[ Upstream commit e928b5d6b75e239feb9c6d5488974b6646a0ebc8 ]
If mv643xx_eth_shared_of_probe() fails, mv643xx_eth_shared_probe()
leaves clk enabled.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
The coalesce settings behave badly when changing just one value:
... # ethtool -c eth0
rx-usecs: 249
... # ethtool -C eth0 tx-usecs 250
rx-usecs: 248
This occurs due to rounding errors when calculating the microseconds
value - the divisons round down. This causes (eg) the rx-usecs to
decrease by one every time the tx-usecs value is set as per the above.
Fix this by making the divison round-to-nearest.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The MAC is capable of RGMII mode and that is probably a more typical
connection type than GMII today (eg it is used by Marvell Reference
designs for several SOCs). Let DT users specify the standard
phy-connection-type = "rgmii-id";
On a phy node.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
The code in txq_put_data() would use txq->tx_curr_desc to index the
tso_hdrs/tso_hdrs_dma buffers, for less than 8 bytes unaligned
fragments, which is already moved to the next descriptor at the
beginning of the function.
If that fragment was the last of the the skb, the next skb would use
that same space to place the ip headers, overwritting that small
fragment data.
Fixes: 91986fd3d335 (net: mv643xx_eth: Ensure proper data alignment in TSO TX path)
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
Reviewed-by: Philipp Kirchhofer <philipp@familie-kirchhofer.de>
Not all devices attached to an MDIO bus are phys. So add an
mdio_device structure to represent the generic parts of an mdio
device, and place this structure into the phy_device.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
These new helpers simplify implementing multi-driver modules and
properly handle failure to register one driver by unregistering all
previously registered drivers.
Signed-off-by: Thierry Reding <treding@nvidia.com>
for_each_available_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
// <smpl>
expression root,e;
local idexpression child;
for_each_available_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
return child;
+ of_node_put(child);
? return ...;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
net/ipv6/xfrm6_output.c
net/openvswitch/flow_netlink.c
net/openvswitch/vport-gre.c
net/openvswitch/vport-vxlan.c
net/openvswitch/vport.c
net/openvswitch/vport.h
The openvswitch conflicts were overlapping changes. One was
the egress tunnel info fix in 'net' and the other was the
vport ->send() op simplification in 'net-next'.
The xfrm6_output.c conflicts was also a simplification
overlapping a bug fix.
To prevent a race between the TX DMA engine and the CPU the writing of the
first transmit descriptor must be deferred until all following descriptors
have been updated. The network card may otherwise start transmitting before
all packet descriptors are set up correctly, which leads to data corruption
or an aborted transmit operation.
This deferral is already done in the non-TSO TX path, implement it also in
the TSO TX path.
Signed-off-by: Philipp Kirchhofer <philipp@familie-kirchhofer.de>
The TX DMA engine requires that buffers with a size of 8 bytes or smaller
must be 64 bit aligned. This requirement may be violated when doing TSO,
as in this case larger skb frags can be broken up and transmitted in small
parts with then inappropriate alignment.
Fix this by checking for proper alignment before handing a buffer to the
DMA engine. If the data is misaligned realign it by copying it into the
TSO header data area.
Many drivers initialize uselessly n_priv_flags, n_stats, testinfo_len,
eedump_len & regdump_len fields in their .get_drvinfo() ethtool op.
It's not necessary as these fields is filled in ethtool_get_drvinfo().
v2: removed unused variable
v3: removed another unused variable
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
The code around the allocation and loops are a bit obfuscated.
Neaten it by using:
o kcalloc with decimal count and sizeof(u32)
o Decimal loop indexing and i++ not i += 4
o A promiscuous block using a similar style
to the multicast block
o Remove unnecessary variables
The double memset is a little ugly; using kzalloc avoids it altogether.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e, func, da;
-init_timer (&e);
+setup_timer (&e, func, da);
-e.data = da;
-e.function = func;
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
Commit 69ad0dd7af22b61d9e0e68e56b6290121618b0fb
Author: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Date: Mon May 19 13:59:59 2014 -0300
net: mv643xx_eth: Use dma_map_single() to map the skb fragments
caused a nasty regression by removing the support for highmem skb
fragments. By using page_address() to get the address of a fragment's
page, we are assuming a lowmem page. However, such assumption is incorrect,
as fragments can be in highmem pages, resulting in very nasty issues.
This commit fixes this by using the skb_frag_dma_map() helper,
which takes care of mapping the skb fragment properly. Additionally,
the type of mapping is now tracked, so it can be unmapped using
dma_unmap_page or dma_unmap_single when appropriate.
This commit also fixes the error path in txq_init() to release the
resources properly.
