commit b645e57debca846f51b3209907546ea857ddd3f5 upstream.
Add missing call to up_write_ref_node() which releases the semaphore
in case the FTE doesn't have destinations, such in drop rule case.
Fixes: 465e7baab6d9 ("net/mlx5: Fix deletion of duplicate rules")
Signed-off-by: Maor Gottlieb <maorg@nvidia.com>
Reviewed-by: Mark Bloch <mbloch@nvidia.com>
Signed-off-by: Saeed Mahameed <saeedm@nvidia.com>
commit ee27e330a953595903979ffdb84926843595a9fe upstream.
Fixes the below flow of sleeping in atomic context by releasing
the RCU lock before calling to free_match_list.
build_match_list() <- disables preempt
-> free_match_list()
-> tree_put_node()
-> down_write_ref_node() <- take write lock
Fixes: 693c6883bbc4 ("net/mlx5: Add hash table for flow groups in flow table")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 8b54874ef1617185048029a3083d510569e93751 ]
Fix a bug when flow table is created in priority that already
has other flow tables as shown in the below diagram.
If the new flow table (FT-B) has the lowest level in the priority,
we need to connect the flow tables from the previous priority (p0)
to this new table. In addition when this flow table is destroyed
(FT-B), we need to connect the flow tables from the previous
priority (p0) to the next level flow table (FT-C) in the same
priority of the destroyed table (if exists).
|root_ns|
|p(prio)-x| | p-y | | p-n |
|ns(e.g bypass)| |ns(e.g. kernel) |
| p0 | | p1 | |p2|
| FT-A | |FT-B | |FT-C|
Fixes: f90edfd279f3 ("net/mlx5_core: Connect flow tables")
[ Upstream commit a5bfe6b4675e0eefbd9418055b5cc6e89af27eb4 ]
When creation of a new rule that requires allocation of an FTE fails,
need to call to tree_put_node on the FTE in order to release its'
resource.
Fixes: cefc23554fc2 ("net/mlx5: Fix FTE cleanup")
Reviewed-by: Alaa Hleihel <alaa@nvidia.com>
[ Upstream commit 487c6ef81eb98d0a43cb08be91b1fcc9b4250626 ]
When we create the ft object we also init rhltable in ft->fgs_hash.
So in error flow before kfree of ft we need to destroy that rhltable.
Signed-off-by: Roi Dayan <roid@nvidia.com>
Reviewed-by: Maor Dickman <maord@nvidia.com>
[ Upstream commit 8cbcc5ef2a281f6bb10099f4572a08cb765ffbf4 ]
Handle destruction of rules with port destination type to enable
full destruction of flow.
Without this handling of TX rules the deletion of these rules fails.
Dmesg of flow destruction failure:
[ 203.714146] mlx5_core 0000:00:0b.0: mlx5_cmd_check:753:(pid 342): SET_FLOW_TABLE_ENTRY(0x936) op_mod(0x0) failed, status bad parameter(0x3), syndrome (0x144b7a)
[ 210.547387] ------------[ cut here ]------------
[ 210.548663] refcount_t: decrement hit 0; leaking memory.
[ 210.550651] WARNING: CPU: 4 PID: 342 at lib/refcount.c:31 refcount_warn_saturate+0x5c/0x110
[ 210.550654] Modules linked in: mlx5_ib mlx5_core ib_ipoib rdma_ucm rdma_cm iw_cm ib_cm ib_umad ib_uverbs ib_core
[ 210.550675] CPU: 4 PID: 342 Comm: test Not tainted 5.8.0-rc2+ #116
[ 210.550678] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.1-0-ga5cab58e9a3f-prebuilt.qemu.org 04/01/2014
[ 210.550680] RIP: 0010:refcount_warn_saturate+0x5c/0x110
[ 210.550685] Code: c6 d1 1b 01 00 0f 84 ad 00 00 00 5b 5d c3 80 3d b5 d1 1b 01 00 75 f4 48 c7 c7 20 d1 15 82 c6 05 a5 d1 1b 01 01 e8 a7 eb af ff <0f> 0b eb dd 80 3d 99 d1 1b 01 00 75 d4 48 c7 c7 c0 cf 15 82 c6 05
[ 210.550687] RSP: 0018:ffff8881642e77e8 EFLAGS: 00010282
[ 210.550691] RAX: 0000000000000000 RBX: 0000000000000004 RCX: 0000000000000000
[ 210.550694] RDX: 0000000000000027 RSI: 0000000000000004 RDI: ffffed102c85ceef
[ 210.550696] RBP: ffff888161720428 R08: ffffffff8124c10e R09: ffffed103243beae
[ 210.550698] R10: ffff8881921df56b R11: ffffed103243bead R12: ffff8881841b4180
[ 210.550701] R13: ffff888161720428 R14: ffff8881616d0000 R15: ffff888161720380
[ 210.550704] FS: 00007fc27f025740(0000) GS:ffff888192000000(0000) knlGS:0000000000000000
[ 210.550706] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 210.550708] CR2: 0000557e4b41a6a0 CR3: 0000000002415004 CR4: 0000000000360ea0
