Convert the memset/memcpy uses of 6 to ETH_ALEN
where appropriate.
Also convert some struct definitions and u8 array
declarations of [6] to ETH_ALEN.
Acked-by: Arend van Spriel <arend@broadcom.com>
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Also, unnecessary dev_set_drvdata() is removed, because the driver core
clears the driver data to NULL after device_release or on probe failure.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Emitting netdev_alloc_skb and netdev_alloc_skb_ip_align OOM
messages is unnecessary as there is already a dump_stack
after allocation failures.
Other trivial changes around these removals:
Convert a few comparisons of pointer to 0 to !pointer.
Change flow to remove unnecessary label.
Remove now unused variable.
Hoist assignment from if.
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force, __iomem and __user.
type T;
T *p;
- (T *)p
+ p
A function in atl1e_main.c was passed a const pointer
when it actually modified elements of the structure.
Change the argument to a non-const pointer.
A function in stmmac needed a __force to avoid a sparse
warning. Added it.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Print MAC/dev_addr via printk extended format specifier %pM
instead of custom code.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Replaced deprecating dev_alloc_skb with netdev_alloc_skb in drivers/net/ethernet
- Removed extra skb->dev = dev after netdev_alloc_skb
Signed-off-by: Pradeep A Dalvi <netdev@pradeepdalvi.com>
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Moves the Sun drivers into drivers/net/ethernet/sun/ and make
the necessary Kconfig and Makefile changes.
Oliver Hartkopp <socketcan@hartkopp.net> suggested removing the
sun* prefix on the driver names. This type of change I will
leave up to the driver maintainers.
CC: Sam Creasey <sammy@sammy.net>
CC: Adrian Sun <asun@darksunrising.com>
CC: Benjamin Herrenscmidt <benh@kernel.crashing.org>
