Kernel source files need not include <linux/kconfig.h> explicitly
because the top Makefile forces to include it with:
-include $(srctree)/include/linux/kconfig.h
This commit removes explicit includes except the following:
* arch/s390/include/asm/facilities_src.h
* tools/testing/radix-tree/linux/kernel.h
These two are used for host programs.
Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com
alloc_workqueue replaces deprecated create_workqueue().
A dedicated workqueue has been used since the workitems are involved
in normal device operation. Workitems &priv->rx_work and &priv->tx_work,
map to w5100_rx_work and w5100_tx_work respectively and are involved in
receiving and transmitting packets. Forward progress under
memory pressure is a requirement here.
create_workqueue has been replaced with alloc_workqueue with max_active
as 0 since there is no need for throttling the number of active work
items.
Since the driver may be used in memory reclaim path,
WQ_MEM_RECLAIM has been set to guarantee forward progress.
flush_workqueue is unnecessary since destroy_workqueue() itself calls
drain_workqueue() which flushes repeatedly till the workqueue
becomes empty. Hence the call to flush_workqueue() has been dropped.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
This adds support to specify the MAC address by 'mac-address' or
'local-mac-address' properties in the device tree. These are common
properties for the Ethernet controller.
Cc: Mike Sinkovsky <msink@permonline.ru>
This increases TX timeout period from one second to 5 seconds which is
the default value if the driver doesn't explicitly set
net_device->watchdog_timeo.
The one second timeout is too short for W5100 with SPI interface mode
which doesn't support burst READ/WRITE processing in the SPI transfer.
If the packet is transmitted while RX packets are being received at a
very high rate, the TX transmittion work in the workqueue is delayed
and the watchdog timer is expired.
W5500 has different bit position for MAC filter in Socket n mode
register from W5100 and W5200.
The is_w5200() function is not used anymore by the commit which adds
the W5500 support.
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
This adds support for W5500 chip.
W5500 has similar register and memory organization with W5100 and W5200.
There are a few important differences listed below but it is still
possible to share common code with W5100 and W5200.
* W5500 register and memory are organized by multiple blocks. Each one
is selected by 16bits offset address and 5bits block select bits.
But the existing register access operations take u16 address. This change
extends the addess by u32 address and put offset address to lower 16bits
and block select bits to upper 16bits.
This change also adds the offset addresses for socket register and TX/RX
memory blocks to the driver private data structure in order to reduce
conditional switches for each chip.
* W5500 has the different register offset for socket interrupt mask
register. Newly added internal functions w5100_enable_intr() and
w5100_disable_intr() take care of the diffrence.
* W5500 has the different register offset for retry time-value register.
But this register is only used to verify that the reset value is correctly
read at initialization. So move the verification to w5100_hw_reset()
which already does different things for different chips.
The w5100-spi driver front-end only makes sense when the w5100
core driver is enabled, not for a configuration that only has w5300:
drivers/net/built-in.o: In function `w5100_spi_remove':
drivers/net/ethernet/wiznet/w5100-spi.c:277: undefined reference to `w5100_remove'
drivers/net/built-in.o: In function `w5100_spi_probe':
drivers/net/ethernet/wiznet/w5100-spi.c:272: undefined reference to `w5100_probe'
drivers/net/built-in.o: In function `w5200_spi_init':
drivers/net/ethernet/wiznet/w5100-spi.c:125: undefined reference to `w5100_ops_priv'
drivers/net/built-in.o: In function `w5200_spi_readbulk':
drivers/net/built-in.o: In function `w5200_spi_writebulk':
drivers/net/built-in.o:(.data+0x3ed1c): undefined reference to `w5100_pm_ops'
This adds an appropriate Kconfig dependency.
Fixes: 630cf09751fe ("net: w5100: support SPI interface mode")
This adds support for W5200 chip.
W5100 and W5200 have similar memory map although some of their offsets
are different. The register access sequences between them are different
but w5100 driver has abstraction layer for difference bus interface
modes so it is easy to add W5200 support to w5100 and w5100-spi drivers.
This adds new w5100-spi driver which shares the bus interface
independent code with existing w5100 driver.
SPI transfer routines are callable only from contexts that can sleep.
This adds ability to tell the core driver that the interface mode
cannot access w5100 register on atomic contexts. In this case,
workqueue and threaded irq are required.
This also corrects timeout period waiting for command register to be
automatically cleared because the latency of the register access with
SPI transfer can be interfered by other contexts.
The w5100 driver currently only supports direct and indirect bus
interface mode which use MMIO space for accessing w5100 registers.
In order to support SPI interface mode which is supported by W5100 chip,
this makes the bus interface abstraction layer more generic so that
separated w5100-spi driver can use w5100 driver as core module.
Instead of sprinkle mmiowb over the driver code, move it into primary
register write callbacks. (w5100_write, w5100_write16, w5100_writebuf)
This is a preparation for supporting SPI interface which doesn't use
MMIO for accessing w5100 registers.