[ 210.550711] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 210.550713] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 210.550715] Call Trace:
[ 210.550717] mlx5_del_flow_rules+0x484/0x490 [mlx5_core]
[ 210.550720] ? mlx5_cmd_set_fte+0xa80/0xa80 [mlx5_core]
[ 210.550722] mlx5_ib_destroy_flow+0x17f/0x280 [mlx5_ib]
[ 210.550724] uverbs_free_flow+0x4c/0x90 [ib_uverbs]
[ 210.550726] destroy_hw_idr_uobject+0x41/0xb0 [ib_uverbs]
[ 210.550728] uverbs_destroy_uobject+0xaa/0x390 [ib_uverbs]
[ 210.550731] __uverbs_cleanup_ufile+0x129/0x1b0 [ib_uverbs]
[ 210.550733] ? uverbs_destroy_uobject+0x390/0x390 [ib_uverbs]
[ 210.550735] uverbs_destroy_ufile_hw+0x78/0x190 [ib_uverbs]
[ 210.550737] ib_uverbs_close+0x36/0x140 [ib_uverbs]
[ 210.550739] __fput+0x181/0x380
[ 210.550741] task_work_run+0x88/0xd0
[ 210.550743] do_exit+0x5f6/0x13b0
[ 210.550745] ? sched_clock_cpu+0x30/0x140
[ 210.550747] ? is_current_pgrp_orphaned+0x70/0x70
[ 210.550750] ? lock_downgrade+0x360/0x360
[ 210.550752] ? mark_held_locks+0x1d/0x90
[ 210.550754] do_group_exit+0x8a/0x140
[ 210.550756] get_signal+0x20a/0xf50
[ 210.550758] do_signal+0x8c/0xbe0
[ 210.550760] ? hrtimer_nanosleep+0x1d8/0x200
[ 210.550762] ? nanosleep_copyout+0x50/0x50
[ 210.550764] ? restore_sigcontext+0x320/0x320
[ 210.550766] ? __hrtimer_init+0xf0/0xf0
[ 210.550768] ? timespec64_add_safe+0x150/0x150
[ 210.550770] ? mark_held_locks+0x1d/0x90
[ 210.550772] ? lockdep_hardirqs_on_prepare+0x14c/0x240
[ 210.550774] __prepare_exit_to_usermode+0x119/0x170
[ 210.550776] do_syscall_64+0x65/0x300
[ 210.550778] ? trace_hardirqs_off+0x10/0x120
[ 210.550781] ? mark_held_locks+0x1d/0x90
[ 210.550783] ? asm_sysvec_apic_timer_interrupt+0xa/0x20
[ 210.550785] ? lockdep_hardirqs_on+0x112/0x190
[ 210.550787] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 210.550789] RIP: 0033:0x7fc27f1cd157
[ 210.550791] Code: Bad RIP value.
[ 210.550793] RSP: 002b:00007ffd4db27ea8 EFLAGS: 00000246 ORIG_RAX: 0000000000000023
[ 210.550798] RAX: fffffffffffffdfc RBX: ffffffffffffff80 RCX: 00007fc27f1cd157
[ 210.550800] RDX: 00007fc27f025740 RSI: 00007ffd4db27eb0 RDI: 00007ffd4db27eb0
[ 210.550803] RBP: 0000000000000016 R08: 0000000000000000 R09: 000000000000000e
[ 210.550805] R10: 00007ffd4db27dc7 R11: 0000000000000246 R12: 0000000000400c00
[ 210.550808] R13: 00007ffd4db285f0 R14: 0000000000000000 R15: 0000000000000000
[ 210.550809] irq event stamp: 49399
[ 210.550812] hardirqs last enabled at (49399): [<ffffffff81172d36>] console_unlock+0x556/0x6f0
[ 210.550815] hardirqs last disabled at (49398): [<ffffffff81172897>] console_unlock+0xb7/0x6f0
[ 210.550818] softirqs last enabled at (48706): [<ffffffff81e0037b>] __do_softirq+0x37b/0x60c
[ 210.550820] softirqs last disabled at (48697): [<ffffffff81c00e2f>] asm_call_on_stack+0xf/0x20
[ 210.550822] ---[ end trace ad18c0e6fa846454 ]---
[ 210.581862] mlx5_core 0000:00:0c.0: mlx5_destroy_flow_table:2132:(pid 342): Flow table 262150 wasn't destroyed, refcount > 1
Fixes: a7ee18bdee83 ("RDMA/mlx5: Allow creating a matcher for a NIC TX flow table")
Signed-off-by: Michael Guralnik <michaelgur@nvidia.com>
Reviewed-by: Maor Gottlieb <maorg@nvidia.com>
[ Upstream commit 465e7baab6d93b399344f5868f84c177ab5cd16f ]
When a rule is duplicated, the refcount of the rule is increased so only
the second deletion of the rule should cause destruction of the FTE.
Currently, the FTE will be destroyed in the first deletion of rule since
the modify_mask will be 0.
Fix it and call to destroy FTE only if all the rules (FTE's children)
have been removed.
Fixes: 718ce4d601db ("net/mlx5: Consolidate update FTE for all removal changes")
[ Upstream commit cefc23554fc259114e78a7b0908aac4610ee18eb ]
Currently, when an FTE is allocated, its refcount is decreased to 0
with the purpose it will not be a stand alone steering object and every
rule (destination) of the FTE would increase the refcount.
When mlx5_cleanup_fs is called while not all rules were deleted by the
steering users, it hit refcount underflow on the FTE once clean_tree
calls to tree_remove_node after the deleted rules already decreased
the refcount to 0.
