path: root/drivers/net/ethernet/xscale
2015-06-23drivers/net: remove all references to obsolete Ethernet-HOWTOPaul Gortmaker
This howto made sense in the 1990s when users had to manually configure ISA cards with jumpers or vendor utilities, but with the implementation of PCI it became increasingly less and less relevant, to the point where it has been well over a decade since I last updated it. And there is no value in anyone else taking over updating it either. However the references to it continue to spread as boiler plate text from one Kconfig file into the next. We are not doing end users any favours by pointing them at this old document, so lets kill it with fire, once and for all, to hopefully stop any further spread. No code is changed in this commit, just Kconfig help text. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/rocker/rocker.c The rocker commit was two overlapping changes, one to rename the ->vport member to ->pport, and another making the bitmask expression use '1ULL' instead of plain '1'. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-03ethernet: Use eth_<foo>_addr instead of memsetJoe Perches
Use the built-in function instead of memset. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-20ethernet/ixp4xx: prevent allmulti from clobbering promiscDerrick Pallas
If both promisc and allmulti are set, promisc should trump allmulti and disable the MAC filter; otherwise, the interface is not really promisc. Previously, this code checked IFF_ALLMULTI prior to and without regard for IFF_PROMISC; if both were set, only multicast and direct unicast traffic would make it through the filter. Signed-off-by: Derrick Pallas <pallas@meraki.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-01net: ptp: move PTP classifier in its own fileDaniel Borkmann
This commit fixes a build error reported by Fengguang, that is triggered when CONFIG_NETWORK_PHY_TIMESTAMPING is not set: ERROR: "ptp_classify_raw" [drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe.ko] undefined! The fix is to introduce its own file for the PTP BPF classifier, so that PTP_1588_CLOCK and/or NETWORK_PHY_TIMESTAMPING can select it independently from each other. IXP4xx driver on ARM needs to select it as well since it does not seem to select PTP_1588_CLOCK or similar that would pull it in automatically. This also allows for hiding all of the internals of the BPF PTP program inside that file, and only exporting relevant API bits to drivers. This patch also adds a kdoc documentation of ptp_classify_raw() API to make it clear that it can return PTP_CLASS_* defines. Also, the BPF program has been translated into bpf_asm code, so that it can be more easily read and altered (extensively documented in [1]). In the kernel tree under tools/net/ we have bpf_asm and bpf_dbg tools, so the commented program can simply be translated via `./bpf_asm -c prog` where prog is a file that contains the commented code. This makes it easily readable/verifiable and when there's a need to change something, jump offsets etc do not need to be replaced manually which can be very error prone. Instead, a newly translated version via bpf_asm can simply replace the old code. I have checked opcode diffs before/after and it's the very same filter. [1] Documentation/networking/filter.txt Fixes: 164d8c666521 ("net: ptp: do not reimplement PTP/BPF classifier") Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Jiri Benc <jbenc@redhat.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31net: ptp: do not reimplement PTP/BPF classifierDaniel Borkmann
There are currently pch_gbe, cpts, and ixp4xx_eth drivers that open-code and reimplement a BPF classifier for the PTP protocol. Since all of them effectively do the very same thing and load the very same PTP/BPF filter, we can just consolidate that code by introducing ptp_classify_raw() in the time-stamping core framework which can be used in drivers. As drivers get initialized after bootstrapping the core networking subsystem, they can make use of ptp_insns wrapped through ptp_classify_raw(), which allows to simplify and remove PTP classifier setup code in drivers. Joint work with Alexei Starovoitov. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Richard Cochran <richard.cochran@omicron.at> Cc: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-21ixp4xx_eth: Implement the SIOCGHWTSTAMP ioctlBen Hutchings
This is untested. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-11-14ixp4xx_eth: Validate hwtstamp_config completely before applying itBen Hutchings
hwtstamp_ioctl() should validate all fields of hwtstamp_config before making any changes. Currently it sets the TX configuration before validating the rx_filter field. Untested as I don't have a cross-compiler to hand. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-30net: ixp4xx_eth: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27net: ethernet: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Roland Stigge <stigge@antcom.de> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Roland Stigge <stigge@antcom.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14net: phy: remove flags argument from phy_{attach, connect, connect_direct}Florian Fainelli
The flags argument of the phy_{attach,connect,connect_direct} functions is then used to assign a struct phy_device dev_flags with its value. All callers but the tg3 driver pass the flag 0, which results in the underlying PHY drivers in drivers/net/phy/ not being able to actually use any of the flags they would set in dev_flags. This patch gets rid of the flags argument, and passes phydev->dev_flags to the internal PHY library call phy_attach_direct() such that drivers which actually modify a phy device dev_flags get the value preserved for use by the underlying phy driver. Acked-by: Kosta Zertsekel <konszert@marvell.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03ixp4xx_eth: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-20ixp4xx_eth: avoid calling dma_pool_create() with NULL devXi Wang
Use &port->netdev->dev instead of NULL since dma_pool_create() doesn't allow NULL dev. Signed-off-by: Xi Wang <xi.wang@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-06ixp4xx_eth: fix ptp_ixp46x build failureArnaud Patard (Rtp)
When building with ixp4xx_eth and ptp_ixp46x as module, one is getting the following error: ERROR: "ixp46x_phc_index" [drivers/ptp/ptp_ixp46x.ko] undefined! This has been introduced by commit 509a7c25729feab353502e1b544c614772a1d49a. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04net: remove ixp2000 ethernet driverRob Herring
The platform is removed, so there are no users of this driver. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Jesse Brandeburg <jesse.brandeburg@intel.com> Cc: Bruce Allan <bruce.w.allan@intel.com> Cc: Carolyn Wyborny <carolyn.wyborny@intel.com> Cc: Don Skidmore <donald.c.skidmore@intel.com> Cc: Greg Rose <gregory.v.rose@intel.com> Cc: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Cc: Alex Duyck <alexander.h.duyck@intel.com> Cc: John Ronciak <john.ronciak@intel.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04ixp4xx_eth: Support the get_ts_info ethtool method.Richard Cochran
Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-24xscale/ixp2000/ixpdev: print MAC via printk format specifierDanny Kukawka
Print MAC/dev_addr via printk extended format specifier %pM instead of custom code. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Acked-by: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-13ixp4xx-eth: fix PHY name to match MDIO bus nameFlorian Fainelli
Commit 0869b3a4: ixp4xx-eth: use an unique MDIO bus name changed the MDIO bus name from "0" to "ixp4xx-eth-0", as a result the PHY name is not longer appropriate and will not match the MDIO bus name so PHY connection will not succeed, fix that. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-10ixp4xx-eth: use an unique MDIO bus name.Florian Fainelli
2011-10-31drivers/net: Add module.h to drivers who were implicitly using itPaul Gortmaker
The device.h header was including module.h, making it present for most of these drivers. But we want to clean that up. Call out the include of module.h in the modular network drivers. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-27drivers/net/ethernet/*: Enabled vendor Kconfig optionsJeff Kirsher
Based on finds for Stephen Rothwell, where current defconfig's enable a ethernet driver and it is not compiled due to the newly added NET_VENDOR_* component of Kconfig. This patch enables all the "new" Kconfig options so that current defconfig's will continue to compile the expected drivers. In addition, by enabling all the new Kconfig options does not add any un-expected options. CC: Stephen Rothwll <sfc@canb.auug.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11xscale: Move the Intel XScale IXP driversJeff Kirsher
Move the Intel XScale IXP drivers into drivers/net/ethernet/xscale/ and make the necessary Kconfig and Makefile changes. CC: Krzysztof Halasa <khc@pm.waw.pl> CC: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
