[ Upstream commit c94f026fb742b2d3199422751dbc4f6fc0e753d8 ]
These functions are supposed to return one on failure and zero on
success. Returning a zero here could cause uninitialized variable
bugs in several of the callers. For example:
drivers/scsi/cxgbi/cxgb4i/cxgb4i.c:1660 get_iscsi_dcb_priority()
error: uninitialized symbol 'caps'.
Fixes: 48365e485275 ("qlcnic: dcb: Add support for CEE Netlink interface.")
The qlcnic_dcb_ops structures are never modified, so declare them as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
v2: fixed issue with checking return of dcbnl_rtnl_ops->getapp()
Signed-off-by: Anish Bhatt <anish@chelsio.com>
This function is called from dcbnl_build_peer_app(). The "info"
struct isn't initialized at all so we disclose 2 bytes of uninitialized
stack data. We should clear it before passing it to the user.
Fixes: 48365e485275 ('qlcnic: dcb: Add support for CEE Netlink interface.')
o INIT_NIC_FUNC should be first mailbox sent. Sending DCB capability and
parameter query commands after that command.
Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com>
Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com>
The ->tc_cfg[] array has QLC_DCB_MAX_TC (8) elements so the check is
off by one. These functions are always called with valid values though
so it doesn't affect how the code works.
Acked-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com>
o DCB AEN registration was reissuing INIT_NIC command. Instead, club
all options of INIT NIC command and issue this command only once.
Signed-off-by: Manish Chopra <manish.chopra@qlogic.com>
o These operations will be supported only through PFs (SR-IOV and non-SR-IOV).
o Move dcb specific function definitions to dcb files.
o Move dcb specific variables to qlcnic_dcb structure.
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
This patch fixes warning "warning: symbol 'qlcnic_set_dcb_ops' was
not declared. Should it be static?"
o Adapter and driver supports only CEE dcbnl ops. Only GET callbacks
within dcbnl ops are supported currently.
o Adapter sends Asynchronous Event Notifications to the driver when
there are changes in the switch or adapter DCBX configuration.
AEN handler updates the driver DCBX parameters.
o Populate driver data structures with local, operational, and peer
DCB parameters.
o Query adapter DCB capabilities and populate local data structures
with relevant information.
o Add QLCNIC_DCB to Kconfig for enabling/disabling DCB.