FTE is no longer destroyed implicitly when the last rule (destination)
is deleted. mlx5_del_flow_rules avoids it by increasing the refcount on
the FTE and destroy it explicitly after all rules were deleted. So we
can avoid the refcount underflow by making FTE as stand alone object.
In addition need to set del_hw_func to FTE so the HW object will be
destroyed when the FTE is deleted from the cleanup_tree flow.
refcount_t: underflow; use-after-free.
WARNING: CPU: 2 PID: 15715 at lib/refcount.c:28 refcount_warn_saturate+0xd9/0xe0
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.13.0-0-gf21b5a4aeb02-prebuilt.qemu.org 04/01/2014
Call Trace:
tree_put_node+0xf2/0x140 [mlx5_core]
clean_tree+0x4e/0xf0 [mlx5_core]
clean_tree+0x5f/0xf0 [mlx5_core]
mlx5_cleanup_fs+0x26/0x270 [mlx5_core]
mlx5_unload+0x2e/0xa0 [mlx5_core]
mlx5_unload_one+0x51/0x120 [mlx5_core]
mlx5_devlink_reload_down+0x51/0x90 [mlx5_core]
devlink_reload+0x39/0x120
? devlink_nl_cmd_reload+0x43/0x220
genl_rcv_msg+0x1e4/0x420
? genl_family_rcv_msg_attrs_parse+0x100/0x100
netlink_rcv_skb+0x47/0x110
genl_rcv+0x24/0x40
netlink_unicast+0x217/0x2f0
netlink_sendmsg+0x30f/0x430
sock_sendmsg+0x30/0x40
__sys_sendto+0x10e/0x140
? handle_mm_fault+0xc4/0x1f0
? do_page_fault+0x33f/0x630
__x64_sys_sendto+0x24/0x30
do_syscall_64+0x48/0x130
Fixes: bd71b08ec2ee ("net/mlx5: Support multiple updates of steering rules in parallel")
[ Upstream commit 6c4e9bcfb48933d533ff975e152757991556294a ]
The WARN_*() macros are intended to catch impossible situations
from the SW point of view. They gave a little in case HW<->SW interface
is out-of-sync.
Such out-of-sync scenario can be due to SW errors that are not part
of this flow or because some HW errors, where dump stack won't help
either.
This specific WARN_ON() is useless because mlx5_core code is prepared
to handle such situations and will unfold everything correctly while
providing enough information to the users to understand why FS is not
working.
WARNING: CPU: 0 PID: 3222 at drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:825 connect_fts_in_prio.isra.20+0x1dd/0x260 linux/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:825
Kernel panic - not syncing: panic_on_warn set ...
CPU: 0 PID: 3222 Comm: syz-executor861 Not tainted 5.5.0-rc6+ #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS
Call Trace:
__dump_stack linux/lib/dump_stack.c:77 [inline]
dump_stack+0x94/0xce linux/lib/dump_stack.c:118
panic+0x234/0x56f linux/kernel/panic.c:221
__warn+0x1cc/0x1e1 linux/kernel/panic.c:582
report_bug+0x200/0x310 linux/lib/bug.c:195
fixup_bug.part.11+0x32/0x80 linux/arch/x86/kernel/traps.c:174
fixup_bug linux/arch/x86/kernel/traps.c:273 [inline]
do_error_trap+0xd3/0x100 linux/arch/x86/kernel/traps.c:267
do_invalid_op+0x31/0x40 linux/arch/x86/kernel/traps.c:286
invalid_op+0x1e/0x30 linux/arch/x86/entry/entry_64.S:1027
RIP: 0010:connect_fts_in_prio.isra.20+0x1dd/0x260
Code: 00 00 48 c7 c2 60 8c 31 84 48 c7 c6 00 81 31 84 48 8b 38 e8 3c a8
cb ff 41 83 fd 01 8b 04 24 0f 8e 29 ff ff ff e8 83 7b bc fe <0f> 0b 8b
04 24 e9 1a ff ff ff 89 04 24 e8 c1 20 e0 fe 8b 04 24 eb
RSP: 0018:ffffc90004bb7858 EFLAGS: 00010293
RAX: ffff88805de98e80 RBX: 0000000000000c96 RCX: ffffffff827a853d
RDX: 0000000000000000 RSI: 0000000000000000 RDI: fffff52000976efa
RBP: 0000000000000007 R08: ffffed100da060e3 R09: ffffed100da060e3
R10: 0000000000000001 R11: ffffed100da060e2 R12: dffffc0000000000
R13: 0000000000000002 R14: ffff8880683a1a10 R15: ffffed100d07bc1c
connect_prev_fts linux/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:844 [inline]
connect_flow_table linux/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:975 [inline]
__mlx5_create_flow_table+0x8f8/0x1710 linux/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:1064
mlx5_create_flow_table linux/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:1094 [inline]
mlx5_create_auto_grouped_flow_table+0xe1/0x210 linux/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c:1136
_get_prio linux/drivers/infiniband/hw/mlx5/main.c:3286 [inline]
get_flow_table+0x2ea/0x760 linux/drivers/infiniband/hw/mlx5/main.c:3376
mlx5_ib_create_flow+0x331/0x11c0 linux/drivers/infiniband/hw/mlx5/main.c:3896
ib_uverbs_ex_create_flow+0x13e8/0x1b40 linux/drivers/infiniband/core/uverbs_cmd.c:3311
ib_uverbs_write+0xaa5/0xdf0 linux/drivers/infiniband/core/uverbs_main.c:769
__vfs_write+0x7c/0x100 linux/fs/read_write.c:494
vfs_write+0x168/0x4a0 linux/fs/read_write.c:558
ksys_write+0xc8/0x200 linux/fs/read_write.c:611
do_syscall_64+0x9c/0x390 linux/arch/x86/entry/common.c:294
RIP: 0033:0x45a059
Code: 00 00 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 89 f8 48 89
f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01
f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007fcc17564c98 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 00007fcc17564ca0 RCX: 000000000045a059
RDX: 0000000000000030 RSI: 00000000200003c0 RDI: 0000000000000005
RBP: 0000000000000007 R08: 0000000000000002 R09: 0000000000003131
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000006e636c
R13: 0000000000000000 R14: 00000000006e6360 R15: 00007ffdcbdaf6a0
Dumping ftrace buffer:
(ftrace buffer empty)
Kernel Offset: disabled
Rebooting in 1 seconds..
