[ Upstream commit bacade822524e02f662d88f784d2ae821a5546fb ]
The method ndo_start_xmit() is defined as returning an 'netdev_tx_t',
which is a typedef for an enum type, so make sure the implementation in
this driver has returns 'netdev_tx_t' value, and change the function
return type to netdev_tx_t.
Found by coccinelle.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
The ethtool api {get|set}_settings is deprecated.
We move this driver to new api {get|set}_link_ksettings.
As I don't have the hardware, I'd be very pleased if
someone may test this patch.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
Tested-by: Geoff Levand <geoff@infradead.org>
napi_complete_done() allows to opt-in for gro_flush_timeout,
added back in linux-3.19, commit 3b47d30396ba
("net: gro: add a per device gro flush timer")
This allows for more efficient GRO aggregation without
sacrifying latencies.
gelic_net: min_mtu 64, max_mtu 1518
- remove gelic_net_change_mtu now that it is redundant
spidernet: min_Mtu 64, max_mtu 2294
- remove spiter_net_change_mtu now that it is redundant
CC: netdev@vger.kernel.org
CC: Geoff Levand <geoff@infradead.org>
CC: Ishizaki Kou <kou.ishizaki@toshiba.co.jp>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Trival fix, dev_dbg message is missing a \n, so add it.
We'd like to eventually remove NO_IRQ on powerpc, so remove usages of it
from powerpc-only drivers.
When the DEBUG preprocessor macro is defined the ps3_gelic_net driver build
fails due to an undeclared routine gelic_descr_get_status(). This problem
was introduced during the code cleanup of commit
6b0c21cede22be1f68f0a632c0ca38008ce1abe7 (net: Fix p3_gelic_net sparse warnings),
which re-arranged the ordering of some of the gelic routines.
This change just moves the gelic_descr_get_status() routine up in the
ps3_gelic_net.c source file. There is no functional change.
Fixes build errors like these:
drivers/net/ethernet/toshiba/ps3_gelic_net.c: error: implicit declaration of function gelic_descr_get_status
Signed-off-by: Geoff Levand <geoff@infradead.org>
To test a checkpatch spelling patch, I ran codespell against
drivers/net/ethernet/.
$ git ls-files drivers/net/ethernet/ | \
while read file ; do \
codespell -w $file; \
done
I removed a false positive in e1000_hw.h
allocation
A check on a memory allocation is checked incorrectly.
This was partly found using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Acked-by: Geoff Levand <geoff@infradead.org>
Set the return variable to propagate any error code as done elsewhere in
the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
This patch proposes to remove the IRQF_DISABLED flag from
It's a NOOP since 2.6.35 and I will remove it one day ;)
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Since commit 82dc3c63 ("net: introduce NAPI_POLL_WEIGHT")
netif_napi_add() produces an error message if a NAPI poll weight
greater than 64 is requested.
GELIC_NET_NAPI_WEIGHT is defined to GELIC_NET_RX_DESCRIPTORS,
which is 128.
Use the standard NAPI weight.
v2: proper reference to the related commit
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Rearrange routines to avoid local declarations and remove
unnecessary inline tags. No functional changes.
Fixes sparse warnings like these:
ps3_gelic_net.c: error: marked inline, but without a definition
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The __dev* removal patches for the network drivers ended up messing up
the function prototypes for a bunch of drivers. This patch fixes all of
them back up to be properly aligned.
Bonus is that this almost removes 100 lines of code, always a nice
surprise.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Geoff Levand <geoff@infradead.org>
Cc: cbe-oss-dev@lists.ozlabs.org
The lv1_net_stop_tx_dma and net_stop_rx_dma hcalls take 2, not 3 input
arguments. Adjust the lv1 hcall table and all calls.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/p3060qds: Add support for P3060QDS board
powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX
powerpc/85xx: Make kexec to interate over online cpus
powerpc/fsl_booke: Fix comment in head_fsl_booke.S
powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices
powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver
powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver
powerpc/86xx: Correct Gianfar support for GE boards
powerpc/cpm: Clear muram before it is in use.
drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager
powerpc/fsl_msi: add support for "msi-address-64" property
powerpc/85xx: Setup secondary cores PIR with hard SMP id
powerpc/fsl-booke: Fix settlbcam for 64-bit
powerpc/85xx: Adding DCSR node to dtsi device trees
powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards
powerpc/85xx: fix PHYS_64BIT selection for P1022DS
powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map
powerpc: respect mem= setting for early memory limit setup
powerpc: Update corenet64_smp_defconfig
powerpc: Update mpc85xx/corenet 32-bit defconfigs
Fix up trivial conflicts in:
- arch/powerpc/configs/40x/hcu4_defconfig
removed stale file, edited elsewhere
- arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c:
added opal and gelic drivers vs added ePAPR driver
- drivers/tty/serial/8250.c
moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Move the Toshiba ethernet drivers into drivers/net/ethernet/toshiba
and make the necessary Kconfig and Makefile changes.
CC: Jens Osterkamp <Jens.Osterkamp@de.ibm.com>
