[ Upstream commit e6dbe1eb2db0d7a14991c06278dd3030c45fb825 ]
priv->hwts_*_en indicate if timestamping is enabled/disabled at run
time. But priv->dma_cap.time_stamp and priv->dma_cap.atime_stamp
indicates HW is support for PTPv1/PTPv2.
Signed-off-by: Phil Reid <preid@electromag.com.au>
Acked-by: Richard Cochran <richardcochran@gmail.com>
This patch is to fix the max coalesce timer setting that can be provided
by ethtool.
The default value (STMMAC_COAL_TX_TIMER) was used in the set_coalesce helper
instead of the max one (STMMAC_MAX_COAL_TX_TICK, so defined but not used).
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
This patch is to fix a typo on mmc rx crc error when reported by ethtool.
This adds simple cleanups for stmmac, removing test we know is always
true, fixing whitespace, and moving code out of if().
Signed-off-by: Pavel Machek <pavel@denx.de>
The synopsys EMAC can be configured for different numbers of multicast hash
bins and perfect filter entries at device creation time and there's no way
to query this configuration information at runtime. As a result, a devicetree
parameter is required in order for the driver to program these filters
correctly for a particular device instance. This patch modifies the
10/100/1000 MAC software interface such that these configuration parameters
can be set at initialization time.
Signed-off-by: Vince Bridgers <vbridgers2013@gmail.com>
The following patch removed unnecessary spin_lock/unlock calls
in ethtool_ops callback functions. In the second and final version
of the patch one spin_lock call was left behind.
commit cab6715c3e8029e98b0b5d4056ceda007c0f6380
Author: Yang Wei <Wei.Yang@windriver.com>
Date: Sun May 25 09:53:44 2014 +0800
net: driver: stmicro: Remove some useless the lock protection
This introduced the following sparse warning:
drivers/net/ethernet/stmicro/stmmac/stmmac_ethtool.c:424:1: warning:
context imbalance in 'stmmac_get_pauseparam' -
different lock contexts for basic block
Signed-off-by: Emil Goode <emilgoode@gmail.com>
kernel always invokes a pair of rtnl_lock adn rtnl_unlock to
protect dev_ethtool(), so its not neccessary to invoke spin_lock/unlock
in ethtool_ops.
Signed-off-by: Yang Wei <Wei.Yang@windriver.com>
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
This patch implements PHC (ptp hardware clock) driver for stmmac
driver to support 1588 PTP.
V2: added support for FINE method, reduced loop delay and review spinlock.
Signed-off-by: Rayagond Kokatanur <rayagond@vayavyalabs.com>
Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Cc: Richard Cochran <richardcochran@gmail.com>
This patch enhances the stmmac driver to support IEEE 1588-2002
PTP (Precision Time Protocol) version 1 and IEEE 1588-2008 PPT
version 2.
Precision Time Protocol(PTP),which enables precise synchronization
of clocks in measurement and control systems implemented with
technologies such as network communication,local computing,
& distributed objects.
Both PTPv1 and PTPv2 is selected at run-time using the HW capability
register.
The PTPv1 TimeStamp support can be used on chips that have the normal
descriptor structures and PTPv2 TimeStamp support can be used on chips
that have the Extended descriptors(DES4-5-6-7). All such sanity checks
are done and verified by using HW capability register.
V2: in this version the ethtool support has been included in this patch;
Koptions have been completely removed (previously added to select
PTP and PTPv2). PTPv1 and PTPv2 is now added in a single patch instead of
two patches.
get_timestamp() and get_systemtime() L/H have been combined into single APIs.
This patch adds the minimal support to manage the PCS
modes (RGMII/SGMII) and restart the ANE.
Both TBI and RTBI are not yet supported.
Thanks to Byungho that wrote some part of this code
and tested SGMII too.
The only thing to be fixed is the get/set pause in
ethtool.
Signed-off-by: Byungho An <bh74.an@samsung.com>
This patch starts adding in the main ISR the management of the PCS and
RGMII/SGMII core interrupts. This is to help further development
on this area. Currently the core irq handler only clears the
PCS and S-R_MII interrupts and reports the event in the ethtool stats.
Tested-by: Byungho An <bh74.an@samsung.com>
Cc: Udit Kumar <udit-dlh.kumar@st.com>
This patch is to support the extend descriptors available
in the chips newer than the 3.50.
In case of the extend descriptors cannot be supported,
at runtime, the driver will continue to work using the old style.
In detail, this support extends the main descriptor structure
adding new descriptors: 4, 5, 6, 7. The desc4 gives us extra
information about the received ethernet payload when it is
carrying PTP packets or TCP/UDP/ICMP over IP packets.
The descriptors 6 and 7 are used for saving HW L/H timestamps (PTP).
V2: this new version removes the Koption added in the first implementation
because all the checks now to verify if the extended descriptors are
actually supported happen at probe time.
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
This patch is to get/set the tx/rx coalesce parameters
via ethtool interface.
