[ Upstream commit d585df1c5ccf995fcee910705ad7a9cdd11d4152 ]
Some Hypervisors detach VFs from VMs by instantly causing an FLR event
to be generated for a VF.
In the mlx4 case, this will cause that VF's comm channel to be disabled
before the VM has an opportunity to invoke the VF device's "shutdown"
method.
The result is that the VF driver on the VM will experience a command
timeout during the shutdown process when the Hypervisor does not deliver
a command-completion event to the VM.
To avoid FW command timeouts on the VM when the driver's shutdown method
is invoked, we detect the absence of the VF's comm channel at the very
start of the shutdown process. If the comm-channel has already been
disabled, we cause all FW commands during the device shutdown process to
immediately return success (and thus avoid all command timeouts).
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Verify that the device state is registered before un-registering it.
This check is required to prevent an OOPS on flows that do
re-registration of the device and its previous state was
unregistered.
Fixes: 225c7b1feef1 ("IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adapters")
Signed-off-by: Alex Vesker <valex@mellanox.com>
Silent a few smatch warnings about indentation.
This include the removal of a 'return' statement in 'resource_tracker.c'.
This 'return' will still be performed when breaking out of the
corresponding 'switch' block.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Implement newly introduced devlink interface. Add devlink port instances
for every port and set the port types accordingly.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
v2->v3:
-add dev param to devlink_register (api change)
The mlx4 network driver was registered in the context of the 'add'
function of the core driver (called when HW should be registered).
This makes the netdev event NETDEV_REGISTER to be sent in a context
where the answer to get_protocol_dev() callback returns NULL. This may
be confusing to listeners of netdev events.
This patch is a preparation to the patch that implements the
get_netdev() callback in the IB/mlx4 driver.
Signed-off-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
When in HA mode, the driver exposes an IB (RoCE) device instance with only
one port. Under SRIOV, the existing implementation doesn't go well with
the PF RoCE driver's role of Special QPs Para-Virtualization, etc.
As such, disable HA for the mlx4 PF RoCE device in SRIOV mode.
Fixes: a57500903093 ('IB/mlx4: Add port aggregation support')
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Supply interface functions to bond and unbond ports of a mlx4 internal
interfaces. Example for such an interface is the one registered by the
mlx4 IB driver under RoCE.
There are
1. Functions to go in/out to/from bonded mode
2. Function to remap virtual ports to physical ports
The bond_mutex prevents simultaneous access to data that keep status of
the device in bonded mode.
The upper mlx4 interface marks to the mlx4 core module that they
want to be subject for such bonding by setting the MLX4_INTFF_BONDING
flag. Interface which goes to/from bonded mode is re-created.
The mlx4 Ethernet driver does not set this flag when registering the
interface, the IB driver does.
In SRIOV, both the PF and the VF may attempt device recovery whenever they
assume that the device is not functioning. When the PF driver resets the
device, the VF should detect this and attempt to reinitialize itself.
The VF must be able to reset itself under all circumstances, even
if the PF is not responsive.
The VF shall reset itself in the following cases:
1. Commands are not processed within reasonable time over the communication channel.
This is done considering device state and the correct return code based on
the command as was done in the native mode, done in the next patch.
2. The VF driver receives an internal error event reported by the PF on the
communication channel. This occurs when the PF driver resets the device or
when VF is out of sync with the PF.
Add 'VF reset' capability, which allows the VF to reinitialize itself even when the
As PF and VF may run their reset flow simulantanisly, there are several cases
that are handled:
- Prevent freeing VF resources upon FLR, when PF is in its unloading stage.
- Prevent PF getting VF commands before it has finished initializing its resources.
- Upon VF startup, check that comm-channel is online before sending
commands to the PF and getting timed-out.
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
We need to manage interface state to sync between reset flow and some other
relative cases such as remove_one. This has to be done to prevent certain
races. For example in case software stack is down as a result of unload call,
the remove_one should skip the unload phase.
Implement the remove_one case, handling AER and other cases comes next.
The interface can be up/down, upon remove_one, the state will include an extra
bit indicating that the device is cleaned-up, forcing other tasks to finish
before the final cleanup.
The port management change event can replace smp_snoop. If the
capability bit for this event is set in dev-caps, the event is used
(by the driver setting the PORT_MNG_CHG_EVENT bit in the async event
mask in the MAP_EQ fw command). In this case, when the driver passes
incoming SMP PORT_INFO SET mads to the FW, the FW generates port
management change events to signal any changes to the driver.
If the FW generates these events, smp_snoop shouldn't be invoked in
ib_process_mad(), or duplicate events will occur (once from the
FW-generated event, and once from smp_snoop).
In the case where the FW does not generate port management change
events smp_snoop needs to be invoked to create these events. The flow
in smp_snoop has been modified to make use of the same procedures as
in the fw-generated-event event case to generate the port management
events (LID change, Client-rereg, Pkey change, and/or GID change).
Port management change event handling required changing the
mlx4_ib_event and mlx4_dispatch_event prototypes; the "param" argument
(last argument) had to be changed to unsigned long in order to
accomodate passing the EQE pointer.
We also needed to move the definition of struct mlx4_eqe from
net/mlx4.h to file device.h -- to make it available to the IB driver,
to handle port management change events.
Signed-off-by: Roland Dreier <roland@purestorage.com>
When running in SRIOV mode, driver should not automatically start/stop
the mlx4_core upon sensing an HCA internal error -- doing this disables/enables
sriov, which will cause the hypervisor to hang if there are running VMs with
attached VFs.
In addition, on VMs the catas process should not run at all, since the HCA
error buffer is not available to VMs in the BARs.
These were getting the macros from an implicit module.h
include via device.h, but we are planning to clean that up.
drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c
This relatively recently added file uses EXPORT_SYMBOL and hence
needs export.h included so that it is compatible with the module.h
split up work.
Moves the Mellanox driver into drivers/net/ethernet/mellanox/ and
make the necessary Kconfig and Makefile changes.
CC: Roland Dreier <roland@kernel.org>
