commit 6098d7ddd62f532f80ee2a4b01aca500a8e4e9e4 upstream.
Inlining these functions creates lots of stack variables that each take
64 bytes when KASAN is enabled, leading to this warning about potential
stack overflow:
drivers/net/ethernet/rocker/rocker_ofdpa.c: In function 'ofdpa_cmd_flow_tbl_add':
drivers/net/ethernet/rocker/rocker_ofdpa.c:621:1: error: the frame size of 2752 bytes is larger than 1536 bytes [-Werror=frame-larger-than=]
gcc-8 can now consolidate the stack slots itself, but on older versions
we get the same behavior by using a temporary variable that holds a
copy of the inline function argument.
Cc: stable@vger.kernel.org
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715
[ Upstream commit da4ed55165d41b1073f9a476f1c18493e9bf8c8e ]
The problem is that fib_info->nh is [0] so the struct fib_info
allocation size depends on number of nexthops. If we just copy fib_info,
we do not copy the nexthops info and driver accesses memory which is not
ours.
Given the fact that fib4 does not defer operations and therefore it does
not need copy, just pass the pointer down to drivers as it was done
before.
Fixes: 850d0cbc91 ("switchdev: remove pointers from switchdev objects")
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 88de1cd457e5cb664d6d437e2ea4750d089165f5 ]
In rocker, ageing time is a per-port attribute, so the next time the FDB
cleanup timer fires should be set according to the lowest ageing time.
This will later allow us to delete the BR_MIN_AGEING_TIME macro, which was
added to guarantee minimum ageing time in the bridge layer, thereby breaking
existing behavior.
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 4f2c6ae5c64c353fb1b0425e4747e5603feadba1 ]
When switchdev drivers process FDB notifications from the underlying
device they resolve the netdev to which the entry points to and notify
the bridge using the switchdev notifier.
However, since the RTNL mutex is not held there is nothing preventing
the netdev from disappearing in the middle, which will cause
br_switchdev_event() to dereference a non-existing netdev.
Make switchdev drivers hold the lock at the beginning of the
notification processing session and release it once it ends, after
notifying the bridge.
Also, remove switchdev_mutex and fdb_lock, as they are no longer needed
when RTNL mutex is held.
Fixes: 03bf0c281234 ("switchdev: introduce switchdev notifier")
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic cleanups from Arnd Bergmann:
"The asm-generic changes for 4.4 are mostly a series from Christoph
Hellwig to clean up various abuses of headers in there. The patch to
rename the io-64-nonatomic-*.h headers caused some conflicts with new
users, so I added a workaround that we can remove in the next merge
window.
The only other patch is a warning fix from Marek Vasut"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
asm-generic: temporarily add back asm-generic/io-64-nonatomic*.h
asm-generic: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
gpio-mxc: stop including <asm-generic/bug>
n_tracesink: stop including <asm-generic/bug>
n_tracerouter: stop including <asm-generic/bug>
mlx5: stop including <asm-generic/kmap_types.h>
hifn_795x: stop including <asm-generic/kmap_types.h>
drbd: stop including <asm-generic/kmap_types.h>
move count_zeroes.h out of asm-generic
move io-64-nonatomic*.h out of asm-generic
No need to avoid sleeping in switchdev callbacks now, as the switchdev
core allows it.
When object is used in deferred work, we cannot use pointers in
switchdev object structures because the memory they point at may be already
used by someone else. So rather do local copy of the value.
Acked-by: Scott Feldman <sfeldma@gmail.com>
Reviewed-by: John Fastabend <john.r.fastabend@intel.com>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
These are not implementations of default architecture code but helpers
for drivers. Move them to the place they belong to.
Acked-by: Darren Hart <dvhart@linux.intel.com>
Acked-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp>
The FDB cleanup timer will get rescheduled to re-evaluate FDB entries
based on new ageing_time.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Suggested-by: Scott Feldman <sfeldma@gmail.com>
Replace "void *obj" with a generic structure. Introduce couple of
helpers along that.
Make the struct name in sync with object id name.
Suggested-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
To be aligned with obj.
