path: root/drivers/net/ethoc.c
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-06-21net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-13ethoc: enable transmit time stamping.Richard Cochran
This patch enables software (and phy device) transmit time stamping for the OpenCores 10/100 MAC driver. Compile tested only. Cc: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-21driver-core: remove conditionals around devicetree pointersGrant Likely
Having conditional around the of_match_table and the of_node pointers turns out to make driver code use ugly #ifdef blocks. Drop the conditionals and remove the #ifdef blocks from the affected drivers. Also tidy up minor whitespace issues within the same hunks. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-28ethoc: remove division from loopsJonas Bonn
Calculating the BD entry using a modulus operation isn't optimal, especially inside the loop. This patch removes the modulus operations in favour of: i) simply checking for wrapping in the case of cur_rx ii) forcing num_tx to be a power of two and using it to mask out the entry from cur_tx The also prevents possible issues related overflow of the cur_rx and cur_tx counters. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ethoc: fix function return typeJonas Bonn
update_ethoc_tx_stats doesn't need to return anything so make its return type void in order to avoid an unnecessary cast when the function is called. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ethoc: rework mdio read/writeJonas Bonn
MDIO read and write were checking whether a timeout had expired to determine whether to recheck the result of the MDIO operation. Under heavy CPU usage, however, it was possible for the timeout to expire before the routine got around to be able to check a second time even, thus erroneousy returning an -EBUSY. This patch changes the the MDIO IO routines to try up to five times to complete the operation before giving up, thus lessening the dependency on CPU load. This resolves a problem whereby a ping flood would keep the CPU so busy that the above problem would manifest itself; the MDIO command to check link status would fail and the interface would erroneously be shut down. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ethoc: rework interrupt handlingJonas Bonn
The old interrupt handling was incorrect in that it did not account for the fact that the interrupt source bits get set irregardless of whether or not their corresponding mask is set. This patch fixes that by masking off the source bits for masked interrupts. Furthermore, the handling of transmission events is moved to the NAPI polling handler alongside the reception handler, thus preventing a whole bunch of interrupts during heavy traffic. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ethoc: Double check pending RX packetJonas Bonn
An interrupt may occur between checking bd.stat and clearing the interrupt source register which would result in the packet going totally unnoticed as the interrupt will be missed. Double check bd.stat after clearing the interrupt source register to guard against such an occurrence. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ethoc: enable interrupts after napi_completeAdam Edvardsson
Occasionally, it seems that some race is causing the interrupts to not be reenabled otherwise with the end result that networking just stops working. Enabling interrupts after calling napi_complete is more in line with what other drivers do. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ethoc: remove unused spinlockJonas Bonn
2010-11-28ethoc: Add device tree configurationJonas Bonn
This patch adds the ability to describe ethernet devices via a flattened device tree. As device tree remains an optional feature, these bits all need to be guarded by CONFIG_OF ifdefs. MAC address is settable via the device tree parameter "local-mac-address"; however, the selection of the phy id is limited to probing, for now. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24ethoc: get rid of ethoc_stats()Eric Dumazet
drivers can avoid implementing ndo_get_stats method if using netdevice stats structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26ethoc: add devinit/devexit section initializersJonas Bonn
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07ethoc: Fix warning in ethoc_init_ring().David S. Miller
Get rid of the pointless back-and-forth casting of dev->mem_start from long to pointer back to long again. Also fixes a warning reported by Stephen Rothwell: drivers/net/ethoc.c: In function 'ethoc_init_ring': drivers/net/ethoc.c:302: warning: assignment makes integer from pointer without a cast Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05ethoc: Use the instance of net_device_stats from net_device.Kulikov Vasiliy
Since net_device has an instance of net_device_stats, we can remove the instance of this from the adapter structure. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11ethoc: use devres resource managementJonas Bonn
The point of using the devres resource management routines is that they simplify the driver by taking care of releasing resources on failure and release. A recent commit added a bunch of error handling that is unnecessary in this context. This patch removes this redundant error handling, as well as using dmam_alloc_coherent in place of dma_alloc_coherent in order to use this framework consistenly throughout the driver. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11ethoc: Clear command buffer after writeJonas Bonn
This matches what ethoc_mdio_read does and makes the functions symmetric. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11Remove unused variableJonas Bonn
2010-06-11ethoc: Clean up PHY probingJonas Bonn
- No need to iterate over all possible addresses on bus - Use helper function phy_find_first - Use phy_connect_direct as we already have the relevant structure Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11ethoc: write number of TX buffers in init_ringJonas Bonn
