to-Node mappings during CPU online
powerpc/iommu: Don't detach device without IOMMU group
powerpc/eeh: Hotplug improvement
powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space
powerpc/eeh: Add restore_config operation
This patch updates the generic iommu backend code to use the
it_page_shift field to determine the iommu page size instead of
using hardcoded values.
Signed-off-by: Alistair Popple <alistair@popple.id.au>
The powerpc iommu uses a hardcoded page size of 4K. This patch changes
the name of the IOMMU_PAGE_* macros to reflect the hardcoded values. A
future patch will use the existing names to support dynamic page
sizes.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Santosh Raspatur <santosh@chelsio.com>
CC: Dimitris Michailidis <dm@chelsio.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Santiago Leon <santil@linux.vnet.ibm.com>
CC: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
CC: Olof Johansson <olof@lixom.net>
CC: Manish Chopra <manish.chopra@qlogic.com>
CC: Sony Chacko <sony.chacko@qlogic.com>
CC: Rajesh Borundia <rajesh.borundia@qlogic.com>
CC: Nicolas Pitre <nico@fluxnic.net>
CC: Steve Glendinning <steve.glendinning@shawell.net>
Convert the memset/memcpy uses of 6 to ETH_ALEN
where appropriate.
Also convert some struct definitions and u8 array
declarations of [6] to ETH_ALEN.
Acked-by: Arend van Spriel <arend@broadcom.com>
The hypervisor is big endian, so little endian kernel builds need
to byteswap.
Some ancient pHyp versions used to create a 8 bytes local-mac-address
property in the device-tree instead of a 6 bytes one for veth.
The Linux driver code to deal with that is an insane hack which also
happens to break with some choices of MAC addresses in qemu by testing
for a bit in the address rather than just looking at the size of the
property.
Sanitize this by doing the latter instead.
CC: <stable@vger.kernel.org>
I believe these error messages are already logged
on allocation failure by warn_alloc_failed and so
get a dump_stack on OOM.
Remove the unnecessary additional error logging.
Around these deletions:
o Alignment neatening.
o Remove unnecessary casts of dma_alloc_coherent.
o Hoist assigns from ifs.
alloc failures already get standardized OOM
messages and a dump_stack.
Convert kzalloc's with multiplies to kcalloc.
Convert kmalloc's with multiplies to kmalloc_array.
Fix a few whitespace defects.
Convert a constant 6 to ETH_ALEN.
Use parentheses around sizeof.
Convert vmalloc/memset to vzalloc.
Remove now unused size variables.
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The __dev* removal patches for the network drivers ended up messing up
the function prototypes for a bunch of drivers. This patch fixes all of
them back up to be properly aligned.
Bonus is that this almost removes 100 lines of code, always a nice
surprise.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Santiago Leon <santil@linux.vnet.ibm.com>
This patch fixes a bug found by Nish Aravamudan
(https://lkml.org/lkml/2012/5/15/220) where the driver is not following
the spec (it is not aligning the rx buffer on a 16-byte boundary) and the
hypervisor aborts the registration, making the device unusable.
The fix follows BenH's recommendation (https://lkml.org/lkml/2012/7/20/461)
to replace the kmalloc+map for a single call to dma_alloc_coherent()
because that function always aligns to a 16-byte boundary.
The stable trees will run into this bug whenever the rx buffer kmalloc call
returns something not aligned on a 16-byte boundary.
Cc: <stable@vger.kernel.org>
Signed-off-by: Santiago Leon <santil@linux.vnet.ibm.com>
This makes vio_register_driver() get the module owner & name at compile
time like PCI drivers do, and adds a name pointer directly in struct
vio_driver to avoid having to explicitly initialize the embedded
struct device.
v2: add couple missing conversions in drivers
split unexporting netdev_fix_features()
implemented %pNF
convert sock::sk_route_(no?)caps
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
To ease skb->truesize sanitization, its better to be able to localize
all references to skb frags size.
Define accessors : skb_frag_size() to fetch frag size, and
skb_frag_size_{set|add|sub}() to manipulate it.
net/batman-adv/soft-interface.c
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: netdev@vger.kernel.org
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Move the IBM drivers into drivers/net/ethernet/ibm/ and make the
necessary Kconfig and Makefile changes.
- Renamed ibm_new_emac to emac
- Cleaned up Makefile and Kconfig options which referred to
IBM_NEW_EMAC to IBM_EMAC
- ibmlana driver is a National Semiconductor SONIC driver so
it was not moved
CC: Christoph Raisch <raisch@de.ibm.com>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: David Gibson <dwg@au1.ibm.com>
CC: Kyle Lucke <klucke@us.ibm.com>
CC: Michael Ellerman <michael@ellerman.id.au>