Reviewed-by: Maor Gottlieb <maorg@mellanox.com>
Reviewed-by: Mark Bloch <markb@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
This reverts commit 3f4f034a8676e366857861e76c3ad11ae059b2fb which is
commit 9ca415399dae133b00273a4283ef31d003a6818d upstream.
It was backported incorrectly, Paul writes at:
https://lore.kernel.org/r/20200607203425.GD23662@windriver.com
I happened to notice this commit:
9ca415399dae - "net/mlx5: Annotate mutex destroy for root ns"
...was backported to 4.19 and 5.4 and v5.6 in linux-stable.
It patches del_sw_root_ns() - which only exists after v5.7-rc7 from:
6eb7a268a99b - "net/mlx5: Don't maintain a case of del_sw_func being
null"
which creates the one line del_sw_root_ns stub function around
kfree(node) by breaking it out of tree_put_node().
In the absense of del_sw_root_ns - the backport finds an identical one
line kfree stub fcn - named del_sw_prio from this earlier commit:
139ed6c6c46a - "net/mlx5: Fix steering memory leak" [in v4.15-rc5]
and then puts the mutex_destroy() into that (wrong) function, instead of
putting it into tree_put_node where the root ns case used to be hand
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Roi Dayan <roid@mellanox.com>
Cc: Mark Bloch <markb@mellanox.com>
Cc: Saeed Mahameed <saeedm@mellanox.com>
Invoke mutex_destroy() to catch any errors.
Fixes: 2cc43b494a6c ("net/mlx5_core: Managing root flow table")
Signed-off-by: Roi Dayan <roid@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit c1948390d78b5183ee9b7dd831efd7f6ac496ab0 ]
free_match_list could be called when the flow table is already
locked. We need to pass this notation to tree_put_node.
It fixes the following lockdep warnning:
[ 1797.268537] ============================================
[ 1797.276837] WARNING: possible recursive locking detected
[ 1797.285101] 5.5.0-rc5+ #10 Not tainted
[ 1797.291641] --------------------------------------------
[ 1797.299917] handler10/9296 is trying to acquire lock:
[ 1797.307885] ffff889ad399a0a0 (&node->lock){++++}, at:
tree_put_node+0x1d5/0x210 [mlx5_core]
[ 1797.319694]
[ 1797.319694] but task is already holding lock:
[ 1797.330904] ffff889ad399a0a0 (&node->lock){++++}, at:
nested_down_write_ref_node.part.33+0x1a/0x60 [mlx5_core]
[ 1797.344707]
[ 1797.344707] other info that might help us debug this:
[ 1797.356952] Possible unsafe locking scenario:
[ 1797.356952]
[ 1797.368333] CPU0
[ 1797.373357] ----
[ 1797.378364] lock(&node->lock);
[ 1797.384222] lock(&node->lock);
[ 1797.390031]
[ 1797.390031] *** DEADLOCK ***
[ 1797.390031]
[ 1797.403003] May be due to missing lock nesting notation
[ 1797.403003]
[ 1797.414691] 3 locks held by handler10/9296:
[ 1797.421465] #0: ffff889cf2c5a110 (&block->cb_lock){++++}, at:
tc_setup_cb_add+0x70/0x250
[ 1797.432810] #1: ffff88a030081490 (&comp->sem){++++}, at:
mlx5_devcom_get_peer_data+0x4c/0xb0 [mlx5_core]
[ 1797.445829] #2: ffff889ad399a0a0 (&node->lock){++++}, at:
[ 1797.459913]
[ 1797.459913] stack backtrace:
[ 1797.469436] CPU: 1 PID: 9296 Comm: handler10 Kdump: loaded Not
tainted 5.5.0-rc5+ #10
[ 1797.480643] Hardware name: Dell Inc. PowerEdge R730/072T6D, BIOS
2.4.3 01/17/2017
[ 1797.491480] Call Trace:
[ 1797.496701] dump_stack+0x96/0xe0
[ 1797.502864] __lock_acquire.cold.63+0xf8/0x212
[ 1797.510301] ? lockdep_hardirqs_on+0x250/0x250
[ 1797.517701] ? mark_held_locks+0x55/0xa0
[ 1797.524547] ? quarantine_put+0xb7/0x160
[ 1797.531422] ? lockdep_hardirqs_on+0x17d/0x250
[ 1797.538913] lock_acquire+0xd6/0x1f0
[ 1797.545529] ? tree_put_node+0x1d5/0x210 [mlx5_core]
[ 1797.553701] down_write+0x94/0x140
[ 1797.560206] ? tree_put_node+0x1d5/0x210 [mlx5_core]
[ 1797.568464] ? down_write_killable_nested+0x170/0x170
[ 1797.576925] ? del_hw_flow_group+0xde/0x1f0 [mlx5_core]
[ 1797.585629] tree_put_node+0x1d5/0x210 [mlx5_core]
