Pull networking changes from David Miller:
"Noteworthy changes this time around:
1) Multicast rejoin support for team driver, from Jiri Pirko.
2) Centralize and simplify TCP RTT measurement handling in order to
reduce the impact of bad RTO seeding from SYN/ACKs. Also, when
both timestamps and local RTT measurements are available prefer
the later because there are broken middleware devices which
scramble the timestamp.
From Yuchung Cheng.
3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel
memory consumed to queue up unsend user data. From Eric Dumazet.
4) Add a "physical port ID" abstraction for network devices, from
Jiri Pirko.
5) Add a "suppress" operation to influence fib_rules lookups, from
Stefan Tomanek.
6) Add a networking development FAQ, from Paul Gortmaker.
7) Extend the information provided by tcp_probe and add ipv6 support,
from Daniel Borkmann.
8) Use RCU locking more extensively in openvswitch data paths, from
Pravin B Shelar.
9) Add SCTP support to openvswitch, from Joe Stringer.
10) Add EF10 chip support to SFC driver, from Ben Hutchings.
11) Add new SYNPROXY netfilter target, from Patrick McHardy.
12) Compute a rate approximation for sending in TCP sockets, and use
this to more intelligently coalesce TSO frames. Furthermore, add
a new packet scheduler which takes advantage of this estimate when
available. From Eric Dumazet.
13) Allow AF_PACKET fanouts with random selection, from Daniel
Borkmann.
14) Add ipv6 support to vxlan driver, from Cong Wang"
Resolved conflicts as per discussion.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits)
openvswitch: Fix alignment of struct sw_flow_key.
netfilter: Fix build errors with xt_socket.c
tcp: Add missing braces to do_tcp_setsockopt
caif: Add missing braces to multiline if in cfctrl_linkup_request
bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize
vxlan: Fix kernel panic on device delete.
net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls
net: mvneta: properly disable HW PHY polling and ensure adjust_link() works
icplus: Use netif_running to determine device state
ethernet/arc/arc_emac: Fix huge delays in large file copies
tuntap: orphan frags before trying to set tx timestamp
tuntap: purge socket error queue on detach
qlcnic: use standard NAPI weights
ipv6:introduce function to find route for redirect
bnx2x: VF RSS support - VF side
bnx2x: VF RSS support - PF side
vxlan: Notify drivers for listening UDP port changes
net: usbnet: update addr_assign_type if appropriate
driver/net: enic: update enic maintainers and driver
driver/net: enic: Exposing symbols for Cisco's low latency driver
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change
to make the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Gotta love a macro that doesn't reduce the typing you have to do.
Also, only the driver core, and one network driver uses this. The
driver core functions will be going away soon, and I'll convert the
network driver soon to not need this as well, so delete it for now
before anyone else gets some bright ideas and wants to use it.
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Also, unnecessary dev_set_drvdata() is removed, because the driver core
clears the driver data to NULL after device_release or on probe failure.
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for
an 802.3 frame. Frames with a lower value in the ethernet type field
are Ethernet II.
Also update all the users of this value that David Miller and
I could find to use the new constant.
Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN
should be >= not >.
As suggested by Jesse Gross.
Compile tested only.
Cc: Jesse Gross <jesse@nicira.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Bart De Schuymer <bart.de.schuymer@pandora.be>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netfilter-devel@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
Cc: linux-wireless@vger.kernel.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-media@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: dev@openvswitch.org
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Simon Horman <horms@verge.net.au>
alloc failures already get standardized OOM
messages and a dump_stack.
Convert kzalloc's with multiplies to kcalloc.
Convert kmalloc's with multiplies to kmalloc_array.
Fix a few whitespace defects.
Convert a constant 6 to ETH_ALEN.
Use parentheses around sizeof.
Convert vmalloc/memset to vzalloc.
Remove now unused size variables.
perm_addr is initialized correctly in register_netdevice() so to init it in
drivers is no longer needed.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The __dev* removal patches for the network drivers ended up messing up
the function prototypes for a bunch of drivers. This patch fixes all of
them back up to be properly aligned.
Bonus is that this almost removes 100 lines of code, always a nice
surprise.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
The function niu_pci_init_one() return 0 for success and negative value
for most of its internal tests failures. There is one exception
that is error case going to err_out_free_res:. For this error case, the
function abort its success execution path, but returns non negative
value, making it difficult for a caller function to notice the error.
