path: root/drivers/net/ethernet/neterion
2015-04-08s2io: Update driver to use dma_wmbAlexander Duyck
This change updates several spots where a wmb was being used to instead use a dma_wmb to flush out writes before updating the control portion of the descriptor. Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-01vxge: Add const to ethtool_driver_stats_keysJoe Perches
Move about half a KB of data to text. Miscellanea: o Move strings out of the .h file into the .c file in case the .h file is ever #included twice Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-08ethernet: codespell comment spelling fixesJoe Perches
To test a checkpatch spelling patch, I ran codespell against drivers/net/ethernet/. $ git ls-files drivers/net/ethernet/ | \ while read file ; do \ codespell -w $file; \ done I removed a false positive in e1000_hw.h Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05vxge: fix sparse warningLad, Prabhakar
this patch fixes following sparse warning: vxge-config.c:4640:30: warning: Using plain integer as NULL pointer Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: arch/arm/boot/dts/imx6sx-sdb.dts net/sched/cls_bpf.c Two simple sets of overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-19s2io: use snprintf() as a safety featureDan Carpenter
"sp->desc[i]" has 25 characters. "dev->name" has 15 characters. If we used all 15 characters then the sprintf() would overflow. I changed the "sprintf(sp->name, "%s Neterion %s"" to snprintf(), as well, even though it can't overflow just to be consistent. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-13net: rename vlan_tx_* helpers since "tx" is misleading thereJiri Pirko
The same macros are used for rx as well. So rename it. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-15net: ethernet: neterion: vxge: vxge-main.c: Cleaning up missing ↵Rickard Strandqvist
null-terminate in conjunction with strncpy Replacing strncpy with strlcpy to avoid strings that lacks null terminate. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-07-29vxge: remove deprecated syststamp timestampWillem de Bruijn
This driver explicitly clears a field that is unused and about to be removed. Remove the initialization. All fields in skb_shared_info before dataref are cleared in __alloc_skb, so the removal is safe even while syststamp exists. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-06net: use SPEED_UNKNOWN and DUPLEX_UNKNOWN when appropriateJiri Pirko
2014-06-02vxge: Remove useless return variablesPeter Senna Tschudin
This patch remove variables that are initialized with a constant, are never updated, and are only used as parameter of return. Return the constant instead of using a variable. Verified by compilation only. The coccinelle script that find and fixes this issue is: // <smpl> @@ type T; constant C; identifier ret; @@ - T ret = C; ... when != ret when strict return - ret + C ; // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21vxge: Use time_before()Manuel Schölling
To be future-proof and for better readability the time comparisons are modified to use time_before() instead of plain, error-prone math. Signed-off-by: Manuel Schölling <manuel.schoelling@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-13net: get rid of SET_ETHTOOL_OPSWilfried Klaebe
net: get rid of SET_ETHTOOL_OPS Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone. This does that. Mostly done via coccinelle script: @@ struct ethtool_ops *ops; struct net_device *dev; @@ - SET_ETHTOOL_OPS(dev, ops); + dev->ethtool_ops = ops; Compile tested only, but I'd seriously wonder if this broke anything. Suggested-by: Dave Miller <davem@davemloft.net> Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-22neterion/s2io: remove unused s2io_start_tx_queue routineYing Xue
Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24vxge: Call dev_kfree_skb_any instead of dev_kfree_skb.Eric W. Biederman
Replace dev_kfree_skb with dev_kfree_skb_any in vxge_xmit that can be called in hard irq and other contexts. vxge_xmit only calls dev_kfree_skb_any when errors result in dropping skbs. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-03-24s2io: Call dev_kfree_skb_any instead of dev_kfree_skb.Eric W. Biederman
Replace dev_kfree_skb with dev_kfree_skb_any in s2io_xmit that can be called in hard irq and other contexts. All instances that are changed are packet drops. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-03-14vxge: Don't receive packets when the napi budget == 0Eric W. Biederman
Processing any incoming packets with a with a napi budget of 0 is incorrect driver behavior. This matters as netpoll will shortly call drivers with a budget of 0 to avoid receive packet processing happening in hard irq context. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14s2io: Don't receive packets when the napi budget == 0Eric W. Biederman
2014-03-14net: Replace u64_stats_fetch_begin_bh to u64_stats_fetch_begin_irqEric W. Biederman
Replace the bh safe variant with the hard irq safe variant. We need a hard irq safe variant to deal with netpoll transmitting packets from hard irq context, and we need it in most if not all of the places using the bh safe variant. Except on 32bit uni-processor the code is exactly the same so don't bother with a bh variant, just have a hard irq safe variant that everyone can use. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-18vxge: Use pci_enable_msix_range() instead of pci_enable_msix()Alexander Gordeev
As result of deprecation of MSI-X/MSI enablement functions pci_enable_msix() and pci_enable_msi_block() all drivers using these two interfaces need to be updated to use the new pci_enable_msi_range() and pci_enable_msix_range() interfaces. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: netdev@vger.kernel.org Cc: linux-pci@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-18s2io: Use pci_enable_msix_range() instead of pci_enable_msix()Alexander Gordeev
2014-02-09net: vxge: Remove unused device pointerChristian Engelmayer
Remove occurrences of unused struct __vxge_hw_device pointer in functions vxge_learn_mac() and vxge_rem_isr(). Detected by Coverity: CID 139839, CID 139842. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-16vxge: make local functions staticstephen hemminger
Remove unused function vxge_hw_vpath_vid_get Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-31net: vxge: slight optimization of addr comparedingtianhong
Use possibly more efficient ether_addr_equal to instead of memcmp. Cc: Jon Mason <jdmason@kudzu.us> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18net: vxge calls skb_set_hashTom Herbert