[ 1797.593891] ? free_match_list.part.25+0x147/0x170 [mlx5_core]
[ 1797.603389] free_match_list.part.25+0xe0/0x170 [mlx5_core]
[ 1797.612654] _mlx5_add_flow_rules+0x17e2/0x20b0 [mlx5_core]
[ 1797.621838] ? lock_acquire+0xd6/0x1f0
[ 1797.629028] ? esw_get_prio_table+0xb0/0x3e0 [mlx5_core]
[ 1797.637981] ? alloc_insert_flow_group+0x420/0x420 [mlx5_core]
[ 1797.647459] ? try_to_wake_up+0x4c7/0xc70
[ 1797.654881] ? lock_downgrade+0x350/0x350
[ 1797.662271] ? __mutex_unlock_slowpath+0xb1/0x3f0
[ 1797.670396] ? find_held_lock+0xac/0xd0
[ 1797.677540] ? mlx5_add_flow_rules+0xdc/0x360 [mlx5_core]
[ 1797.686467] mlx5_add_flow_rules+0xdc/0x360 [mlx5_core]
[ 1797.695134] ? _mlx5_add_flow_rules+0x20b0/0x20b0 [mlx5_core]
[ 1797.704270] ? irq_exit+0xa5/0x170
[ 1797.710764] ? retint_kernel+0x10/0x10
[ 1797.717698] ? mlx5_eswitch_set_rule_source_port.isra.9+0x122/0x230
[mlx5_core]
[ 1797.728708] mlx5_eswitch_add_offloaded_rule+0x465/0x6d0 [mlx5_core]
[ 1797.738713] ? mlx5_eswitch_get_prio_range+0x30/0x30 [mlx5_core]
[ 1797.748384] ? mlx5_fc_stats_work+0x670/0x670 [mlx5_core]
[ 1797.757400] mlx5e_tc_offload_fdb_rules.isra.27+0x24/0x90 [mlx5_core]
[ 1797.767665] mlx5e_tc_add_fdb_flow+0xaf8/0xd40 [mlx5_core]
[ 1797.776886] ? mlx5e_encap_put+0xd0/0xd0 [mlx5_core]
[ 1797.785562] ? mlx5e_alloc_flow.isra.43+0x18c/0x1c0 [mlx5_core]
[ 1797.795353] __mlx5e_add_fdb_flow+0x2e2/0x440 [mlx5_core]
[ 1797.804558] ? mlx5e_tc_update_neigh_used_value+0x8c0/0x8c0
[mlx5_core]
[ 1797.815093] ? wait_for_completion+0x260/0x260
[ 1797.823272] mlx5e_configure_flower+0xe94/0x1620 [mlx5_core]
[ 1797.832792] ? __mlx5e_add_fdb_flow+0x440/0x440 [mlx5_core]
[ 1797.842096] ? down_read+0x11a/0x2e0
[ 1797.849090] ? down_write+0x140/0x140
[ 1797.856142] ? mlx5e_rep_indr_setup_block_cb+0xc0/0xc0 [mlx5_core]
[ 1797.866027] tc_setup_cb_add+0x11a/0x250
[ 1797.873339] fl_hw_replace_filter+0x25e/0x320 [cls_flower]
[ 1797.882385] ? fl_hw_destroy_filter+0x1c0/0x1c0 [cls_flower]
[ 1797.891607] fl_change+0x1d54/0x1fb6 [cls_flower]
[ 1797.899772] ? __rhashtable_insert_fast.constprop.50+0x9f0/0x9f0
[cls_flower]
[ 1797.910728] ? lock_downgrade+0x350/0x350
[ 1797.918187] ? __radix_tree_lookup+0xa5/0x130
[ 1797.926046] ? fl_set_key+0x1590/0x1590 [cls_flower]
[ 1797.934611] ? __rhashtable_insert_fast.constprop.50+0x9f0/0x9f0
[cls_flower]
[ 1797.945673] tc_new_tfilter+0xcd1/0x1240
[ 1797.953138] ? tc_del_tfilter+0xb10/0xb10
[ 1797.960688] ? avc_has_perm_noaudit+0x92/0x320
[ 1797.968721] ? avc_has_perm_noaudit+0x1df/0x320
[ 1797.976816] ? avc_has_extended_perms+0x990/0x990
[ 1797.985090] ? mark_lock+0xaa/0x9e0
[ 1797.991988] ? match_held_lock+0x1b/0x240
[ 1797.999457] ? match_held_lock+0x1b/0x240
[ 1798.006859] ? find_held_lock+0xac/0xd0
[ 1798.014045] ? symbol_put_addr+0x40/0x40
[ 1798.021317] ? rcu_read_lock_sched_held+0xd0/0xd0
[ 1798.029460] ? tc_del_tfilter+0xb10/0xb10
[ 1798.036810] rtnetlink_rcv_msg+0x4d5/0x620
[ 1798.044236] ? rtnl_bridge_getlink+0x460/0x460
[ 1798.052034] ? lockdep_hardirqs_on+0x250/0x250
[ 1798.059837] ? match_held_lock+0x1b/0x240
[ 1798.067146] ? find_held_lock+0xac/0xd0
[ 1798.074246] netlink_rcv_skb+0xc6/0x1f0
[ 1798.081339] ? rtnl_bridge_getlink+0x460/0x460
[ 1798.089104] ? netlink_ack+0x440/0x440
[ 1798.096061] netlink_unicast+0x2d4/0x3b0
[ 1798.103189] ? netlink_attachskb+0x3f0/0x3f0
[ 1798.110724] ? _copy_from_iter_full+0xda/0x370
[ 1798.118415] netlink_sendmsg+0x3ba/0x6a0
[ 1798.125478] ? netlink_unicast+0x3b0/0x3b0
[ 1798.132705] ? netlink_unicast+0x3b0/0x3b0
[ 1798.139880] sock_sendmsg+0x94/0xa0
[ 1798.146332] ____sys_sendmsg+0x36c/0x3f0
[ 1798.153251] ? copy_msghdr_from_user+0x165/0x230
[ 1798.160941] ? kernel_sendmsg+0x30/0x30
[ 1798.167738] ___sys_sendmsg+0xeb/0x150
[ 1798.174411] ? sendmsg_copy_msghdr+0x30/0x30
[ 1798.181649] ? lock_downgrade+0x350/0x350
