[ Upstream commit bacade822524e02f662d88f784d2ae821a5546fb ]
The method ndo_start_xmit() is defined as returning an 'netdev_tx_t',
which is a typedef for an enum type, so make sure the implementation in
this driver has returns 'netdev_tx_t' value, and change the function
return type to netdev_tx_t.
Found by coccinelle.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 125b7e0949d4e72b15c2b1a1590f8cece985a918 ]
clang warns:
drivers/net/ethernet/toshiba/tc35815.c:1507:30: warning: use of logical
'&&' with constant operand [-Wconstant-logical-operand]
if (!HAVE_DMA_RXALIGN(lp) && NET_IP_ALIGN)
drivers/net/ethernet/toshiba/tc35815.c:1507:30: note: use '&' for a
bitwise operation
drivers/net/ethernet/toshiba/tc35815.c:1507:30: note: remove constant to
silence this warning
1 warning generated.
Explicitly check that NET_IP_ALIGN is not zero, which matches how this
is checked in other parts of the tree. Because NET_IP_ALIGN is a build
time constant, this check will be constant folded away during
optimization.
Fixes: 82a9928db560 ("tc35815: Enable StripCRC feature")
Link: https://github.com/ClangBuiltLinux/linux/issues/608
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Processing any incoming packets with a with a napi budget of 0
is incorrect driver behavior.
This matters as netpoll will shortly call drivers with a budget of 0
to avoid receive packet processing happening in hard irq context.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This covers everything under drivers/net except for wireless, which
has been submitted separately.
Instead of open-coding the PHY reset through MII BMCR, use phy_init_hw()
which does that for us and also makes sure that any PHY specific fixups
are applied.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Removing some boilerplate by using module_pci_driver instead of calling
register and unregister in the otherwise empty init/exit functions.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
The flags argument of the phy_{attach,connect,connect_direct} functions
is then used to assign a struct phy_device dev_flags with its value.
All callers but the tg3 driver pass the flag 0, which results in the
underlying PHY drivers in drivers/net/phy/ not being able to actually
use any of the flags they would set in dev_flags. This patch gets rid of
the flags argument, and passes phydev->dev_flags to the internal PHY
library call phy_attach_direct() such that drivers which actually modify
a phy device dev_flags get the value preserved for use by the underlying
phy driver.
Acked-by: Kosta Zertsekel <konszert@marvell.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
perm_addr is initialized correctly in register_netdevice() so to init it in
drivers is no longer needed.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
The __dev* removal patches for the network drivers ended up messing up
the function prototypes for a bunch of drivers. This patch fixes all of
them back up to be properly aligned.
Bonus is that this almost removes 100 lines of code, always a nice
surprise.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Replace usage of random_ether_addr() with eth_hw_addr_random()
to set addr_assign_type correctly to NET_ADDR_RANDOM.
Change the trivial cases.
v2: adapt to renamed eth_hw_addr_random()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Replaced deprecating dev_alloc_skb with netdev_alloc_skb in drivers/net/ethernet
- Removed extra skb->dev = dev after netdev_alloc_skb
Signed-off-by: Pradeep A Dalvi <netdev@pradeepdalvi.com>
alloc_etherdev has a generic OOM/unable to alloc message.
Remove the duplicative messages after alloc_etherdev calls.
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Move the Toshiba ethernet drivers into drivers/net/ethernet/toshiba
and make the necessary Kconfig and Makefile changes.
CC: Geoff Levand <geoff@infradead.org>
CC: Jens Osterkamp <Jens.Osterkamp@de.ibm.com>
CC: Ishizaki Kou <kou.ishizaki@toshiba.co.jp>
