pch_gbe_tx_ring.tx_lock is only used in the hard_xmit handler and
in the transmit completion reaper called from NAPI context.
Compile-tested only. Potential victims Cced.
Someone more knowledgeable may check if pch_gbe_tx_queue could
have some use for a mmiowb.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Darren Hart <dvhart@infradead.org>
Cc: Andy Cress <andy.cress@us.kontron.com>
Cc: bryan@fossetcon.org
Should have converted 'if (trylock)' to 'lock'.
Fixes: a6086a893718db ("drivers: net: remove NETDEV_TX_LOCKED")
replace the trylock by a full spin_lock and remove TX_LOCKED return value.
Followup patch will remove TX_LOCKED from the kernel.
Cc: Jon Mason <jdmason@kudzu.us>
Cc: Andy Gospodarek <andy@greyhouse.net>
The name NETIF_F_ALL_CSUM is a misnomer. This does not correspond to the
set of features for offloading all checksums. This is a mask of the
checksum offload related features bits. It is incorrect to set both
NETIF_F_HW_CSUM and NETIF_F_IP_CSUM or NETIF_F_IPV6 at the same time for
features of a device.
This patch:
- Changes instances of NETIF_F_ALL_CSUM to NETIF_F_CSUM_MASK (where
NETIF_F_ALL_CSUM is being used as a mask).
- Changes bonding, sfc/efx, ipvlan, macvlan, vlan, and team drivers to
use NEITF_F_HW_CSUM in features list instead of NETIF_F_ALL_CSUM.
Signed-off-by: Tom Herbert <tom@herbertland.com>
Many drivers initialize uselessly n_priv_flags, n_stats, testinfo_len,
eedump_len & regdump_len fields in their .get_drvinfo() ethtool op.
It's not necessary as these fields is filled in ethtool_get_drvinfo().
v2: removed unused variable
v3: removed another unused variable
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
This howto made sense in the 1990s when users had to manually configure
ISA cards with jumpers or vendor utilities, but with the implementation
of PCI it became increasingly less and less relevant, to the point where
it has been well over a decade since I last updated it. And there is
no value in anyone else taking over updating it either.
However the references to it continue to spread as boiler plate text
from one Kconfig file into the next. We are not doing end users any
favours by pointing them at this old document, so lets kill it with
fire, once and for all, to hopefully stop any further spread.
No code is changed in this commit, just Kconfig help text.
To test a checkpatch spelling patch, I ran codespell against
drivers/net/ethernet/.
$ git ls-files drivers/net/ethernet/ | \
while read file ; do \
codespell -w $file; \
done
I removed a false positive in e1000_hw.h
Fixes the following randconfig build failure:
> drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe_main.c: In function
> ‘pch_ptp_match’:
> drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe_main.c:130:2: error:
> implicit declaration of function ‘ptp_classify_raw’
> [-Werror=implicit-function-declaration]
> if (ptp_classify_raw(skb) == PTP_CLASS_NONE)
> cc1: some warnings being treated as errors
> make[5]: *** [drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe_main.o] Error 1
Reported-by: Jim Davis <jim.epost@gmail.com>
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The pch_gbe driver is for a companion chip to the Intel Atom E600
series processors. These are 32-bit x86 processors so the driver is
only needed on X86_32.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Jiri Slaby <jslaby@suse.cz>
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
There are currently pch_gbe, cpts, and ixp4xx_eth drivers that open-code
and reimplement a BPF classifier for the PTP protocol. Since all of them
effectively do the very same thing and load the very same PTP/BPF filter,
we can just consolidate that code by introducing ptp_classify_raw() in
the time-stamping core framework which can be used in drivers.
As drivers get initialized after bootstrapping the core networking
subsystem, they can make use of ptp_insns wrapped through
ptp_classify_raw(), which allows to simplify and remove PTP classifier
setup code in drivers.
Joint work with Alexei Starovoitov.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Richard Cochran <richard.cochran@omicron.at>
Cc: Jiri Benc <jbenc@redhat.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Santosh Raspatur <santosh@chelsio.com>
CC: Dimitris Michailidis <dm@chelsio.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Santiago Leon <santil@linux.vnet.ibm.com>
CC: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
CC: Olof Johansson <olof@lixom.net>
CC: Manish Chopra <manish.chopra@qlogic.com>
CC: Sony Chacko <sony.chacko@qlogic.com>
CC: Rajesh Borundia <rajesh.borundia@qlogic.com>
CC: Nicolas Pitre <nico@fluxnic.net>
CC: Steve Glendinning <steve.glendinning@shawell.net>
hwtstamp_ioctl() should validate all fields of hwtstamp_config
before making any changes. Currently it sets the TX configuration
before validating the rx_filter field.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
__GFP_ZERO is an uncommon flag and perhaps is better
not used. static inline dma_zalloc_coherent exists
so convert the uses of dma_alloc_coherent with __GFP_ZERO
to the more common kernel style with zalloc.