[ 1798.188559] ? rcu_read_lock_sched_held+0xd0/0xd0
[ 1798.196239] ? __fget+0x21d/0x320
[ 1798.202335] ? do_dup2+0x2a0/0x2a0
[ 1798.208499] ? lock_downgrade+0x350/0x350
[ 1798.215366] ? __fget_light+0xd6/0xf0
[ 1798.221808] ? syscall_trace_enter+0x369/0x5d0
[ 1798.229112] __sys_sendmsg+0xd3/0x160
[ 1798.235511] ? __sys_sendmsg_sock+0x60/0x60
[ 1798.242478] ? syscall_trace_enter+0x233/0x5d0
[ 1798.249721] ? syscall_slow_exit_work+0x280/0x280
[ 1798.257211] ? do_syscall_64+0x1e/0x2e0
[ 1798.263680] do_syscall_64+0x72/0x2e0
[ 1798.269950] entry_SYSCALL_64_after_hwframe+0x49/0xbe
Signed-off-by: Maor Gottlieb <maorg@mellanox.com>
Signed-off-by: Alaa Hleihel <alaa@mellanox.com>
Once all the large flow groups (defined by the user when the flow table
is created - max_num_groups) were created, then all the following new
flow groups will have only one flow table entry, even though the flow table
has place to larger groups.
Fix the condition to prefer large flow group.
Fixes: f0d22d187473 ("net/mlx5_core: Introduce flow steering autogrouped flow table")
Add API to set the flow steering root namesapce mode.
Setting new mode should be called before any steering operation
is executed on the namespace.
This API is going to be used by steering users such switchdev.
Add support to create flow steering objects
via direct rule API (SW steering).
New layer is added - fs_dr, this layer translates the command that
fs_core sends to the FW into direct rule API. In case that direct
rule is not supported in some feature then -EOPNOTSUPP is
returned.
Add flow steering actions: modify header and packet reformat
to the fs_cmd shim layer. This allows each namespace to define
possibly different functionality for alloc/dealloc action commands.
Use different namespaces for bypass and switchdev loopback because they
have different priorities and default table miss action requirement:
1. bypass: with multiple priorities support, and
MLX5_FLOW_TABLE_MISS_ACTION_DEF as the default table miss action;
2. switchdev loopback: with single priority support, and
MLX5_FLOW_TABLE_MISS_ACTION_SWITCH_DOMAIN as the default table miss
action.
Signed-off-by: Mark Zhang <markz@mellanox.com>
Currently all the namespaces under the same steering domain share the same
default table miss action, however in some situations (e.g., RDMA RX)
different actions are required. This patch adds a per-namespace default
table miss action instead of using the miss action of the steering domain.
git://git.kernel.org/pub/scm/linux/kernel/git/mellanox/linux
Misc updates from mlx5-next branch:
1) Add the required HW definitions and structures for upcoming TLS
support.
2) Add support for MCQI and MCQS hardware registers for fw version query.
3) Added hardware bits and structures definitions for sub-functions
4) Small code cleanup and improvement for PF pci driver.
5) Bluefield (ECPF) updates and refactoring for better E-Switch
management on ECPF embedded CPU NIC:
5.1) Consolidate querying eswitch number of VFs
5.2) Register event handler at the correct E-Switch init stage
5.3) Setup PF's inline mode and vlan pop when the ECPF is the
E-Swtich manager ( the host PF is basically a VF ).
5.4) Handle Vport UC address changes in switchdev mode.
6) Cleanup the rep and netdev reference when unloading IB rep.
i# All conflicts fixed but you are still merging.
Instead MLX5_TOTAL_VPORTS, use mlx5_eswitch_get_total_vports().
mlx5_eswitch_get_total_vports() in subsequent patch accounts for SF
vports as well.
Expanding MLX5_TOTAL_VPORTS macro would require exposing SF internals to
more generic vport.h header file. Such exposure is not desired.
Hence a mlx5_eswitch_get_total_vports() is introduced.
Given that mlx5_eswitch_get_total_vports() API wants to work on const
mlx5_core_dev*, change its helper functions also to accept const *dev.