Tests have been done on several platform with different GMAC chips w/o and w/
RX watchdog feature.
V2: reject coalesce settings that are not supported.
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
GMAC devices newer than databook 3.40 has an embedded timer
that can be used for mitigating the number of interrupts.
So this patch adds this optimizations.
At any rate, the Rx watchdog can be disable (on bugged HW) by
passing from the platform the riwt_off field.
In this implementation the rx timer stored in the Reg9 is fixed
to the max value. This will be tuned by using ethtool.
V2: added a platform parameter to force to disable the rx-watchdog
for example on new core where it is bugged.
V3: do not disable NAPI when Rx watchdog is used.
V4: a new extra statistic field has been added to show the early
receive status in the interrupt handler.
This patch also adds an extra check to avoid to call
napi_schedule when the DMA_INTR_ENA_RIE bit is disabled in the
Interrupt Mask register.
This patch adds a new schema used for mitigating the
number of transmit interrupts.
It is based on a SW timer and a threshold value.
The timer is used to periodically call the stmmac_tx_clean
function; the threshold is used for setting the IC (Interrupt
on Completion bit). The ISR will then invoke the poll method.
Also the patch improves some ethtool stat fields.
V2: review the logic to manage the IC bit in the TDESC
that was bugged because it didn't take care about the
fragments. Also fix the tx_count_frames that has not to be
limited to TX DMA ring. Thanks to Ben Hutchings.
V3: removed the spin_lock irqsave/restore as D. Miller suggested.
This patch adds the Energy Efficient Ethernet support to the stmmac.
Please see the driver's documentation for further details about this support
in the driver.
Thanks also goes to Rayagond Kokatanur for his first implementation.
Note:
to clearly manage and expose the lpi interrupt status and eee ethtool
stats I've had to do some modifications to the driver's design and I
found really useful to move other parts of the code (e.g. mmc irq stat)
in the main directly. So this means that some core has been reworked
to introduce the EEE.
v1: initial patch
v2: fixed some sparse issues (typos)
v3: erroneously sent the v2 renamed as v3
v4:
o Fixed the return value of the stmmac_eee_init as suggested by D.Miller
o Totally reviewed the ethtool support for EEE
o Added a new internal parameter to tune the SW timer for TX LPI.
v5: do not change any eee setting in case of the stmmac_ethtool_op_set_eee fails
(it has to return -EOPNOTSUPP in that case).
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
If this bit is set and the CRC error is reset, then the packet is valid.
Only report this as stat info.
Auditing all usage of ethtool_ops found several drivers that
are not declaring the struct const when it should be.
The forcedeth changes had a conflict with the conversion over
to atomic u64 statistics in net-next.
The libertas cfg.c code had a conflict with the bss reference
counting fix by John Linville in net-next.
drivers/net/ethernet/nvidia/forcedeth.c
drivers/net/wireless/libertas/cfg.c
New GMAC devices (newer than the databook 3.50a) have the
HW capability register that provides which features are actually
supported by the hardware.
On old devices many information have to be passed through the
platform, for example: enhanced descriptor structure,
TX COE etc. These are mandatory to properly configure the driver.
This remains still valid because the driver has to support old
Synopsys devices but now it's also able to override them using the
values from the HW capability register if supported.
Convert some remaining straglers' .get_drvinfo routines to use strlcpy
rather than strcpy/strncpy.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
This patch updates the normal descriptor structure
to work fine on new GMAC Synopsys chips.
Normal descriptors were designed on the old MAC10/100
databook 1.91 where some bits were reserved: for example
the tx checksum insertion and rx checksum offload.
The patch maintains the back-compatibility with old
MAC devices (tested on STx7109 MAC10/100) and adds new
fields that actually new GMAC devices can use.
For example, STx7109 (MAC10/100) will pass from the platform
tx_coe = 0, enh_desc = 0, has_gmac = 0.
A platform like Loongson1B (GMAC) will pass:
tx_coe = 1, enh_desc = 0, has_gmac = 1.
Thanks to Kelvin, he enhanced the normal descriptors for
GMAC (on MIPS Loongson1B platform).
Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com>
Enable the MMC support if it is actually available from the
This patch adds the MMC management counters support.
MMC module is an extension of the register address
space and all the hardware counters can be accessed
via ethtoo -S ethX.
Note that, the MMC interrupts remain masked and the logic
to handle this kind of interrupt will be added later (if
actually useful).
On some platforms e.g. SPEAr the wake up irq differs from the
GMAC interrupt source.
With this patch an external wake up irq can be passed through the
platform code and named as "eth_wake_irq".
In case the wake up interrupt is not passed from the platform
so the driver will continue to use the mac irq (ndev->irq)
Signed-off-by: Deepak Sikri <deepak.sikri@st.com>
Move the STMicroelectronics driver into driver/net/ethernet/stmicro/ and
make the necessary Kconfig and Makefile changes.
CC: Giuseppe Cavallaro <peppe.cavallaro@st.com>
