Trivial fix to spelling mistakes in the mlx4 driver
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Add the SET_VPORT_QOS device command, which is ntended for virtual
granular QoS configuration per VF in SRIOV mode. The SET_VPORT_QOS
command sets and queries QoS parameters of a VPort. Each priority
allowed for a VPort is assigned with a share of the BW, and a BW
limitation. QoS parameters can be modified at any time, but must be
initialized before any QP is associated with the VPort.
Signed-off-by: Ido Shamay <idos@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Implements device ALLOCATE_VPP command, to be used for granular QoS
configuration of VFs by the PF device. Defines and queries the amount
of VPPs assigned to each port, and the amount of VPPs assigned to each
priority of each port. Once the total VPPs are split between the priorities
of a port, they may be assigned with a share of the BW or a rate limit.
Split into two functions (get/set) whoch are supplied with
mlx4_alloc_vpp_context and physical port number.
Create two new files fw_qos.h and fw_qos.c in mlx4_core module.
It gathers all relevant QoS firmware related commands etc, thus improving
encapsulation of the mlx4_core module. For now it contains the QoS existing
commands: mlx4_SET_PORT_SCHEDULER and mlx4_SET_PORT_PRIO2TC.