Drivers should call skb_set_hash to set the hash and its type in an skbuff. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-05Merge branch 'siocghwtstamp' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfc-next Ben Hutchings says: ==================== SIOCGHWTSTAMP ioctl 1. Add the SIOCGHWTSTAMP ioctl and update the timestamping documentation. 2. Implement SIOCGHWTSTAMP in most drivers that support SIOCSHWTSTAMP. 3. Add a test program to exercise SIOC{G,S}HWTSTAMP. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-21vxge: Implement the SIOCGHWTSTAMP ioctlBen Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-11-14Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest changes: - add lockdep support for seqcount/seqlocks structures, this unearthed both bugs and required extra annotation. - move the various kernel locking primitives to the new kernel/locking/ directory" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) block: Use u64_stats_init() to initialize seqcounts locking/lockdep: Mark __lockdep_count_forward_deps() as static lockdep/proc: Fix lock-time avg computation locking/doc: Update references to kernel/mutex.c ipv6: Fix possible ipv6 seqlock deadlock cpuset: Fix potential deadlock w/ set_mems_allowed seqcount: Add lockdep functionality to seqcount/seqlock structures net: Explicitly initialize u64_stats_sync structures for lockdep locking: Move the percpu-rwsem code to kernel/locking/ locking: Move the lglocks code to kernel/locking/ locking: Move the rwsem code to kernel/locking/ locking: Move the rtmutex code to kernel/locking/ locking: Move the semaphore core to kernel/locking/ locking: Move the spinlock code to kernel/locking/ locking: Move the lockdep code to kernel/locking/ locking: Move the mutex code to kernel/locking/ hung_task debugging: Add tracepoint to report the hang x86/locking/kconfig: Update paravirt spinlock Kconfig description lockstat: Report avg wait and hold times lockdep, x86/alternatives: Drop ancient lockdep fixup message ...
2013-11-06net: Explicitly initialize u64_stats_sync structures for lockdepJohn Stultz
In order to enable lockdep on seqcount/seqlock structures, we must explicitly initialize any locks. The u64_stats_sync structure, uses a seqcount, and thus we need to introduce a u64_stats_init() function and use it to initialize the structure. This unfortunately adds a lot of fairly trivial initialization code to a number of drivers. But the benefit of ensuring correctness makes this worth while. Because these changes are required for lockdep to be enabled, and the changes are quite trivial, I've not yet split this patch out into 30-some separate patches, as I figured it would be better to get the various maintainers thoughts on how to best merge this change along with the seqcount lockdep enablement. Feedback would be appreciated! Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: James Morris <jmorris@namei.org> Cc: Jesse Gross <jesse@nicira.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Mirko Lindner <mlindner@marvell.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Roger Luethi <rl@hellgate.ch> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Simon Horman <horms@verge.net.au> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: netdev@vger.kernel.org Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-21net: neterion: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-18treewide: Fix typo in printkMasanari Iida
Correct spelling typo in printk within various drivers. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-19net: vlan: add protocol argument to packet tagging functionsPatrick McHardy
Add a protocol argument to the VLAN packet tagging functions. In case of HW tagging, we need that protocol available in the ndo_start_xmit functions, so it is stored in a new field in the skb. The new field fits into a hole (on 64 bit) and doesn't increase the sks's size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: prepare for 802.1ad VLAN filtering offloadPatrick McHardy
Change the rx_{add,kill}_vid callbacks to take a protocol argument in preparation of 802.1ad support. The protocol argument used so far is always htons(ETH_P_8021Q). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*Patrick McHardy
Rename the hardware VLAN acceleration features to include "CTAG" to indicate that they only support CTAGs. Follow up patches will introduce 802.1ad server provider tagging (STAGs) and require the distinction for hardware not supporting acclerating both. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18net: neterion: replace ip_fast_csum with csum_replace2Li RongQing
replace ip_fast_csum with csum_replace2 to save cpu cycles Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-08remove init of dev->perm_addr in driversJiri Pirko
perm_addr is initialized correctly in register_netdevice() so to init it in drivers is no longer needed. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-07drivers/net: fix up function prototypes after __dev* removalsGreg Kroah-Hartman
The __dev* removal patches for the network drivers ended up messing up the function prototypes for a bunch of drivers. This patch fixes all of them back up to be properly aligned. Bonus is that this almost removes 100 lines of code, always a nice surprise. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-04net: neterion: use for_each_pci_dev to simplify the codeWei Yongjun
Use for_each_pci_dev to simplify the code. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03vxge/s2io: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jon Mason <jdmason@kudzu.us> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-19net: Remove bogus dependencies on INETBen Hutchings
Various drivers depend on INET because they used to select INET_LRO, but they have all been converted to use GRO which has no such dependency. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-03net: neterion: Do not break word unregister.YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-09-12Merge branch 'pci/stephen-const' into nextBjorn Helgaas
* pci/stephen-const: make drivers with pci error handlers const scsi: make pci error handlers const netdev: make pci_error_handlers const PCI: Make pci_error_handlers const
2012-09-07netdev: make pci_error_handlers constStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-08-23vxge: Use PCI Express Capability accessorsJiang Liu
Use PCI Express Capability access functions to simplify vxge driver. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-22net: fix race condition in several drivers when reading statsKevin Groeneveld
Fix race condition in several network drivers when reading stats on 32bit UP architectures. These drivers update their stats in a BH context and therefore should use u64_stats_fetch_begin_bh/u64_stats_fetch_retry_bh instead of u64_stats_fetch_begin/u64_stats_fetch_retry when reading the stats. Signed-off-by: Kevin Groeneveld <kgroeneveld@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10vxge/s2io: remove dead URLsJon Mason
URLs to neterion.com and s2io.com no longer resolve. Remove all references to these URLs in the driver source and documentation. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