Fixes: 69ad0dd7af22 ("net: mv643xx_eth: Use dma_map_single() to map the skb fragments")
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
ATM, txq_reclaim will dequeue and free an skb for each tx desc released
by the hw that has TX_LAST_DESC set. However, in case of TSO, each
hw desc embedding the last part of a segment has TX_LAST_DESC set,
losing the one-to-one 'last skb frag'/'TX_LAST_DESC set' correspondance,
which causes data corruption.
Fix this by checking TX_ENABLE_INTERRUPT instead of TX_LAST_DESC, and
warn when trying to dequeue from an empty txq (which can be symptomatic
of releasing skbs prematurely).
Fixes: 3ae8f4e0b98 ('net: mv643xx_eth: Implement software TSO')
Reported-by: Slawomir Gajzner <slawomir.gajzner@gmail.com>
Reported-by: Julien D'Ascenzio <jdascenzio@yahoo.fr>
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The buffers for the TSO headers belong to a DMA coherent region which is
allocated at ndo_open() time, and released at ndo_stop() time.
Therefore, and contrary to the TSO payload descriptor buffers, the TSO header
buffers don't need to be unmapped. This commit adds a check to detect a
TSO header buffer and explicitly prevent the unmap.
After adding proper stop/wake thresholds, we can expect a queue to never
be full and drop the NETDEV_TX_BUSY return path. In any case, if the queue
cannot accommodate a TSO packet, the packet would be discarded.
Currently small MSS values may require too many TSO descriptors for
the default queue size. This commit prevents this situation by fixing
the maximum supported TSO number of segments to 100 and by setting a
minimum Tx queue size. The minimum Tx queue size is set so that at
least 2 worst-case skb can be accommodated.
In addition, the queue stop and wake thresholds values are adjusted
accordingly. The queue is stopped when there's room for only 1 worst-case
skb and waked when the number of descriptors is half that value.
This commit fixes the current dropped packet count by doing it properly,
increasing the count when a packet is discarded; i.e. the packet is not
processed and the driver returns NETDEV_TX_OK.
Currently, mv643xx_eth_adjust_link() is only used to call mv643xx_adjust_pscr().
This commit renames the latter to the former, and therefore removes the extra
and useless function.
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Now that the TSO helper API has been introduced, this commit makes use
of it to add support for software TSO in this driver.
This feature allows to improve outbound throughput performance significantly.
Running iperf tests shows a 30% improvement, tested on a Kirkwood Openblocks
A6 board.
$ ethtool -K eth0 tso off
$ iperf -c 192.168.0.45 -t 3
Client connecting to 192.168.0.45, TCP port 5001
TCP window size: 43.8 KByte (default)
[ 3] local 192.168.0.159 port 46389 connected with 192.168.0.45 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 3.0 sec 217 MBytes 607 Mbits/sec
$ ethtool -K eth0 tso on
[ 3] local 192.168.0.159 port 46390 connected with 192.168.0.45 port 5001
[ 3] 0.0- 3.0 sec 336 MBytes 938 Mbits/sec
This commit is just an example of the usage of the TSO API, it works fine
but needs some more work. In particular, the descriptor unmapping path must
avoid unmapping the TSO headers.
Using dma_map_single() instead of skb_frag_dma_map() allows to unmap
all the descriptors using dma_unmap_single(). This change allows
to introduce software TSO in a less intrusive way.
In order to ease the addition of new features, let's factorize the
feature list.
As specified in the datasheet, the driver can set the "L4Chk_Mode" flag
(bit 10) in the Tx descriptor command/status to specify that a frame is not
IP fragmented and that the controller is in charge of generating the TCP/IP
checksum. This must be used together with the "GL4chk" flag (bit 17).
These two flags allow to avoid setting the initial TCP checksum in the l4i_chk
field of the Tx descriptor, which is needed to support software TSO.
Make the code more readable by moving the initial checksum setup
and the command/status preparation to its own function.
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
Replace dev_kfree_skb with dev_kfree_skb_any in mv643xx_eth_xmit and
txq_submit_skb that can be called in hard irq and other contexts,
on paths where the skbs are dropped.
When using phydev, it should be phy_start/phy_stop'ed properly. This
driver doesn't do that, so add the corresponding calls to port_start/
stop respectively.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Instead of open-coding a PHY reset through the MII BMCR register, use
phy_init_hw() which does that for us and will also make sure that PHY
fixups are applied if required. We also remove a call to phy_reset()
due to the following sequence of calls in the driver:
phy_scan()
-> phy_connect()
-> phy_connect_direct()
-> phy_attach_direct()
-> phy_init_hw()
and we only have a call to phy_init() after phy_scan().
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Santosh Raspatur <santosh@chelsio.com>
CC: Dimitris Michailidis <dm@chelsio.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Santiago Leon <santil@linux.vnet.ibm.com>
CC: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
CC: Olof Johansson <olof@lixom.net>
CC: Manish Chopra <manish.chopra@qlogic.com>
CC: Sony Chacko <sony.chacko@qlogic.com>
CC: Rajesh Borundia <rajesh.borundia@qlogic.com>
CC: Nicolas Pitre <nico@fluxnic.net>
CC: Steve Glendinning <steve.glendinning@shawell.net>
We assume that "mp->phy" can be NULL a couple lines before the
dereference.