Similar to the notifier_call callback of a notifier_block, change the
function signature of switchdev add and del operations to:
int switchdev_port_obj_add/del(struct net_device *dev,
enum switchdev_obj_id id, void *obj);
This allows the caller to pass a specific switchdev_obj_* structure
instead of the generic switchdev_obj one.
Drivers implementation of these operations and switchdev have been
changed accordingly.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
function signature of switchdev dump operation to:
int switchdev_port_obj_dump(struct net_device *dev,
enum switchdev_obj_id id, void *obj,
int (*cb)(void *obj));
This allows the caller to pass and expect back a specific
switchdev_obj_* structure instead of the generic switchdev_obj one.
Drivers implementation of dump operation can now expect this specific
structure and call the callback with it. Drivers have been changed
accordingly.
The net_device associated to a dump operation does not have to be passed
to the callback. switchdev stores it in a superset struct, if needed.
Also some drivers (such as DSA drivers) may not have easy access to it.
This will simplify pushing the callback function down to the drivers.
Benefit from previously introduced transaction item queue infrastructure
and remove rocker specific transaction memory management.
There will be needed to have switchdev_trans available down in the call
chain, so propagate it instead of trans phase enum. This enum will be
removed anyway. Also, use prepare/commit phase check helpers to get
information about current phase of transaction.
Before it disappears completely, move transaction phase enum under
transaction structure and make attr/obj structures a bit cleaner.
Now, the memory allocation in prepare/commit state is done separatelly
in each driver (rocker). Introduce the similar mechanism in generic
switchdev code, in form of queue. That can be used not only for memory
allocations, but also for different items. Abort item destruction
is handled as well.
This is temporary, name "trans" will be used for something else and
"trans_ph" will eventually disappear.
Add a timer to each rocker switch to do FDB entry cleanup by ageing out
expired entries. The timer scheduling algo is copied from the bridge
driver, for the most part, to keep the firing of the timer to a minimum.
Acked-by: Jiri Pirko <jiri@resnulli.us>
Follow-up patcheset will allow user to change ageing_time, but for now
just hard-code it to a fixed value (the same value used as the default
for the bridge driver).
We'll need more info from rocker_port than just pport when we age out fdb
entries, so store rocker_port rather than pport in each fdb entry.
The entry is touched once when created, and touched again for each update.
The touched time is used to calculate FDB entry age.
Since now information about changed upper is passed along, benefit from
that and use this info directly.
This also fixes possible issues that could happen when non-master device
is added (current code does not distinguish between master and non-master
upper device).
Looking at rtnl kind string is kind of ugly. So use new helpers to do
this in nicer way.
Rocker driver tracks arp_tbl neighs to resolve IPv4 route nexthops. The
driver uses NETEVENT_NEIGH_UPDATE for neigh adds and updates, but there is
no event when the neigh is removed from the device (such as when the device
goes admin down). This patches hooks ndo_neigh_destroy so the driver can
know when a neigh is removed from the device. In response, the driver will
purge the neigh entry from its internal tbl.
I didn't find an in-tree users of ndo_neigh_destroy, so I'm not sure if
this ndo is vestigial or if there are out-of-tree users. In any case, it
does what I need here. An alternative design would be to generate
NETEVENT_NEIGH_UPDATE event when neigh is being destroyed, setting state to
NUD_NONE so driver knows neigh entry is dead.
On sucessful probe, driver prints the switch ID. This patch changes the
format of the printed ID to match what's used in sysfs phys_switch_id node.
drivers/net/ethernet/cavium/Kconfig
The cavium conflict was overlapping dependency
changes.
This patch adds an ndm_state member to the switchdev_obj_fdb structure,
in order to support static FDB addresses.
Set Rocker ndm_state to NUD_REACHABLE.
This reverts commit f1d5ca434413b20cd3f8c18ff2b634b7782149a5, reversing
changes made to 4933d85c5173832ebd261756522095837583c458.
I applied v2 instead of v3.
The address in the switchdev_obj_fdb structure is currently represented
as a pointer. Replacing it for a 6-byte array allows switchdev to carry
addresses directly read from hardware registers, not stored by the
switch chip driver (as in Rocker).
After successful register_netdev, we can use netdev_err rather the more
generic dev_err.