Signed-off-by: Parav Pandit <parav@mellanox.com>
Putting an empty 'mlx5_flow_spec' structure on the stack is a bit
wasteful and causes a warning on 32-bit architectures when building
with clang -fsanitize-coverage:
drivers/net/ethernet/mellanox/mlx5/core/eswitch_offloads_termtbl.c: In function 'mlx5_eswitch_termtbl_create':
drivers/net/ethernet/mellanox/mlx5/core/eswitch_offloads_termtbl.c:90:1: error: the frame size of 1032 bytes is larger than 1024 bytes [-Werror=frame-larger-than=]
Since the structure is never written to, we can statically allocate
it to avoid the stack usage. To be on the safe side, mark all
subsequent function arguments that we pass it into as 'const'
as well.
Fixes: 10caabdaad5a ("net/mlx5e: Use termination table for VLAN push actions")
Acked-by: Saeed Mahameed <saeedm@mellanox.com>
Acked-by: Mark Bloch <markb@mellanox.com>
1) E-Switch vport metadata support for source vport matching
2) Convert mkey_table to XArray
3) Shared IRQs and to use single IRQ for all async EQs
Refactor the flow data structures, add new flow_context and move
flow_tag into it, as flow_tag doesn't belong to the rule action.
Signed-off-by: Jianbo Liu <jianbol@mellanox.com>
root ns is yet another fs core node which is freed using kfree() by
tree_put_node().
Rest of the other fs core objects are also allocated using kmalloc
variants.
However, root ns memory is allocated using kvzalloc().
Hence allocate root ns memory using kzalloc().
Fixes: 2530236303d9e ("net/mlx5_core: Flow steering tree initialization")
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
In below code flow, for ingress acl table root ns memory leads
to double free.
mlx5_init_fs
init_ingress_acls_root_ns()
init_ingress_acl_root_ns
kfree(steering->esw_ingress_root_ns);
/* steering->esw_ingress_root_ns is not marked NULL */
mlx5_cleanup_fs
cleanup_ingress_acls_root_ns
steering->esw_ingress_root_ns non NULL check passes.
/* double free */
Similar issue exist for other tables.
Hence zero out the pointers to not process the table again.
Fixes: 9b93ab981e3bf ("net/mlx5: Separate ingress/egress namespaces for each vport")
Fixes: 40c3eebb49e51 ("net/mlx5: Add support in RDMA RX steering")
When root ns setup for rdma, sniffer tx and sniffer rx fails,
such root ns cleanup is done by the error unwinding path of
mlx5_cleanup_fs().
Below call graph shows an example for sniffer_rx_root_ns.
mlx5_init_fs()
init_sniffer_rx_root_ns()
cleanup_root_ns(steering->sniffer_rx_root_ns);
mlx5_cleanup_fs()
/* double free of sniffer_rx_root_ns */
Hence, use the existing cleanup_fs to cleanup.
Fixes: d83eb50e29de3 ("net/mlx5: Add support in RDMA RX steering")
Fixes: 87d22483ce68e ("net/mlx5: Add sniffer namespaces")
Flow destination comparison has an inaccuracy: code see no
difference between same vf ports, which belong to different pfs.
Example: If start ping from VF0 (PF1) to VF1 (PF1) and mirror
all traffic to VF0 (PF2), icmp reply to VF0 (PF1) and mirrored
flow to VF0 (PF2) would be determined as same destination. It lead
to creating flow handler with rule nodes, which not added to node
tree. When later driver try to delete this flow rules we got
kernel crash.
Add comparison of vhca_id field to avoid this.
Fixes: 1228e912c934 ("net/mlx5: Consider encapsulation properties when comparing destinations")
Signed-off-by: Dmytro Linkin <dmitrolin@mellanox.com>
Reviewed-by: Roi Dayan <roid@mellanox.com>
Reviewed-by: Vlad Buslov <vladbu@mellanox.com>
Flow table supports three types of miss action:
1. Default miss action - go to default miss table according to table.
2. Go to specific table.
3. Switch domain - go to the root table of an alternative steering
table domain.
New table miss action was added - switch_domain.
The next domain for RDMA_RX namespace is the NIC RX domain.
Add new flow steering namespace - MLX5_FLOW_NAMESPACE_RDMA_RX.
Flow steering rules in this namespace are used to filter
RDMA traffic.
Pass the flow steering objects instead of their attributes
to fs_cmd in order to decrease number of arguments and in
addition it will be used to update object fields.
Pass the flow steering root namespace instead of the device
so will have context to the namespace in the fs_cmd layer.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into mlx5-next
Linux 5.1-rc1
We forgot to reset the branch last merge window thus mlx5-next is outdated
and still based on 5.0-rc2. This merge commit is needed to sync mlx5-next
branch with 5.1-rc1.
Create a new prio in the FDB, it will be used when inserting steering rules
into the FDB from the RDMA side. We create a new PRIO so rules from the
net side and rules from the RDMA side won't be inserted to the same PRIO,
each side has it's own sandbox to play in.
Signed-off-by: Mark Bloch <markb@mellanox.com>
When creating the FDB prios, use the enum values already defined and not
the hardcoded values.
Fix the following warning:
drivers/net/ethernet/mellanox/mlx5/core//fs_core.c:845:5:
warning: 'err' may be used uninitialized in this function
[-Wmaybe-uninitialized]
No real issue here. This is only a false compiler warning.