This moves the write of the TX_BD_NUM to init_ring together with the rest of the code setting up the transmission buffers. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11ethoc: Write bus addresses to registersJonas Bonn
The ethoc driver should be writing bus addresses to the ethoc registers, not virtual addresses. This patch adds an array to store the virtual addresses in and references that array when manipulating the contents of the buffer descriptors. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11ethoc: calculate number of buffers in ethoc_probeJonas Bonn
This moves the calculation of the number of transmission buffers to ethoc_probe where it more logically fits with the rest of the memory allocation code. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23ethoc: fix null dereference in ethoc_probeThomas Chou
Dan reported the patch 0baa080c75c: "ethoc: use system memory as buffer" introduced a potential null dereference. 1060 free: 1061 if (priv->dma_alloc) ^^^^^^^^^^^^^^^ priv can be null here. He also suggested that the error handling is not complete. This patch fixes the null priv issue and improves resources releasing in ethoc_probe() and ethoc_remove(). Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06ethoc: Remove unnecessary memset of napi member in netdev private dataTobias Klauser
The memory for the private data is allocated using kzalloc in alloc_etherdev (or alloc_netdev_mq respectively) so there is no need to set the napi member it to 0 explicitely. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part4Jiri Pirko
2010-01-15ethoc: Use resource_sizeTobias Klauser
Use the resource_size function instead of manually calculating the resource size. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18drivers/net: remove exceptional & on function nameJulia Lawall
In this file, function names are otherwise used as pointers without &. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) niu: VLAN_ETH_HLEN should be used to make sure that the whole MAC header was copied to the head buffer in the Vlan packets case KS8851: Fix ks8851_set_rx_mode() for IFF_MULTICAST KS8851: Fix MAC address write order KS8851: Add soft reset at probe time net: fix section mismatch in fec.c net: Fix struct inet_timewait_sock bitfield annotation tcp: Try to catch MSG_PEEK bug net: Fix IP_MULTICAST_IF bluetooth: static lock key fix bluetooth: scheduling while atomic bug fix tcp: fix TCP_DEFER_ACCEPT retrans calculation tcp: reduce SYN-ACK retrans for TCP_DEFER_ACCEPT tcp: accept socket after TCP_DEFER_ACCEPT period Revert "tcp: fix tcp_defer_accept to consider the timeout" AF_UNIX: Fix deadlock on connecting to shutdown socket ethoc: clear only pending irqs ethoc: inline regs access vmxnet3: use dev_dbg, fix build for CONFIG_BLOCK=n virtio_net: use dev_kfree_skb_any() in free_old_xmit_skbs() be2net: fix support for PCI hot plug ...
2009-10-18ethoc: clear only pending irqsThomas Chou
This patch fixed the problem of dropped packets due to lost of interrupt requests. We should only clear what was pending at the moment we read the irq source reg. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18ethoc: inline regs accessThomas Chou
2009-10-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) vmxnet: fix 2 build problems net: add support for STMicroelectronics Ethernet controllers. net: ks8851_mll uses mii interfaces net/fec_mpc52xx: Fix kernel panic on FEC error net: Fix OF platform drivers coldplug/hotplug when compiled as modules TI DaVinci EMAC: Clear statistics register properly. r8169: partial support and phy init for the 8168d irda/sa1100_ir: check return value of startup hook udp: Fix udp_poll() and ioctl() WAN: fix Cisco HDLC handshaking. tcp: fix tcp_defer_accept to consider the timeout 3c574_cs: spin_lock the set_multicast_list function net: Teach pegasus driver to ignore bluetoother adapters with clashing Vendor:Product IDs netxen: fix pci bar mapping ethoc: fix warning from 32bit build libertas: fix build net: VMware virtual Ethernet NIC driver: vmxnet3 net: Fix IXP 2000 network driver building. libertas: fix build mac80211: document ieee80211_rx() context requirement ...
2009-10-13Merge branch 'master' of ↵David S. Miller
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-10-13ethoc: fix warning from 32bit buildAlan Cox
drivers/net/ethoc.c: In function ‘ethoc_open’: drivers/net/ethoc.c:667: warning: comparison of distinct pointer types lacks a cast Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-07ethoc: limit the number of buffers to 128Thomas Chou
Only 128 buffer descriptors are supported in the core. Limit the number in case we have more memory. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07ethoc: use system memory as bufferThomas Chou
This patch enabled the ethoc to allocate system memory as buffer when there is no dedicated buffer memory. Some hardware designs may not have dedicated buffer memory such as on chip or off chip SRAM. In this case, only one memory resource is supplied in the platform data instead of two. Then a DMA buffer can be allocated from system memory and used for the transfer. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07ethoc: align received packet to make IP header at word boundaryThomas Chou
The packet buffer is allocated at 4 bytes boundary, but the IP header length and version bits is located at byte 14. These bit fields access as 32 bits word and caused exception on processors that do not support unaligned access. The patch adds 2 bytes offset to make the bit fields word aligned. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07ethoc: fix buffer address mappingThomas Chou
The pointer address in buffer descriptors is physical address. The pointer that processor used to access packet is virtual address. Though the higher bits of pointer address used by the MAC may be truncated to zero in special case, it is not always true in larger designs. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