This patch fixes the error case that do not return negative value.
This was found by Coccinelle, but the code change was made by hand.
This patch is not robot generated.
A simplified version of the semantic match that finds this problem is
as follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
Use PCI Express Capability access functions to simplify niu driver.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
return value
Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return
value to be consistent with the rest of the checks after niu_rbr_add_page()
calls in this file.
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
Fix Neptune ethernet driver to check dma mapping error after map_page()
interface returns.
This reverts commit efa230f2c68abab817f13473077f8d0cc74f43f3.
BQL doesn't work with how this driver currently only takes TX
interrupts every 1/4 of the TX ring. That behavior needs to be fixed,
but that's a larger non-trivial task and for now we have to revert
BQL support as this makes the device currently completely unusable.
The idea here seems to be to get a 44bit DMA mask working and if this
fails it should fallback to a 32bit DMA mask. The dma_mask variable is
assigned once to 44bit and never updated. pci_set_dma_mask() and
pci_set_consistent_dma_mask() are both implemented as functions so there
is no evil macro which might update dma_mask. Looking at the assembly, I
see a call to dma_set_mask() followed by dma_supported() and then a jump
passed the second dma_set_mask(). The only way to get to second
dma_set_mask() call is by an error code in the first one.
So I hereby remove the check since it looks superfluous. Please ignore
the path if there is black magic involved.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Unify return value of .ndo_set_mac_address if the given address
isn't valid. Return -EADDRNOTAVAIL as eth_mac_addr() already does
if is_valid_ether_addr() fails.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
alloc_etherdev has a generic OOM/unable to alloc message.
Remove the duplicative messages after alloc_etherdev calls.
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
This patch implements advice by Ben Hutchings to change the mii side of
the function names to look more like the register whose values they
convert. New LPA translation functions have been added as well.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Translating between ethtool advertisement settings and MII
advertisements are common operations for ethernet drivers. This patch
adds a set of helper functions that implements the conversion. The
patch then modifies a couple of the drivers to use the new functions.
Perform another round of floor sweeping, converting the .get_drvinfo
routines of additional drivers from strcpy to strlcpy along with
some conversion of sprintf to snprintf.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
To ease skb->truesize sanitization, its better to be able to localize
all references to skb frags size.
Define accessors : skb_frag_size() to fetch frag size, and
skb_frag_size_{set|add|sub}() to manipulate it.
Add a 'truesize' argument to niu_rx_skb_append(), filled with rcr_size
by the caller to properly account frag sizes in skb->truesize
A user-space process must use ETHTOOL_GRXCLSRLCNT to find the number
of classification rules, then allocate a buffer of the right size,
then use ETHTOOL_GRXCLSRLALL to fill the buffer. If some other
process inserts or deletes a rule between those two operations,
the user buffer might turn out to be the wrong size.
If it's too small, the return value will be -EMSGSIZE. But if it's
too large, there is no indication of this. Fix this by updating
the rule_cnt field on return.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Correct the description of ethtool_rxnfc::rule_locs; it is an array
of currently used locations, not all possible valid locations.
Add note that drivers must not use ethtool_rxnfc::rule_locs.
The rule_locs argument to ethtool_ops::get_rxnfc is either NULL or a
pointer to an array of u32, so change the parameter type accordingly.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Use IFF_UNICAST_FTL to find out if driver handles unicast address
filtering. In case it does not, promisc mode is entered.
Patch also fixes following drivers:
stmmac, niu: support uc filtering and yet it propagated
ndo_set_multicast_list
bna, benet, pxa168_eth, ks8851, ks8851_mll, ksz884x : has set
ndo_set_rx_mode but do not support uc filtering
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Moves the Sun drivers into drivers/net/ethernet/sun/ and make
the necessary Kconfig and Makefile changes.
Oliver Hartkopp <socketcan@hartkopp.net> suggested removing the
sun* prefix on the driver names. This type of change I will
leave up to the driver maintainers.
CC: Sam Creasey <sammy@sammy.net>
CC: Adrian Sun <asun@darksunrising.com>
CC: Benjamin Herrenscmidt <benh@kernel.crashing.org>