The 'err' variable is guaranteed to be init by time of usage.
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-4)
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Reviewed-by: Alex Vesker <valex@mellanox.com>
With commit a18e879d4e45 ("net/mlx5e: Annul encap action ordering
requirement") and a use-case of e-switch remote mirroring, the
incremental/stepped FTE removal process done by the fs core got us to
illegal transient states and FW errors:
parameter(0x3), syndrome (0x9c2e40)
To avoid that and improve FTE removal performance, aggregate the FTE's
updates that should be applied. Remove the FTE if it is empty, or apply
one FW update command with the aggregated updates.
Fixes: a18e879d4e45 ("net/mlx5e: Annul encap action ordering requirement")
Signed-off-by: Eli Britstein <elibr@mellanox.com>
Add a locked flag to the node removal functions to signal if the
parent is already locked from the caller function or not as a pre-step
towards outside lock. Currently always use false with no functional
change.
Add modify FTE helper function and use it when deleting a rule, as a
pre-step towards consolidated FTE modification, with no functional
change.
There might be a condition where the fte found is not active yet. In
this case we should not use it, but continue to search for another, or
allocate a new one.
Merge mlx5-next shared branched into net-next,
From Bodong Wang:
1) Introduction of ECPF (Embedded CPU Physical Function), and low level
bits for mlx5 SmartNic capabilities support.
2) Vport enumeration refactoring that affect mlx5_ib and mlx5_core
From Aya Levin,
3) Add support for 50Gbps per lane link modes in the Port Type and Speed
register (PTYS)
4) Refactor low level query functions for PTYS register
5) Add support for 50Gbps per lane link modes to mlx5_ib
Note: due to a change in API in mlx5/core and a later patch from net-next,
a fixup was squashed with this merge commit that replaces FDB_UPLINK_VPORT
with MLX5_VPORT_UPLINK which exists only in upstream net-next.
These are two macros in the driver general header which deal with the
number of total vports and if a vport is vport manager. Such macros
are vport entities, better to place them at the vport header file.
This patch doesn't change any functionality.
Signed-off-by: Bodong Wang <bodong@mellanox.com>
Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com>
Add the tab before '}' and keep the code style consistent.
Signed-off-by: Tonghao Zhang <xiangxia.m.yue@gmail.com>
We were not tracking flow tables so far, add it up.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Lots of conflicts, by happily all cases of overlapping
changes, parallel adds, things of that nature.
Thanks to Stephen Rothwell, Saeed Mahameed, and others
for their guidance in these resolutions.
Expression terminated with "," instead of ";", resulted in
set_fte getting bad value for modify_enable_mask field.
Fixes: bd5251dbf156 ("net/mlx5_core: Introduce flow steering destination of type counter")
Signed-off-by: Yuval Avnery <yuvalav@mellanox.com>
Currently the driver identifies identical vport destinations by
comparing the vport ID. The FW extended destination feature enables the
driver to forward the packet to the same vport with multiple
encapsulation properties.
Change the vport destination comparison logic to compare
the encapsulation properties in addition to the vport ID.
Acked-by: Or Gerlitz <ogerlitz@mellanox.com>
Reviewed-by: Oz Shlomo <ozsh@mellanox.com>
FDB_MAX_CHAIN is three. We wanted to allocate enough memory to hold four
structs but there are missing parentheses so we only allocate enough
memory for three structs and the first byte of the fourth one.
Fixes: 328edb499f99 ("net/mlx5: Split FDB fast path prio to multiple namespaces")
If no-append flag is set, we will add a new FTE, instead of appending
the actions of the inserted rule when the same match already exists.
While here, move the has_flow_tag boolean indicator to be a flag too.
Signed-off-by: Paul Blakey <paulb@mellanox.com>
Reviewed-by: Or Gerlitz <ogerlitz@mellanmox.com>
Towards supporting multi-chains and priorities, split the FDB fast path
to multiple namespaces (sub namespaces), each with multiple priorities.
This patch adds a new flow steering type, FS_TYPE_PRIO_CHAINS, which is
like current FS_TYPE_PRIO, but may contain only namespaces, and those
will be in parallel to one another in terms of managing of the flow
tables connections inside them. Meaning, while searching for the next
or previous flow table to connect for a new table inside such namespace
we skip the parallel namespaces in the same level under the
FS_TYPE_PRIO_CHAINS prio we originated from.
We use this new type for splitting the fast path prio into multiple
parallel namespaces, each containing normal prios.
The prios inside them (and their tables) will be connected to one
another, but not from one parallel namespace to another, instead the
last prio in each namespace will be connected to the next prio in
the containing FDB namespace, which is the slow path prio.
Currently, when a flow rule is created using the FS core layer, the caller
has to pass the entire flow counter object and not just the counter HW
handle (ID). This requires both the FS core and the caller to have
knowledge about the inner implementation of the FS layer flow counters
cache and limits the possible users.
Move to use the counter ID across the place when dealing with flows.
Doing this decoupling, now can we privatize the inner implementation
of the flow counters.
There's no real reason for the e-switch logic to manage the creation of
counters for offloaded flows. The API already has the directive for the
caller to denote they want to attach a counter to the created flow.
As such, we go and move the management of flow counters to the mlx5e
tc offload logic. This also lets us remove an inelegant interface where
the FS layer had to provide a way to retrieve a counter from a flow rule.