Remove memset from the static inline dma_zalloc_coherent
and add just one use of __GFP_ZERO instead.
Trivially reduces the size of the existing uses of
dma_zalloc_coherent.
Realign arguments as appropriate.
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
When attempting to change e.g. the advertising mask when the link is down
ecmd->speed is -1 causing mii_ethtool_sset() to bail out.
This bug bit when connecting to a gigabit switch through a 4-pin (industrial)
cable, since link negotiation would not complete (both endpoints claimed to
be gigabit-capable, but this is not possible with only 4 pins).
Any attempt to fix this by setting autonegation to not offer 1000Mbps
failed as the setting would not be accepted while the link was still down...
Set ecmd->speed to SPEED_1000 to satisfy mii_ethtool_sset()
(the actual value of ecmd->speed doesn't matter as long as it is valid,
since a re-negotation is forced afterwards).
Signed-off-by: Anders Larsen <al@alarsen.net>
Merge net into net-next to setup some infrastructure Eric
Dumazet needs for usbnet changes.
The MinnowBoard uses an AR803x PHY with the PCH GBE which requires
special handling. Use the MinnowBoard PCI Subsystem ID to detect this
and add a pci_device_id.driver_data structure and functions to handle
platform setup.
The AR803x does not implement the RGMII 2ns TX clock delay in the trace
routing nor via strapping. Add a detection method for the board and the
PHY and enable the TX clock delay via the registers.
This PHY will hibernate without link for 10 seconds. Ensure the PHY is
awake for probe and then disable hibernation. A future improvement would
be to convert pch_gbe to using PHYLIB and making sure we can wake the
PHY at the necessary times rather than permanently disabling it.
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Cc: Peter Waskiewicz <peter.p.waskiewicz.jr@intel.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Joe Perches <joe@perches.com>
Cc: netdev@vger.kernel.org
Avoid using magic numbers when we have perfectly good defines just lying
around.
Since 4bb1667255a86360721291fe59991d033bbc2f2a (build some drivers only
when compile-testing), PTP_1588_CLOCK_PCH depends on (X86 ||
COMPILE_TEST). But PCH_GBE selects PTP_1588_CLOCK_PCH without
depending on x86. Fix this by adding the same dependency here.
Reported-by: <fengguang.wu@intel.com> [intel's build test robot]
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: kbuild-all@01.org
This makes the error handling much more simpler than open-coding everything and
in addition makes the probe function smaller an tidier.
We may use nice macros to prefix our messages with proper device name.
There is no much sense to mark functions inline that are going to be used in
the other compile modules.
All drivers that select MII also need to select NET_CORE because MII
depends on it. This is a bit ridiculous because NET_CORE is just a
menu option that doesn't enable any code by itself.
There is also no need for it to be a visible option, since its users
all select it.
If we can't _up() after changing the MTU, report the actual error instead
of -ENOMEM. It can be really misleading cause pch_gbe is usually used in
scenarios where the memory amount is really small, and thus hiding the
real cause.
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
include/net/ipip.h
The changes made to ipip.h in 'net' were already included
in 'net-next' before that header was moved to another location.
skb->ip_summed should be CHECKSUM_UNNECESSARY when the driver reports that
checksums were correct and CHECKSUM_NONE in any other case. They're
currently placed vice versa, which breaks the forwarding scenario. Fix it
by placing them as described above.
Reduce the number of calls required to alloc
a zeroed block of memory.
Trivially reduces overall object size.
Other changes around these removals
o Neaten call argument alignment
o Remove an unnecessary OOM message after dma_alloc_coherent failure
o Remove unnecessary gfp_t stack variable
I believe these error messages are already logged
on allocation failure by warn_alloc_failed and so
get a dump_stack on OOM.
Remove the unnecessary additional error logging.
Around these deletions:
o Alignment neatening.
o Remove unnecessary casts of dma_alloc_coherent.
o Hoist assigns from ifs.
In commit a24006ed12616bde1bbdb26868495906a212d8dc ('ptp: Enable clock
drivers along with associated net/PHY drivers') I wrongly made
PTP_1588_CLOCK_PCH depend on PCH_GBE. The dependency is really the
other way around. Therefore make PCH_GBE select PTP_1588_CLOCK_PCH
and remove the 'default y' from the latter.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
Minor conflict between the BCM_CNIC define removal in net-next
and a bug fix added to net. Based upon a conflict resolution
patch posted by Stephen Rothwell.
Where a PTP clock driver is associated with a net or PHY driver, it
should be enabled automatically whenever that driver is enabled.
Therefore:
- Make PTP clock drivers select rather than depending on PTP_1588_CLOCK
- Remove separate boolean options for PTP clock drivers that are built
as part of net driver modules. (This also fixes cases where the PTP
subsystem is wrongly forced to be built-in.)
- Set 'default y' for PTP clock drivers that depend on specific net
drivers but are built separately
PTP hardware clock drivers that select PTP_1588_CLOCK must currently
also select PPS. For those drivers that don't, the user must enable
PPS, then enable PTP_1588_CLOCK, then the driver. Simplify things for
developers and users by putting this selection in one place.