Fixes: 1cce16d37d0f ('net: mv643xx_eth: Add missing phy_addr_set in DT mode')
Acked-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Commit cc9d4598 'net: mv643xx_eth: use of_phy_connect if phy_node
present' made the call to phy_scan optional, if the DT has a link to
the phy node.
However phy_scan has the side effect of calling phy_addr_set, which
writes the phy MDIO address to the ethernet controller. If phy_addr_set
is not called, and the bootloader has not set the correct address then
the driver will fail to function.
Tested on Kirkwood.
Tested-by: Arnaud Ebalard <arno@natisbad.org>
include/linux/netdevice.h
net/core/sock.c
Trivial merge issues.
Removal of "extern" for functions declaration in netdevice.h
at the same time "const" was added to an argument.
Two parallel line additions in net/core/sock.c
DT-based mv643xx_eth probes and creates platform_devices for the
port devices on its own. To allow fixups for ports based on the
device_node, we need to set .of_node of the corresponding device
with the correct node.
Acked-by: Jason Cooper <jason@lakedaemon.net>
The periodic statistics timer gets started at port _probe() time, but
is stopped on _stop() only. In a modular environment, this can cause
the timer to access already deallocated memory, if the module is unloaded
without starting the eth device. To fix this, we add the timer right
before the port is started, instead of at _probe() time.
Each port driver installs a periodic timer to update port statistics
by calling mib_counters_update. As mib_counters_update is also called
from non-timer context, we should not reschedule the timer there but
rather move it to timer-only context.
Convert the memset/memcpy uses of 6 to ETH_ALEN
where appropriate.
Also convert some struct definitions and u8 array
declarations of [6] to ETH_ALEN.
Acked-by: Arend van Spriel <arend@broadcom.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change
to make the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The port number is only local to the ethernet block, not global, so
there can be two ethernet blocks both using the same port, like
kirkwood with both using port 0.
Fix this by using the array index offset for the allocated platform
devices as the id.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
drivers/net/ethernet/freescale/fec_main.c
drivers/net/ethernet/renesas/sh_eth.c
net/ipv4/gre.c
The GRE conflict is between a bug fix (kfree_skb --> kfree_skb_list)
and the splitting of the gre.c code into seperate files.
The FEC conflict was two sets of changes adding ethtool support code
in an "!CONFIG_M5272" CPP protected block.
Finally the sh_eth.c conflict was between one commit add bits set
in the .eesr_err_check mask whilst another commit removed the
.tx_error_check member and assignments.
Zero pointer in rx_skb is how respective rxq_deinit() finds out out that a skb
slot is unallocated. If rxq_refill() fails (e.g. on OOM condition), subsequent
teardown would result in an attempt to kfree() invalid pointers.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: netdev@vger.kernel.org
The change set of 4305b541 "[SK_BUFF]: Convert skb->end to sk_buff_data_t"
converted skb->end from pointer to sk_buff_data_t.
The pointed value should be accessed via skb_end_pointer().
Since arm or ppc arch doesn't define NET_SKBUFF_DATA_USES_OFFSET,
skb->end is effectively pointer. So it doesn't cause a real problem.
But this patch is good for consistency.
Found by inspection. Compile test only.
Cc: Simon Horman <horms@verge.net.au>
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
Reviewed-by: Simon Horman <horms@verge.net.au>
76723bca28 "net: mv643xx_eth: add DT parsing support" added a
dummy mv643xx_eth_shared_of_probe() fallback function with a
typo.
This adds the missing semicolon so we can build without CONFIG_OF
again, and changes both dummy functions to the more conventional
"static inline" syntax, which can avoid potential problems with
the empty macro.
This adds device tree parsing support for the shared driver of mv643xx_eth.
As the bindings are slightly different from current PPC bindings new binding
documentation is also added. Following PPC-style device setup, the shared
driver now also adds port platform_devices and sets up port platform_data.
Ethernet controllers found on Kirkwood SoCs not only suffer from loosing
MAC address register contents on clock gating but also some important
registers are reset to values that would break ethernet. This patch
clears the CLK125_BYPASS_EN bit for DT enabled Kirkwood only by using
of_device_is_compatible() instead of #ifdefs. Non-DT Kirkwood is not
affected as it installs a clock gating workaround because of the MAC
address issue above. Other Orion SoCs do not suffer from register reset,
do not have the bit in question, or do not have the register at all.
Moreover, system controllers on PPC using this driver should also be
protected from clearing that bit.
This connects to a phy node passed to the port device instead of probing
the phy by phy_addr.