Set port to NULL if port probe fails so we don't try to remove partially
initialized port on port probe err cleanup path.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
rocker supports the transmission of scattered packets, so let the kernel
know about it by setting the NETIF_F_SG bit in the device's features.
When removing a port's netdevice in 'rocker_remove_ports', we should
also free the allocated 'net_device' structure. Do that by calling
'free_netdev' after unregistering it.
Fixes: 4b8ac9660af ("rocker: introduce rocker switch driver")
If device flags ingress packet as "fwd offload", mark the
skb->offlaod_fwd_mark using the ingress port's dev->offlaod_fwd_mark. This
will be the hint to the kernel that this packet has already been forwarded
by device to egress ports matching skb->offlaod_fwd_mark.
For rocker, derive port dev->offlaod_fwd_mark based on device switch ID and
port ifindex. If port is bridged, use the bridge ifindex rather than the
port ifindex.
Teach rocker to forward packets to CPU when a port is joined to Open vSwitch.
There is scope to later refine what is passed up as per Open vSwitch flows
on a port.
This does not change the behaviour of rocker ports that are
not joined to Open vSwitch.
Signed-off-by: Simon Horman <simon.horman@netronome.com>
protodown can be set by user space applications like MLAG on detecting
errors on a switch port. This patch provides sample switch driver changes
for handling protodown. Rocker PHYS disables the port in response to
protodown.
Signed-off-by: Anuradha Karuppiah <anuradhak@cumulusnetworks.com>
Signed-off-by: Andy Gospodarek <gospo@cumulusnetworks.com>
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Signed-off-by: Wilson Kok <wkok@cumulusnetworks.com>
Implement ndo_change_mtu: on MTU change, reallocate Rx ring bufs and signal
HW of new port MTU value.
Reviewed-by: Simon Horman <simon.horman@netronome.com>
Tested-by: Simon Horman <simon.horman@netronome.com>
drivers/net/ethernet/mellanox/mlx4/main.c
net/packet/af_packet.c
Both conflicts were cases of simple overlapping changes.
Use the correct unregister function matching the register
function on the error path.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
Fixes: c1beeef7a32a791a ("rocker: implement IPv4 fib offloading")
One more missing piece of the puzzle. Add vlan dump support to switchdev
port's bridge_getlink. iproute2 "bridge vlan show" cmd already knows how
to show the vlans installed on the bridge and the device , but (until now)
no one implemented the port vlan part of the netlink PF_BRIDGE:RTM_GETLINK
msg. Before this patch, "bridge vlan show":
$ bridge -c vlan show
port vlan ids
sw1p1 30-34 << bridge side vlans
57
sw1p1 << device side vlans (missing)
sw1p2 57
sw1p2
sw1p3
sw1p4
br0 None
(When the port is bridged, the output repeats the vlan list for the vlans
on the bridge side of the port and the vlans on the device side of the
port. The listing above show no vlans for the device side even though they
are installed).
After this patch:
port vlan ids
57
sw1p1 30-34 << device side vlans
57
3840 PVID
sw1p2 57
sw1p2 57
3840 PVID
sw1p3 3842 PVID
sw1p4 3843 PVID
br0 None
I re-used ndo_dflt_bridge_getlink to add vlan fill call-back func.
switchdev support adds an obj dump for VLAN objects, using the same
call-back scheme as FDB dump. Support included for both compressed and
un-compressed vlan dumps.
Use vid_begin/end to be consistent with BRIDGE_VLAN_INFO_RANGE_BEGIN/END.
We need to delete from offload the device externally learnded fdbs when any
one of these events happen:
1) Bridge ages out fdb. (When bridge is doing ageing vs. device doing
ageing. If device is doing ageing, it would send SWITCHDEV_FDB_DEL
directly).
2) STP state change flushes fdbs on port.
3) User uses sysfs interface to flush fdbs from bridge or bridge port:
echo 1 >/sys/class/net/BR_DEV/bridge/flush
echo 1 >/sys/class/net/BR_PORT/brport/flush
4) Offload driver send event SWITCHDEV_FDB_DEL to delete fdb entry.
For rocker, we can now get called to delete fdb entry in wait and nowait
contexts, so set NOWAIT flag when deleting fdb entry.