These are now established subsystems, and we want drivers to be able
to select PPS and PTP_1588_CLOCK without depending on EXPERIMENTAL.
Further, the use of EXPERIMENTAL is now deprecated in general.
If we fail to allocate rx buffers pool by any reason, we'll just return
with an error, however we've previously successfully requested an irq. Fix
this by releasing the irq before returning the error.
Currently, when FIFO_ERR happens, we stop the dma, wait for it to become
idle and then reset the whole MAC_RX logic (and after that we must re-set
multicast addresses and also re-enable MAC_RX when we're finally ready to
accept new packets). This leads to CRC errors on high number of incoming
packets and is not needed according to the datasheet.
This patch fixes it by the following steps:
1) remove this reset in pch_gbe_stop_receive(), which causes some functions
to not be used anywhere
2) remove already unused functions pch_gbe_wait_clr_bit_irq() and
pch_gbe_mac_reset_rx() to correctly build
3) move pch_gbe_enable_mac_rx() out of pch_gbe_start_receive() to
pch_gbe_up() where it's only needed after we've removed the MAC_RX reset
4) rename pch_gbe_start/stop_receive() to pch_gbe_enable/disable_dma_rx()
to more precisely reflect what the functions are now doing.
After these changes we already don't see the CRC errors and gain some
increase in RX processing speed.
If we were in RX_FIFO_ERR state and entered pch_gbe_napi_poll(), we'll
anyway clean some rx space and thus can continue to receive more packets.
Currently, we re-set the RX_FIFO_ERR in situations when we've exhausted our
budget for RX cleaning or cleaned some TX packets. Removing it gives us
+20%-40% speed increase and a lot less of RX_FIFO_ERRors reported.
Move MAC_RX-related bits into separate functions.
Fengguang reported a kernel build failure as following:
drivers/built-in.o: In function `pch_gbe_ioctl':
pch_gbe_main.c:(.text+0x510370): undefined reference to `pch_ch_control_write'
pch_gbe_main.c:(.text+0x510393): undefined reference to `pch_ch_control_write'
pch_gbe_main.c:(.text+0x5103b3): undefined reference to `pch_ch_control_write'
It's a regression by commit da1586461. The root cause is that
the CONFIG_PPS is not set there, consequently CONFIG_PTP_1588_CLOCK
can not be set anyway, which finally causes ptp_pch and pch_gbe_main
build failures.
As David prefers to use *select* to fix such module co-dependency issues,
this patch explicitly selects all the possible dependencies of PCH_PTP.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reviewed-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Haicheng Li <haicheng.lee@gmail.com>
The config combination:
CONFIG_PCH_GBE=y
CONFIG_PCH_PTP=y
CONFIG_PTP_1588_CLOCK=m
doesn't work, because then you have a built-in kernel
object (the PCH_PTP code) referring to symbols in a
module (PTP_1588_CLOCK).
Fix this like IXGBE, by using "select PTP_1588_CLOCK"
instead of a "depends on".
Reported-by: Haicheng Li <haicheng.li@linux.intel.com>
pch_gbe_xmit_frame skb->len verification was incorrect in vlan case
causing bogus transfer length errors. One correction could be:
offset = skb->protocol == htons(ETH_P_8021Q) ? 0 : 4;
if (unlikely(skb->len > (adapter->hw.mac.max_frame_size - offset)))
However, this verification is not necessary, so remove it.
Signed-off-by: Andy Cress <andy.cress@us.kontron.com>
This adds extra cleaning to the pch_gbe_clean_tx routine to avoid
transmit timeouts on some BCM PHYs that have different timing.
Also update the DRV_VERSION to 1.01, and show it.
An extended ping test with 6 vlans resulted in a driver oops with a
netdev transmit timeout.
Fix WATCHDOG_TIMEOUT to be more like e1000e at 5 * HZ, to avoid
unnecessary transmit timeouts.
When attempting to disable ethernet autonegation via ethtool,
the pch_gpe driver will set software reset bit of PHY chip, But
control register of PHY chip of FRI2 will reenable ethernet autonegation.
Signed-off-by: Wei Yang <w90p710@gmail.com>
Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches. Delete
a few that are content-free.
Andy reported pch_gbe triggered "NETDEV WATCHDOG" errors.
May 11 11:06:09 kontron kernel: WARNING: at net/sched/sch_generic.c:261
dev_watchdog+0x1ec/0x200() (Not tainted)
May 11 11:06:09 kontron kernel: Hardware name: N/A
May 11 11:06:09 kontron kernel: NETDEV WATCHDOG: eth0 (pch_gbe):
transmit queue 0 timed out
It seems pch_gbe has a racy tx path (races with TX completion path)
Remove tx_queue_lock lock since it has no purpose, we must use tx_lock
instead.
Reported-by: Andy Cress <andy.cress@us.kontron.com>
Tested-by: Andy Cress <andy.cress@us.kontron.com>