This howto made sense in the 1990s when users had to manually configure
ISA cards with jumpers or vendor utilities, but with the implementation
of PCI it became increasingly less and less relevant, to the point where
it has been well over a decade since I last updated it. And there is
no value in anyone else taking over updating it either.
However the references to it continue to spread as boiler plate text
from one Kconfig file into the next. We are not doing end users any
favours by pointing them at this old document, so lets kill it with
fire, once and for all, to hopefully stop any further spread.
No code is changed in this commit, just Kconfig help text.
drivers/net/ethernet/emulex/benet/be_main.c
net/core/sysctl_net_core.c
net/ipv4/inet_diag.c
The be_main.c conflict resolution was really tricky. The conflict
hunks generated by GIT were very unhelpful, to say the least. It
split functions in half and moved them around, when the real actual
conflict only existed solely inside of one function, that being
be_map_pci_bars().
So instead, to resolve this, I checked out be_main.c from the top
of net-next, then I applied the be_main.c changes from 'net' since
the last time I merged. And this worked beautifully.
The inet_diag.c and sysctl_net_core.c conflicts were simple
overlapping changes, and were easily to resolve.
The interrupt is enabled before napi_complete(). A network timeout
occurs if the interrupt handler is called before napi_complete().
Fix the bug by enabling the interrupt after napi_complete().
Signed-off-by: Yongbae Park <yongbae2@gmail.com>
To test a checkpatch spelling patch, I ran codespell against
drivers/net/ethernet/.
$ git ls-files drivers/net/ethernet/ | \
while read file ; do \
codespell -w $file; \
done
I removed a false positive in e1000_hw.h
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
devm_ioremap_resource checks platform_get_resource() return value.
We can remove the duplicate check here.
Signed-off-by: Varka Bhadram <varkab@cdac.in>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
There is no need to call ether_setup after alloc_ethdev since it was
already called there.
Follow commits c706471b2601 ("net: axienet: remove unnecessary
ether_setup after alloc_etherdev") and 3c87dcbfb36c ("net: ll_temac:
Remove unnecessary ether_setup after alloc_etherdev") and fix the
pattern in all remaining ethernet drivers.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Use devm_ioremap_resource() in order to make the code simpler.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change
to make the code simpler and enhance the readability.
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Roland Stigge <stigge@antcom.de>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Tested-by: Roland Stigge <stigge@antcom.de>
Add CONFIG_PM_SLEEP to suspend/resume functions to fix the following
build warning when CONFIG_PM_SLEEP is not selected. This is because
sleep PM callbacks defined by SIMPLE_DEV_PM_OPS are only used when
the CONFIG_PM_SLEEP is enabled.
drivers/net/ethernet/wiznet/w5100.c:758:12: warning: 'w5100_suspend' defined but not used [-Wunused-function]
drivers/net/ethernet/wiznet/w5100.c:773:12: warning: 'w5100_resume' defined but not used [-Wunused-function]
drivers/net/ethernet/wiznet/w5300.c:670:12: warning: 'w5300_suspend' defined but not used [-Wunused-function]
drivers/net/ethernet/wiznet/w5300.c:685:12: warning: 'w5300_resume' defined but not used [-Wunused-function]
NET_ADDR_SET is set in dev_set_mac_address() no need to alter
dev->addr_assign_type value in drivers.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
If ndo_validate_addr is set to the generic eth_validate_addr
function there is no point in calling is_valid_ether_addr
from driver ndo_open if ndo_open is not used elsewhere in
the driver.
With this change is_valid_ether_addr will be called from the
generic eth_validate_addr function. So there should be no change
in the actual behavior.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Using eth_hw_addr_random() to generate a random Ethernet address
(MAC) to be used by a net device and set addr_assign_type.
Not need to duplicating its implementation.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The "WIZnet devices" config option should depend on HAS_IOMEM as
all wiznet drivers require it as well.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Convert the existing uses of random_ether_addr to
the new eth_random_addr.
This fixes possible null dereference in probe() function: when both
.mac_addr and .link_gpio are unknown, dev.platform_data may be NULL
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Mike Sinkovsky <msink@permonline.ru>
m68k/allmodconfig:
drivers/net/ethernet/wiznet/w5100.c: In function ‘w5100_hw_probe’:
drivers/net/ethernet/wiznet/w5100.c:680: error: ‘IRQ_TYPE_LEVEL_LOW’ undeclared (first use in this function)
drivers/net/ethernet/wiznet/w5300.c: In function ‘w5300_hw_probe’:
drivers/net/ethernet/wiznet/w5300.c:594: error: ‘IRQ_TYPE_LEVEL_LOW’ undeclared (first use in this function)
Include <linux/irq.h>, which provides the declaration for IRQ_TYPE_LEVEL_LOW.
This option was there for debugging race conditions,
just remove it, and assume TX_FLOW is always enabled.
Both drivers need to depend upon HAS_IOMEM, otherwise we
get a build failure on platforms like S390.
All the driver specific config options need to depend upon
the drivers themselves.
Based on original driver from chip manufacturer, but nearly full rewite.
Tested and used in production with Blackfin BF531 embedded processor.
